multiple users: how to set default settings?
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by tino, 2002/01/10.
  1. 2002/01/10
    tino
    tino Guest Thread Starter
    Does anyone know how to make a default profile, that will be the starting profile for all the users creating their own profile? I'm specially interested in setting the proxy once for ever.
    cheers
    Tino
    tino,
  2. 2002/01/10
    tino
    I'm using in Communicator 4.x =)
    fill
    tino,
    Antony
    Antony Inactive
    For bookmarks, easy,
    Check the following folder
    ... Program Files/Netscape/Communicator/Program/Defaults/
    If you want to change other settings as default settings (new user profile), you might want to try to use Netscape CCK. Not recommended, too much trouble.
  5. 2002/01/11
    tino
    bookmarks
    thanx Antony. The Bookmarks are set.
    I found that CCK-thing and I'm gonna try it, but i hope there some easier way...
    tino,
    Ramona
    Ramona Geek Member Alumni
    Hi tino,
    Sorry I haven't been able to help you with your problem. I'm definitely not NT literate, so hesitate to give you an answer, for fear of steering you in the wrong direction.
    I am trying to get you some information, though.
    Ramona
  7. 2002/01/15
    tino
    solved
    I finally solved the problem by creating a default profile folder in every user's network folder.
    tino,
    #6
  8. 2002/01/15
    Ramona
    tino,
    Thanks for posting back and letting us know that your problem is solved! Good news too!
    Ramona :D
