Need some help with Clustering
Discussion in 'Windows Server System' started by Char Aznable, 2005/10/24.
  1. 2005/10/24
    Char Aznable
    Char Aznable Inactive Thread Starter
    I'm currently testing a new storage device with 2 servers(I named the 2 system "test" and "test3" respectively) attached to it via SCSI Port. 2 servers are running Windows 2003 Enterprise and I've configured the clustering service( "test" is the main node). It seems to work. Pull the plug on one of them and the other takes over the file sharing and other simple services. Right now I'm trying to configure the thing to work with MySQL, Exhcange and MS SQL. Started out by installing MySQL on "test "(all default settings on the Quorum Disk). Added MySQL as a generic service to the cluster. So far so good but this time when I turn off "test" like before, "test3" was able to continue handling the other service by failed to bring MySQL online. Can someone guide me through the process of adding the thing or point me to the proper direction. Cant seem to find proper material on technet
  2. 2005/10/24
    Char Aznable
    Thanks a lot dude
  5. 2005/10/25
    Did that information answer what you needed?
