Need Help debuggin dmp file
Discussion in 'Windows XP' started by geddon, 2007/10/27.
  1. 2007/10/27
    geddon
    geddon Inactive Thread Starter
    My computer randomly reboots to the login screen. Could be one day, every 3rd day, who knows??? But here is my latest crash dump file. Need help pinpointing the problems. Thanks!
    * using the -y <symbol_path> argument when starting the debugger. *
    * using .sympath and .sympath+ *
    * Symbols can not be loaded because symbol path is not initialized. *
    * The Symbol Path can be set by: *
    * using the _NT_SYMBOL_PATH environment variable. *
    MODULE_NAME: zmxpzip
    FAULTING_MODULE: 804d4000 nt
    DEBUG_FLR_IMAGE_TIMESTAMP: 42726f83
    READ_ADDRESS: unable to get nt!MmSpecialPoolStart
    unable to get nt!MmSpecialPoolEnd
    unable to get nt!MmPoolCodeStart
    unable to get nt!MmPoolCodeEnd
    a810eb30
    FAULTING_IP:
    zmxpzip+82fb
    f783e2fb 0fb711 movzx edx,word ptr [ecx]
    MM_INTERNAL_CODE: 0
    CUSTOMER_CRASH_COUNT: 1
    DEFAULT_BUCKET_ID: WRONG_SYMBOLS
    BUGCHECK_STR: 0x50
    LAST_CONTROL_TRANSFER: from f783e1fc to f783e2fb
    STACK_TEXT:
    a66300b4 f783e1fc 00000000 88d35690 00000000 zmxpzip+0x82fb
    a6630134 f783aee2 00000000 889e2f90 00000000 zmxpzip+0x81fc
    a6630154 f783b9b7 889e2f90 89b86758 00000000 zmxpzip+0x4ee2
    a6630188 aa9c7f5b 889e2f90 00000001 a6630340 zmxpzip+0x59b7
    a66301b0 80561bad 889e2f90 00000001 a6630340 SYMEVENT+0x3f5b
    a6630254 80531814 80000698 a6630358 a6630340 nt+0x8dbad
    a6630270 8054f5e0 8054c560 00000009 a66302f0 nt+0x5d814
    00000000 00000000 00000000 00000000 00000000 nt+0x7b5e0
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    zmxpzip+82fb
    SYMBOL_STACK_INDEX: 0
    SYMBOL_NAME: zmxpzip+82fb
    FOLLOWUP_NAME: MachineOwner
    IMAGE_NAME: zmxpzip.sys
    Followup: MachineOwner
  2. 2007/10/27
    geddon - Welcome to the Board :)
    Your dump log is incomplete and has a symbol problem. Please see our Dump Data Collection Tool and run the dump through that.
    Please also note ....
    Unfortunately these logs require expert knowledge to analyze and there are only 2 members (who occasionally visit WindowsBBS.com) that have the depth of knowledge necessary. Other members can make observations and suggestions as to how you might proceed toward finding the cause ....
    geddon
    Debugging Dump - - System keeps rebooting - -HELP!
    My system keeps rebooting to login screen. I have other dumps if needed.
    Please help me pinpoint where the problem is. System has been fine for a couple of years and now all of a sudden, this is happeing. THANKS:)
    Opened log file 'c:\debuglog.txt'
    Microsoft (R) Windows Debugger Version 6.8.0004.0 X86
    Loading Dump File [C:\WINDOWS\Minidump\Mini012007-01.dmp]
    Executable search path is: C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\system32\drivers
    Windows XP Kernel Version 2600 (Service Pack 1) MP (2 procs) Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 2600.xpsp2.050301-1526
    Kernel base = 0x804d4000 PsLoadedModuleList = 0x8054c150
    Debug session time: Sat Jan 20 10:18:10.022 2007 (GMT-7)
    System Uptime: 6 days 17:47:09.315
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    *** ERROR: Module load completed but symbols could not be loaded for zmxpzip.sys
    ERROR: FindPlugIns 8007007b
    * Bugcheck Analysis *
    BugCheck 10000050, {a810eb30, 0, f783e2fb, 0}
    *** ERROR: Symbol file could not be found. Defaulted to export symbols for SYMEVENT.SYS -
    Could not read faulting driver name
    *** WARNING: Unable to verify timestamp for SRTSPL.SYS
    *** ERROR: Module load completed but symbols could not be loaded for SRTSPL.SYS
    *** WARNING: Unable to verify timestamp for NAVEX15.SYS
    *** ERROR: Module load completed but symbols could not be loaded for NAVEX15.SYS
    Probably caused by : zmxpzip.sys ( zmxpzip+82fb )
    1: kd> !analyze -v;r;kv;lmtn;.logclose;q
    PAGE_FAULT_IN_NONPAGED_AREA (50)
    Invalid system memory was referenced. This cannot be protected by try-except,
    it must be protected by a Probe. Typically the address is just plain bad or it
    is pointing at freed memory.
    Arguments:
    Arg1: a810eb30, memory referenced.
    Arg2: 00000000, value 0 = read operation, 1 = write operation.
    Arg3: f783e2fb, If non-zero, the instruction address which referenced the bad memory
    address.
    Arg4: 00000000, (reserved)
    Debugging Details:
    READ_ADDRESS: a810eb30
    FAULTING_IP:
    zmxpzip+82fb
    MM_INTERNAL_CODE: 0
    BUGCHECK_STR: 0x50
    PROCESS_NAME: IEXPLORE.EXE
    STACK_TEXT:
    a66301b0 80561bad 889e2f90 00000001 a6630340 SYMEVENT!SYMEvent_AllocVMData+0x257b
    a6630254 80531814 80000698 a6630358 a6630340 nt!NtQueryInformationFile+0x205
    a6630254 804fb071 80000698 a6630358 a6630340 nt!KiSystemService+0xc9
    a66302e0 aa9faac9 80000698 a6630358 a6630340 nt!ZwQueryInformationFile+0x11
    a6630320 aaa042d9 e3ef4b68 a6630358 a6630340 SRTSPL+0x13ac9
    a6630360 aaa048b4 00000000 00008000 a6630380 SRTSPL+0x1d2d9
    a6630370 aaa16cf5 00000000 00000000 a66303d0 SRTSPL+0x1d8b4
    a6630380 a61b741e e427abd8 00000000 00000000 SRTSPL+0x2fcf5
    a66303d0 a61d4bd8 e815c9a0 e427abd8 e4ee44a0 NAVEX15+0x5941e
    a66303f8 a61d4db3 00000000 e815c9a0 e427abd8 NAVEX15+0x76bd8
    a6630418 a61a6dbd e29e4008 e815c9a0 e427abd8 NAVEX15+0x76db3
    a6630660 a61a6e6f e4ee44ac e54de008 e815c9a0 NAVEX15+0x48dbd
    a6630690 a61a8162 e4ee44ac e54de008 e815c9a0 NAVEX15+0x48e6f
    a663072c a61a8696 00000000 e54de008 e815c9a0 NAVEX15+0x4a162
    a66307c8 80538043 89c3a000 00004042 0000000a NAVEX15+0x4a696
    a66307f0 a6630820 a61a8aed e4ee44ac e54de008 nt!MiFreePoolPages+0x5c9
    a66307f8 e4ee44ac e54de008 e815c9a0 e29b9010 0xa6630820
    a66307fc e54de008 e815c9a0 e29b9010 e29b9610 0xe4ee44ac
    a6630800 e815c9a0 e29b9010 e29b9610 00000003 0xe54de008
    a6630804 e29b9010 e29b9610 00000003 a66308b0 0xe815c9a0
    a6630808 e29b9610 00000003 a66308b0 00000001 0xe29b9010
    a663080c 00000000 a66308b0 00000001 e57888a0 0xe29b9610
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    zmxpzip+82fb
    FAILURE_BUCKET_ID: 0x50_zmxpzip+82fb
    eax=a810eb30 ebx=a6630340 ecx=a810eb30 edx=a810eb30 esi=89b86758 edi=88e922be
    eip=f783e2fb esp=a663004c ebp=a66300b4 iopl=0 nv up ei pl zr na pe cy
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010247
    zmxpzip+0x82fb:
    f783e2fb 0fb711 movzx edx,word ptr [ecx] ds:0023:a810eb30=????
    a6630254 80531814 80000698 a6630358 a6630340 nt!NtQueryInformationFile+0x205 (FPO: [Non-Fpo])
    a6630254 804fb071 80000698 a6630358 a6630340 nt!KiSystemService+0xc9 (FPO: [0,0] TrapFrame @ a6630270)
    a66302e0 aa9faac9 80000698 a6630358 a6630340 nt!ZwQueryInformationFile+0x11 (FPO: [5,0,0])
    a66307f0 a6630820 a61a8aed e4ee44ac e54de008 nt!MiFreePoolPages+0x5c9 (FPO: [Non-Fpo])
    start end module name
    804d4000 806bb000 nt ntkrnlmp.exe Tue Mar 01 16:36:33 2005 (42250A91)
    806bb000 806dab80 hal halmacpi.dll Thu Aug 29 01:05:02 2002 (3D6DD5AE)
    a614c000 a615dee0 NAVENG NAVENG.SYS Thu Sep 21 12:01:06 2006 (4512E172)
    a615e000 a6227ae0 NAVEX15 NAVEX15.SYS Thu Sep 21 11:34:08 2006 (4512DB20)
    a6347000 a636a700 Fastfat Fastfat.SYS Thu Aug 29 02:12:45 2002 (3D6DE58D)
    a7793000 a77b9e80 kmixer kmixer.sys Thu Aug 29 01:32:28 2002 (3D6DDC1C)
    a789d000 a78afe80 wdmaud wdmaud.sys Thu Aug 29 02:00:46 2002 (3D6DE2BE)
    a799b000 a79b7500 RDPWD RDPWD.SYS Thu Jun 09 16:45:20 2005 (42A8D490)
    a7b5c000 a7baa800 srv srv.sys Mon Aug 14 01:59:18 2006 (44E03B66)
    a7bd3000 a7be4180 LxrSII1d LxrSII1d.sys Thu May 19 15:48:22 2005 (428D17B6)
    a7e8d000 a7eb7500 mrxdav mrxdav.sys Mon Apr 25 18:58:01 2005 (426DA029)
    a7efc000 a7effee0 Aspi32 Aspi32.SYS Mon May 06 09:43:02 2002 (3CD6B296)
    a7f98000 a7fa5e00 sysaudio sysaudio.sys Thu Aug 29 02:01:17 2002 (3D6DE2DD)
    a81b0000 a81d0380 afd afd.sys Thu Aug 29 02:01:13 2002 (3D6DE2D9)
    a8219000 a821c000 ndisuio ndisuio.sys Thu Aug 29 01:35:40 2002 (3D6DDCDC)
    aa531000 aa53a700 dcfs2k dcfs2k.sys Wed Jun 02 10:18:57 2004 (40BE0C01)
    aa579000 aa58e400 dump_atapi dump_atapi.sys Fri Jan 31 15:43:28 2003 (3E3B0A20)
    aa58f000 aa5ac000 EraserUtilRebootDrv EraserUtilRebootDrv.sys Tue Nov 28 14:41:47 2006 (456CBB2B)
    aa5ac000 aa60e000 eeCtrl eeCtrl.sys Tue Nov 28 14:41:47 2006 (456CBB2B)
    aa60e000 aa677c00 mrxsmb mrxsmb.sys Fri May 05 02:31:01 2006 (445B1B55)
    aa678000 aa6a0b00 rdbss rdbss.sys Fri May 05 02:40:30 2006 (445B1D8E)
    aa6a1000 aa707000 SPBBCDrv SPBBCDrv.sys Fri Aug 18 06:14:54 2006 (44E5BD4E)
    aa707000 aa72b700 netbt netbt.sys Tue Jul 08 16:48:51 2003 (3F0B5863)
    aa72c000 aa75a000 SymIDSCo SymIDSCo.sys Thu Oct 19 20:57:10 2006 (45384916)
    aa75a000 aa77bf00 SYMFW SYMFW.SYS Sat Sep 02 12:16:54 2006 (44F9D8A6)
    aa77c000 aa7a8000 SYMTDI SYMTDI.SYS Sat Sep 02 12:16:52 2006 (44F9D8A4)
    aa7a8000 aa7fb200 tcpip tcpip.sys Thu Apr 20 04:38:42 2006 (444772C2)
    aa7fc000 aa80e280 ipsec ipsec.sys Sat May 13 03:13:30 2006 (4465B14A)
    aa839000 aa85e180 EXPORTIT EXPORTIT.SYS Wed Jun 02 10:17:52 2004 (40BE0BC0)
    aa9b3000 aa9c4000 SRTSPX SRTSPX.SYS Wed Dec 06 18:17:50 2006 (457779CE)
    aa9c4000 aa9e7000 SYMEVENT SYMEVENT.SYS Fri Dec 15 16:30:34 2006 (45833E2A)
    aa9e7000 aaa34000 SRTSPL SRTSPL.SYS Wed Dec 06 18:17:50 2006 (457779CE)
    bab1c000 bab4f180 update update.sys Wed Sep 01 15:27:22 2004 (41364CCA)
    bab50000 bab7c880 rdpdr rdpdr.sys Thu Aug 29 01:06:34 2002 (3D6DD60A)
    bab7d000 bab8d200 psched psched.sys Thu Aug 29 01:35:54 2002 (3D6DDCEA)
    bab8e000 baba3600 ndiswan ndiswan.sys Thu Aug 29 01:58:38 2002 (3D6DE23E)
    babac000 babae280 rasacd rasacd.sys Fri Aug 17 13:55:39 2001 (3B7D84CB)
    babcc000 babe38a0 aeaudio aeaudio.sys Thu Mar 13 14:54:09 2003 (3E70FE01)
    babe4000 bac04c80 portcls portcls.sys Thu Aug 29 02:00:58 2002 (3D6DE2CA)
    bac05000 bac92300 smwdm smwdm.sys Mon Jun 02 10:42:12 2003 (3EDB8C74)
    bad13000 bad21900 Cdfs Cdfs.SYS Thu Aug 29 01:58:50 2002 (3D6DE24A)
    bad23000 bad2b880 Fips Fips.SYS Fri Aug 17 18:31:49 2001 (3B7DC585)
    bad33000 bad52d00 ks ks.sys Wed Dec 04 09:09:38 2002 (3DEE36D2)
    bad53000 bad65900 parport parport.sys Thu Aug 29 01:27:29 2002 (3D6DDAF1)
    bad66000 bad6ad00 vga vga.sys Thu Aug 29 01:32:03 2002 (3D6DDC03)
    bad6e000 bad75000 ghpciscan ghpciscan.sys Tue Aug 13 20:11:14 2002 (3D59CA52)
    badb6000 badd9800 e100b325 e100b325.sys Tue Mar 04 11:56:25 2003 (3E6504E9)
    badda000 badfb180 USBPORT USBPORT.SYS Thu Aug 29 01:32:49 2002 (3D6DDC31)
    badfc000 bae0d500 VIDEOPRT VIDEOPRT.SYS Thu Aug 29 01:32:03 2002 (3D6DDC03)
    bae0e000 baf84000 ati2mtag ati2mtag.sys Tue Jan 24 19:52:30 2006 (43D6F5FE)
    baff0000 baff3f80 TDI TDI.SYS Fri Aug 17 13:57:25 2001 (3B7D8535)
    bf800000 bf9b7580 win32k win32k.sys Mon Oct 03 18:38:07 2005 (4341DCFF)
    bf9b8000 bf9fa000 ati2dvag ati2dvag.dll Tue Jan 24 19:52:48 2006 (43D6F610)
    bf9fa000 bfa39000 ati2cqag ati2cqag.dll Tue Jan 24 19:10:37 2006 (43D6EC2D)
    bfa39000 bfa6f000 atikvmag atikvmag.dll Tue Jan 24 19:16:49 2006 (43D6EDA1)
    bfa6f000 bfceac60 ati3duag ati3duag.dll Tue Jan 24 19:36:47 2006 (43D6F24F)
    bfceb000 bfdbd020 ativvaxx ativvaxx.dll Tue Jan 24 19:30:18 2006 (43D6F0CA)
    bff80000 bff90d80 dxg dxg.sys Thu Aug 29 03:40:42 2002 (3D6DFA2A)
    f7400000 f7410e80 sr sr.sys Thu Aug 29 01:17:56 2002 (3D6DD8B4)
    f7411000 f7419180 netbios netbios.sys Thu Aug 29 01:35:45 2002 (3D6DDCE1)
    f7421000 f7429200 SYMIDS SYMIDS.SYS Sat Sep 02 12:16:55 2006 (44F9D8A7)
    f7431000 f743f000 arp1394 arp1394.sys Thu Aug 29 01:33:29 2002 (3D6DDC59)
    f7441000 f7449200 wanarp wanarp.sys Fri Aug 17 13:55:23 2001 (3B7D84BB)
    f7461000 f746a000 DcCam DcCam.sys Thu May 20 05:15:59 2004 (40ACA17F)
    f7491000 f749db00 usbhub usbhub.sys Thu Aug 29 01:32:49 2002 (3D6DDC31)
    f74b1000 f74c6400 atapi atapi.sys Fri Jan 31 15:43:28 2003 (3E3B0A20)
    f74c7000 f74eab80 dmio dmio.sys Fri Aug 17 13:58:27 2001 (3B7D8573)
    f74eb000 f7509880 ftdisk ftdisk.sys Fri Aug 17 13:52:41 2001 (3B7D8419)
    f752a000 f7533480 NDProxy NDProxy.SYS Fri Aug 17 13:55:30 2001 (3B7D84C2)
    f753a000 f7543400 termdd termdd.sys Thu Aug 29 01:40:32 2002 (3D6DDE00)
    f754a000 f7552400 msgpc msgpc.sys Fri Aug 17 13:54:19 2001 (3B7D847B)
    f755a000 f7565480 raspptp raspptp.sys Tue Oct 01 17:52:28 2002 (3D9A434C)
    f756a000 f7573800 raspppoe raspppoe.sys Fri Aug 17 13:55:33 2001 (3B7D84C5)
    f757a000 f7585d00 rasl2tp rasl2tp.sys Thu Aug 29 02:06:36 2002 (3D6DE41C)
    f758a000 f7598200 drmk drmk.sys Thu Aug 29 01:32:30 2002 (3D6DDC1E)
    f759a000 f75a3b80 imapi imapi.sys Thu Aug 29 01:28:05 2002 (3D6DDB15)
    f75aa000 f75d5c80 ACPI ACPI.sys Thu Aug 29 01:09:03 2002 (3D6DD69F)
    f75f7000 f7606600 pci pci.sys Thu Aug 29 01:09:10 2002 (3D6DD6A6)
    f7607000 f760fc00 isapnp isapnp.sys Fri Aug 17 13:58:01 2001 (3B7D8559)
    f7617000 f7624980 ohci1394 ohci1394.sys Thu Aug 29 01:33:19 2002 (3D6DDC4F)
    f7627000 f7633580 1394BUS 1394BUS.SYS Thu Aug 29 01:33:19 2002 (3D6DDC4F)
    f7637000 f7640280 MountMgr MountMgr.sys Fri Aug 17 13:47:36 2001 (3B7D82E8)
    f7647000 f7653000 VolSnap VolSnap.sys Fri Aug 17 13:53:19 2001 (3B7D843F)
    f7657000 f765f400 disk disk.sys Thu Aug 29 01:27:56 2002 (3D6DDB0C)
    f7667000 f7672500 CLASSPNP CLASSPNP.SYS Thu Aug 29 02:08:42 2002 (3D6DE49A)
    f7697000 f769fe40 SMBios SMBios.sys Thu Sep 11 15:20:22 2003 (3F60F526)
    f76b7000 f76c5280 nic1394 nic1394.sys Thu Aug 29 01:33:29 2002 (3D6DDC59)
    f76c7000 f76d3780 i8042prt i8042prt.sys Thu Aug 29 02:06:37 2002 (3D6DE41D)
    f76d7000 f76e6400 serial serial.sys Thu Aug 29 02:08:27 2002 (3D6DE48B)
    f76e7000 f76f2980 cdrom cdrom.sys Thu Aug 29 01:27:55 2002 (3D6DDB0B)
    f76f7000 f7704d00 redbook redbook.sys Thu Aug 29 01:27:45 2002 (3D6DDB01)
    f7707000 f770cc80 PCIIDEX PCIIDEX.SYS Fri Jan 31 15:43:28 2003 (3E3B0A20)
    f770f000 f7713900 PartMgr PartMgr.sys Fri Aug 17 18:32:23 2001 (3B7DC5A7)
    f7717000 f771bbc0 PxHelp20 PxHelp20.sys Tue Oct 28 11:25:49 2003 (3F9EB4AD)
    f771f000 f7725380 agp440 agp440.sys Fri Aug 17 13:57:59 2001 (3B7D8557)
    f775f000 f7763080 raspti raspti.sys Fri Aug 17 13:55:32 2001 (3B7D84C4)
    f7767000 f776e780 processr processr.sys Thu Aug 29 01:05:03 2002 (3D6DD5AF)
    f7777000 f777bb80 usbuhci usbuhci.sys Thu Aug 29 01:32:48 2002 (3D6DDC30)
    f7787000 f778bb80 usbehci usbehci.sys Thu Aug 29 01:32:47 2002 (3D6DDC2F)
    f778f000 f7793e80 TDTCP TDTCP.SYS Fri Aug 17 13:46:43 2001 (3B7D82B3)
    f7797000 f779bd00 flpydisk flpydisk.sys Thu Aug 29 01:27:43 2002 (3D6DDAFF)
    f77a7000 f77acb80 kbdclass kbdclass.sys Thu Aug 29 01:26:59 2002 (3D6DDAD3)
    f77af000 f77b4600 mouclass mouclass.sys Thu Aug 29 01:27:00 2002 (3D6DDAD4)
    f77b7000 f77bb680 Msfs Msfs.SYS Fri Aug 17 13:50:02 2001 (3B7D837A)
    f77bf000 f77c0000 fdc fdc.sys unavailable (00000000)
    f77c7000 f77ce380 Npfs Npfs.SYS Fri Aug 17 13:50:03 2001 (3B7D837B)
    f77cf000 f77d4300 pfc pfc.sys Fri Sep 19 16:45:46 2003 (3F6B952A)
    f77df000 f77e4080 SYMREDRV SYMREDRV.SYS Sat Sep 02 12:16:55 2006 (44F9D8A7)
    f77e7000 f77ee000 GEARAspiWDM GEARAspiWDM.sys Tue Feb 01 21:19:49 2005 (420062F5)
    f77ef000 f77f5b00 SYMNDIS SYMNDIS.SYS Sat Sep 02 12:16:54 2006 (44F9D8A6)
    f77f7000 f77fbf20 smb smb.sys Wed Oct 23 09:05:04 2002 (3DB6C8B0)
    f7807000 f780ea40 sf sf.sys Thu May 08 21:00:55 2003 (3EBB27F7)
    f7817000 f781b580 ptilink ptilink.sys Fri Aug 17 13:49:53 2001 (3B7D8371)
    f7836000 f7896300 zmxpzip zmxpzip.sys Fri Apr 29 10:31:47 2005 (42726F83)
    f7897000 f789a000 BOOTVID BOOTVID.dll Fri Aug 17 13:49:09 2001 (3B7D8345)
    f791b000 f791d900 Dxapi Dxapi.sys Fri Aug 17 13:53:19 2001 (3B7D843F)
    f791f000 f7923000 watchdog watchdog.sys Thu Aug 29 01:32:20 2002 (3D6DDC14)
    f7923000 f7926a80 serenum serenum.sys Fri Aug 17 13:50:13 2001 (3B7D8385)
    f792f000 f7932780 usbscan usbscan.sys Thu Aug 29 01:48:51 2002 (3D6DDFF3)
    f794b000 f794d580 ndistapi ndistapi.sys Fri Aug 17 13:55:29 2001 (3B7D84C1)
    f7959000 f7972680 Mup Mup.sys Thu Aug 29 02:12:53 2002 (3D6DE595)
    f7973000 f7986780 KSecDD KSecDD.sys Fri Aug 17 13:50:01 2001 (3B7D8379)
    f7987000 f7988b80 kdcom kdcom.dll Fri Aug 17 13:49:10 2001 (3B7D8346)
    f7989000 f798a100 WMILIB WMILIB.SYS Fri Aug 17 14:07:23 2001 (3B7D878B)
    f798b000 f798c700 dmload dmload.sys Fri Aug 17 13:58:15 2001 (3B7D8567)
    f79a5000 f79a6280 USBD USBD.SYS Fri Aug 17 14:02:58 2001 (3B7D8682)
    f79b1000 f79b2f00 Fs_Rec Fs_Rec.SYS Fri Aug 17 13:49:37 2001 (3B7D8361)
    f79b3000 f79b4080 Beep Beep.SYS Fri Aug 17 13:47:33 2001 (3B7D82E5)
    f79b5000 f79b6080 mnmdd mnmdd.SYS Fri Aug 17 13:57:28 2001 (3B7D8538)
    f79b7000 f79b8080 RDPCDD RDPCDD.sys Fri Aug 17 13:46:56 2001 (3B7D82C0)
    f79cb000 f79cc800 SYMDNS SYMDNS.SYS Sat Sep 02 12:16:53 2006 (44F9D8A5)
    f79d7000 f79d8a80 ParVdm ParVdm.SYS Fri Aug 17 13:49:49 2001 (3B7D836D)
    f79e7000 f79e8100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 14:07:23 2001 (3B7D878B)
    f7a26000 f7a4ee80 NDIS NDIS.sys Thu Aug 29 02:09:23 2002 (3D6DE4C3)
    f7a4f000 f7a4fd00 pciide pciide.sys Fri Aug 17 13:51:49 2001 (3B7D83E5)
    f7a72000 f7a72c00 audstub audstub.sys Fri Aug 17 13:59:40 2001 (3B7D85BC)
    f7a7a000 f7a7b000 swenum swenum.sys Wed Dec 04 09:10:07 2002 (3DEE36EF)
    f7a81000 f7a81b80 Null Null.SYS Fri Aug 17 13:47:39 2001 (3B7D82EB)
    f7ab6000 f7ab6d00 dxgthk dxgthk.sys Fri Aug 17 13:53:12 2001 (3B7D8438)
    f7b55000 f7bde300 Ntfs Ntfs.sys Thu Aug 29 02:13:37 2002 (3D6DE5C1)
    Unloaded modules:
    a66c5000 a66c7000 splitter.sys
    Checksum: 00000000
    bad86000 bad8d000 usbprint.sys
    Checksum: 00000000
    bad96000 bad9c000 USBSTOR.SYS
    Checksum: 00000000
    bada6000 badad000 usbccgp.sys
    Checksum: 00000000
    a636b000 a637d000 NAVENG.SYS
    Checksum: 00000000
    a637d000 a6447000 NAVEX15.SYS
    Checksum: 00000000
    a679f000 a67a1000 splitter.sys
    Checksum: 00000000
    a6831000 a6833000 splitter.sys
    Checksum: 00000000
    a6755000 a6757000 splitter.sys
    Checksum: 00000000
    a6a8f000 a6aa1000 NAVENG.SYS
    Checksum: 00000000
    a6aa1000 a6b6b000 NAVEX15.SYS
    Checksum: 00000000
    f79e5000 f79e7000 splitter.sys
    Checksum: 00000000
    f799f000 f79a1000 splitter.sys
    Checksum: 00000000
    Checksum: 00000000
    Checksum: 00000000
    a79e0000 a79f2000 NAVENG.SYS
    Checksum: 00000000
    a79f2000 a7abc000 NAVEX15.SYS
    Checksum: 00000000
    f79bb000 f79bd000 splitter.sys
    Checksum: 00000000
    f7aa9000 f7aaa000 drmkaud.sys
    Checksum: 00000000
    a786e000 a789d000 MidiSyn.sys
    Checksum: 00000000
    a78d8000 a78fb000 aec.sys
    Checksum: 00000000
    a8261000 a826e000 DMusic.sys
    Checksum: 00000000
    a7f78000 a7f86000 swmidi.sys
    Checksum: 00000000
    aa8d7000 aa8e9000 NAVENG.SYS
    Checksum: 00000000
    aa8e9000 aa9b3000 NAVEX15.SYS
    Checksum: 00000000
    bad7e000 bad83000 Cdaudio.SYS
    Checksum: 00000000
    Closing open log file c:\debuglog.txt
  5. 2007/10/28
    Hi,
    This file appears to be part of the Stuffit compression program. This is their Technical Support page:
    http://www.allume.com/support/techsupport/index.html
    Uninstall and reinstall Stuffit and look for an version upgrade.
    If the problem continues you will need to check several logs and look for any consistencies (or if they are totally inconsistent).
    If you know what will actually cause the crash, post back with logs of those episodes.
  6. 2007/10/28
    geddon .....
    When replying to a response in your thread please hit the reply button and enter your reply in the message pane - NOT in a new thread.
    Your threads merged.
