Need to connect to web via wireless laptop routered to desktop modem
Discussion in 'Networking (Hardware & Software)' started by Judy, 2008/09/24.
  1. 2008/09/24
    Judy
    Judy Inactive Thread Starter
    I have a Vista laptop using wireless.
    I will be visiting a friend who has a desktop ( XP ) and modem.
    Radio Shack said that all I need to do is buy a wireless router to connect to the desk top modem.
    I am not wanting to share computers.
    Just want to get to the internet.
    Is this the way to do it?
    Judy,
  2. 2008/09/24
    Simply put - Yes. Will cost at least 50 bucks....
    jacrabbit
    jacrabbit Inactive
    If they don't have a wireless modem, but have an available ethernet jack/port on the modem plug it in that way, even if they do have a wireless router/modem, all you will need is the configuration details to connect to it, you do not need to set up on their home network as you would if you intend to file/computer share
    regards
    Jac
  5. 2008/09/28
    visionof
    visionof Inactive
    Internet sharing connection - Vista
    you can also hook up to your friend's desktop
    if you install a second network card ( could be wireless network adapter but a bit more complex)
    turn on internet sharing connection
    Links a crossover cable between the two computer network cards
    http://windowshelp.microsoft.com/Windows/en-us/help/bfd3bd31-82f0-4b9c-9cde-fb92bc2b14771033.mspx
    http://www.windowsreference.com/win...ternet-connection-sharing-ics-setup-in-vista/
    all said and done spring for or borrow a wireless or non wireless router
  6. 2008/10/11
    Judy
    Thanks for all you help.
    Good to know that buying a wireless router will work, and that is the simplest solution.
    So will do that...
    Judy,
    #5
