Need help deciding whether to get free upgrade
Discussion in 'Windows 10' started by Barry, 2015/06/02.
  1. 2015/06/02
    Barry
    Obviously, Microsoft is looking for this free upgrade to be a way of bringing in more money for them, but I'd like to know the true cost before I decide to change from 8.1.
    Will I be able to burn an ISO of 10 Pro, in case my OS crashes and I need to reinstall? What problems, if any, are anticipated with the upgrade versus a clean install (which we'd apparently have to pay for)?
    Will these mandatory updates end up exceeding my available free space on my HD? Will any of these mandatory updates require payment?
    Will I have to keep a bootable Win 8.1 in order to continue to run Office Professional 2007, Adobe Acrobat Professional 8.0 & Photoshop CS3?
    Is there a complete cost vs asset assessment that can help me decide whether to upgrade or not?
    Any other information that might help me make a decision would be appreciated.
  2. 2015/06/02
    Win 10 is still work in progress & MS is not coming out with all the details. Like you, I also have a lot of questions about the upgrade and have decided to stick with Win 8.1 for the time being.
    We have anyway, one year to decide to take the plunge or not. By then, I assume, most of the things would be pretty clear.
    My advice - hold your horses.
    Hi Barry. In addition to what rsinfo stated:
    Yes you will be able to get an ISO but you will need to wait until Microsoft makes Windows 10 RTM ISO's available.
    As far as problems upgrading from Windows 8.1, it honestly depends on what programs you have installed and what hardware devices you have installed. In most cases, an in-place upgrade should work without any problems but if you want the best experience possible with Windows 10 then you should perform a clean install of Windows 10 when Microsoft makes the Windows 10 RTM ISO's available.
    No to the first question. For the second question, Windows 10 is free for the first year so if you do not get a Windows 10 product key from Microsoft within that time period then you will need to pay to upgrade.
    Nope. Windows 10 replaces Windows 8.1 once you install it.
    There will be but wait until Windows 10 gets released before making a decision. Its not worth worrying about it at this point.
    I'd wait until Windows 10 gets released, and then I'd read a couple of reviews and see what kinds of features have been added to the new OS. If you think Windows 10 is better than Windows 8.1 which I think it is then its definitely an OS I'd upgrade to from Windows 8.1.
  5. 2015/06/02
    Barry
    Thank you for the information. I'm thinking of waiting till the first service pack is issued, as long as it is within the first year. I do need a little more clarification, though.
    If I take the upgrade, will the ISO be available at no charge? That way, I could do the upgrade and then do a clean install from the ISO.
    I have two bootable harddrives, so I have no problem keeping one as 8.1 if certain programs won't run on 10. Is there a list of common programs that will no longer be workable with 10?
    This free for the first year reminds me of cable company or cellphone providers that give you a come on low price for the first year and then require mandatory high payments after that to offset their losses. I can ignore their store, but am wary of other fees. Will we be charged for Windows 10 updates?
    Also, please comment on Microsoft's instructions for a clean install in their FAQs for Win10:
    Will users who take advantage of the upgrade offer for Windows 10 from Windows 8.1 and Windows 7 also be able to obtain recovery media?
    Microsoft recently noted the following options available:
    With Windows 10, you can create your own recovery media and back up the pristine state of the operating system and preinstalled software. If things go wrong and you are unable to refresh or reset your device successfully, you can boot the device using recovery media and reset to the prior pristine state.
    Source: http://blogs.windows.com/bloggingwindows/2015/03/16/how-windows-10-achieves-its-compact-footprint/
    You can also initiate a clean install by doing the following:
    You can do a clean install a couple ways.
    Press Windows key + i
    Click Update and Security
    Click Recovery
    Under Remove everything and reinstall Windows, click Get started
    or
    At the Sign in screen
    Hold down the shift key on your keyboard while clicking the Power icon on the screen
    Continue to hold down the shift key while clicking Restart
    Continue to hold down the shift key until the Advanced Recovery Options menu appears
    Click Troubleshoot
    Click Reset
    Thank you for your feedback.
  6. 2015/06/02
    Yes the ISO will be free.
    You can use the Windows Compatibility Center to see what software is compatible with Windows 10.
    No, updates for Windows 10 will be free just like in previous versions of Windows.
    There are a couple ways of doing a clean install. The method described in that statement is using the Reset feature to completely remove everything and reinstall Windows but if you want to make sure everything is gone then you would boot from your Windows 10 DVD and remove the partitions on the hard drive and then you would perform a clean install of Windows 10 that way.
  7. 2015/06/02
    Barry
    It just seems that there should be more of a catch than I'm seeing. Does Microsoft expect the sales of apps to balance out giving Win10 for free? Maybe it is cost effective... I'll just have to wait to see how the reviews come out on its stability, speed, functionality and security.
  8. 2015/06/02
    Hi Barry, I have been signed up in the "Insider" program for W10 Preview Evaluation and have received a total of 9 updates. The first was an ISO which you burned to DVD and installed to your HDD.
    I have put my Motherboard Drivers onto the HDD and my normal use Software eg. Mozilla FF and TB and Open Office, Foxit and Malwarebytes etc.
    I have not had any major problems when the 9 updates have been applied - all my software has worked including Graphics card driver updates.
    As I understand it, if you 'own' a legit/activated MS OS ie. W7/W8.1 you can sign up to receive the "FREE" upgrade to W10 and receive all upgrades from then on "Free" for the life of the comp.
    Again, I understand this is because you have paid for your original OS, Microsoft are competing with Apple to secure user numbers and the endeavour is to attract 2 Billion users to this new W10 OS.
    I stand to be corrected if I have not understood what I have read in releases from MS. Neil.
    PS. I'm in boots and all as I enjoy the W10 Evaluation and I've had to purchase Windows 98/SE, ME, XP, Vista, W7 & W8.1 filling the MS coffers for some years.
    https://www.thurrott.com/windows/windows-10/3898/a-few-more-answers-about-windows-10-upgrades
  9. 2015/06/02
    Barry
    I've heard that MS plans to pay for the program the way Google does (spyware). To maintain privacy, we'll need to find the spyware implanted into Windows 10 and find a way to defeat it. Has anyone heard this or know the best steps to prevent personal information from being sent to MS to be sold?
  10. 2015/06/02
  11. 2015/06/03
    Barry
    Neil, nowhere in those articles did I see anything saying that Microsoft would be receiving data from our computers that they plan to sell to others. I don't think MS would want to admit that. I guess we need to research and discover what MS is using to send information back to them and then find a way to disable that. At least Google is upfront in stating they sell information they glean from users.
