Need 800 X 600 resolution
Discussion in 'PC Hardware' started by jawdoc, 2007/09/30.
  1. 2007/09/30
    jawdoc
    jawdoc Inactive Thread Starter
    I have an issue that I hope someone can help with.
    I have a laptop that when I try to set the display resolution to 800 X 600 is occupies about half of the display in the center.
    BIOS and windows splash screens the same.
    I looked in the CMOS setup and could not find anything to change.
    I have an old program that requires 800 X 600 resolution. Do I have a laptop that will not support that resolution?
    Anything I can do?
    Thanks in advance!
  2. 2007/09/30
    charlesvar
    charlesvar Inactive Alumni
    Hello jawdoc,
    Tell us what the laptop is.
    Download this free program - System information for Windows http://www.gtopala.com/ and lookup the Video card specs and post the info here.
    jawdoc
    It's a Dell Latitude CSx Model: PMP
    The laptop is a Dell Latitude CSx Model: PMP
    Old laptop running 95 2nd edition.
    It is a client of mine, but I don't think the OS is the problem because the BIOS/splash screen is small as well.
    Currently is supporting much higher resolution in the windows enviroment.
  5. 2007/10/01
    http://support.dell.com/support/edocs/systems/pmac2cm/en/en_ug/display.htm
