Resolved Need help with Win7 Ultimate dump file analyses
Discussion in 'Windows 7' started by pcbugfixer, 2012/08/19.
  1. 2012/08/19
    pcbugfixer
    pcbugfixer Inactive Thread Starter
    G'day Folks,
    I Need help with Win7 Ultimate dump file analyses please, i.e. interpret cause of the BSOD.
    I have saved the "BSOD00.txt" which is the error message text, "081812-19640-01.dmp" file and the "WER-41714-0.sysdata.xml" file in relation to the 2 BSOD crashes.
    The first occurred at my workshop after performing extensive Virus scans and the running a chkdsk C: /f /r options during which the BSOD occurred and saved the dmp files after the system rebooted.
    The second occurred at the Clients location after attempting to view video clips during which time the BSOD occurred and I then managed to perform a remote logon and again save the dmp data files.
    Both dmp files are named the same unfortunately so I have compressed all 3 files for each.
    Where can I upload both zip files for you to help me please in possibly determining the causes of the BSOD
    I admit that I was never good at diagnosing dmp files. ;)
    Regards
    pcbugfixer :D
  2. 2012/08/19
    Just unzip them and post them here. Even if it takes more than one post. Some people including me will not open a .zip file or other .files because of bad possibilities.
    pcbugfixer
    OK MrBill
    This is the first at my workshop
    1. the BSOD00.txt
    Problem signature:
    Problem Event Name: BlueScreen
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 3081
    Additional information about the problem:
    BCCode: 3b
    BCP1: 00000000C0000005
    BCP2: FFFFF88001048468
    BCP3: FFFFF88009B75DB0
    BCP4: 0000000000000000
    OS Version: 6_1_7601
    Service Pack: 1_0
    Product: 256_1
    Files that help describe the problem:
    C:\Windows\Minidump\081812-19640-01.dmp
    C:\Users\David\AppData\Local\Temp\WER-41714-0.sysdata.xml
    Read our privacy statement online:
    http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
    2. the WER-41714-0.sysdata.xml (which is too large - refer 2nd post please)
    3. as to the 081812-19640-01.dmp file how do I post that here?
    here is the link to the file which I uploaded onto my server in the zip file containing all 3 files that I previously wentioned.
    1st at y workshop,
    www.pcbugfixer.com/temp/Minidump01.rar
    and the 2nd at the Clients Home.
    www.pcbugfixer.com/temp/Minidump02.rar
    Regards
    pcbugfixer :D
  5. 2012/08/19
    pcbugfixer
    MrBill,
    2. the WER-41714-0.sysdata.xml (which is rather large
    The file is too large to post here
    The text that you have entered is too long (102241 characters)
    Please download the zip files - Thanks
    Guaranteed to be safe and only contain the files I mentioned !
    Regards
    pcbugfixer :D
  6. 2012/08/20
    Please follow the procedures outlined here to debug the dump files and post the logs generated in posts in this thread..
  7. 2012/08/20
    pcbugfixer
    G'day PeterC,
    Thanks for your help, here is the 1st result from the dmp file resulting from the BSOD which occurred when running the chkdsk C: /f /r at my workshop.
    debuglog.txt file 1
    Opened log file 'c:debuglog.txt'
    Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
    Loading Dump File [G:\Client Information\DavidParkinson\DPbsod1\081812-19640-01.dmp]
    Executable search path is: C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\system32\drivers
    Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 7601.17835.amd64fre.win7sp1_gdr.120503-2030
    Machine Name:
    Kernel base = 0xfffff800`03050000 PsLoadedModuleList = 0xfffff800`03294670
    Debug session time: Sat Aug 18 12:35:00.028 2012 (UTC + 10:00)
    System Uptime: 0 days 1:33:09.903
    Loading Kernel Symbols
    Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
    Run !sym noisy before .reload to track down problems loading symbols.
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck 3B, {c0000005, fffff88001048468, fffff88009b75db0, 0}
    Probably caused by : fltmgr.sys ( fltmgr!FltpPassThrough+418 )
    Followup: MachineOwner
    0: kd> !analyze -v;r;kv;lmtn;.logclose;q
    SYSTEM_SERVICE_EXCEPTION (3b)
    An exception happened while executing a system service routine.
    Arguments:
    Arg1: 00000000c0000005, Exception code that caused the bugcheck
    Arg2: fffff88001048468, Address of the instruction which caused the bugcheck
    Arg3: fffff88009b75db0, Address of the context record for the exception that caused the bugcheck
    Arg4: 0000000000000000, zero.
    Debugging Details:
    EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx ". The memory could not be "%s ".
    FAULTING_IP:
    fffff880`01048468 ff4014 inc dword ptr [rax+14h]
    CONTEXT: fffff88009b75db0 -- (.cxr 0xfffff88009b75db0)
    rax=ffff0e800d38d0c0 rbx=fffff88009b76830 rcx=ffff0e800d38d0c0
    rdx=0000000000000001 rsi=0000000000000000 rdi=fffff88009b76840
    rip=fffff88001048468 rsp=fffff88009b76790 rbp=fffff88009b76b60
    r8=0000000000000007 r9=0000000000000000 r10=fffffa800d9a1010
    r11=0000000000000000 r12=0000000000000007 r13=fffffa800d383630
    r14=0000000010000000 r15=00000000000004d0
    iopl=0 nv up ei pl nz na pe nc
    cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010202
    fltmgr!FltpPassThrough+0x418:
    fffff880`01048468 ff4014 inc dword ptr [rax+14h] ds:002b:ffff0e80`0d38d0d4=????????
    .cxr
    Resetting default scope
    CUSTOMER_CRASH_COUNT: 1
    DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
    BUGCHECK_STR: 0x3B
    PROCESS_NAME: SearchIndexer.
    CURRENT_IRQL: 0
    LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff88001048468
    STACK_TEXT:
    fffff880`09b76790 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : fltmgr!FltpPassThrough+0x418
    FOLLOWUP_IP:
    SYMBOL_STACK_INDEX: 0
    SYMBOL_NAME: fltmgr!FltpPassThrough+418
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: fltmgr
    IMAGE_NAME: fltmgr.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 4ce7929c
    STACK_COMMAND: .cxr 0xfffff88009b75db0 ; kb
    FAILURE_BUCKET_ID: X64_0x3B_fltmgr!FltpPassThrough+418
    rax=fffff88009b755f0 rbx=fffff80003216638 rcx=000000000000003b
    rdx=00000000c0000005 rsi=fffff80003050000 rdi=0000000000000000
    rip=fffff800030cf1c0 rsp=fffff88009b754e8 rbp=0000000000000000
    r8=fffff88001048468 r9=fffff88009b75db0 r10=0000000000000000
    r11=fffff88009b756e8 r12=fffff800030ce453 r13=fffff800032d4f0c
    r14=fffff800030ce040 r15=0000000000000000
    iopl=0 nv up ei ng nz na po nc
    cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00000286
    nt!KeBugCheckEx:
    fffff800`030cf1c0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffff880`09b754f0=000000000000003b
    Child-SP RetAddr : Args to Child : Call Site
    fffff880`09b754e8 fffff800`030ce769 : 00000000`0000003b 00000000`c0000005 fffff880`01048468 fffff880`09b75db0 : nt!KeBugCheckEx
    fffff880`09b754f0 fffff800`030ce0bc : fffff880`09b76558 fffff880`09b75db0 00000000`00000000 fffff800`030fa320 : nt!KiBugCheckDispatch+0x69
    fffff880`09b75630 fffff800`030f9e2d : fffff800`032e89dc fffff800`0320fa50 fffff800`03050000 fffff880`09b76558 : nt!KiSystemServiceHandler+0x7c
    fffff880`09b75670 fffff800`030f8c05 : fffff800`03216638 fffff880`09b756e8 fffff880`09b76558 fffff800`03050000 : nt!RtlpExecuteHandlerForException+0xd
    fffff880`09b756a0 fffff800`03109b81 : fffff880`09b76558 fffff880`09b75db0 fffff880`00000000 fffff880`09b76840 : nt!RtlDispatchException+0x415
    fffff880`09b75d80 fffff800`030ce842 : fffff880`09b76558 fffff880`09b76830 fffff880`09b76600 00000000`00000000 : nt!KiDispatchException+0x135
    fffff880`09b76420 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatch+0xc2
    start end module name
    fffff800`00bbd000 fffff800`00bc7000 kdcom kdcom.dll Sun Feb 06 03:52:49 2011 (4D4D8061)
    fffff800`03007000 fffff800`03050000 hal hal.dll Sun Nov 21 00:00:25 2010 (4CE7C669)
    fffff800`03050000 fffff800`03638000 nt ntkrnlmp.exe Fri May 04 18:18:59 2012 (4FA390F3)
    fffff880`00c00000 fffff880`00c4f000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sun Nov 21 00:03:51 2010 (4CE7C737)
    fffff880`00c4f000 fffff880`00c63000 PSHED PSHED.dll Tue Jul 14 11:32:23 2009 (4A5BE027)
    fffff880`00c63000 fffff880`00cc1000 CLFS CLFS.SYS Tue Jul 14 09:19:57 2009 (4A5BC11D)
    fffff880`00cc1000 fffff880`00d81000 CI CI.dll Sun Nov 21 00:12:36 2010 (4CE7C944)
    fffff880`00d81000 fffff880`00ddd000 volmgrx volmgrx.sys unavailable (00000000)
    fffff880`00ddd000 fffff880`00df7000 rassstp rassstp.sys Tue Jul 14 10:10:25 2009 (4A5BCCF1)
    fffff880`00e00000 fffff880`00e33000 pci pci.sys Sat Nov 20 20:19:11 2010 (4CE7928F)
    fffff880`00e33000 fffff880`00e40000 vdrvroot vdrvroot.sys Tue Jul 14 10:01:31 2009 (4A5BCADB)
    fffff880`00e40000 fffff880`00e55000 partmgr partmgr.sys Sat Mar 17 16:06:09 2012 (4F641BC1)
    fffff880`00e55000 fffff880`00e6a000 volmgr volmgr.sys Sat Nov 20 20:19:28 2010 (4CE792A0)
    fffff880`00e6a000 fffff880`00e71000 pciide pciide.sys Tue Jul 14 09:19:49 2009 (4A5BC115)
    fffff880`00e71000 fffff880`00e81000 PCIIDEX PCIIDEX.SYS Tue Jul 14 09:19:48 2009 (4A5BC114)
    fffff880`00e81000 fffff880`00e9b000 mountmgr mountmgr.sys Sat Nov 20 20:19:21 2010 (4CE79299)
    fffff880`00e9b000 fffff880`00ea4000 atapi atapi.sys Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`00ea4000 fffff880`00eaf000 amdxata amdxata.sys Sat Mar 20 03:18:18 2010 (4BA3A3CA)
    fffff880`00eb7000 fffff880`00f5b000 Wdf01000 Wdf01000.sys Tue Jul 14 09:22:07 2009 (4A5BC19F)
    fffff880`00f5b000 fffff880`00f6a000 WDFLDR WDFLDR.SYS Tue Jul 14 09:19:54 2009 (4A5BC11A)
    fffff880`00f6a000 fffff880`00fc1000 ACPI ACPI.sys Sat Nov 20 20:19:16 2010 (4CE79294)
    fffff880`00fc1000 fffff880`00fca000 WMILIB WMILIB.SYS Tue Jul 14 09:19:51 2009 (4A5BC117)
    fffff880`00fca000 fffff880`00fd4000 msisadrv msisadrv.sys Tue Jul 14 09:19:26 2009 (4A5BC0FE)
    fffff880`00fd4000 fffff880`00ffe000 ataport ataport.SYS Sat Nov 20 20:19:15 2010 (4CE79293)
    fffff880`01000000 fffff880`0101b000 raspppoe raspppoe.sys Tue Jul 14 10:10:17 2009 (4A5BCCE9)
    fffff880`0101b000 fffff880`0103c000 raspptp raspptp.sys Sat Nov 20 21:52:31 2010 (4CE7A86F)
    fffff880`01045000 fffff880`01091000 fltmgr fltmgr.sys Sat Nov 20 20:19:24 2010 (4CE7929C)
    fffff880`01091000 fffff880`010a5000 fileinfo fileinfo.sys Tue Jul 14 09:34:25 2009 (4A5BC481)
    fffff880`010a5000 fffff880`01153000 avc3 avc3.sys Tue Mar 20 22:04:13 2012 (4F68642D)
    fffff880`01153000 fffff880`01184000 gzflt gzflt.sys Thu Apr 12 00:03:18 2012 (4F858F26)
    fffff880`01184000 fffff880`011df000 trufos trufos.sys Wed Oct 19 20:10:43 2011 (4E9E9413)
    fffff880`011df000 fffff880`011eae00 PxHlpa64 PxHlpa64.sys Wed Jun 24 09:16:35 2009 (4A416253)
    fffff880`01215000 fffff880`013b8000 Ntfs Ntfs.sys Fri Mar 11 14:39:39 2011 (4D79997B)
    fffff880`013b8000 fffff880`013e7000 ndiswan ndiswan.sys Sat Nov 20 21:52:32 2010 (4CE7A870)
    fffff880`01400000 fffff880`01425000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 09:38:51 2009 (4A5BC58B)
    fffff880`01425000 fffff880`0142e000 rdprefmp rdprefmp.sys Tue Jul 14 10:16:35 2009 (4A5BCE63)
    fffff880`0142e000 fffff880`01439000 Msfs Msfs.SYS Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`01439000 fffff880`0144a000 Npfs Npfs.SYS Tue Jul 14 09:19:48 2009 (4A5BC114)
    fffff880`0144a000 fffff880`01476000 bdfndisf6 bdfndisf6.sys Mon Jun 18 21:55:01 2012 (4FDF1715)
    fffff880`01476000 fffff880`01498000 tdx tdx.sys Sat Nov 20 20:21:54 2010 (4CE79332)
    fffff880`01498000 fffff880`014a5000 TDI TDI.SYS Sat Nov 20 20:22:06 2010 (4CE7933E)
    fffff880`014a5000 fffff880`014d6000 EuFdDisk EuFdDisk.sys Thu Apr 19 13:50:31 2012 (4F8F8B87)
    fffff880`014e2000 fffff880`01540000 msrpc msrpc.sys unavailable (00000000)
    fffff880`01540000 fffff880`0155b000 ksecdd ksecdd.sys Sat Jun 02 12:50:23 2012 (4FC97F6F)
    fffff880`0155b000 fffff880`015cd000 cng cng.sys Sat Jun 02 13:25:51 2012 (4FC987BF)
    fffff880`015cd000 fffff880`015de000 pcw pcw.sys Tue Jul 14 09:19:27 2009 (4A5BC0FF)
    fffff880`015de000 fffff880`015e8000 Fs_Rec Fs_Rec.sys unavailable (00000000)
    fffff880`015e8000 fffff880`015f7000 discache discache.sys Tue Jul 14 09:37:18 2009 (4A5BC52E)
    fffff880`01600000 fffff880`0162a000 ksecpkg ksecpkg.sys Sat Jun 02 13:27:11 2012 (4FC9880F)
    fffff880`0163d000 fffff880`01667000 cdrom cdrom.sys Sat Nov 20 20:19:20 2010 (4CE79298)
    fffff880`01667000 fffff880`01670000 FNETURPX FNETURPX.SYS Sat Oct 04 12:27:02 2008 (48E6D476)
    fffff880`01670000 fffff880`0167e000 vga vga.sys Tue Jul 14 09:38:47 2009 (4A5BC587)
    fffff880`0167e000 fffff880`01687000 rdpencdd rdpencdd.sys Tue Jul 14 10:16:34 2009 (4A5BCE62)
    fffff880`0168d000 fffff880`01780000 ndis ndis.sys Sat Nov 20 20:23:30 2010 (4CE79392)
    fffff880`01780000 fffff880`017e0000 NETIO NETIO.SYS Sat Nov 20 20:23:13 2010 (4CE79381)
    fffff880`017e0000 fffff880`017f0000 watchdog watchdog.sys Tue Jul 14 09:37:35 2009 (4A5BC53F)
    fffff880`017f0000 fffff880`017f9000 RDPCDD RDPCDD.sys Tue Jul 14 10:16:34 2009 (4A5BCE62)
    fffff880`01800000 fffff880`0183a000 fvevol fvevol.sys Sat Nov 20 20:24:06 2010 (4CE793B6)
    fffff880`0183a000 fffff880`0184a000 EUBKMON EUBKMON.sys Thu Apr 19 13:50:26 2012 (4F8F8B82)
    fffff880`0184a000 fffff880`0185c000 eubakup eubakup.sys Thu Apr 19 13:50:05 2012 (4F8F8B6D)
    fffff880`0185c000 fffff880`01872000 disk disk.sys Tue Jul 14 09:19:57 2009 (4A5BC11D)
    fffff880`01872000 fffff880`018a2000 CLASSPNP CLASSPNP.SYS Sat Nov 20 20:19:23 2010 (4CE7929B)
    fffff880`018b5000 fffff880`01ab8000 tcpip tcpip.sys Fri Mar 30 19:34:26 2012 (4F757012)
    fffff880`01ab8000 fffff880`01b02000 fwpkclnt fwpkclnt.sys Sat Nov 20 20:21:37 2010 (4CE79321)
    fffff880`01b02000 fffff880`01b12000 vmstorfl vmstorfl.sys unavailable (00000000)
    fffff880`01b12000 fffff880`01b5e000 volsnap volsnap.sys Sat Nov 20 20:20:08 2010 (4CE792C8)
    fffff880`01b5e000 fffff880`01b66000 spldr spldr.sys Tue May 12 02:56:27 2009 (4A0858BB)
    fffff880`01b66000 fffff880`01ba0000 rdyboost rdyboost.sys Sat Nov 20 20:43:10 2010 (4CE7982E)
    fffff880`01ba0000 fffff880`01bb6000 NBVol NBVol.sys Tue May 17 20:50:37 2011 (4DD252FD)
    fffff880`01bb6000 fffff880`01bbf000 NBVolUp NBVolUp.sys Tue May 17 20:51:20 2011 (4DD25328)
    fffff880`01bbf000 fffff880`01bd1000 mup mup.sys Tue Jul 14 09:23:45 2009 (4A5BC201)
    fffff880`01bd1000 fffff880`01bda000 hwpolicy hwpolicy.sys Sat Nov 20 20:18:54 2010 (4CE7927E)
    fffff880`01bef000 fffff880`01bf8000 Null Null.SYS unavailable (00000000)
    fffff880`01bf8000 fffff880`01bff000 Beep Beep.SYS Tue Jul 14 10:00:13 2009 (4A5BCA8D)
    fffff880`02e00000 fffff880`02e1d000 serial serial.sys Tue Jul 14 10:00:40 2009 (4A5BCAA8)
    fffff880`02e1d000 fffff880`02e38000 wanarp wanarp.sys Sat Nov 20 21:52:36 2010 (4CE7A874)
    fffff880`02e38000 fffff880`02e4c000 termdd termdd.sys Sat Nov 20 22:03:40 2010 (4CE7AB0C)
    fffff880`02e4c000 fffff880`02e66000 SCDEmu SCDEmu.SYS Wed Jun 15 18:29:27 2011 (4DF86D67)
    fffff880`02e66000 fffff880`02e70000 SASKUTIL64 SASKUTIL64.SYS Wed Jul 13 07:00:01 2011 (4E1CB5D1)
    fffff880`02e70000 fffff880`02e7a000 SASDIFSV64 SASDIFSV64.SYS Fri Jul 22 09:03:00 2011 (4E28B024)
    fffff880`02e7a000 fffff880`02ecb000 rdbss rdbss.sys Sat Nov 20 20:27:51 2010 (4CE79497)
    fffff880`02ecb000 fffff880`02ed7000 nsiproxy nsiproxy.sys Tue Jul 14 09:21:02 2009 (4A5BC15E)
    fffff880`02ed7000 fffff880`02ee2000 mssmbios mssmbios.sys Tue Jul 14 09:31:10 2009 (4A5BC3BE)
    fffff880`02ee9000 fffff880`02f72000 afd afd.sys Wed Dec 28 14:59:20 2011 (4EFA9418)
    fffff880`02f72000 fffff880`02fb7000 netbt netbt.sys Sat Nov 20 20:23:18 2010 (4CE79386)
    fffff880`02fb7000 fffff880`02fc0000 wfplwf wfplwf.sys Tue Jul 14 10:09:26 2009 (4A5BCCB6)
    fffff880`02fc0000 fffff880`02fe6000 pacer pacer.sys Sat Nov 20 21:52:18 2010 (4CE7A862)
    fffff880`02fe6000 fffff880`02ff5000 netbios netbios.sys Tue Jul 14 10:09:26 2009 (4A5BCCB6)
    fffff880`02ff5000 fffff880`02ffe000 eudskacs eudskacs.sys Thu Apr 19 13:50:01 2012 (4F8F8B69)
    fffff880`04600000 fffff880`0460c000 serenum serenum.sys Tue Jul 14 10:00:33 2009 (4A5BCAA1)
    fffff880`0460c000 fffff880`04619000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 22:17:04 2009 (4A1151C0)
    fffff880`04619000 fffff880`0462f000 intelppm intelppm.sys Tue Jul 14 09:19:25 2009 (4A5BC0FD)
    fffff880`0462f000 fffff880`0463f000 CompositeBus CompositeBus.sys Sat Nov 20 21:33:17 2010 (4CE7A3ED)
    fffff880`0463f000 fffff880`04682000 ks ks.sys Sat Nov 20 21:33:23 2010 (4CE7A3F3)
    fffff880`04682000 fffff880`04698000 AgileVpn AgileVpn.sys Tue Jul 14 10:10:24 2009 (4A5BCCF0)
    fffff880`04698000 fffff880`046bc000 rasl2tp rasl2tp.sys Sat Nov 20 21:52:34 2010 (4CE7A872)
    fffff880`046bc000 fffff880`046c8000 ndistapi ndistapi.sys Tue Jul 14 10:10:00 2009 (4A5BCCD8)
    fffff880`046c8000 fffff880`046d3000 rdpbus rdpbus.sys Tue Jul 14 10:17:46 2009 (4A5BCEAA)
    fffff880`046d6000 fffff880`04759000 csc csc.sys Sat Nov 20 20:27:12 2010 (4CE79470)
    fffff880`04759000 fffff880`04777000 dfsc dfsc.sys Sat Nov 20 20:26:31 2010 (4CE79447)
    fffff880`04777000 fffff880`04788000 blbdrive blbdrive.sys Tue Jul 14 09:35:59 2009 (4A5BC4DF)
    fffff880`04788000 fffff880`047b0000 bdfwfpf bdfwfpf.sys Tue Nov 15 04:16:17 2011 (4EC14CE1)
    fffff880`047b0000 fffff880`047b7000 AsrAppCharger AsrAppCharger.sys Fri Jun 11 16:37:12 2010 (4C11D998)
    fffff880`047b7000 fffff880`047dd000 tunnel tunnel.sys Sat Nov 20 21:51:50 2010 (4CE7A846)
    fffff880`047dd000 fffff880`047e6a00 ATKDispLowFilter ATKDispLowFilter.sys Wed May 14 13:03:13 2008 (482A5671)
    fffff880`047e7000 fffff880`047f6000 mouclass mouclass.sys Tue Jul 14 09:19:50 2009 (4A5BC116)
    fffff880`04a00000 fffff880`04a15000 L1C62x64 L1C62x64.sys Tue Aug 24 19:14:01 2010 (4C738D59)
    fffff880`04a15000 fffff880`04a33000 i8042prt i8042prt.sys Tue Jul 14 09:19:57 2009 (4A5BC11D)
    fffff880`04a33000 fffff880`04a42000 kbdclass kbdclass.sys Tue Jul 14 09:19:50 2009 (4A5BC116)
    fffff880`04a42000 fffff880`04a47200 ksthunk ksthunk.sys Tue Jul 14 10:00:19 2009 (4A5BCA93)
    fffff880`04a4a000 fffff880`04b3e000 dxgkrnl dxgkrnl.sys Sat Nov 20 20:50:50 2010 (4CE799FA)
    fffff880`04b3e000 fffff880`04b84000 dxgmms1 dxgmms1.sys Sat Nov 20 20:49:53 2010 (4CE799C1)
    fffff880`04b84000 fffff880`04b95000 HECIx64 HECIx64.sys Wed Oct 20 10:33:43 2010 (4CBE2AD7)
    fffff880`04b95000 fffff880`04ba6000 usbehci usbehci.sys Fri Mar 25 14:29:04 2011 (4D8C0C00)
    fffff880`04ba6000 fffff880`04bfc000 USBPORT USBPORT.SYS Fri Mar 25 14:29:12 2011 (4D8C0C08)
    fffff880`04c00000 fffff880`04c22000 drmk drmk.sys Tue Jul 14 11:01:25 2009 (4A5BD8E5)
    fffff880`04c22000 fffff880`04c8b000 srv2 srv2.sys Fri Apr 29 13:05:46 2011 (4DBA2B0A)
    fffff880`04ca0000 fffff880`04ce4000 avchv avchv.sys Fri Nov 25 20:04:45 2011 (4ECF5A2D)
    fffff880`04ce4000 fffff880`04cf6000 umbus umbus.sys Sat Nov 20 21:44:37 2010 (4CE7A695)
    fffff880`04cf6000 fffff880`04d50000 usbhub usbhub.sys Fri Mar 25 14:29:25 2011 (4D8C0C15)
    fffff880`04d50000 fffff880`04d59c00 EtronHub3 EtronHub3.sys Sat Jan 29 08:46:45 2011 (4D433945)
    fffff880`04d5a000 fffff880`04d5bf00 USBD USBD.SYS Fri Mar 25 14:28:59 2011 (4D8C0BFB)
    fffff880`04d5c000 fffff880`04d71000 NDProxy NDProxy.SYS Sat Nov 20 21:52:20 2010 (4CE7A864)
    fffff880`04d71000 fffff880`04da3000 nvhda64v nvhda64v.sys Thu Apr 19 03:07:54 2012 (4F8EF4EA)
    fffff880`04da3000 fffff880`04de0000 portcls portcls.sys Tue Jul 14 10:06:27 2009 (4A5BCC03)
    fffff880`05600000 fffff880`056a6000 peauth peauth.sys Tue Jul 14 11:01:19 2009 (4A5BD8DF)
    fffff880`056c0000 fffff880`05748000 avckf avckf.sys Fri Feb 10 21:39:13 2012 (4F34F3D1)
    fffff880`05748000 fffff880`05769000 WudfPf WudfPf.sys Sat Nov 20 21:42:44 2010 (4CE7A624)
    fffff880`05769000 fffff880`0578e000 DefragFS DefragFS.SYS Fri Dec 02 18:02:03 2011 (4ED877EB)
    fffff880`0578e000 fffff880`057a3000 lltdio lltdio.sys Tue Jul 14 10:08:50 2009 (4A5BCC92)
    fffff880`057a3000 fffff880`057bb000 rspndr rspndr.sys Tue Jul 14 10:08:50 2009 (4A5BCC92)
    fffff880`05800000 fffff880`0580e000 crashdmp crashdmp.sys Tue Jul 14 10:01:01 2009 (4A5BCABD)
    fffff880`0580e000 fffff880`0581a000 dump_dumpata dump_dumpata.sys Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`0581a000 fffff880`05823000 dump_atapi dump_atapi.sys Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`05823000 fffff880`05836000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 09:21:51 2009 (4A5BC18F)
    fffff880`05836000 fffff880`05842000 Dxapi Dxapi.sys Tue Jul 14 09:38:28 2009 (4A5BC574)
    fffff880`05842000 fffff880`05850000 monitor monitor.sys Tue Jul 14 09:38:52 2009 (4A5BC58C)
    fffff880`05850000 fffff880`05873000 luafv luafv.sys Tue Jul 14 09:26:13 2009 (4A5BC295)
    fffff880`05873000 fffff880`0588b000 PDFsFilter PDFsFilter.sys Fri May 11 02:29:02 2012 (4FABECCE)
    fffff880`058dd000 fffff880`05b61b80 RTKVHD64 RTKVHD64.sys Tue Nov 30 20:03:19 2010 (4CF4BDD7)
    fffff880`05b8e000 fffff880`05bab000 usbccgp usbccgp.sys Fri Mar 25 14:29:14 2011 (4D8C0C0A)
    fffff880`05bab000 fffff880`05bb9000 hidusb hidusb.sys Sat Nov 20 21:43:49 2010 (4CE7A665)
    fffff880`05bb9000 fffff880`05bd2000 HIDCLASS HIDCLASS.SYS Sat Nov 20 21:43:49 2010 (4CE7A665)
    fffff880`05bd2000 fffff880`05bda080 HIDPARSE HIDPARSE.SYS Tue Jul 14 10:06:17 2009 (4A5BCBF9)
    fffff880`05bdb000 fffff880`05be9000 kbdhid kbdhid.sys Sat Nov 20 21:33:25 2010 (4CE7A3F5)
    fffff880`05be9000 fffff880`05bf6000 mouhid mouhid.sys Tue Jul 14 10:00:20 2009 (4A5BCA94)
    fffff880`06200000 fffff880`06231000 srvnet srvnet.sys Fri Apr 29 13:05:35 2011 (4DBA2AFF)
    fffff880`06256000 fffff880`0631f000 HTTP HTTP.sys Sat Nov 20 20:24:30 2010 (4CE793CE)
    fffff880`0631f000 fffff880`0633d000 bowser bowser.sys Wed Feb 23 15:55:04 2011 (4D649328)
    fffff880`0633d000 fffff880`06355000 mpsdrv mpsdrv.sys Tue Jul 14 10:08:25 2009 (4A5BCC79)
    fffff880`06355000 fffff880`06382000 mrxsmb mrxsmb.sys Wed Apr 27 12:40:38 2011 (4DB78226)
    fffff880`06382000 fffff880`063d0000 mrxsmb10 mrxsmb10.sys Sat Jul 09 12:46:28 2011 (4E17C104)
    fffff880`063d0000 fffff880`063f4000 mrxsmb20 mrxsmb20.sys Wed Apr 27 12:39:37 2011 (4DB781E9)
    fffff880`06826000 fffff880`069de000 rikvm_2B072CAB rikvm_2B072CAB.sys Thu Apr 29 12:26:32 2010 (4BD8EE58)
    fffff880`069de000 fffff880`069e9000 secdrv secdrv.SYS Wed Sep 13 23:18:38 2006 (4508052E)
    fffff880`069e9000 fffff880`069fb000 tcpipreg tcpipreg.sys Sat Nov 20 21:51:48 2010 (4CE7A844)
    fffff880`0703a000 fffff880`070d2000 srv srv.sys Fri Apr 29 13:06:06 2011 (4DBA2B1E)
    fffff880`070d2000 fffff880`070dc000 mbam mbam.sys Wed Mar 21 03:04:48 2012 (4F68AAA0)
    fffff880`0714d000 fffff880`07158000 asyncmac asyncmac.sys Tue Jul 14 10:10:13 2009 (4A5BCCE5)
    fffff880`0f200000 fffff880`0f20fc00 EtronXHCI EtronXHCI.sys Sat Jan 29 08:46:43 2011 (4D433943)
    fffff880`0f210000 fffff880`0ffd2000 nvlddmkm nvlddmkm.sys Tue May 15 17:35:36 2012 (4FB20748)
    fffff880`0ffd2000 fffff880`0fff6000 HDAudBus HDAudBus.sys Sat Nov 20 21:43:42 2010 (4CE7A65E)
    fffff880`0fff6000 fffff880`0fffa580 asusgsb asusgsb.sys Thu Sep 27 23:14:50 2007 (46FBACCA)
    fffff880`0fffb000 fffff880`0fffc480 swenum swenum.sys Tue Jul 14 10:00:18 2009 (4A5BCA92)
    fffff960`00090000 fffff960`003a5000 win32k win32k.sys Thu Jul 19 04:14:37 2012 (5006FD0D)
    fffff960`00450000 fffff960`0045a000 TSDDD TSDDD.dll Tue Jul 14 10:16:34 2009 (4A5BCE62)
    fffff960`00650000 fffff960`00677000 cdd cdd.dll unavailable (00000000)
    fffff960`00940000 fffff960`009a1000 ATMFD ATMFD.DLL Sat Feb 19 20:00:32 2011 (4D5F86B0)
    Unloaded modules:
    fffff880`07158000 fffff880`071c9000 spsys.sys
    Checksum: 00000000
    ImageSize: 00071000
    fffff880`071c9000 fffff880`071d1000 epmntdrv.sys
    Checksum: 00000000
    ImageSize: 00008000
    fffff880`05b6f000 fffff880`05b8a000 USBSTOR.SYS
    Checksum: 00000000
    ImageSize: 0001B000
    fffff880`05b62000 fffff880`05b6f000 FNETTBOH_305
    Checksum: 00000000
    ImageSize: 0000D000
    fffff880`05b8a000 fffff880`05b8e000 wdcsam64.sys
    Checksum: 00000000
    ImageSize: 00004000
    fffff880`070dc000 fffff880`0714d000 spsys.sys
    Checksum: 00000000
    ImageSize: 00071000
    fffff880`018a2000 fffff880`018b0000 crashdmp.sys
    Checksum: 00000000
    ImageSize: 0000E000
    fffff880`01bda000 fffff880`01be6000 dump_ataport
    Checksum: 00000000
    ImageSize: 0000C000
    fffff880`01be6000 fffff880`01bef000 dump_atapi.s
    Checksum: 00000000
    ImageSize: 00009000
    fffff880`0162a000 fffff880`0163d000 dump_dumpfve
    Checksum: 00000000
    ImageSize: 00013000
    Closing open log file c:debuglog.txt
    I will post the 2nd result in the next post
    Regards
    pcbugfixer :D
  8. 2012/08/20
    pcbugfixer
    Hi PeterC,
    This is the result of the 2nd dmp file caused by the BSOD at the Client Home while watching a Dean Martin and Perry Como video clip on line.
    ISP is a Bigpond cable. System is win7 Ultimate 64bit, has a nVidia 1024Mb card and has 16GB of ram.
    debuglog.txt file 2.
    Loading Dump File [G:\Client Information\DavidParkinson\DPbsod2\081812-24055-01.dmp]
    Machine Name:
    Kernel base = 0xfffff800`03052000 PsLoadedModuleList = 0xfffff800`03296670
    Debug session time: Sat Aug 18 14:21:36.354 2012 (UTC + 10:00)
    System Uptime: 0 days 0:15:02.118
    BugCheck 50, {ffffa8800fb39cf8, 0, fffff800031173e6, 7}
    Could not read faulting driver name
    Probably caused by : win32k.sys ( win32k!SURFACE::bDeleteSurface+3c8 )
    4: kd> !analyze -v;r;kv;lmtn;.logclose;q
    PAGE_FAULT_IN_NONPAGED_AREA (50)
    Invalid system memory was referenced. This cannot be protected by try-except,
    it must be protected by a Probe. Typically the address is just plain bad or it
    is pointing at freed memory.
    Arguments:
    Arg1: ffffa8800fb39cf8, memory referenced.
    Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
    Arg3: fffff800031173e6, If non-zero, the instruction address which referenced the bad memory
    address.
    Arg4: 0000000000000007, (reserved)
    Debugging Details:
    READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80003300100
    ffffa8800fb39cf8
    FAULTING_IP:
    nt!MiFindNodeOrParent+e
    fffff800`031173e6 483b5018 cmp rdx,qword ptr [rax+18h]
    MM_INTERNAL_CODE: 7
    BUGCHECK_STR: 0x50
    PROCESS_NAME: sidebar.exe
    CURRENT_IRQL: 0
    TRAP_FRAME: fffff880042f7f70 -- (.trap 0xfffff880042f7f70)
    NOTE: The trap frame does not contain all registers.
    Some register values may be zeroed or incorrect.
    rax=ffffa8800fb39ce0 rbx=0000000000000000 rcx=ffffa8800fb39ce0
    rdx=0000000000004c90 rsi=0000000000000000 rdi=0000000000000000
    rip=fffff800031173e6 rsp=fffff880042f8108 rbp=fffff880042f8290
    r8=fffff880042f8188 r9=fffffa8010696060 r10=0000000000008000
    r11=0000000000008000 r12=0000000000000000 r13=0000000000000000
    r14=0000000000000000 r15=0000000000000000
    iopl=0 nv up ei ng nz na pe nc
    nt!MiFindNodeOrParent+0xe:
    fffff800`031173e6 483b5018 cmp rdx,qword ptr [rax+18h] ds:0bc8:ffffa880`0fb39cf8=????????????????
    .trap
    LAST_CONTROL_TRANSFER: from fffff80003077e97 to fffff800030d11c0
    STACK_TEXT:
    fffff880`042f7e08 fffff800`03077e97 : 00000000`00000050 ffffa880`0fb39cf8 00000000`00000000 fffff880`042f7f70 : nt!KeBugCheckEx
    fffff880`042f7e10 fffff800`030cf2ee : 00000000`00000000 ffffa880`0fb39cf8 fffffa80`10696000 fffffa80`109475d0 : nt! ?? ::FNODOBFM::`string'+0x43cd1
    fffff880`042f7f70 fffff800`031173e6 : fffff800`030bd54b fffff880`042f82f0 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e
    fffff880`042f8108 fffff800`030bd54b : fffff880`042f82f0 00000000`00000000 00000000`00000000 fffff880`042f81d8 : nt!MiFindNodeOrParent+0xe
    fffff880`042f8110 fffff800`030d0453 : ffffffff`ffffffff fffff880`042f83e0 fffff880`042f8448 00000000`00008000 : nt!NtFreeVirtualMemory+0x1bb
    fffff880`042f8210 fffff800`030cca10 : fffff960`000e7068 00000000`00000001 00000000`00000000 fffff900`c0c59cc0 : nt!KiSystemServiceCopyEnd+0x13
    fffff880`042f83a8 fffff960`000e7068 : 00000000`00000001 00000000`00000000 fffff900`c0c59cc0 00000000`00000000 : nt!KiServiceLinkage
    fffff880`042f83b0 fffff960`000e73c4 : ffffffff`00000000 fffff880`00000000 fffff900`c0c59cc0 00000000`00000000 : win32k!SURFACE::bDeleteSurface+0x3c8
    fffff880`042f8500 fffff960`000a7f95 : ffffffff`bf050c79 fffff900`c0c59cc0 ffffffff`bf050c79 00000000`0302b1c0 : win32k!bDeleteSurface+0x34
    fffff880`042f8530 fffff800`030d0453 : fffffa80`108bd420 00000000`03da8000 00000000`0302a201 00000000`0302b360 : win32k!NtGdiDeleteObjectApp+0xd5
    fffff880`042f8560 000007fe`fe38108a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
    00000000`0302b078 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`fe38108a
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    fffff960`000e7068 e9b0010000 jmp win32k!SURFACE::bDeleteSurface+0x57d (fffff960`000e721d)
    SYMBOL_STACK_INDEX: 7
    SYMBOL_NAME: win32k!SURFACE::bDeleteSurface+3c8
    MODULE_NAME: win32k
    IMAGE_NAME: win32k.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 5006fd0d
    FAILURE_BUCKET_ID: X64_0x50_win32k!SURFACE::bDeleteSurface+3c8
    rax=fffff6fb7dbed000 rbx=fffff6fb7db51000 rcx=0000000000000050
    rdx=ffffa8800fb39cf8 rsi=0000000000000000 rdi=0000000000000000
    rip=fffff800030d11c0 rsp=fffff880042f7e08 rbp=fffff880042f7e80
    r8=0000000000000000 r9=fffff880042f7f70 r10=0000000000000000
    r11=0000000000000000 r12=fffff6fb6a2003e8 r13=ffffa8800fb39cf8
    r14=fffff880042f7f70 r15=0000000000000151
    iopl=0 nv up ei pl zr na po nc
    cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00000246
    nt!KeBugCheckEx:
    fffff800`030d11c0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffff880`042f7e10=0000000000000050
    fffff880`042f7f70 fffff800`031173e6 : fffff800`030bd54b fffff880`042f82f0 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e (TrapFrame @ fffff880`042f7f70)
    fffff880`042f8210 fffff800`030cca10 : fffff960`000e7068 00000000`00000001 00000000`00000000 fffff900`c0c59cc0 : nt!KiSystemServiceCopyEnd+0x13 (TrapFrame @ fffff880`042f8210)
    fffff880`042f8560 000007fe`fe38108a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13 (TrapFrame @ fffff880`042f8560)
    fffff800`00bcd000 fffff800`00bd7000 kdcom kdcom.dll Sun Feb 06 03:52:49 2011 (4D4D8061)
    fffff800`03009000 fffff800`03052000 hal hal.dll Sun Nov 21 00:00:25 2010 (4CE7C669)
    fffff800`03052000 fffff800`0363a000 nt ntkrnlmp.exe Fri May 04 18:18:59 2012 (4FA390F3)
    fffff880`00c00000 fffff880`00cc0000 CI CI.dll Sun Nov 21 00:12:36 2010 (4CE7C944)
    fffff880`00cc0000 fffff880`00cd0000 PCIIDEX PCIIDEX.SYS Tue Jul 14 09:19:48 2009 (4A5BC114)
    fffff880`00cd0000 fffff880`00cea000 mountmgr mountmgr.sys Sat Nov 20 20:19:21 2010 (4CE79299)
    fffff880`00cf8000 fffff880`00d47000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sun Nov 21 00:03:51 2010 (4CE7C737)
    fffff880`00d47000 fffff880`00d5b000 PSHED PSHED.dll Tue Jul 14 11:32:23 2009 (4A5BE027)
    fffff880`00d5b000 fffff880`00db9000 CLFS CLFS.SYS Tue Jul 14 09:19:57 2009 (4A5BC11D)
    fffff880`00db9000 fffff880`00de3000 ataport ataport.SYS Sat Nov 20 20:19:15 2010 (4CE79293)
    fffff880`00e00000 fffff880`00e15000 volmgr volmgr.sys Sat Nov 20 20:19:28 2010 (4CE792A0)
    fffff880`00e15000 fffff880`00e71000 volmgrx volmgrx.sys Sat Nov 20 20:20:43 2010 (4CE792EB)
    fffff880`00e71000 fffff880`00e78000 pciide pciide.sys Tue Jul 14 09:19:49 2009 (4A5BC115)
    fffff880`00e78000 fffff880`00e81000 atapi atapi.sys Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`00e83000 fffff880`00f27000 Wdf01000 Wdf01000.sys Tue Jul 14 09:22:07 2009 (4A5BC19F)
    fffff880`00f27000 fffff880`00f36000 WDFLDR WDFLDR.SYS Tue Jul 14 09:19:54 2009 (4A5BC11A)
    fffff880`00f36000 fffff880`00f8d000 ACPI ACPI.sys Sat Nov 20 20:19:16 2010 (4CE79294)
    fffff880`00f8d000 fffff880`00f96000 WMILIB WMILIB.SYS Tue Jul 14 09:19:51 2009 (4A5BC117)
    fffff880`00f96000 fffff880`00fa0000 msisadrv msisadrv.sys Tue Jul 14 09:19:26 2009 (4A5BC0FE)
    fffff880`00fa0000 fffff880`00fd3000 pci pci.sys Sat Nov 20 20:19:11 2010 (4CE7928F)
    fffff880`00fd3000 fffff880`00fe0000 vdrvroot vdrvroot.sys Tue Jul 14 10:01:31 2009 (4A5BCADB)
    fffff880`00fe0000 fffff880`00ff5000 partmgr partmgr.sys Sat Mar 17 16:06:09 2012 (4F641BC1)
    fffff880`00ff5000 fffff880`01000000 amdxata amdxata.sys Sat Mar 20 03:18:18 2010 (4BA3A3CA)
    fffff880`01000000 fffff880`0105b000 trufos trufos.sys Wed Oct 19 20:10:43 2011 (4E9E9413)
    fffff880`0105b000 fffff880`01066e00 PxHlpa64 PxHlpa64.sys Wed Jun 24 09:16:35 2009 (4A416253)
    fffff880`010a0000 fffff880`010ec000 fltmgr fltmgr.sys Sat Nov 20 20:19:24 2010 (4CE7929C)
    fffff880`010ec000 fffff880`01100000 fileinfo fileinfo.sys Tue Jul 14 09:34:25 2009 (4A5BC481)
    fffff880`01100000 fffff880`011ae000 avc3 avc3.sys Tue Mar 20 22:04:13 2012 (4F68642D)
    fffff880`011ae000 fffff880`011df000 gzflt gzflt.sys Thu Apr 12 00:03:18 2012 (4F858F26)
    fffff880`01200000 fffff880`0120f000 kbdclass kbdclass.sys Tue Jul 14 09:19:50 2009 (4A5BC116)
    fffff880`0120f000 fffff880`0121e000 mouclass mouclass.sys Tue Jul 14 09:19:50 2009 (4A5BC116)
    fffff880`01221000 fffff880`013c4000 Ntfs Ntfs.sys Fri Mar 11 14:39:39 2011 (4D79997B)
    fffff880`013c4000 fffff880`013e5000 raspptp raspptp.sys Sat Nov 20 21:52:31 2010 (4CE7A86F)
    fffff880`013e5000 fffff880`013ff000 rassstp rassstp.sys Tue Jul 14 10:10:25 2009 (4A5BCCF1)
    fffff880`01400000 fffff880`0142c000 bdfndisf6 bdfndisf6.sys Mon Jun 18 21:55:01 2012 (4FDF1715)
    fffff880`0142c000 fffff880`0144e000 tdx tdx.sys Sat Nov 20 20:21:54 2010 (4CE79332)
    fffff880`0144e000 fffff880`0145b000 TDI TDI.SYS Sat Nov 20 20:22:06 2010 (4CE7933E)
    fffff880`0145b000 fffff880`0148c000 EuFdDisk EuFdDisk.sys Thu Apr 19 13:50:31 2012 (4F8F8B87)
    fffff880`0148c000 fffff880`0149b000 discache discache.sys Tue Jul 14 09:37:18 2009 (4A5BC52E)
    fffff880`0149b000 fffff880`014a6000 rdpbus rdpbus.sys Tue Jul 14 10:17:46 2009 (4A5BCEAA)
    fffff880`014b1000 fffff880`0150f000 msrpc msrpc.sys Sat Nov 20 20:21:56 2010 (4CE79334)
    fffff880`0150f000 fffff880`0152a000 ksecdd ksecdd.sys Sat Jun 02 12:50:23 2012 (4FC97F6F)
    fffff880`0152a000 fffff880`0159c000 cng cng.sys Sat Jun 02 13:25:51 2012 (4FC987BF)
    fffff880`0159c000 fffff880`015ad000 pcw pcw.sys Tue Jul 14 09:19:27 2009 (4A5BC0FF)
    fffff880`015ad000 fffff880`015b7000 Fs_Rec Fs_Rec.sys Thu Mar 01 14:41:06 2012 (4F4EEFD2)
    fffff880`015b7000 fffff880`015c7000 watchdog watchdog.sys Tue Jul 14 09:37:35 2009 (4A5BC53F)
    fffff880`015c7000 fffff880`015d0000 RDPCDD RDPCDD.sys Tue Jul 14 10:16:34 2009 (4A5BCE62)
    fffff880`015d0000 fffff880`015d9000 rdpencdd rdpencdd.sys Tue Jul 14 10:16:34 2009 (4A5BCE62)
    fffff880`015d9000 fffff880`015e2000 rdprefmp rdprefmp.sys Tue Jul 14 10:16:35 2009 (4A5BCE63)
    fffff880`015e2000 fffff880`015ed000 Msfs Msfs.SYS Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`015ed000 fffff880`015fe000 Npfs Npfs.SYS Tue Jul 14 09:19:48 2009 (4A5BC114)
    fffff880`01613000 fffff880`0163d000 cdrom cdrom.sys Sat Nov 20 20:19:20 2010 (4CE79298)
    fffff880`0163d000 fffff880`01646000 FNETURPX FNETURPX.SYS Sat Oct 04 12:27:02 2008 (48E6D476)
    fffff880`01646000 fffff880`01654000 vga vga.sys Tue Jul 14 09:38:47 2009 (4A5BC587)
    fffff880`01654000 fffff880`01679000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 09:38:51 2009 (4A5BC58B)
    fffff880`01681000 fffff880`01774000 ndis ndis.sys Sat Nov 20 20:23:30 2010 (4CE79392)
    fffff880`01774000 fffff880`017d4000 NETIO NETIO.SYS Sat Nov 20 20:23:13 2010 (4CE79381)
    fffff880`017d4000 fffff880`017fe000 ksecpkg ksecpkg.sys Sat Jun 02 13:27:11 2012 (4FC9880F)
    fffff880`01800000 fffff880`01812000 mup mup.sys Tue Jul 14 09:23:45 2009 (4A5BC201)
    fffff880`01812000 fffff880`0181b000 hwpolicy hwpolicy.sys Sat Nov 20 20:18:54 2010 (4CE7927E)
    fffff880`0181b000 fffff880`01855000 fvevol fvevol.sys Sat Nov 20 20:24:06 2010 (4CE793B6)
    fffff880`01855000 fffff880`01865000 EUBKMON EUBKMON.sys Thu Apr 19 13:50:26 2012 (4F8F8B82)
    fffff880`01865000 fffff880`01877000 eubakup eubakup.sys Thu Apr 19 13:50:05 2012 (4F8F8B6D)
    fffff880`01877000 fffff880`0188d000 disk disk.sys Tue Jul 14 09:19:57 2009 (4A5BC11D)
    fffff880`0188d000 fffff880`018bd000 CLASSPNP CLASSPNP.SYS Sat Nov 20 20:19:23 2010 (4CE7929B)
    fffff880`018e0000 fffff880`018e9000 Null Null.SYS Tue Jul 14 09:19:37 2009 (4A5BC109)
    fffff880`018ef000 fffff880`01af2000 tcpip tcpip.sys Fri Mar 30 19:34:26 2012 (4F757012)
    fffff880`01af2000 fffff880`01b3c000 fwpkclnt fwpkclnt.sys Sat Nov 20 20:21:37 2010 (4CE79321)
    fffff880`01b3c000 fffff880`01b4c000 vmstorfl vmstorfl.sys Sat Nov 20 20:57:30 2010 (4CE79B8A)
    fffff880`01b4c000 fffff880`01b98000 volsnap volsnap.sys Sat Nov 20 20:20:08 2010 (4CE792C8)
    fffff880`01b98000 fffff880`01ba0000 spldr spldr.sys Tue May 12 02:56:27 2009 (4A0858BB)
    fffff880`01ba0000 fffff880`01bda000 rdyboost rdyboost.sys Sat Nov 20 20:43:10 2010 (4CE7982E)
    fffff880`01bda000 fffff880`01bf0000 NBVol NBVol.sys Tue May 17 20:50:37 2011 (4DD252FD)
    fffff880`01bf0000 fffff880`01bf9000 NBVolUp NBVolUp.sys Tue May 17 20:51:20 2011 (4DD25328)
    fffff880`01bf9000 fffff880`01c00000 Beep Beep.SYS Tue Jul 14 10:00:13 2009 (4A5BCA8D)
    fffff880`02e00000 fffff880`02e0c000 nsiproxy nsiproxy.sys Tue Jul 14 09:21:02 2009 (4A5BC15E)
    fffff880`02e0c000 fffff880`02e17000 mssmbios mssmbios.sys Tue Jul 14 09:31:10 2009 (4A5BC3BE)
    fffff880`02e17000 fffff880`02e20000 eudskacs eudskacs.sys Thu Apr 19 13:50:01 2012 (4F8F8B69)
    fffff880`02e24000 fffff880`02ead000 afd afd.sys Wed Dec 28 14:59:20 2011 (4EFA9418)
    fffff880`02ead000 fffff880`02ef2000 netbt netbt.sys Sat Nov 20 20:23:18 2010 (4CE79386)
    fffff880`02ef2000 fffff880`02efb000 wfplwf wfplwf.sys Tue Jul 14 10:09:26 2009 (4A5BCCB6)
    fffff880`02efb000 fffff880`02f21000 pacer pacer.sys Sat Nov 20 21:52:18 2010 (4CE7A862)
    fffff880`02f21000 fffff880`02f30000 netbios netbios.sys Tue Jul 14 10:09:26 2009 (4A5BCCB6)
    fffff880`02f30000 fffff880`02f4d000 serial serial.sys Tue Jul 14 10:00:40 2009 (4A5BCAA8)
    fffff880`02f4d000 fffff880`02f68000 wanarp wanarp.sys Sat Nov 20 21:52:36 2010 (4CE7A874)
    fffff880`02f68000 fffff880`02f7c000 termdd termdd.sys Sat Nov 20 22:03:40 2010 (4CE7AB0C)
    fffff880`02f7c000 fffff880`02f96000 SCDEmu SCDEmu.SYS Wed Jun 15 18:29:27 2011 (4DF86D67)
    fffff880`02f96000 fffff880`02fa0000 SASKUTIL64 SASKUTIL64.SYS Wed Jul 13 07:00:01 2011 (4E1CB5D1)
    fffff880`02fa0000 fffff880`02faa000 SASDIFSV64 SASDIFSV64.SYS Fri Jul 22 09:03:00 2011 (4E28B024)
    fffff880`02faa000 fffff880`02ffb000 rdbss rdbss.sys Sat Nov 20 20:27:51 2010 (4CE79497)
    fffff880`03e00000 fffff880`03e09a00 ATKDispLowFilter ATKDispLowFilter.sys Wed May 14 13:03:13 2008 (482A5671)
    fffff880`03e0a000 fffff880`03e20000 intelppm intelppm.sys Tue Jul 14 09:19:25 2009 (4A5BC0FD)
    fffff880`03e20000 fffff880`03e63000 ks ks.sys Sat Nov 20 21:33:23 2010 (4CE7A3F3)
    fffff880`03e63000 fffff880`03e79000 AgileVpn AgileVpn.sys Tue Jul 14 10:10:24 2009 (4A5BCCF0)
    fffff880`03e79000 fffff880`03e9d000 rasl2tp rasl2tp.sys Sat Nov 20 21:52:34 2010 (4CE7A872)
    fffff880`03e9d000 fffff880`03ea9000 ndistapi ndistapi.sys Tue Jul 14 10:10:00 2009 (4A5BCCD8)
    fffff880`03ea9000 fffff880`03ed8000 ndiswan ndiswan.sys Sat Nov 20 21:52:32 2010 (4CE7A870)
    fffff880`03ed8000 fffff880`03ef3000 raspppoe raspppoe.sys Tue Jul 14 10:10:17 2009 (4A5BCCE9)
    fffff880`03ef3000 fffff880`03f76000 csc csc.sys Sat Nov 20 20:27:12 2010 (4CE79470)
    fffff880`03f76000 fffff880`03f94000 dfsc dfsc.sys Sat Nov 20 20:26:31 2010 (4CE79447)
    fffff880`03f94000 fffff880`03fa5000 blbdrive blbdrive.sys Tue Jul 14 09:35:59 2009 (4A5BC4DF)
    fffff880`03fa5000 fffff880`03fcd000 bdfwfpf bdfwfpf.sys Tue Nov 15 04:16:17 2011 (4EC14CE1)
    fffff880`03fcd000 fffff880`03fd4000 AsrAppCharger AsrAppCharger.sys Fri Jun 11 16:37:12 2010 (4C11D998)
    fffff880`03fd4000 fffff880`03ffa000 tunnel tunnel.sys Sat Nov 20 21:51:50 2010 (4CE7A846)
    fffff880`04600000 fffff880`0463d000 portcls portcls.sys Tue Jul 14 10:06:27 2009 (4A5BCC03)
    fffff880`0463d000 fffff880`0465f000 drmk drmk.sys Tue Jul 14 11:01:25 2009 (4A5BD8E5)
    fffff880`046e1000 fffff880`04725000 avchv avchv.sys Fri Nov 25 20:04:45 2011 (4ECF5A2D)
    fffff880`04725000 fffff880`04737000 umbus umbus.sys Sat Nov 20 21:44:37 2010 (4CE7A695)
    fffff880`04737000 fffff880`04791000 usbhub usbhub.sys Fri Mar 25 14:29:25 2011 (4D8C0C15)
    fffff880`04791000 fffff880`0479ac00 EtronHub3 EtronHub3.sys Sat Jan 29 08:46:45 2011 (4D433945)
    fffff880`0479b000 fffff880`0479cf00 USBD USBD.SYS Fri Mar 25 14:28:59 2011 (4D8C0BFB)
    fffff880`0479d000 fffff880`047b2000 NDProxy NDProxy.SYS Sat Nov 20 21:52:20 2010 (4CE7A864)
    fffff880`047b2000 fffff880`047e4000 nvhda64v nvhda64v.sys Thu Apr 19 03:07:54 2012 (4F8EF4EA)
    fffff880`04a00000 fffff880`04a11000 HECIx64 HECIx64.sys Wed Oct 20 10:33:43 2010 (4CBE2AD7)
    fffff880`04a11000 fffff880`04a22000 usbehci usbehci.sys Fri Mar 25 14:29:04 2011 (4D8C0C00)
    fffff880`04a22000 fffff880`04a78000 USBPORT USBPORT.SYS Fri Mar 25 14:29:12 2011 (4D8C0C08)
    fffff880`04a78000 fffff880`04a8d000 L1C62x64 L1C62x64.sys Tue Aug 24 19:14:01 2010 (4C738D59)
    fffff880`04a8d000 fffff880`04a99000 serenum serenum.sys Tue Jul 14 10:00:33 2009 (4A5BCAA1)
    fffff880`04a99000 fffff880`04aa6000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 22:17:04 2009 (4A1151C0)
    fffff880`04aa6000 fffff880`04ab6000 CompositeBus CompositeBus.sys Sat Nov 20 21:33:17 2010 (4CE7A3ED)
    fffff880`04ab6000 fffff880`04baa000 dxgkrnl dxgkrnl.sys Sat Nov 20 20:50:50 2010 (4CE799FA)
    fffff880`04baa000 fffff880`04bf0000 dxgmms1 dxgmms1.sys Sat Nov 20 20:49:53 2010 (4CE799C1)
    fffff880`04bf0000 fffff880`04bf5200 ksthunk ksthunk.sys Tue Jul 14 10:00:19 2009 (4A5BCA93)
    fffff880`05400000 fffff880`054a6000 peauth peauth.sys Tue Jul 14 11:01:19 2009 (4A5BD8DF)
    fffff880`054ae000 fffff880`05536000 avckf avckf.sys Fri Feb 10 21:39:13 2012 (4F34F3D1)
    fffff880`05536000 fffff880`0555b000 DefragFS DefragFS.SYS Fri Dec 02 18:02:03 2011 (4ED877EB)
    fffff880`0555b000 fffff880`05570000 lltdio lltdio.sys Tue Jul 14 10:08:50 2009 (4A5BCC92)
    fffff880`05570000 fffff880`05588000 rspndr rspndr.sys Tue Jul 14 10:08:50 2009 (4A5BCC92)
    fffff880`05588000 fffff880`055f1000 srv2 srv2.sys Fri Apr 29 13:05:46 2011 (4DBA2B0A)
    fffff880`0584e000 fffff880`05ad2b80 RTKVHD64 RTKVHD64.sys Tue Nov 30 20:03:19 2010 (4CF4BDD7)
    fffff880`05ad3000 fffff880`05ae1000 crashdmp crashdmp.sys Tue Jul 14 10:01:01 2009 (4A5BCABD)
    fffff880`05ae1000 fffff880`05aed000 dump_dumpata dump_dumpata.sys Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`05aed000 fffff880`05af6000 dump_atapi dump_atapi.sys Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`05af6000 fffff880`05b09000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 09:21:51 2009 (4A5BC18F)
    fffff880`05b09000 fffff880`05b26000 usbccgp usbccgp.sys Fri Mar 25 14:29:14 2011 (4D8C0C0A)
    fffff880`05b26000 fffff880`05b34000 hidusb hidusb.sys Sat Nov 20 21:43:49 2010 (4CE7A665)
    fffff880`05b34000 fffff880`05b4d000 HIDCLASS HIDCLASS.SYS Sat Nov 20 21:43:49 2010 (4CE7A665)
    fffff880`05b4d000 fffff880`05b55080 HIDPARSE HIDPARSE.SYS Tue Jul 14 10:06:17 2009 (4A5BCBF9)
    fffff880`05b56000 fffff880`05b62000 Dxapi Dxapi.sys Tue Jul 14 09:38:28 2009 (4A5BC574)
    fffff880`05b62000 fffff880`05b70000 kbdhid kbdhid.sys Sat Nov 20 21:33:25 2010 (4CE7A3F5)
    fffff880`05b70000 fffff880`05b7d000 mouhid mouhid.sys Tue Jul 14 10:00:20 2009 (4A5BCA94)
    fffff880`05b7d000 fffff880`05b8b000 monitor monitor.sys Tue Jul 14 09:38:52 2009 (4A5BC58C)
    fffff880`05b8b000 fffff880`05bae000 luafv luafv.sys Tue Jul 14 09:26:13 2009 (4A5BC295)
    fffff880`05bae000 fffff880`05bc6000 PDFsFilter PDFsFilter.sys Fri May 11 02:29:02 2012 (4FABECCE)
    fffff880`05bc6000 fffff880`05be7000 WudfPf WudfPf.sys Sat Nov 20 21:42:44 2010 (4CE7A624)
    fffff880`06e00000 fffff880`06e4e000 mrxsmb10 mrxsmb10.sys Sat Jul 09 12:46:28 2011 (4E17C104)
    fffff880`06e4e000 fffff880`06e72000 mrxsmb20 mrxsmb20.sys Wed Apr 27 12:39:37 2011 (4DB781E9)
    fffff880`06e72000 fffff880`06e84000 tcpipreg tcpipreg.sys Sat Nov 20 21:51:48 2010 (4CE7A844)
    fffff880`06ea6000 fffff880`06f6f000 HTTP HTTP.sys Sat Nov 20 20:24:30 2010 (4CE793CE)
    fffff880`06f6f000 fffff880`06f8d000 bowser bowser.sys Wed Feb 23 15:55:04 2011 (4D649328)
    fffff880`06f8d000 fffff880`06fa5000 mpsdrv mpsdrv.sys Tue Jul 14 10:08:25 2009 (4A5BCC79)
    fffff880`06fa5000 fffff880`06fd2000 mrxsmb mrxsmb.sys Wed Apr 27 12:40:38 2011 (4DB78226)
    fffff880`07600000 fffff880`0760b000 secdrv secdrv.SYS Wed Sep 13 23:18:38 2006 (4508052E)
    fffff880`0760b000 fffff880`0763c000 srvnet srvnet.sys Fri Apr 29 13:05:35 2011 (4DBA2AFF)
    fffff880`07647000 fffff880`077ff000 rikvm_2B072CAB rikvm_2B072CAB.sys Thu Apr 29 12:26:32 2010 (4BD8EE58)
    fffff880`07cc5000 fffff880`07d5d000 srv srv.sys Fri Apr 29 13:06:06 2011 (4DBA2B1E)
    fffff880`07d5d000 fffff880`07d67000 mbam mbam.sys Wed Mar 21 03:04:48 2012 (4F68AAA0)
    fffff880`07dd8000 fffff880`07de3000 asyncmac asyncmac.sys Tue Jul 14 10:10:13 2009 (4A5BCCE5)
    fffff960`00020000 fffff960`00335000 win32k win32k.sys Thu Jul 19 04:14:37 2012 (5006FD0D)
    fffff960`004e0000 fffff960`004ea000 TSDDD TSDDD.dll unavailable (00000000)
    fffff960`00670000 fffff960`00697000 cdd cdd.dll Sat Nov 20 23:55:34 2010 (4CE7C546)
    fffff960`00870000 fffff960`008d1000 ATMFD ATMFD.DLL Sat Feb 19 20:00:32 2011 (4D5F86B0)
    Unloaded modules:
    fffff880`07d67000 fffff880`07dd8000 spsys.sys
    Checksum: 00000000
    ImageSize: 00071000
    fffff880`018bd000 fffff880`018cb000 crashdmp.sys
    Checksum: 00000000
    ImageSize: 0000E000
    fffff880`018cb000 fffff880`018d7000 dump_ataport
    Checksum: 00000000
    ImageSize: 0000C000
    fffff880`018d7000 fffff880`018e0000 dump_atapi.s
    Checksum: 00000000
    ImageSize: 00009000
    fffff880`01600000 fffff880`01613000 dump_dumpfve
    Checksum: 00000000
    ImageSize: 00013000
    Regards
    pcbugfixer :D
  9. 2012/08/20
    3B Probably caused by : fltmgr.sys. This is a Windows component and likely means something else drove it to fault.
    Suggestions:
    1. Download and install updates and device drivers for your computer from Windows Update
    2. Scan your computer for computer viruses
    3. Check your hard disk for errors
    4. Could be caused by a memory issue so check the memory
    Memory testing: Run Memtest86 or Windows Memory Diagnostic.
    Windows 7 DVD also includes a memory testing option called Windows Memory Diagnostic which can be accessed by booting off your Windows DVD, choosing your language/keyboard options, and clicking the link Repair your computer at the bottom left on the Install Now screen. When prompted select your Windows Installation and click Next, here you can select the Windows Memory Diagnostic option.
    *) Windows Memory Diagnostic Note: Windows Memory Diagnostic is limited to testing only the first 4 gigabytes (GB) of RAM. If you have more than 4 GB of RAM, the remaining RAM after the first 4 GB will not be tested by Windows Memory Diagnostic.
    Memory Testing Note:
    To work around the above, test the installed RAM in various configurations. If you have a single module, swap it around the slots. If you have a pair of modules, run each one singly, swapping between slots; and then run them in pairs swapping between pairs of slots. If you have 2 sets of matched modules do not get them mixed up.
  10. 2012/08/20
    Bug Check 0x50: PAGE_FAULT_IN_NONPAGED_AREA
    So follow the same steps as in my post above.
  11. 2012/08/20
    pcbugfixer
    Thanks Arie,
    I will post the results of re-testing everything on this PC and in particular the memory modules.
    Mind you they all tested out with no errors on the previous tests I conducted on all the hardware before I performed a fresh installation.
    Also the security is the BitDefender Internet Security 2013 (latest) and I installed 3 other Malware / Virus scanners ( used custom installation so not to cause conflict with BDIS and they are not resident, only BDIS is) and all came up with "No infections detected "
    Regards
    pcbugfixer :D
  12. 2012/08/26
    pcbugfixer
    Need help with this please.
    This occurred during a test run using the 3DMark 11 Advanced Edition 1.0.3 Basic Game Configuration.
    Loading Dump File [G:\Client Information\DavidParkinson\Minidump88\082612-19468-01.dmp]
    Machine Name:
    Kernel base = 0xfffff800`0304a000 PsLoadedModuleList = 0xfffff800`0328e670
    Debug session time: Sun Aug 26 14:49:38.967 2012 (UTC + 10:00)
    System Uptime: 0 days 2:50:32.841
    BugCheck D1, {fffffc800fafba10, 2, 0, fffff8800ff4a1c0}
    Unable to load image \SystemRoot\system32\DRIVERS\nvlddmkm.sys, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for nvlddmkm.sys
    *** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
    *** WARNING: Unable to verify timestamp for win32k.sys
    *** ERROR: Module load completed but symbols could not be loaded for win32k.sys
    Probably caused by : nvlddmkm.sys ( nvlddmkm+d271c0 )
    DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If kernel debugger is available get stack backtrace.
    Arguments:
    Arg1: fffffc800fafba10, memory referenced
    Arg2: 0000000000000002, IRQL
    Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
    Arg4: fffff8800ff4a1c0, address which referenced memory
    Debugging Details:
    READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800032f8100
    fffffc800fafba10
    CURRENT_IRQL: 2
    FAULTING_IP:
    nvlddmkm+d271c0
    fffff880`0ff4a1c0 ff5018 call qword ptr [rax+18h]
    BUGCHECK_STR: 0xD1
    PROCESS_NAME: System
    TRAP_FRAME: fffff880042fdf70 -- (.trap 0xfffff880042fdf70)
    rax=fffffc800fafb9f8 rbx=0000000000000000 rcx=fffffa8010b843f0
    rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
    rip=fffff8800ff4a1c0 rsp=fffff880042fe100 rbp=0000000000000000
    r8=0000000000000000 r9=fffff880042fe260 r10=fffff8800fb1e920
    r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
    nvlddmkm+0xd271c0:
    fffff880`0ff4a1c0 ff5018 call qword ptr [rax+18h] ds:db30:fffffc80`0fafba10=????????????????
    .trap
    LAST_CONTROL_TRANSFER: from fffff800030c8769 to fffff800030c91c0
    STACK_TEXT:
    fffff880`042fde28 fffff800`030c8769 : 00000000`0000000a fffffc80`0fafba10 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
    fffff880`042fde30 fffff800`030c73e0 : 00000000`00000000 fffffa80`0ef38000 00000000`00000000 00000000`00000001 : nt!KiBugCheckDispatch+0x69
    fffff880`042fdf70 fffff880`0ff4a1c0 : 00000000`00000001 00000000`00000000 fffffa80`116bdb30 00000000`00000000 : nt!KiPageFault+0x260
    fffff880`042fe100 00000000`00000001 : 00000000`00000000 fffffa80`116bdb30 00000000`00000000 00000000`00000050 : nvlddmkm+0xd271c0
    fffff880`042fe108 00000000`00000000 : fffffa80`116bdb30 00000000`00000000 00000000`00000050 fffff880`0f332545 : 0x1
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    nvlddmkm+d271c0
    SYMBOL_STACK_INDEX: 3
    SYMBOL_NAME: nvlddmkm+d271c0
    MODULE_NAME: nvlddmkm
    IMAGE_NAME: nvlddmkm.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 4fb20748
    FAILURE_BUCKET_ID: X64_0xD1_nvlddmkm+d271c0
    rax=fffff880042fdf30 rbx=0000000000000001 rcx=000000000000000a
    rdx=fffffc800fafba10 rsi=fffffa80116bdb30 rdi=0000000000000001
    rip=fffff800030c91c0 rsp=fffff880042fde28 rbp=fffff880042fdff0
    r8=0000000000000002 r9=0000000000000000 r10=fffff8800ff4a1c0
    r11=0000000000000000 r12=fffff880042fe210 r13=0000000000000000
    r14=0000000000000082 r15=fffffa80116bd9f0
    nt!KeBugCheckEx:
    fffff800`030c91c0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffff880`042fde30=000000000000000a
    fffff880`042fdf70 fffff880`0ff4a1c0 : 00000000`00000001 00000000`00000000 fffffa80`116bdb30 00000000`00000000 : nt!KiPageFault+0x260 (TrapFrame @ fffff880`042fdf70)
    fffff800`00bb4000 fffff800`00bbe000 kdcom kdcom.dll Sun Feb 06 03:52:49 2011 (4D4D8061)
    fffff800`03001000 fffff800`0304a000 hal hal.dll Sun Nov 21 00:00:25 2010 (4CE7C669)
    fffff800`0304a000 fffff800`03632000 nt ntkrnlmp.exe Fri May 04 18:18:59 2012 (4FA390F3)
    fffff880`00c00000 fffff880`00c5c000 volmgrx volmgrx.sys Sat Nov 20 20:20:43 2010 (4CE792EB)
    fffff880`00c5c000 fffff880`00c6c000 PCIIDEX PCIIDEX.SYS Tue Jul 14 09:19:48 2009 (4A5BC114)
    fffff880`00c6c000 fffff880`00c86000 mountmgr mountmgr.sys Sat Nov 20 20:19:21 2010 (4CE79299)
    fffff880`00c86000 fffff880`00cb0000 ataport ataport.SYS Sat Nov 20 20:19:15 2010 (4CE79293)
    fffff880`00cb0000 fffff880`00cbb000 amdxata amdxata.sys Sat Mar 20 03:18:18 2010 (4BA3A3CA)
    fffff880`00cbe000 fffff880`00d0d000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sun Nov 21 00:03:51 2010 (4CE7C737)
    fffff880`00d0d000 fffff880`00d21000 PSHED PSHED.dll Tue Jul 14 11:32:23 2009 (4A5BE027)
    fffff880`00d21000 fffff880`00d7f000 CLFS CLFS.SYS Tue Jul 14 09:19:57 2009 (4A5BC11D)
    fffff880`00d7f000 fffff880`00db2000 pci pci.sys Sat Nov 20 20:19:11 2010 (4CE7928F)
    fffff880`00db2000 fffff880`00dc7000 partmgr partmgr.sys Sat Mar 17 16:06:09 2012 (4F641BC1)
    fffff880`00dc7000 fffff880`00ddc000 volmgr volmgr.sys Sat Nov 20 20:19:28 2010 (4CE792A0)
    fffff880`00e00000 fffff880`00ea4000 Wdf01000 Wdf01000.sys Tue Jul 14 09:22:07 2009 (4A5BC19F)
    fffff880`00ea4000 fffff880`00eb3000 WDFLDR WDFLDR.SYS Tue Jul 14 09:19:54 2009 (4A5BC11A)
    fffff880`00eb3000 fffff880`00ec0000 vdrvroot vdrvroot.sys Tue Jul 14 10:01:31 2009 (4A5BCADB)
    fffff880`00ec0000 fffff880`00ec7000 pciide pciide.sys Tue Jul 14 09:19:49 2009 (4A5BC115)
    fffff880`00ec7000 fffff880`00ed0000 atapi atapi.sys Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`00ed2000 fffff880`00f92000 CI CI.dll Sun Nov 21 00:12:36 2010 (4CE7C944)
    fffff880`00f92000 fffff880`00fe9000 ACPI ACPI.sys Sat Nov 20 20:19:16 2010 (4CE79294)
    fffff880`00fe9000 fffff880`00ff2000 WMILIB WMILIB.SYS Tue Jul 14 09:19:51 2009 (4A5BC117)
    fffff880`00ff2000 fffff880`00ffc000 msisadrv msisadrv.sys Tue Jul 14 09:19:26 2009 (4A5BC0FE)
    fffff880`01000000 fffff880`01031000 gzflt gzflt.sys Thu Apr 12 00:03:18 2012 (4F858F26)
    fffff880`01031000 fffff880`0108c000 trufos trufos.sys Wed Oct 19 20:10:43 2011 (4E9E9413)
    fffff880`0108c000 fffff880`01097e00 PxHlpa64 PxHlpa64.sys Wed Jun 24 09:16:35 2009 (4A416253)
    fffff880`01098000 fffff880`010b9000 raspptp raspptp.sys Sat Nov 20 21:52:31 2010 (4CE7A86F)
    fffff880`010c6000 fffff880`01112000 fltmgr fltmgr.sys Sat Nov 20 20:19:24 2010 (4CE7929C)
    fffff880`01112000 fffff880`01126000 fileinfo fileinfo.sys Tue Jul 14 09:34:25 2009 (4A5BC481)
    fffff880`01126000 fffff880`011d4000 avc3 avc3.sys Tue Mar 20 22:04:13 2012 (4F68642D)
    fffff880`011d4000 fffff880`011ee000 rassstp rassstp.sys Tue Jul 14 10:10:25 2009 (4A5BCCF1)
    fffff880`01217000 fffff880`013ba000 Ntfs Ntfs.sys Fri Mar 11 14:39:39 2011 (4D79997B)
    fffff880`013ba000 fffff880`013e9000 ndiswan ndiswan.sys Sat Nov 20 21:52:32 2010 (4CE7A870)
    fffff880`01400000 fffff880`0140b000 rdpbus rdpbus.sys Tue Jul 14 10:17:46 2009 (4A5BCEAA)
    fffff880`0140f000 fffff880`0146d000 msrpc msrpc.sys Sat Nov 20 20:21:56 2010 (4CE79334)
    fffff880`0146d000 fffff880`01488000 ksecdd ksecdd.sys Sat Jun 02 12:50:23 2012 (4FC97F6F)
    fffff880`01488000 fffff880`014fa000 cng cng.sys Sat Jun 02 13:25:51 2012 (4FC987BF)
    fffff880`014fa000 fffff880`0150b000 pcw pcw.sys Tue Jul 14 09:19:27 2009 (4A5BC0FF)
    fffff880`0150b000 fffff880`01515000 Fs_Rec Fs_Rec.sys Thu Mar 01 14:41:06 2012 (4F4EEFD2)
    fffff880`01515000 fffff880`01525000 watchdog watchdog.sys Tue Jul 14 09:37:35 2009 (4A5BC53F)
    fffff880`01525000 fffff880`0152e000 RDPCDD RDPCDD.sys Tue Jul 14 10:16:34 2009 (4A5BCE62)
    fffff880`0152e000 fffff880`01537000 rdpencdd rdpencdd.sys Tue Jul 14 10:16:34 2009 (4A5BCE62)
    fffff880`01537000 fffff880`01540000 rdprefmp rdprefmp.sys Tue Jul 14 10:16:35 2009 (4A5BCE63)
    fffff880`01540000 fffff880`0154b000 Msfs Msfs.SYS Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`0154b000 fffff880`0155c000 Npfs Npfs.SYS Tue Jul 14 09:19:48 2009 (4A5BC114)
    fffff880`0155c000 fffff880`01588000 bdfndisf6 bdfndisf6.sys Mon Jun 18 21:55:01 2012 (4FDF1715)
    fffff880`01588000 fffff880`015aa000 tdx tdx.sys Sat Nov 20 20:21:54 2010 (4CE79332)
    fffff880`015aa000 fffff880`015b7000 TDI TDI.SYS Sat Nov 20 20:22:06 2010 (4CE7933E)
    fffff880`015b7000 fffff880`015fa000 ks ks.sys Sat Nov 20 21:33:23 2010 (4CE7A3F3)
    fffff880`01600000 fffff880`01625000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 09:38:51 2009 (4A5BC58B)
    fffff880`0162a000 fffff880`0171d000 ndis ndis.sys Sat Nov 20 20:23:30 2010 (4CE79392)
    fffff880`0171d000 fffff880`0177d000 NETIO NETIO.SYS Sat Nov 20 20:23:13 2010 (4CE79381)
    fffff880`0177d000 fffff880`017a7000 ksecpkg ksecpkg.sys Sat Jun 02 13:27:11 2012 (4FC9880F)
    fffff880`017ba000 fffff880`017e4000 cdrom cdrom.sys Sat Nov 20 20:19:20 2010 (4CE79298)
    fffff880`017e4000 fffff880`017ed000 FNETURPX FNETURPX.SYS Sat Oct 04 12:27:02 2008 (48E6D476)
    fffff880`017ed000 fffff880`017fb000 vga vga.sys Tue Jul 14 09:38:47 2009 (4A5BC587)
    fffff880`018e0000 fffff880`018e7000 Beep Beep.SYS Tue Jul 14 10:00:13 2009 (4A5BCA8D)
    fffff880`018e8000 fffff880`01aeb000 tcpip tcpip.sys Fri Mar 30 19:34:26 2012 (4F757012)
    fffff880`01aeb000 fffff880`01b35000 fwpkclnt fwpkclnt.sys Sat Nov 20 20:21:37 2010 (4CE79321)
    fffff880`01b35000 fffff880`01b45000 vmstorfl vmstorfl.sys Sat Nov 20 20:57:30 2010 (4CE79B8A)
    fffff880`01b45000 fffff880`01b91000 volsnap volsnap.sys Sat Nov 20 20:20:08 2010 (4CE792C8)
    fffff880`01b91000 fffff880`01b99000 spldr spldr.sys Tue May 12 02:56:27 2009 (4A0858BB)
    fffff880`01b99000 fffff880`01bd3000 rdyboost rdyboost.sys Sat Nov 20 20:43:10 2010 (4CE7982E)
    fffff880`01bd3000 fffff880`01be9000 NBVol NBVol.sys Tue May 17 20:50:37 2011 (4DD252FD)
    fffff880`01be9000 fffff880`01bf2000 NBVolUp NBVolUp.sys Tue May 17 20:51:20 2011 (4DD25328)
    fffff880`01bf2000 fffff880`01bfb000 Null Null.SYS Tue Jul 14 09:19:37 2009 (4A5BC109)
    fffff880`02e00000 fffff880`02e0c000 ndistapi ndistapi.sys Tue Jul 14 10:10:00 2009 (4A5BCCD8)
    fffff880`02e0c000 fffff880`02e27000 raspppoe raspppoe.sys Tue Jul 14 10:10:17 2009 (4A5BCCE9)
    fffff880`02e2c000 fffff880`02eb5000 afd afd.sys Wed Dec 28 14:59:20 2011 (4EFA9418)
    fffff880`02eb5000 fffff880`02efa000 netbt netbt.sys Sat Nov 20 20:23:18 2010 (4CE79386)
    fffff880`02efa000 fffff880`02f03000 wfplwf wfplwf.sys Tue Jul 14 10:09:26 2009 (4A5BCCB6)
    fffff880`02f03000 fffff880`02f29000 pacer pacer.sys Sat Nov 20 21:52:18 2010 (4CE7A862)
    fffff880`02f29000 fffff880`02f38000 netbios netbios.sys Tue Jul 14 10:09:26 2009 (4A5BCCB6)
    fffff880`02f38000 fffff880`02f55000 serial serial.sys Tue Jul 14 10:00:40 2009 (4A5BCAA8)
    fffff880`02f55000 fffff880`02f70000 wanarp wanarp.sys Sat Nov 20 21:52:36 2010 (4CE7A874)
    fffff880`02f70000 fffff880`02f84000 termdd termdd.sys Sat Nov 20 22:03:40 2010 (4CE7AB0C)
    fffff880`02f84000 fffff880`02f9e000 SCDEmu SCDEmu.SYS Wed Jun 15 18:29:27 2011 (4DF86D67)
    fffff880`02f9e000 fffff880`02fa8000 SASKUTIL64 SASKUTIL64.SYS Wed Jul 13 07:00:01 2011 (4E1CB5D1)
    fffff880`02fa8000 fffff880`02fb2000 SASDIFSV64 SASDIFSV64.SYS Fri Jul 22 09:03:00 2011 (4E28B024)
    fffff880`02fb2000 fffff880`02fc2000 CompositeBus CompositeBus.sys Sat Nov 20 21:33:17 2010 (4CE7A3ED)
    fffff880`02fc2000 fffff880`02fd8000 AgileVpn AgileVpn.sys Tue Jul 14 10:10:24 2009 (4A5BCCF0)
    fffff880`02fd8000 fffff880`02ffc000 rasl2tp rasl2tp.sys Sat Nov 20 21:52:34 2010 (4CE7A872)
    fffff880`03e00000 fffff880`03e46000 dxgmms1 dxgmms1.sys Sat Nov 20 20:49:53 2010 (4CE799C1)
    fffff880`03e46000 fffff880`03e6a000 HDAudBus HDAudBus.sys Sat Nov 20 21:43:42 2010 (4CE7A65E)
    fffff880`03e6a000 fffff880`03ec0000 USBPORT USBPORT.SYS Fri Mar 25 14:29:12 2011 (4D8C0C08)
    fffff880`03ec0000 fffff880`03ed5000 L1C62x64 L1C62x64.sys Tue Aug 24 19:14:01 2010 (4C738D59)
    fffff880`03ed5000 fffff880`03ee4000 kbdclass kbdclass.sys Tue Jul 14 09:19:50 2009 (4A5BC116)
    fffff880`03ee4000 fffff880`03ef1000 GEARAspiWDM GEARAspiWDM.sys Mon May 18 22:17:04 2009 (4A1151C0)
    fffff880`03ef1000 fffff880`03fe5000 dxgkrnl dxgkrnl.sys Sat Nov 20 20:50:50 2010 (4CE799FA)
    fffff880`03fe5000 fffff880`03ff4000 mouclass mouclass.sys Tue Jul 14 09:19:50 2009 (4A5BC116)
    fffff880`03ff4000 fffff880`04000000 serenum serenum.sys Tue Jul 14 10:00:33 2009 (4A5BCAA1)
    fffff880`04461000 fffff880`044a5000 avchv avchv.sys Fri Nov 25 20:04:45 2011 (4ECF5A2D)
    fffff880`044a5000 fffff880`044b7000 umbus umbus.sys Sat Nov 20 21:44:37 2010 (4CE7A695)
    fffff880`044b7000 fffff880`04511000 usbhub usbhub.sys Fri Mar 25 14:29:25 2011 (4D8C0C15)
    fffff880`04511000 fffff880`0451ac00 EtronHub3 EtronHub3.sys Sat Jan 29 08:46:45 2011 (4D433945)
    fffff880`0451b000 fffff880`0451cf00 USBD USBD.SYS Fri Mar 25 14:28:59 2011 (4D8C0BFB)
    fffff880`0451d000 fffff880`04532000 NDProxy NDProxy.SYS Sat Nov 20 21:52:20 2010 (4CE7A864)
    fffff880`04532000 fffff880`04564000 nvhda64v nvhda64v.sys Thu Apr 19 03:07:54 2012 (4F8EF4EA)
    fffff880`04564000 fffff880`045a1000 portcls portcls.sys Tue Jul 14 10:06:27 2009 (4A5BCC03)
    fffff880`045a1000 fffff880`045c3000 drmk drmk.sys Tue Jul 14 11:01:25 2009 (4A5BD8E5)
    fffff880`04601000 fffff880`04652000 rdbss rdbss.sys Sat Nov 20 20:27:51 2010 (4CE79497)
    fffff880`04652000 fffff880`0465e000 nsiproxy nsiproxy.sys Tue Jul 14 09:21:02 2009 (4A5BC15E)
    fffff880`0465e000 fffff880`04669000 mssmbios mssmbios.sys Tue Jul 14 09:31:10 2009 (4A5BC3BE)
    fffff880`04669000 fffff880`0469a000 EuFdDisk EuFdDisk.sys Thu Apr 19 13:50:31 2012 (4F8F8B87)
    fffff880`0469a000 fffff880`046a3000 eudskacs eudskacs.sys Thu Apr 19 13:50:01 2012 (4F8F8B69)
    fffff880`046a3000 fffff880`046b2000 discache discache.sys Tue Jul 14 09:37:18 2009 (4A5BC52E)
    fffff880`046b2000 fffff880`04735000 csc csc.sys Sat Nov 20 20:27:12 2010 (4CE79470)
    fffff880`04735000 fffff880`04753000 dfsc dfsc.sys Sat Nov 20 20:26:31 2010 (4CE79447)
    fffff880`04753000 fffff880`04764000 blbdrive blbdrive.sys Tue Jul 14 09:35:59 2009 (4A5BC4DF)
    fffff880`04764000 fffff880`0478c000 bdfwfpf bdfwfpf.sys Tue Nov 15 04:16:17 2011 (4EC14CE1)
    fffff880`0478c000 fffff880`04793000 AsrAppCharger AsrAppCharger.sys Fri Jun 11 16:37:12 2010 (4C11D998)
    fffff880`04793000 fffff880`047b9000 tunnel tunnel.sys Sat Nov 20 21:51:50 2010 (4CE7A846)
    fffff880`047b9000 fffff880`047c2a00 ATKDispLowFilter ATKDispLowFilter.sys Wed May 14 13:03:13 2008 (482A5671)
    fffff880`047c3000 fffff880`047e1000 i8042prt i8042prt.sys Tue Jul 14 09:19:57 2009 (4A5BC11D)
    fffff880`047e1000 fffff880`047f7000 intelppm intelppm.sys Tue Jul 14 09:19:25 2009 (4A5BC0FD)
    fffff880`047f7000 fffff880`047fc200 ksthunk ksthunk.sys Tue Jul 14 10:00:19 2009 (4A5BCA93)
    fffff880`05863000 fffff880`05ae7b80 RTKVHD64 RTKVHD64.sys Tue Nov 30 20:03:19 2010 (4CF4BDD7)
    fffff880`05ae8000 fffff880`05af4000 Dxapi Dxapi.sys Tue Jul 14 09:38:28 2009 (4A5BC574)
    fffff880`05af4000 fffff880`05b02000 crashdmp crashdmp.sys Tue Jul 14 10:01:01 2009 (4A5BCABD)
    fffff880`05b02000 fffff880`05b0e000 dump_dumpata dump_dumpata.sys Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`05b0e000 fffff880`05b17000 dump_atapi dump_atapi.sys Tue Jul 14 09:19:47 2009 (4A5BC113)
    fffff880`05b17000 fffff880`05b2a000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 09:21:51 2009 (4A5BC18F)
    fffff880`05b2a000 fffff880`05b47000 usbccgp usbccgp.sys Fri Mar 25 14:29:14 2011 (4D8C0C0A)
    fffff880`05b47000 fffff880`05b55000 hidusb hidusb.sys Sat Nov 20 21:43:49 2010 (4CE7A665)
    fffff880`05b55000 fffff880`05b6e000 HIDCLASS HIDCLASS.SYS Sat Nov 20 21:43:49 2010 (4CE7A665)
    fffff880`05b6e000 fffff880`05b76080 HIDPARSE HIDPARSE.SYS Tue Jul 14 10:06:17 2009 (4A5BCBF9)
    fffff880`05b77000 fffff880`05b85000 kbdhid kbdhid.sys Sat Nov 20 21:33:25 2010 (4CE7A3F5)
    fffff880`05b85000 fffff880`05b92000 mouhid mouhid.sys Tue Jul 14 10:00:20 2009 (4A5BCA94)
    fffff880`05b92000 fffff880`05ba0000 monitor monitor.sys Tue Jul 14 09:38:52 2009 (4A5BC58C)
    fffff880`05ba0000 fffff880`05bc3000 luafv luafv.sys Tue Jul 14 09:26:13 2009 (4A5BC295)
    fffff880`05bc3000 fffff880`05bdb000 PDFsFilter PDFsFilter.sys Fri May 11 02:29:02 2012 (4FABECCE)
    fffff880`05e56000 fffff880`05ede000 avckf avckf.sys Fri Feb 10 21:39:13 2012 (4F34F3D1)
    fffff880`05ede000 fffff880`05eff000 WudfPf WudfPf.sys Sat Nov 20 21:42:44 2010 (4CE7A624)
    fffff880`05eff000 fffff880`05f24000 DefragFS DefragFS.SYS Fri Dec 02 18:02:03 2011 (4ED877EB)
    fffff880`05f24000 fffff880`05f39000 lltdio lltdio.sys Tue Jul 14 10:08:50 2009 (4A5BCC92)
    fffff880`05f39000 fffff880`05f51000 rspndr rspndr.sys Tue Jul 14 10:08:50 2009 (4A5BCC92)
    fffff880`05f51000 fffff880`05ff7000 peauth peauth.sys Tue Jul 14 11:01:19 2009 (4A5BD8DF)
    fffff880`0641b000 fffff880`064e4000 HTTP HTTP.sys Sat Nov 20 20:24:30 2010 (4CE793CE)
    fffff880`064e4000 fffff880`06502000 bowser bowser.sys Wed Feb 23 15:55:04 2011 (4D649328)
    fffff880`06502000 fffff880`0651a000 mpsdrv mpsdrv.sys Tue Jul 14 10:08:25 2009 (4A5BCC79)
    fffff880`0651a000 fffff880`06547000 mrxsmb mrxsmb.sys Wed Apr 27 12:40:38 2011 (4DB78226)
    fffff880`06547000 fffff880`06595000 mrxsmb10 mrxsmb10.sys Sat Jul 09 12:46:28 2011 (4E17C104)
    fffff880`06595000 fffff880`065b9000 mrxsmb20 mrxsmb20.sys Wed Apr 27 12:39:37 2011 (4DB781E9)
    fffff880`065b9000 fffff880`065cb000 tcpipreg tcpipreg.sys Sat Nov 20 21:51:48 2010 (4CE7A844)
    fffff880`06a00000 fffff880`06a0b000 secdrv secdrv.SYS Wed Sep 13 23:18:38 2006 (4508052E)
    fffff880`06a0b000 fffff880`06a3c000 srvnet srvnet.sys Fri Apr 29 13:05:35 2011 (4DBA2AFF)
    fffff880`06a44000 fffff880`06bfc000 rikvm_2B072CAB rikvm_2B072CAB.sys Thu Apr 29 12:26:32 2010 (4BD8EE58)
    fffff880`08271000 fffff880`0827c000 asyncmac asyncmac.sys Tue Jul 14 10:10:13 2009 (4A5BCCE5)
    fffff880`0827c000 fffff880`08285000 cpuz135_x64 cpuz135_x64.sys Thu May 24 00:53:22 2012 (4FBCF9E2)
    fffff880`082c0000 fffff880`08329000 srv2 srv2.sys Fri Apr 29 13:05:46 2011 (4DBA2B0A)
    fffff880`08329000 fffff880`083c1000 srv srv.sys Fri Apr 29 13:06:06 2011 (4DBA2B1E)
    fffff880`083c1000 fffff880`083cb000 mbam mbam.sys Wed Mar 21 03:04:48 2012 (4F68AAA0)
    fffff880`0f200000 fffff880`0f211000 usbehci usbehci.sys Fri Mar 25 14:29:04 2011 (4D8C0C00)
    fffff880`0f211000 fffff880`0f220c00 EtronXHCI EtronXHCI.sys Sat Jan 29 08:46:43 2011 (4D433943)
    fffff880`0f223000 fffff880`0ffe5000 nvlddmkm nvlddmkm.sys Tue May 15 17:35:36 2012 (4FB20748)
    fffff880`0ffe5000 fffff880`0fff6000 HECIx64 HECIx64.sys Wed Oct 20 10:33:43 2010 (4CBE2AD7)
    fffff960`00000000 fffff960`00315000 win32k win32k.sys unavailable (00000000)
    fffff960`00480000 fffff960`0048a000 TSDDD TSDDD.dll unavailable (00000000)
    fffff960`007c0000 fffff960`007e7000 cdd cdd.dll unavailable (00000000)
    fffff960`00810000 fffff960`00871000 ATMFD ATMFD.DLL unavailable (00000000)
    Unloaded modules:
    fffff880`08200000 fffff880`08271000 spsys.sys
    Checksum: 00000000
    ImageSize: 00071000
    Checksum: 00000000
    ImageSize: 0000E000
    Checksum: 00000000
    ImageSize: 0000C000
    Checksum: 00000000
    ImageSize: 00009000
    fffff880`017a7000 fffff880`017ba000 dump_dumpfve
    Checksum: 00000000
    ImageSize: 00013000
    Regards
    pcbugfixer :D
  13. 2012/08/27
    pcbugfixer
    pcbugfixer Inactive Thread Starter
    System Test results.
    [FONT=&quot]The results of the extensive tests over the last 2 weeks on this system were as follows.[/FONT]
    [FONT=&quot]1. After scanning the system for parasites (any type of a virus) using /A. BitDefender Internet Security 2013, /B. SpyBot Search and Destroy, /C. Super AntiSpyware, and /D. MalwareBytes (all the latest versions and updated prior to each scan) [/FONT]
    [FONT=&quot]- There were no infections of any type found !![/FONT]
    [FONT=&quot]2. Memory was scanned from a boot CD using /A. Memtest86+ 4.20 - PC Memory Test. (able to test memory up to 64GB) /B. GoldMemory 5.07 - Memory Diagnostic Tests. /C. MemTest 1.0 - a Memory Testing Tool, and /D. Windows Memory Diagnostic - a RAM Test tool. (Dos Freeware) [/FONT]
    [FONT=&quot]- Test A. Method used for this test was to test each module in each slot one at a time, then test 2 modules in slot 1 and 3, then 2 and 4, then all 4 mounted in slots (total test runs 19)[/FONT]
    [FONT=&quot]- Test B, C and D were run on individual modules (total runs 16 each testing the 4GB modules individually)[/FONT]
    [FONT=&quot]- All memory modules tests had no errors[/FONT][FONT=&quot].[/FONT]
    [FONT=&quot]3. Using the /Test A. Video Memory Stress Test 1.7.116 - a tool to thoroughly test your video RAM for errors and faults. (Windows Freeware) /Test B. Video Memory Stress Test CE 1.21 - Tests all video RAM accessible by 32-bit CPU address space from a clean environment. (Dos Freeware) and /Test C. 3DMark 11 Advanced Edition 1.0.3[/FONT]
    [FONT=&quot]- Test A and B were run from the boot CD and Test D was run in / from windows 7 Ultimate.[/FONT]
    [FONT=&quot]Item 3.A and 3.C is where we ran into problems, results were as follows, i.e. the nVidia card did not pass the memory and other stress tests.[/FONT]
    [FONT=&quot]Images and text as follows. [/FONT]
    [FONT=&quot]Refer to the attached (linked) "Stress Test Video Memory v1.doc " and "3DMark Score01.doc†"3DMark Score02.doc" and "3DMark Score03.docâ€[/FONT]
    [FONT=&quot]These clearly show that the nVidia GeForce GTX 560 card failed constantly or would not yield a average scored result.[/FONT]
    [FONT=&quot]We attribute that the BSOD that the customer is experiencing, is due to the faulty nVidia card and its memory.[/FONT]
    Ok, looking at the last dmp file debuglog.txt results I posted, I think we may have found the problem.
    Any suggestions as to the correctness of this conclusion - please
    Regards
    pcbugfixer :D
  14. 2012/08/27
    The last one indicates nvlddmkm.sys which is indeed the Nvidia driver.
    It does indeed look like the video memory is defect, so I'd be looking to replace the card. If it is still under warranty I'd start a RMA case.
