Need recommendation on Key Capture software
Discussion in 'Other PC Software' started by robls99, 2009/05/03.
  1. 2009/05/03
    robls99 Lifetime Subscription
    robls99 Well-Known Member Thread Starter
    I'm looking for a simple key capture software (either freeware or inexpensive).
    Appreciate any help.
  2. 2009/05/04
    Software keys? Try Belarc Advisor - free version or SIW (Software > Installed Programs) depending on which sort of key you refer to.
    If you're looking for a "Key logger" type application - that's getting into a gray area here;)
  5. 2009/05/04
    All I want to do is create a macro script for the PageUp/Dn key that I can call automatically from a stock market program (TradeStation) using a RunCommandOnLastBar which I use to run other macros.
