Solved Multiple MS explorer.exe problems!
Discussion in 'Malware and Virus Removal Archive' started by nykrumrie, 2012/04/18.
  1. 2012/04/18
    nykrumrie
    nykrumrie Inactive Thread Starter
    [Resolved] Multiple MS explorer.exe problems!
    I was asked to run some diagnostic tools to see if I can provide more info on my computer issues. You can see the full description of my problem in your forum page:
    http://www.windowsbbs.com/windows-7/102410-i-need-help-ms-explorer-exe-problems.html
    I've done the best I can here are the results in the order asked:
    Malwarebytes (MBAM)
    Malwarebytes Anti-Malware (Trial) 1.61.0.1400
    www.malwarebytes.org
    Database version: v2012.04.17.06
    Windows 7 Service Pack 1 x64 NTFS
    Internet Explorer 9.0.8112.16421
    john :: ROCCO-WIN7-X64 [administrator]
    Protection: Enabled
    4/17/2012 8:30:27 PM
    mbam-log-2012-04-17 (20-30-27).txt
    Scan type: Quick scan
    Scan options enabled: Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken | PUP | PUM
    Scan options disabled: P2P
    Objects scanned: 223968
    Time elapsed: 4 minute(s), 44 second(s)
    Memory Processes Detected: 0
    (No malicious items detected)
    Memory Modules Detected: 0
    Registry Keys Detected: 0
    Registry Values Detected: 0
    Registry Data Items Detected: 0
    Folders Detected: 0
    Files Detected: 0
    (end)
    GMER
    I ran it twice & it produced no report or results of errors. gmer.log file was blank.
    MBRCheck
    aswMBR version 0.9.9.1665 Copyright(c) 2011 AVAST Software
    Run date: 2012-04-18 03:38:36
    03:38:36.961 OS Version: Windows x64 6.1.7601 Service Pack 1
    03:38:36.961 Number of processors: 2 586 0x170A
    03:38:36.962 ComputerName: ROCCO-WIN7-X64 UserName: john
    03:38:37.501 Initialze error C000010E - driver not loaded
    03:38:37.687 AVAST engine defs: 12041701
    03:38:46.012 Service scanning
    03:39:26.764 Modules scanning
    03:39:26.764 Disk 0 trace - called modules:
    03:39:26.765
    03:39:27.257 AVAST engine scan C:\Windows
    03:39:29.925 AVAST engine scan C:\Windows\system32
    03:42:42.880 AVAST engine scan C:\Windows\system32\drivers
    03:42:56.177 AVAST engine scan C:\Users\john.IBC1
    03:56:41.113 AVAST engine scan C:\ProgramData
    04:00:33.975 Scan finished successfully
    10:12:34.022 The log file has been saved successfully to "C:\Users\john.IBC1\Desktop\aswMBR.txt "
    DDS(2 logs)
    I ran it 3 times & it seemed to be progressing. The (#) progress bar was moving. The bar always stopped at the same point & never produced a log or opened a window like I was expecting.
    A friend told me he doesn't think it has anything to do with malware or viruses he thinks its probably a memory or hard drive problem. He didn't know what I can do to try & determine if its a hardware issue. I did the Memory Diagnostic tool test & it didn't find anything.
  2. 2012/04/18
    Welcome aboard [​IMG]
    Please, observe following rules:
    • Read all of my instructions very carefully. Your mistakes during cleaning process may have very serious consequences, like unbootable computer.
    • If you're stuck, or you're not sure about certain step, always ask before doing anything else.
    • Please refrain from running tools or applying updates other than those I suggest.
    • Never run more than one scan at a time.
    • Keep updating me regarding your computer behavior, good, or bad.
    • The cleaning process, once started, has to be completed. Even if your computer appears to act better, it may still be infected. Once the computer is totally clean, I'll certainly let you know.
    • If you leave the topic without explanation in the middle of a cleaning process, you may not be eligible to receive any more help in malware removal forum.
    • I close my topics if you have not replied in 5 days. If you need more time, simply let me know. If I closed your topic and you need it to be reopened, simply PM me.
    aswMBR log is incomplete.
    Re-run it and be more patient. Let it finish.
    Then...
    Download Bootkit Remover to your desktop.
    • Unzip downloaded file to your Desktop.
    • Double-click on boot_cleaner.exe to run the program (Vista/7 users,right click on boot_cleaner.exe and click Run As Administrator).
    • It will show a Black screen with some data on it.
    • Right click on the screen and click Select All.
    • Press CTRL+C
    • Open a Notepad and press CTRL+V
    • Post the output back here.
    nykrumrie
    Hi Broni! I did what you asked. I ran aswMBR again. Actually twice. It never seems to want to launch the 1st time. I have the log below:
    Run date: 2012-04-19 02:23:14
    02:23:14.952 OS Version: Windows x64 6.1.7601 Service Pack 1
    02:23:14.953 Number of processors: 2 586 0x170A
    02:23:14.954 ComputerName: ROCCO-WIN7-X64 UserName: john
    02:23:15.848 Initialze error C000010E - driver not loaded
    02:23:15.984 AVAST engine defs: 12041802
    02:23:20.070 Service scanning
    02:24:01.789 Modules scanning
    02:24:01.789 Disk 0 trace - called modules:
    02:24:01.790
    02:24:02.317 AVAST engine scan C:\Windows
    02:24:04.929 AVAST engine scan C:\Windows\system32
    02:27:22.360 AVAST engine scan C:\Windows\system32\drivers
    02:27:35.703 AVAST engine scan C:\Users\john.IBC1
    02:42:38.682 AVAST engine scan C:\ProgramData
    02:44:50.583 Scan finished successfully
    03:01:19.982 The log file has been saved successfully to "C:\Users\john.IBC1\Desktop\aswMBR#3.txt "
    As you can see it started at 2:23am & finished 2:44am. I didn't see the process light running anymore but I left it alone. At 3:01am nothing had changes so I saved the log. I'll runn it again before bed & leave it alone for hours to see if it makes a difference.
    Here is the log for the Bootkit remover:
    Bootkit Remover
    (c) 2009 Esage Lab
    www.esagelab.com
    Program version: 1.2.0.1
    OS Version: Microsoft Windows 7 Service Pack 1 (build 7601), 64-bit
    System volume is \\.\C:
    \\.\C: -> \\.\PhysicalDrive0 at offset 0x00000021`04a83200
    Size Device Name MBR Status
    232 GB \\.\PhysicalDrive0 Controlled by rootkit!
    Boot code on some of your physical disks is hidden by a rootkit.
    To disinfect the master boot sector, use the following command:
    remover.exe fix <device_name>
    To inspect the boot code manually, dump the master boot sector:
    remover.exe dump <device_name> [output_file]
    Done;
    Press any key to quit...
    Does that mean I have a rootkit virus!!! The 2 lines that are highlighted were highlighted in the program log. Top was red. The bottom was gold. I don't know if that means anything.
    Let me know what else I can do. Thanks!
  5. 2012/04/19
    nykrumrie
    After reading about rootkits I decided to run MBRCheck. Here is what it found:
    MBRCheck, version 1.2.3
    (c) 2010, AD
    Command-line:
    Windows Version: Windows 7 Professional
    Windows Information: Service Pack 1 (build 7601), 64-bit
    Base Board Manufacturer: Acer
    BIOS Manufacturer: Phoenix Technologies LTD
    System Manufacturer: Acer
    System Product Name: Aspire 5738
    Logical Drives Mask: 0x0000023c
    \\.\C: --> \\.\PhysicalDrive0 at offset 0x00000021`04a83200 (NTFS)
    \\.\D: --> \\.\PhysicalDrive0 at offset 0x00000002`ee102000 (NTFS)
    232 GB \\.\PhysicalDrive0 Windows 7 MBR code detected
    SHA1: 4379A3D43019B46FA357F7DD6A53B45A3CA8FB79
    Done!
    Press ENTER to exit...
  6. 2012/04/19
    nykrumrie
    I did the aswMBR scan again & left it alone for hours.
    Run date: 2012-04-19 03:52:18
    03:52:18.545 OS Version: Windows x64 6.1.7601 Service Pack 1
    03:52:18.545 Number of processors: 2 586 0x170A
    03:52:18.545 ComputerName: ROCCO-WIN7-X64 UserName: john
    03:52:19.887 Initialze error C000010E - driver not loaded
    03:52:20.027 AVAST engine defs: 12041802
    03:52:33.989 Service scanning
    03:53:08.123 Modules scanning
    03:53:08.123 Disk 0 trace - called modules:
    03:53:08.123
    03:53:09.044 AVAST engine scan C:\Windows
    03:53:11.727 AVAST engine scan C:\Windows\system32
    03:56:26.417 AVAST engine scan C:\Windows\system32\drivers
    03:56:40.192 AVAST engine scan C:\Users\john.IBC1
    04:13:30.350 AVAST engine scan C:\ProgramData
    04:15:55.726 Scan finished successfully
    10:21:50.181 The log file has been saved successfully to "C:\Users\john.IBC1\Desktop\Fix Programs\Logs\aswMBR#4.txt "
    As you can see I started it at 3:52 am & it finished 4:15am. I left it alone until recently at 10:21am. I hope this is helpful.
    -So if I have a Rootkit virus what's the best way to kill it?
  7. 2012/04/19
    Please observe rules I posted earlier:
    Now...
    Download TDSSKiller and save it to your desktop.
    • Extract (unzip) its contents to your desktop.
    • Open the TDSSKiller folder and doubleclick on TDSSKiller.exe to run the application, then on Start Scan.
    • If an infected file is detected, the default action will be Cure, click on Continue.
    • If a suspicious file is detected, the default action will be Skip, click on Continue.
    • It may ask you to reboot the computer to complete the process. Click on Reboot Now.
    • If no reboot is require, click on Report. A log file should appear. Please copy and paste the contents of that file here.
    • If a reboot is required, the report can also be found in your root directory (usually C:\ folder) in the form of TDSSKiller_xxxx_log.txt. Please copy and paste the contents of that file here.
  8. 2012/04/19
    nykrumrie
    I ran TDDSSkiller & it found no threats. I tried to post the report to this thread but the system says its too long. "133209 characters" too large. Would you like me to cut it into 2-3 parts & post?
  9. 2012/04/19
    That's fine....
    Please download and run ListParts by Farbar (for 32-bit system) to your desktop.
    Please download and run ListParts64 by Farbar (for 64-bit system) to your desktop.
    Click on Scan button.
    Scan result will open in Notepad.
    Post it in your next reply.
  10. 2012/04/19
    nykrumrie
    ListParts by Farbar Version: 12-03-2012 03
    Ran by john (administrator) on 19-04-2012 at 17:27:52
    Windows 7 (X64)
    Running From: C:\Users\john.IBC1\Desktop\Fix Programs
    Language: 0409
    ========================= Memory info ======================
    Percentage of memory in use: 46%
    Total physical RAM: 4024.93 MB
    Available physical RAM: 2149.98 MB
    Total Pagefile: 12072.97 MB
    Available Pagefile: 10114.03 MB
    Total Virtual: 8192 MB
    Available Virtual: 8191.89 MB
    ======================= Partitions =========================
    1 Drive c: () (Fixed) (Total:100.81 GB) (Free:11.39 GB) NTFS
    2 Drive d: (ACER) (Fixed) (Total:120.35 GB) (Free:37.18 GB) NTFS ==>[System with boot components (obtained from reading drive)]
    5 Drive j: () (Removable) (Total:14.96 GB) (Free:14.95 GB) FAT32
    6 Drive q: (Accounting) (Network) (Total:403.8 GB) (Free:377.95 GB) NTFS
    Disk ### Status Size Free Dyn Gpt
    Disk 0 Online 232 GB 1024 KB
    Disk 1 Online 14 GB 0 B
    Partitions of Disk 0:
    Partition ### Type Size Offset
    Partition 1 Recovery 11 GB 1024 KB
    Partition 2 Primary 120 GB 11 GB
    Partition 3 Primary 100 GB 132 GB
    Disk: 0
    Partition 1
    Type : 27
    Hidden: Yes
    Active: No
    Volume ### Ltr Label Fs Type Size Status Info
    * Volume 4 PQSERVICE FAT32 Partition 11 GB Healthy Hidden
    Disk: 0
    Partition 2
    Type : 07
    Hidden: No
    Active: Yes
    * Volume 2 D ACER NTFS Partition 120 GB Healthy System (partition with boot components)
    Disk: 0
    Partition 3
    Type : 07
    Hidden: No
    Active: No
    * Volume 3 C NTFS Partition 100 GB Healthy Boot
    Partitions of Disk 1:
    Partition 1 Primary 14 GB 4096 KB
    Disk: 1
    Partition 1
    Type : 0C
    Hidden: No
    Active: No
    * Volume 5 J FAT32 Removable 14 GB Healthy
    ****** End Of Log ******
  11. 2012/04/19
    Download the FixTDSS.exe
    Save the file to your Windows desktop.
    Close all running programs.
    If you are running Windows XP, turn off System Restore. How to turn off or turn on Windows XP System Restore
    Double-click the FixTDSS.exe file to start the removal tool.
    Click Start to begin the process, and then allow the tool to run.
    OK any security prompts.
    Restart the computer when prompted by the tool.
    After the computer has started, the tool will inform you of the state of infection (make sure to let me know what it said)
    If you are running Windows XP, re-enable System Restore.
  12. 2012/04/19
    nykrumrie
    I don't know if I'm doing something wrong but when I ran FixTDSS.exe no scan or process that I could tell was running. I ran it twice to be sure.
    (btw:I'm running Win7 Pro x64)
    I double click on the program. It launches a window TDSS Fix Tool EULA. Its a license window. I click accept. I see TDSS Fix tool 2.1.3 "This tool will scan & remove TDSS from your system. Once you click proceed your system will be prepared for Restart. After the restart, this toll will be launched automatically to display the results... "
    My Laptop restarts. It restarts to the point I see my Desktop Icons. Then a window pops up asking me if I want to allow the scan to run, I accept. A few moments later I get the results. I never see a program running a scan or anything. The window closes & a few moments later I get the result window say..
    Suspicious use of kernel callback but MBR appears in tact. Repair not done.
    No infection were found
  13. 2012/04/19
    That's fine.
    Please download ComboFix from Here or Here to your Desktop.
    **Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**
    • Never rename Combofix unless instructed.
    • Close any open browsers.
    • Close/disable all anti virus and anti malware programs so they do not interfere with the running of ComboFix.
    • Click on this link to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
    • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
    • Double click on combofix.exe & follow the prompts.
    • NOTE1. If Combofix asks you to install Recovery Console, please allow it.
    • When finished, it will produce a report for you.
    • Please post the "C:\ComboFix.txt"
    **Note 1: Do not mouseclick combofix's window while it's running. That may cause it to stall
    **Note 2 for AVG and CA Internet Security users: ComboFix will not run until AVG/CA Internet Security is uninstalled as a protective measure against the anti-virus. This is because AVG/CA Internet Security "falsely" detects ComboFix (or its embedded files) as a threat and may remove them resulting in the tool not working correctly which in turn can cause "unpredictable results ". Since AVG/CA Internet Security cannot be effectively disabled before running ComboFix, the author recommends you to uninstall AVG/CA Internet Security first.
    Use AppRemover to uninstall it: http://www.appremover.com/
    We can reinstall it when we're done with CF.
    **Note 3: If you receive an error "Illegal operation attempted on a registery key that has been marked for deletion ", restart computer to fix the issue.
    **Note 4: Some infections may take some significant time to be cured. As long as your computer clock is running Combofix is still working. Be patient.
    NOTE.
    If, for some reason, Combofix refuses to run, try one of the following:
    1. Run Combofix from Safe Mode.
    2. Delete Combofix file, download fresh one, but rename combofix.exe to your_name.exe BEFORE saving it to your desktop.
    Do NOT run it yet.
    Please download and run the below tool named Rkill (courtesy of BleepingComputer.com) which may help allow other programs to run.
    There are 4 different versions. If one of them won't run then download and try to run the other one.
    Vista and Win7 users need to right click Rkill and choose Run as Administrator
    You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
    * Rkill.com
    * Rkill.scr
    * Rkill.exe
    • Double-click on the Rkill icon to run the tool.
    • If using Vista or Windows 7 right-click on it and choose Run As Administrator.
    • A black DOS box will briefly flash and then disappear. This is normal and indicates the tool ran successfully.
    • If not, delete the file, then download and use the one provided in Link 2.
    • If it does not work, repeat the process and attempt to use one of the remaining links until the tool runs.
    • Do not reboot until instructed.
    • If the tool does not run from any of the links provided, please let me know.
    Once you've gotten one of them to run, immediately run your_name.exe by double clicking on it.
    If normal mode still doesn't work, run BOTH tools from safe mode.
    In case #2, please post BOTH logs, rKill and Combofix.
  14. 2012/04/19
    nykrumrie
    ComboFix 12-04-19.02 - john 04/19/2012 20:56:18.1.2 - x64
    Microsoft Windows 7 Professional 6.1.7601.1.1252.1.1033.18.4025.2772 [GMT -4:00]
    Running from: c:\downloads\ComboFix.exe
    SP: Windows Defender *Enabled/Updated* {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
    c:\program files (x86)\Search Toolbar
    c:\program files (x86)\Search Toolbar\icon.ico
    c:\program files (x86)\Search Toolbar\SearchToolbarUninstall.exe
    c:\program files (x86)\Search Toolbar\SearchToolbarUpdater.exe
    c:\users\john.IBC1\AppData\Roaming\Mozilla\Firefox\Profiles\k4bd1r1m.default\searchplugins\bing-zugo.xml
    c:\windows\ST6UNST.000
    c:\windows\system32\drivers\etc\hosts.ics
    c:\windows\SysWow64\Nagasoft
    c:\windows\SysWow64\Nagasoft\Codecs\asyncflt.ax
    c:\windows\SysWow64\Nagasoft\Codecs\atrc.dll
    c:\windows\SysWow64\Nagasoft\Codecs\cook.dll
    c:\windows\SysWow64\Nagasoft\Codecs\drvc.dll
    c:\windows\SysWow64\Nagasoft\Codecs\raac.dll
    c:\windows\SysWow64\Nagasoft\Codecs\RealMediaSplitter.ax
    c:\windows\SysWow64\Nagasoft\Codecs\WMFDemux.dll
    c:\windows\SysWow64\Nagasoft\GifShower.dll
    c:\windows\SysWow64\Nagasoft\vjocx.dll
    c:\windows\UA000106.DLL
    ((((((((((((((((((((((((((((((((((((((( Drivers/Services )))))))))))))))))))))))))))))))))))))))))))))))))
    -------\Service_vvdsvc
    ((((((((((((((((((((((((( Files Created from 2012-03-20 to 2012-04-20 )))))))))))))))))))))))))))))))
    2012-04-20 01:05 . 2012-04-20 01:05 -------- d-----w- c:\users\JOHN~1~IBC\AppData\Local\temp
    2012-04-20 01:05 . 2012-04-20 01:05 -------- d-----w- c:\users\John\AppData\Local\temp
    2012-04-20 01:05 . 2012-04-20 01:05 -------- d-----w- c:\users\Default\AppData\Local\temp
    2012-04-19 16:05 . 2010-11-20 13:26 381440 ----a-w- c:\windows\system32\mfds.dll.bak
    2012-04-19 14:59 . 2012-04-19 16:06 -------- d-----w- c:\users\john.IBC1\AppData\Roaming\Win7codecs
    2012-04-19 14:59 . 2012-04-19 14:59 -------- d-----w- c:\program files (x86)\Win7codecs
    2012-04-19 06:53 . 2012-04-19 16:06 -------- d-----w- c:\programdata\Win7codecs
    2012-04-18 00:03 . 2012-03-14 03:27 8669240 ----a-w- c:\programdata\Microsoft\Windows Defender\Definition Updates\{E6F66C72-1C9C-4BAA-B745-8CCA20C6AA42}\mpengine.dll
    2012-04-17 06:21 . 2012-04-17 06:34 3602521 ----a-w- C:\regdll.bat
    2012-04-12 23:08 . 2012-04-12 23:08 -------- d-----w- c:\users\john.IBC1\AppData\Local\ElevatedDiagnostics
    2012-04-12 22:57 . 2012-03-06 06:53 5559152 ----a-w- c:\windows\system32\ntoskrnl.exe
    2012-04-12 22:57 . 2012-03-06 05:59 3968368 ----a-w- c:\windows\SysWow64\ntkrnlpa.exe
    2012-04-12 22:57 . 2012-03-06 05:59 3913072 ----a-w- c:\windows\SysWow64\ntoskrnl.exe
    2012-04-12 22:50 . 2012-03-01 06:46 23408 ----a-w- c:\windows\system32\drivers\fs_rec.sys
    2012-04-12 22:50 . 2012-03-01 06:33 81408 ----a-w- c:\windows\system32\imagehlp.dll
    2012-04-12 22:50 . 2012-03-01 05:33 159232 ----a-w- c:\windows\SysWow64\imagehlp.dll
    2012-04-12 22:50 . 2012-03-01 06:38 220672 ----a-w- c:\windows\system32\wintrust.dll
    2012-04-12 22:50 . 2012-03-01 05:37 172544 ----a-w- c:\windows\SysWow64\wintrust.dll
    2012-04-12 22:50 . 2012-03-01 06:28 5120 ----a-w- c:\windows\system32\wmi.dll
    2012-04-12 22:50 . 2012-03-01 05:29 5120 ----a-w- c:\windows\SysWow64\wmi.dll
    2012-04-09 16:32 . 2012-04-09 16:32 -------- d-----w- c:\programdata\Freemake
    2012-04-04 05:53 . 2012-04-04 05:53 182160 ----a-w- c:\program files (x86)\Mozilla Firefox\plugins\nppdf32.dll
    2012-04-04 05:53 . 2012-04-04 05:53 182160 ----a-w- c:\program files (x86)\Internet Explorer\Plugins\nppdf32.dll
    2012-04-03 13:39 . 2012-04-03 13:39 -------- d-----w- c:\program files\iPod
    2012-04-03 13:39 . 2012-04-03 13:40 -------- d-----w- c:\program files\iTunes
    2012-04-03 13:39 . 2012-04-03 13:39 -------- d-----w- c:\program files (x86)\iTunes
    2012-03-30 17:42 . 2012-03-30 17:42 -------- d-----w- c:\users\john.IBC1\AppData\Roaming\FastStone
    2012-03-30 17:40 . 2012-03-30 17:40 -------- d-----w- c:\program files (x86)\FastStone Image Viewer
    2012-03-30 04:27 . 2012-04-14 17:27 8741536 ----a-w- c:\windows\SysWow64\FlashPlayerInstaller.exe
    2012-03-30 03:40 . 2012-04-14 17:27 418464 ----a-w- c:\windows\SysWow64\FlashPlayerApp.exe
    2012-03-22 23:00 . 2012-03-22 23:00 48128 ----a-w- c:\windows\SysWow64\ff_acm.acm
    2012-03-21 13:44 . 2012-03-21 13:44 -------- d-----w- c:\users\john.IBC1\AppData\Roaming\SUPERAntiSpyware.com
    2012-03-21 08:21 . 2012-03-21 08:21 -------- d-----w- c:\users\john.IBC1\AppData\Roaming\Malwarebytes
    2012-03-21 08:21 . 2012-03-21 08:21 -------- d-----w- c:\programdata\Malwarebytes
    2012-03-21 08:21 . 2012-04-18 00:08 -------- d-----w- c:\program files (x86)\Malwarebytes' Anti-Malware
    2012-03-21 08:21 . 2012-04-04 19:56 24904 ----a-w- c:\windows\system32\drivers\mbam.sys
    2012-04-14 17:27 . 2011-05-17 16:34 70304 ----a-w- c:\windows\SysWow64\FlashPlayerCPLApp.cpl
    2012-03-15 11:40 . 2012-03-15 11:40 4826112 ----a-w- c:\windows\SysWow64\x264vfw.dll
    2012-03-05 21:06 . 2010-04-19 14:21 472808 ----a-w- c:\windows\SysWow64\deployJava1.dll
    2012-02-23 14:18 . 2010-01-26 16:48 279656 ------w- c:\windows\system32\MpSigStub.exe
    2012-02-17 06:38 . 2012-03-13 18:02 1031680 ----a-w- c:\windows\system32\rdpcore.dll
    2012-02-17 05:34 . 2012-03-13 18:02 826880 ----a-w- c:\windows\SysWow64\rdpcore.dll
    2012-02-17 04:58 . 2012-03-13 18:02 210944 ----a-w- c:\windows\system32\drivers\rdpwd.sys
    2012-02-17 04:57 . 2012-03-13 18:02 23552 ----a-w- c:\windows\system32\drivers\tdtcp.sys
    2012-02-15 15:01 . 2012-02-15 15:01 52736 ----a-w- c:\windows\system32\drivers\usbaapl64.sys
    2012-02-15 15:01 . 2012-02-15 15:01 4547944 ----a-w- c:\windows\system32\usbaaplrc.dll
    2012-02-15 15:00 . 2012-02-15 15:00 1287168 ----a-w- c:\windows\SysWow64\VSFilter.dll
    2012-02-10 06:36 . 2012-03-14 18:01 1544192 ----a-w- c:\windows\system32\DWrite.dll
    2012-02-10 05:38 . 2012-03-14 18:01 1077248 ----a-w- c:\windows\SysWow64\DWrite.dll
    2012-02-03 04:34 . 2012-03-14 18:01 3145728 ----a-w- c:\windows\system32\win32k.sys
    2012-01-25 19:21 . 2012-01-25 19:21 913920 ----a-w- c:\windows\SysWow64\lameACM.acm
    2012-01-25 06:38 . 2012-03-13 18:02 77312 ----a-w- c:\windows\system32\rdpwsx.dll
    2012-01-25 06:38 . 2012-03-13 18:02 149504 ----a-w- c:\windows\system32\rdpcorekmts.dll
    2012-01-25 06:33 . 2012-03-13 18:02 9216 ----a-w- c:\windows\system32\rdrmemptylst.exe
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run]
    "AppleSyncNotifier "= "c:\program files (x86)\Common Files\Apple\Mobile Device Support\AppleSyncNotifier.exe" [2011-09-27 59240]
    "LManager "= "c:\program files (x86)\Launch Manager\LManager.exe" [2009-08-18 1157640]
    "Google Desktop Search "= "c:\program files (x86)\Google\Google Desktop Search\GoogleDesktop.exe" [2010-07-01 30192]
    "APSDaemon "= "c:\program files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe" [2012-02-21 59240]
    "Adobe ARM "= "c:\program files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2012-01-03 843712]
    "iTunesHelper "= "c:\program files (x86)\iTunes\iTunesHelper.exe" [2012-03-27 421736]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
    "ConsentPromptBehaviorAdmin "= 5 (0x5)
    "ConsentPromptBehaviorUser "= 3 (0x3)
    "EnableUIADesktopToggle "= 0 (0x0)
    "EnableLinkedConnections "= 1 (0x1)
    [HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\windows]
    "AppInit_DLLs "=c:\progra~2\Google\GOOGLE~1\GoogleDesktopNetwork3.dll
    [HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\drivers32]
    "aux "=wdmaud.drv
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa]
    Security Packages REG_MULTI_SZ kerberos msv1_0 schannel wdigest tspkg pku2u livessp
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\!SASCORE]
    R2 ASTUSB2;POLYMATH Astar2200 series USB2.0 Driver (Ast2200u.sys);c:\windows\system32\Drivers\AST2200u.sys [2011-04-20 67624]
    R2 clr_optimization_v4.0.30319_32;Microsoft .NET Framework NGEN v4.0.30319_X86;c:\windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe [2010-03-18 130384]
    R2 clr_optimization_v4.0.30319_64;Microsoft .NET Framework NGEN v4.0.30319_X64;c:\windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe [2010-03-18 138576]
    R2 WatAdminSvc;Windows Activation Technologies Service;c:\windows\system32\Wat\WatAdminSvc.exe [x]
    R3 AdobeFlashPlayerUpdateSvc;Adobe Flash Player Update Service;c:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2012-04-14 253088]
    R3 BrSerIb;Brother MFC Serial Interface Driver(WDM);c:\windows\system32\DRIVERS\BrSerIb.sys [x]
    R3 BrUsbSIb;Brother MFC Serial USB Driver(WDM);c:\windows\system32\DRIVERS\BrUsbSIb.sys [x]
    R3 dgderdrv;dgderdrv;c:\windows\system32\drivers\dgderdrv.sys [x]
    R3 GoogleDesktopManager-051210-111108;Google Desktop Manager 5.9.1005.12335;c:\program files (x86)\Google\Google Desktop Search\GoogleDesktop.exe [2010-07-01 30192]
    R3 HitachiBackupService;Hitachi Backup Service;c:\program files (x86)\Hitachi\Hitachi Backup\HitachiBackupService.exe [2011-01-06 56832]
    R3 Microsoft SharePoint Workspace Audit Service;Microsoft SharePoint Workspace Audit Service;c:\program files\Microsoft Office\Office14\GROOVE.EXE [2011-06-12 51740536]
    R3 ose64;Office 64 Source Engine;c:\program files\Common Files\Microsoft Shared\Source Engine\OSE.EXE [2010-01-10 174440]
    R3 silabenm;Silicon Labs CP210x USB to UART Bridge Serial Port Enumerator Driver;c:\windows\system32\DRIVERS\silabenm.sys [x]
    R3 silabser;Silicon Labs CP210x USB to UART Bridge Driver;c:\windows\system32\DRIVERS\silabser.sys [x]
    R3 TeamViewer6;TeamViewer 6;c:\program files (x86)\TeamViewer\Version6\TeamViewer_Service.exe [2011-06-01 2337144]
    R3 TFsExDisk;TFsExDisk;c:\windows\System32\Drivers\TFsExDisk.sys [2010-09-15 16392]
    R3 TsUsbFlt;TsUsbFlt;c:\windows\system32\drivers\tsusbflt.sys [x]
    R3 USBAAPL64;Apple Mobile USB Driver;c:\windows\system32\Drivers\usbaapl64.sys [x]
    R3 wlcrasvc;Windows Live Mesh remote connections service;c:\program files\Windows Live\Mesh\wlcrasvc.exe [2010-09-22 57184]
    R4 DMAgent;Intel® PROSet/Wireless WiMAX Red Bend Device Management Service;c:\program files\Intel\WiMAX\Bin\DMAgent.exe [2009-07-30 402432]
    R4 WiMAXAppSrv;Intel® PROSet/Wireless WiMAX Service;c:\program files\Intel\WiMAX\Bin\AppSrv.exe [2009-07-30 1048576]
    S0 fltsrv;Acronis Storage Filter Management;c:\windows\system32\DRIVERS\fltsrv.sys [x]
    S0 SmartDefragDriver;SmartDefragDriver;c:\windows\System32\Drivers\SmartDefragDriver.sys [x]
    S0 vidsflt58;Acronis Disk Storage Filter (58);c:\windows\system32\DRIVERS\vsflt58.sys [x]
    S1 RDPDISPM;RDPDISPM;c:\windows\system32\DRIVERS\rdpdispm.sys [x]
    S1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\SASDIFSV64.SYS [2011-07-22 14928]
    S1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL64.SYS [2011-07-12 12368]
    S1 vwififlt;Virtual WiFi Filter Driver;c:\windows\system32\DRIVERS\vwififlt.sys [x]
    S2 !SASCORE;SAS Core Service;c:\program files\SUPERAntiSpyware\SASCORE64.EXE [2011-08-11 140672]
    S2 AdobeARMservice;Adobe Acrobat Update Service;c:\program files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe [2012-01-03 63928]
    S2 DsiWMIService;Dritek WMI Service;c:\program files (x86)\Launch Manager\dsiwmis.exe [2009-03-24 117256]
    S2 MBAMService;MBAMService;c:\program files (x86)\Malwarebytes' Anti-Malware\mbamservice.exe [2012-04-04 654408]
    S2 osppsvc;Office Software Protection Platform;c:\program files\Common Files\Microsoft Shared\OfficeSoftwareProtectionPlatform\OSPPSVC.EXE [2010-01-10 4925184]
    S2 QBVSS;QBIDPService;c:\program files (x86)\Common Files\Intuit\DataProtect\QBIDPService.exe [2011-08-20 1248256]
    S3 bpenum;Intel(R) WiMAX Link Enumerator;c:\windows\system32\DRIVERS\bpenum.sys [x]
    S3 dc3d;MS Hardware Device Detection Driver (USB);c:\windows\system32\DRIVERS\dc3d.sys [x]
    S3 IntcHdmiAddService;Intel(R) High Definition Audio HDMI;c:\windows\system32\drivers\IntcHdmi.sys [x]
    S3 k57nd60a;Broadcom NetLink (TM) Gigabit Ethernet - NDIS 6.0;c:\windows\system32\DRIVERS\k57nd60a.sys [x]
    S3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [x]
    S3 Point64;Microsoft IntelliPoint Filter Driver;c:\windows\system32\DRIVERS\point64.sys [x]
    S3 vwifimp;Microsoft Virtual WiFi Miniport Service;c:\windows\system32\DRIVERS\vwifimp.sys [x]
    *NewlyCreated* - WS2IFSL
    [HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\windows nt\currentversion\svchost]
    vvdsvc REG_MULTI_SZ vvdsvc
    [HKEY_LOCAL_MACHINE\software\wow6432node\microsoft\active setup\installed components\{2D46B6DC-2207-486B-B523-A557E6D54B47}]
    2010-11-20 12:17 302592 ----a-w- c:\windows\System32\cmd.exe
    2012-04-20 c:\windows\Tasks\Adobe Flash Player Updater.job
    - c:\windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2012-03-30 17:27]
    --------- x86-64 -----------
    "IAAnotif "= "c:\program files (x86)\Intel\Intel Matrix Storage Manager\iaanotif.exe" [2009-06-05 186904]
    "itype "= "c:\program files\Microsoft IntelliType Pro\itype.exe" [2011-04-13 1860496]
    "IntelliPoint "= "c:\program files\Microsoft IntelliPoint\ipoint.exe" [2011-04-13 2399632]
    "Persistence "= "c:\windows\system32\igfxpers.exe" [2009-09-02 358912]
    "IgfxTray "= "c:\windows\system32\igfxtray.exe" [2009-09-02 159232]
    "HotKeysCmds "= "c:\windows\system32\hkcmd.exe" [2009-09-02 380928]
    "PLFSetI "= "c:\windows\PLFSetI.exe" [2010-02-05 200704]
    "combofix "= "c:\combofix\CF5147.3XE" [2010-11-20 345088]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
    "LoadAppInit_DLLs "=0x0
    uLocal Page = c:\windows\system32\blank.htm
    uStart Page = hxxp://isearch.avg.com/?cid={090EAFFA-CB63-4399-AE9C-8104093AF1B8}&mid=54135626aa8147d08d85d15650732158-8d9fe92e443fd0b1251281228e6ffc2f6e655618&lang=en&ds=is015&pr=sa&d=2012-03-22 20:56&v=10.2.0.3&sap=hp
    mLocal Page = c:\windows\SysWOW64\blank.htm
    uInternet Settings,ProxyOverride = *.local
    IE: &Download by Orbit - c:\program files (x86)\Orbitdownloader\orbitmxt.dll/201
    IE: &Grab video by Orbit - c:\program files (x86)\Orbitdownloader\orbitmxt.dll/204
    IE: Do&wnload selected by Orbit - c:\program files (x86)\Orbitdownloader\orbitmxt.dll/203
    IE: Down&load all by Orbit - c:\program files (x86)\Orbitdownloader\orbitmxt.dll/202
    IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~1\Office14\EXCEL.EXE/3000
    IE: Se&nd to OneNote - c:\progra~1\MICROS~1\Office14\ONBttnIE.dll/105
    TCP: DhcpNameServer = 192.168.15.1
    Handler: intu-help-qb5 - {867FCB77-9823-4cd6-8210-D85F968D466F} - c:\program files (x86)\Intuit\QuickBooks Enterprise Solutions 10.0\HelpAsyncPluggableProtocol.dll
    DPF: {971FC730-55F1-461F-83FD-B3BF5E1F039E} - hxxp://ibcoffice.dnsalias.net:81/AVC_AX_742.cab
    DPF: {9B479D7B-916A-45B0-B042-D42865A60E21} - hxxp://bygollys.dnsalias.net/DvrOcx.cab
    FF - ProfilePath - c:\users\john.IBC1\AppData\Roaming\Mozilla\Firefox\Profiles\k4bd1r1m.default\
    FF - prefs.js: browser.search.defaulturl - hxxp://www.bing.com/search?FORM=IEFM1&q=
    FF - prefs.js: browser.search.selectedEngine - Google
    FF - prefs.js: browser.startup.homepage - hxxp://my.myway.com/
    FF - prefs.js: keyword.URL - hxxp://isearch.avg.com/search?cid=%7B1f529c22-0c82-49ab-891c-bbb5018f8118%7D&mid=54135626aa8147d08d85d15650732158-8d9fe92e443fd0b1251281228e6ffc2f6e655618&ds=is015&v=10.2.0.3&lang=en&pr=sa&d=2012-03-22%2020%3A56%3A49&sap=ku&q=
    WebBrowser-{D4027C7F-154A-4066-A1AD-4243D8127440} - (no file)
    AddRemove-Smart Defrag 2_is1 - c:\program files (x86)\IObit\Smart Defrag 2\unins000.exe
    [HKEY_USERS\S-1-5-21-3852137769-1796420447-4257946896-1148\Software\Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Favorites\T*V* ]
    @Allowed: (Read) (RestrictedCode)
    @SACL=(02 0001)
    "Order "=hex:08,00,00,00,02,00,00,00,ce,06,00,00,01,00,00,00,09,00,00,00,7c,00,
    00,00,08,00,00,00,6e,00,32,00,8a,00,00,00,3d,3f,99,96,20,00,42,59,47,4f,4c,\
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}]
    @Denied: (A 2) (Everyone)
    @= "FlashBroker "
    "LocalizedString "= "@c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil32_11_2_202_233_ActiveX.exe,-101 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\Elevation]
    "Enabled "=dword:00000001
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\LocalServer32]
    @= "c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil32_11_2_202_233_ActiveX.exe "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\TypeLib]
    @= "{FAB3E735-69C7-453B-A446-B6823C6DF1C9} "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}]
    @= "Shockwave Flash Object "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32]
    @= "c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash32_11_2_202_233.ocx "
    "ThreadingModel "= "Apartment "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus]
    @= "0 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID]
    @= "ShockwaveFlash.ShockwaveFlash.11 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
    @= "c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash32_11_2_202_233.ocx, 1 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib]
    @= "{D27CDB6B-AE6D-11cf-96B8-444553540000} "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version]
    @= "1.0 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
    @= "ShockwaveFlash.ShockwaveFlash "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}]
    @= "Macromedia Flash Factory Object "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\InprocServer32]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ProgID]
    @= "FlashFactory.FlashFactory.1 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\TypeLib]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\Version]
    @= "1.0 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
    @= "FlashFactory.FlashFactory "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}]
    @= "IFlashBroker4 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\ProxyStubClsid32]
    @= "{00020424-0000-0000-C000-000000000046} "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{E3F2C3CB-5EB8-4A04-B22C-7E3B4B6AF30F}\TypeLib]
    "Version "= "1.0 "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Office\Common\Smart Tag\Actions\{B9A09F18-45AB-4F09-A117-A4ADDA8FA8C8}]
    @Denied: (A) (Everyone)
    "Solution "= "{36eb6792-3a29-43b3-8cd0-f67d266fb426} "
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Schema Library\ActionsPane]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Schema Library\ActionsPane\0]
    "Key "= "ActionsPane "
    "Location "= "c:\\Program Files (x86)\\Common Files\\Microsoft Shared\\VSTO\\8.0\\ActionsPane.xsd "
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet005\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0000\AllUserSettings]
    @Denied: (A) (Users)
    @Allowed: (B 1 2 3 4 5) (S-1-5-20)
    "BlindDial "=dword:00000000
    "MSCurrentCountry "=dword:000000b5
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet005\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0001\AllUserSettings]
    [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet005\Control\PCW\Security]
    @Denied: (Full) (Everyone)
    ------------------------ Other Running Processes ------------------------
    c:\program files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
    c:\program files (x86)\Common Files\Intuit\QuickBooks\QBCFMonitorService.exe
    c:\program files (x86)\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
    c:\program files (x86)\Intel\Intel Matrix Storage Manager\IAANTMon.exe
    Completion time: 2012-04-19 21:29:55 - machine was rebooted
    ComboFix-quarantined-files.txt 2012-04-20 01:29
    Pre-Run: 12,084,269,056 bytes free
    Post-Run: 13,500,739,584 bytes free
    - - End Of File - - 0A98BD1855CE40D66C0EDF343C01D3A7
  15. 2012/04/19
    Looks good.
    How is computer doing?
    Download OTL to your Desktop.
    • Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
    • Click the Scan All Users checkbox.
    • Under the Custom Scan box paste this in:
    netsvcs
    drivers32
    %SYSTEMDRIVE%\*.*
    %systemroot%\Fonts\*.com
    %systemroot%\Fonts\*.dll
    %systemroot%\Fonts\*.ini
    %systemroot%\Fonts\*.ini2
    %systemroot%\Fonts\*.exe
    %systemroot%\system32\spool\prtprocs\w32x86\*.*
    %systemroot%\REPAIR\*.bak1
    %systemroot%\REPAIR\*.ini
    %systemroot%\*.scr
    %systemroot%\*._sy
    %APPDATA%\Adobe\Update\*.*
    %ALLUSERSPROFILE%\Favorites\*.*
    %APPDATA%\Microsoft\*.*
    %PROGRAMFILES%\*.*
    %APPDATA%\Update\*.*
    %systemroot%\*. /mp /s
    CREATERESTOREPOINT
    %systemroot%\System32\config\*.sav
    %PROGRAMFILES%\bak. /s
    %systemroot%\system32\bak. /s
    %ALLUSERSPROFILE%\Start Menu\*.lnk /x
    %systemroot%\system32\config\systemprofile\*.dat /x
    %systemroot%\*.config
    %systemroot%\system32\*.db
    %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x
    %USERPROFILE%\Desktop\*.exe
    %PROGRAMFILES%\Common Files\*.*
    %systemroot%\*.src
    %systemroot%\install\*.*
    %systemroot%\system32\DLL\*.*
    %systemroot%\system32\HelpFiles\*.*
    %systemroot%\tasks\*.*
    %systemroot%\system32\rundll\*.*
    %systemroot%\winn32\*.*
    %systemroot%\Java\*.*
    %systemroot%\system32\test\*.*
    %systemroot%\system32\Rundll32\*.*
    %systemroot%\AppPatch\Custom\*.*
    %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x
    %PROGRAMFILES%\PC-Doctor\Downloads\*.*
    %PROGRAMFILES%\Internet Explorer\*.tmp
    %PROGRAMFILES%\Internet Explorer\*.dat
    %USERPROFILE%\My Documents\*.exe
    %USERPROFILE%\*.exe
    %systemroot%\ADDINS\*.*
    %systemroot%\assembly\*.bak2
    %systemroot%\Config\*.*
    %systemroot%\REPAIR\*.bak2
    %systemroot%\SECURITY\Database\*.sdb /x
    %systemroot%\SYSTEM\*.bak2
    %systemroot%\Web\*.bak2
    %systemroot%\Driver Cache\*.*
    %PROGRAMFILES%\Mozilla Firefox\0*.exe
    %ProgramFiles%\Microsoft Common\*.*
    %ProgramFiles%\TinyProxy.
    %USERPROFILE%\Favorites\*.url /x
    %systemroot%\system32\*.bk
    %systemroot%\*.te
    %systemroot%\system32\system32\*.*
    %ALLUSERSPROFILE%\*.dat /x
    %systemroot%\system32\drivers\*.rmv
    dir /b "%systemroot%\system32\*.exe" | find /i " " /c
    dir /b "%systemroot%\*.exe" | find /i " " /c
    %PROGRAMFILES%\Microsoft\*.*
    %systemroot%\System32\Wbem\proquota.exe
    %PROGRAMFILES%\Mozilla Firefox\*.dat
    %USERPROFILE%\Cookies\*.txt /x
    %SystemRoot%\system32\fonts\*.*
    %systemroot%\system32\winlog\*.*
    %systemroot%\system32\Language\*.*
    %systemroot%\system32\Settings\*.*
    %systemroot%\system32\*.quo
    %SYSTEMROOT%\AppPatch\*.exe
    %SYSTEMROOT%\inf\*.exe
    %SYSTEMROOT%\Installer\*.exe
    %systemroot%\system32\config\*.bak2
    %systemroot%\system32\Computers\*.*
    %SystemRoot%\system32\Sound\*.*
    %SystemRoot%\system32\SpecialImg\*.*
    %SystemRoot%\system32\code\*.*
    %SystemRoot%\system32\draft\*.*
    %SystemRoot%\system32\MSSSys\*.*
    %ProgramFiles%\Javascript\*.*
    %systemroot%\pchealth\helpctr\System\*.exe /s
    %systemroot%\Web\*.exe
    %systemroot%\system32\msn\*.*
    %systemroot%\system32\*.tro
    %AppData%\Microsoft\Installer\msupdates\*.*
    %ProgramFiles%\Messenger\*.*
    %systemroot%\system32\systhem32\*.*
    %systemroot%\system\*.exe
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install|LastSuccessTime /rs
    /md5start
    /md5stop
    • Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
    • When the scan completes, it will open two notepad windows: OTL.txt and Extras.txt. These are saved in the same location as OTL.
    • Please copy (Edit->Select All, Edit->Copy) the contents of these files, one at a time, and post them back here.
  16. 2012/04/19
    nykrumrie
    I do not notice any change after running ComboFix. The laptop still has all the same issues. It never shuts down cleanly. I always have to hold the power button down to turn it off soIi can reboot. I unplugged everything except the power cable. I rebooted 3 time. This is crazy, it seems like after a reboot it might have all the icons at the bottom right. It boots up super fast (under 3 mins). I can click on empty space & the window comes up without any issue. I still get an explorer.exe error if I double click personalize. All the annoying problems seem to still all be there however. I then restart. Of course I have to hold the power down to shut it down. It reboots & this time the process takes longer. When the desktop appears I'm missing Icons on the bottom right corner. I click on the empty desktop space & it caused explorer.exe to crash. It restarts but it's worthless I can not launch most of the programs. I'm forced to reboot. Upon the next reboot I tend to get the Good Reboot like I described before.
    Other notes:
    -When I go to all Programs & double click Windows Update it asks like its going to launch but it very does.
    -What does the yellow circle in the wifi signal meter icon mean? Here at home I always have it. But when I travel to different places i sometime see the circle & sometimes I don't. Just thought I'd ask.
    I ran the OTL & will post the logs next. I have not rebooted since I ran the OTL scan.
  17. 2012/04/19
    nykrumrie
    OTL is too big for 1 post. I'm cutting in 2 parts
    OTL logfile created on: 4/19/2012 11:08:32 PM - Run 1
    OTL by OldTimer - Version 3.2.40.0 Folder = C:\Users\john.IBC1\Desktop\Fix Programs
    64bit- Professional Service Pack 1 (Version = 6.1.7601) - Type = NTWorkstation
    Internet Explorer (Version = 9.0.8112.16421)
    Locale: 00000409 | Country: United States | Language: ENU | Date Format: M/d/yyyy
    3.93 Gb Total Physical Memory | 2.83 Gb Available Physical Memory | 72.02% Memory free
    11.79 Gb Paging File | 10.62 Gb Available in Paging File | 90.08% Paging File free
    Paging file location(s): c:\pagefile.sys 0 0d:\pagefile.sys 0 0 [binary data]
    %SystemDrive% = C: | %SystemRoot% = C:\Windows | %ProgramFiles% = C:\Program Files (x86)
    Drive C: | 100.81 Gb Total Space | 12.69 Gb Free Space | 12.59% Space Free | Partition Type: NTFS
    Drive D: | 120.35 Gb Total Space | 41.96 Gb Free Space | 34.86% Space Free | Partition Type: NTFS
    Drive J: | 14.96 Gb Total Space | 14.95 Gb Free Space | 99.96% Space Free | Partition Type: FAT32
    Computer Name: ROCCO-WIN7-X64 | User Name: john | Logged in as Administrator.
    Boot Mode: Normal | Scan Mode: All users | Quick Scan | Include 64bit Scans
    Company Name Whitelist: On | Skip Microsoft Files: On | No Company Name Whitelist: On | File Age = 30 Days
    PRC - [2012/04/19 22:40:13 | 000,595,968 | ---- | M] (OldTimer Tools) -- C:\Users\john.IBC1\Desktop\Fix Programs\OTL.exe
    PRC - [2012/04/04 15:56:40 | 000,654,408 | ---- | M] (Malwarebytes Corporation) -- C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamservice.exe
    PRC - [2012/03/14 11:19:46 | 000,045,056 | ---- | M] (Intuit) -- C:\Program Files (x86)\Common Files\Intuit\QuickBooks\QBCFMonitorService.exe
    PRC - [2012/01/03 09:10:42 | 000,063,928 | ---- | M] (Adobe Systems Incorporated) -- C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
    PRC - [2011/08/19 22:31:14 | 001,248,256 | ---- | M] (Intuit Inc.) -- C:\Program Files (x86)\Common Files\Intuit\DataProtect\QBIDPService.exe
    PRC - [2010/02/05 12:10:17 | 000,200,704 | ---- | M] () -- C:\Windows\PLFSetI.exe
    PRC - [2009/08/18 18:42:34 | 001,157,640 | ---- | M] (Dritek System Inc.) -- C:\Program Files (x86)\Launch Manager\LManager.exe
    PRC - [2009/06/04 20:03:32 | 000,186,904 | ---- | M] (Intel Corporation) -- C:\Program Files (x86)\Intel\Intel Matrix Storage Manager\IAAnotif.exe
    PRC - [2009/06/04 20:03:06 | 000,354,840 | ---- | M] (Intel Corporation) -- C:\Program Files (x86)\Intel\Intel Matrix Storage Manager\IAANTmon.exe
    PRC - [2009/03/23 20:51:32 | 000,117,256 | ---- | M] (Dritek System Inc.) -- C:\Program Files (x86)\Launch Manager\dsiwmis.exe
    ========== Modules (No Company Name) ==========
    MOD - [2011/09/27 08:23:00 | 000,087,912 | ---- | M] () -- C:\Program Files (x86)\Common Files\Apple\Apple Application Support\zlib1.dll
    MOD - [2011/09/27 08:22:40 | 001,242,472 | ---- | M] () -- C:\Program Files (x86)\Common Files\Apple\Apple Application Support\libxml2.dll
    MOD - [2010/02/05 12:10:17 | 000,200,704 | ---- | M] () -- C:\Windows\PLFSetI.exe
    SRV:64bit: - [2011/08/11 19:38:04 | 000,140,672 | ---- | M] (SUPERAntiSpyware.com) [Auto | Running] -- C:\Program Files\SUPERAntiSpyware\SASCore64.exe -- (!SASCORE)
    SRV:64bit: - [2010/09/22 18:10:10 | 000,057,184 | ---- | M] (Microsoft Corporation) [On_Demand | Stopped] -- C:\Program Files\Windows Live\Mesh\wlcrasvc.exe -- (wlcrasvc)
    SRV:64bit: - [2009/07/30 10:35:54 | 001,048,576 | ---- | M] (Intel(R) Corporation) [Disabled | Stopped] -- C:\Program Files\Intel\WiMAX\Bin\AppSrv.exe -- (WiMAXAppSrv)
    SRV:64bit: - [2009/07/30 10:16:40 | 000,402,432 | ---- | M] (Red Bend Ltd.) [Disabled | Stopped] -- C:\Program Files\Intel\WiMAX\Bin\DMAgent.exe -- (DMAgent)
    SRV:64bit: - [2009/07/13 21:41:27 | 001,011,712 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Program Files\Windows Defender\MpSvc.dll -- (WinDefend)
    SRV:64bit: - [2009/07/13 21:40:01 | 000,193,536 | ---- | M] (Microsoft Corporation) [Auto | Running] -- C:\Windows\SysNative\appmgmts.dll -- (AppMgmt)
    SRV:64bit: - [2009/03/27 19:10:16 | 000,016,896 | ---- | M] (LSI Corporation) [Auto | Running] -- C:\Program Files\LSI SoftModem\agr64svc.exe -- (AgereModemAudio)
    SRV - [2012/04/14 13:27:08 | 000,253,088 | ---- | M] (Adobe Systems Incorporated) [On_Demand | Stopped] -- C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe -- (AdobeFlashPlayerUpdateSvc)
    SRV - [2012/04/04 15:56:40 | 000,654,408 | ---- | M] (Malwarebytes Corporation) [Auto | Running] -- C:\Program Files (x86)\Malwarebytes' Anti-Malware\mbamservice.exe -- (MBAMService)
    SRV - [2012/03/14 11:19:46 | 000,045,056 | ---- | M] (Intuit) [Auto | Running] -- C:\Program Files (x86)\Common Files\Intuit\QuickBooks\QBCFMonitorService.exe -- (QBCFMonitorService)
    SRV - [2012/01/03 09:10:42 | 000,063,928 | ---- | M] (Adobe Systems Incorporated) [Auto | Running] -- C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe -- (AdobeARMservice)
    SRV - [2011/09/14 23:12:14 | 000,655,624 | ---- | M] (Acresso Software Inc.) [On_Demand | Stopped] -- C:\Program Files (x86)\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe -- (FLEXnet Licensing Service)
    SRV - [2011/08/19 22:31:14 | 001,248,256 | ---- | M] (Intuit Inc.) [Auto | Running] -- C:\Program Files (x86)\Common Files\Intuit\DataProtect\QBIDPService.exe -- (QBVSS)
    SRV - [2011/08/19 22:30:58 | 000,061,440 | ---- | M] (Intuit Inc.) [On_Demand | Stopped] -- C:\Program Files (x86)\Common Files\Intuit\QuickBooks\FCS\Intuit.QuickBooks.FCS.exe -- (QBFCService)
    SRV - [2011/06/01 08:44:54 | 002,337,144 | ---- | M] (TeamViewer GmbH) [On_Demand | Stopped] -- C:\Program Files (x86)\TeamViewer\Version6\TeamViewer_Service.exe -- (TeamViewer6)
    SRV - [2011/01/06 12:13:00 | 000,056,832 | ---- | M] (Hitachi GST) [On_Demand | Stopped] -- C:\Program Files (x86)\Hitachi\Hitachi Backup\HitachiBackupService.exe -- (HitachiBackupService)
    SRV - [2010/03/18 13:16:28 | 000,130,384 | ---- | M] (Microsoft Corporation) [Auto | Stopped] -- C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe -- (clr_optimization_v4.0.30319_32)
    SRV - [2009/06/10 17:23:09 | 000,066,384 | ---- | M] (Microsoft Corporation) [Disabled | Stopped] -- C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe -- (clr_optimization_v2.0.50727_32)
    SRV - [2009/06/04 20:03:06 | 000,354,840 | ---- | M] (Intel Corporation) [Auto | Running] -- C:\Program Files (x86)\Intel\Intel Matrix Storage Manager\IAANTmon.exe -- (IAANTMON) Intel(R)
    SRV - [2009/03/23 20:51:32 | 000,117,256 | ---- | M] (Dritek System Inc.) [Auto | Running] -- C:\Program Files (x86)\Launch Manager\dsiwmis.exe -- (DsiWMIService)
    DRV:64bit: - [2012/04/04 15:56:40 | 000,024,904 | ---- | M] (Malwarebytes Corporation) [File_System | On_Demand | Running] -- C:\Windows\SysNative\drivers\mbam.sys -- (MBAMProtector)
    DRV:64bit: - [2012/03/01 02:46:16 | 000,023,408 | ---- | M] (Microsoft Corporation) [Recognizer | Boot | Unknown] -- C:\Windows\SysNative\drivers\fs_rec.sys -- (Fs_Rec)
    DRV:64bit: - [2012/02/15 11:01:50 | 000,052,736 | ---- | M] (Apple, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\usbaapl64.sys -- (USBAAPL64)
    DRV:64bit: - [2011/09/07 22:09:04 | 000,142,944 | ---- | M] (Acronis) [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\vsflt58.sys -- (vidsflt58) Acronis Disk Storage Filter (58)
    DRV:64bit: - [2011/09/07 22:08:54 | 000,132,704 | ---- | M] (Acronis) [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\fltsrv.sys -- (fltsrv)
    DRV:64bit: - [2011/07/28 18:37:10 | 000,052,584 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\dc3d.sys -- (dc3d) MS Hardware Device Detection Driver (USB)
    DRV:64bit: - [2011/07/22 12:26:56 | 000,014,928 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\sasdifsv64.sys -- (SASDIFSV)
    DRV:64bit: - [2011/07/12 17:55:18 | 000,012,368 | ---- | M] (SUPERAdBlocker.com and SUPERAntiSpyware.com) [Kernel | System | Running] -- C:\Program Files\SUPERAntiSpyware\saskutil64.sys -- (SASKUTIL)
    DRV:64bit: - [2011/05/20 09:53:44 | 000,557,848 | ---- | M] (Intel Corporation) [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\iaStor.sys -- (iaStor)
    DRV:64bit: - [2011/05/09 20:42:16 | 000,425,000 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\k57nd60a.sys -- (k57nd60a) Broadcom NetLink (TM)
    DRV:64bit: - [2011/04/20 13:51:58 | 000,067,624 | ---- | M] (PEFIS Co.,Ltd) [Kernel | Auto | Stopped] -- C:\Windows\SysNative\drivers\AST2200u.sys -- (ASTUSB2) POLYMATH Astar2200 series USB2.0 Driver (Ast2200u.sys)
    DRV:64bit: - [2011/04/13 15:04:38 | 000,045,432 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\point64.sys -- (Point64)
    DRV:64bit: - [2011/04/13 15:04:38 | 000,023,960 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\nuidfltr.sys -- (NuidFltr)
    DRV:64bit: - [2011/03/14 10:53:42 | 000,412,712 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\b57nd60a.sys -- (b57nd60a)
    DRV:64bit: - [2011/03/11 02:41:12 | 000,107,904 | ---- | M] (Advanced Micro Devices) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\amdsata.sys -- (amdsata)
    DRV:64bit: - [2011/03/11 02:41:12 | 000,027,008 | ---- | M] (Advanced Micro Devices) [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\amdxata.sys -- (amdxata)
    DRV:64bit: - [2011/01/15 12:21:04 | 000,036,352 | ---- | M] (Elaborate Bytes AG) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\VClone.sys -- (VClone)
    DRV:64bit: - [2010/12/16 18:58:14 | 000,040,816 | ---- | M] (Elaborate Bytes AG) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\ElbyCDIO.sys -- (ElbyCDIO)
    DRV:64bit: - [2010/11/26 18:02:18 | 000,017,720 | ---- | M] () [Kernel | Boot | Running] -- C:\Windows\SysNative\drivers\SmartDefragDriver.sys -- (SmartDefragDriver)
    DRV:64bit: - [2010/11/20 09:33:35 | 000,078,720 | ---- | M] (Hewlett-Packard Company) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\HpSAMD.sys -- (HpSAMD)
    DRV:64bit: - [2010/11/20 07:07:05 | 000,059,392 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\TsUsbFlt.sys -- (TsUsbFlt)
    DRV:64bit: - [2010/09/23 00:36:48 | 000,048,488 | ---- | M] (Microsoft Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\fssfltr.sys -- (fssfltr)
    DRV:64bit: - [2010/09/15 04:42:12 | 000,020,552 | ---- | M] (Devguru Co., Ltd) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\dgderdrv.sys -- (dgderdrv)
    DRV:64bit: - [2010/09/15 04:33:32 | 000,016,392 | ---- | M] (Teruten Inc) [File_System | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\TFsExDisk.sys -- (TFsExDisk)
    DRV:64bit: - [2010/08/31 12:32:44 | 000,010,752 | ---- | M] (Microsoft Corporation) [Kernel | System | Running] -- C:\Windows\SysNative\drivers\rdpdispm.sys -- (RDPDISPM)
    DRV:64bit: - [2010/07/28 10:19:28 | 000,067,584 | ---- | M] (Silicon Laboratories) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\silabser.sys -- (silabser)
    DRV:64bit: - [2010/07/28 10:19:28 | 000,027,336 | ---- | M] (Silicon Laboratories) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\silabenm.sys -- (silabenm)
    DRV:64bit: - [2010/03/15 08:45:28 | 000,145,408 | ---- | M] (Intel(R) Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\IntcHdmi.sys -- (IntcHdmiAddService) Intel(R)
    DRV:64bit: - [2009/10/22 15:10:30 | 000,069,320 | ---- | M] (FTDI Ltd.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\ftdibus.sys -- (FTDIBUS)
    DRV:64bit: - [2009/10/22 15:09:12 | 000,084,808 | ---- | M] (FTDI Ltd.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\ftser2k.sys -- (FTSER2K)
    DRV:64bit: - [2009/10/05 17:34:00 | 001,542,656 | ---- | M] (Atheros Communications, Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\athrx.sys -- (athr)
    DRV:64bit: - [2009/09/02 18:54:20 | 007,369,728 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\igdkmd64.sys -- (igfx)
    DRV:64bit: - [2009/07/30 10:05:36 | 000,070,144 | ---- | M] (Intel Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\bpenum.sys -- (bpenum) Intel(R)
    DRV:64bit: - [2009/07/13 21:52:20 | 000,194,128 | ---- | M] (AMD Technologies Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\amdsbs.sys -- (amdsbs)
    DRV:64bit: - [2009/07/13 21:48:04 | 000,065,600 | ---- | M] (LSI Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\lsi_sas2.sys -- (LSI_SAS2)
    DRV:64bit: - [2009/07/13 21:45:55 | 000,024,656 | ---- | M] (Promise Technology) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\stexstor.sys -- (stexstor)
    DRV:64bit: - [2009/07/13 21:18:06 | 000,281,088 | ---- | M] (Brother Industries Ltd.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\BrSerIb.sys -- (BrSerIb) Brother MFC Serial Interface Driver(WDM)
    DRV:64bit: - [2009/06/10 16:41:10 | 000,015,360 | ---- | M] (Brother Industries Ltd.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\BrUsbSIb.sys -- (BrUsbSIb) Brother MFC Serial USB Driver(WDM)
    DRV:64bit: - [2009/06/10 16:34:33 | 003,286,016 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\evbda.sys -- (ebdrv)
    DRV:64bit: - [2009/06/10 16:34:28 | 000,468,480 | ---- | M] (Broadcom Corporation) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\bxvbda.sys -- (b06bdrv)
    DRV:64bit: - [2009/06/10 16:31:59 | 000,031,232 | ---- | M] (Hauppauge Computer Works, Inc.) [Kernel | On_Demand | Stopped] -- C:\Windows\SysNative\drivers\hcw85cir.sys -- (hcw85cir)
    DRV:64bit: - [2009/05/18 15:17:08 | 000,034,152 | ---- | M] (GEAR Software Inc.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\GEARAspiWDM.sys -- (GEARAspiWDM)
    DRV:64bit: - [2009/04/06 18:31:08 | 001,208,320 | ---- | M] (LSI Corporation) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\agrsm64.sys -- (AgereSoftModem)
    DRV:64bit: - [2008/12/02 15:01:42 | 000,068,608 | ---- | M] (Realtek Semiconductor Corp.) [Kernel | On_Demand | Running] -- C:\Windows\SysNative\drivers\RTSTOR64.sys -- (RTSTOR)
    DRV - [2010/09/15 04:33:32 | 000,016,392 | ---- | M] (Teruten Inc) [File_System | On_Demand | Stopped] -- C:\Windows\SysWOW64\drivers\TFsExDisk.Sys -- (TFsExDisk)
    DRV - [2009/07/13 21:19:10 | 000,019,008 | ---- | M] (Microsoft Corporation) [File_System | On_Demand | Stopped] -- C:\Windows\SysWOW64\drivers\wimmount.sys -- (WIMMount)
    DRV - [2003/10/11 03:00:00 | 000,012,928 | ---- | M] (Philips Semiconductors) [Kernel | Auto | Stopped] -- C:\Windows\SysWOW64\drivers\Ast2200u.SYS -- (ASTUSB2) POLYMATH Astar2200 series USB2.0 Driver (Ast2200u.sys)
    IE:64bit: - HKLM\..\SearchScopes,DefaultScope = {0633EE93-D776-472f-A0FF-E1416B8B2E3A}
    IE:64bit: - HKLM\..\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: "URL" = http://www.bing.com/search?q={searchTerms}&FORM=IE8SRC
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
    IE - HKLM\..\SearchScopes,DefaultScope = {FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF}
    IE - HKLM\..\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: "URL" = http://www.bing.com/search?q={searchTerms}&FORM=IE8SRC
    IE - HKLM\..\SearchScopes\{44475ACF-AC79-4352-B49B-5C569BA1927D}: "URL" = http://www.google.com/search?q={searchTerms}
    IE - HKLM\..\SearchScopes\{FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF}: "URL" = http://www.live.com/?q={searchTerms}
    IE - HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-20\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = http://isearch.avg.com/?cid={090EAFFA-CB63-4399-AE9C-8104093AF1B8}&mid=54135626aa8147d08d85d15650732158-8d9fe92e443fd0b1251281228e6ffc2f6e655618&lang=en&ds=is015&pr=sa&d=2012-03-22 20:56:49&v=10.2.0.3&sap=hp
    IE - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Redirect Cache AcceptLangs = en-us
    IE - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page Redirect Cache_TIMESTAMP = E7 63 9E 77 98 5E CB 01 [binary data]
    IE - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\..\SearchScopes,DefaultScope = {95B7759C-8C7F-4BF1-B163-73684A933233}
    IE - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\..\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}: "URL" = http://www.bing.com/search?q={searchTerms}&src=IE-SearchBox&FORM=IE8SRC
    IE - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\..\SearchScopes\{51FD6F31-C0A7-440B-FB7E-82A5FFE11EEA}: "URL" = http://www.bing.com/search?q={searchTerms}&pc=Z017&form=ZGAIDF
    IE - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\..\SearchScopes\{70D46D94-BF1E-45ED-B567-48701376298E}: "URL" = http://127.0.0.1:4664/search&s=mvMOzvA9CykSl2gGpSORYje3sZ4?q={searchTerms}
    IE - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\..\SearchScopes\{95B7759C-8C7F-4BF1-B163-73684A933233}: "URL" = http://isearch.avg.com/search?cid={090EAFFA-CB63-4399-AE9C-8104093AF1B8}&mid=54135626aa8147d08d85d15650732158-8d9fe92e443fd0b1251281228e6ffc2f6e655618&lang=en&ds=is015&pr=sa&d=2012-03-22 20:56:49&v=10.2.0.3&sap=dsp&q={searchTerms}
    IE - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\..\SearchScopes\{C86609C6-D809-43CD-B6BA-B6C05C2C92E4}: "URL" = http://websearch.ask.com/redirect?client=ie&tb=ANT&o=102821&src=kw&q={searchTerms}&locale=en_US&apn_ptnrs=4N&apn_dtid=YYYYYYYYUS&apn_uid=3ba874f7-26f6-4801-a03d-e5d22cc50425&apn_sauid=E0C4DC07-DF99-487D-8C3A-A719281EC4FA
    IE - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyEnable" = 0
    IE - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\Software\Microsoft\Windows\CurrentVersion\Internet Settings: "ProxyOverride" = *.local
    ========== FireFox ==========
    FF - prefs.js..browser.search.defaultengine: "Ask.com "
    FF - prefs.js..browser.search.defaultenginename: "Ask.com "
    FF - prefs.js..browser.search.defaulturl: "http://www.bing.com/search?FORM=IEFM1&q= "
    FF - prefs.js..browser.search.order.1: "Ask.com "
    FF - prefs.js..browser.search.selectedEngine: "Google "
    FF - prefs.js..browser.search.useDBForOrder: true
    FF - prefs.js..browser.startup.homepage: "http://my.myway.com/ "
    FF - prefs.js..extensions.enabledItems: tabscope@xuldev.org:1.1.2
    FF - prefs.js..extensions.enabledItems: {d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}:1.3.9
    FF - prefs.js..extensions.enabledItems: {b9db16a4-6edc-47ec-a1f4-b86292ed211d}:4.9.4
    FF - prefs.js..extensions.enabledItems: firefox@tvunetworks.com:2
    FF - prefs.js..extensions.enabledItems: 4
    FF - prefs.js..extensions.enabledItems: 9
    FF - prefs.js..extensions.enabledItems: 1
    FF - prefs.js..extensions.enabledItems: {0538E3E3-7E9B-4d49-8831-A227C80A7AD3}:2.0.19
    FF - prefs.js..extensions.enabledItems: ietab@ip.cn:1.98.20110322
    FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}:6.0.20
    FF - prefs.js..extensions.enabledItems: {CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA}:6.0.21
    FF - prefs.js..extensions.enabledItems: vshareus@toolbar:1.0.0
    FF - prefs.js..extensions.enabledItems: foxmarks@kei.com:4.0.0
    FF - prefs.js..extensions.enabledItems: {340c2bbc-ce74-4362-90b5-7c26312808ef}:1.7
    FF - prefs.js..extensions.enabledItems: searchtoolbar@zugo.com:1.2
    FF - prefs.js..extensions.enabledItems: fmconverter@gmail.com:1.0
    FF - prefs.js..extensions.enabledItems: engine@conduit.com:3.3.3.2
    FF - prefs.js..extensions.enabledItems: {e0204bd5-9d31-402b-a99d-a6aa8ffebdca}:1.2.5
    FF - prefs.js..keyword.URL: "http://isearch.avg.com/search?cid=%7B1f529c22-0c82-49ab-891c-bbb5018f8118%7D&mid=54135626aa8147d08d85d15650732158-8d9fe92e443fd0b1251281228e6ffc2f6e655618&ds=is015&v=10.2.0.3&lang=en&pr=sa&d=2012-03-22%2020%3A56%3A49&sap=ku&q= "
    FF - user.js - File not found
    FF:64bit: - HKLM\Software\MozillaPlugins\@adobe.com/FlashPlayer: C:\Windows\system32\Macromed\Flash\NPSWF64_11_2_202_233.dll File not found
    FF:64bit: - HKLM\Software\MozillaPlugins\@docu-track.com/PDF-XChange Viewer Plugin,version=1.0,application/pdf: File not found
    FF:64bit: - HKLM\Software\MozillaPlugins\@microsoft.com/GENUINE: disabled File not found
    FF:64bit: - HKLM\Software\MozillaPlugins\@microsoft.com/OfficeAuthz,version=14.0: C:\PROGRA~1\MICROS~1\Office14\NPAUTHZ.DLL (Microsoft Corporation)
    FF - HKLM\Software\MozillaPlugins\@adobe.com/FlashPlayer: C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_2_202_233.dll ()
    FF - HKLM\Software\MozillaPlugins\@Apple.com/iTunes,version=: File not found
    FF - HKLM\Software\MozillaPlugins\@Apple.com/iTunes,version=1.0: C:\Program Files (x86)\iTunes\Mozilla Plugins\npitunes.dll ()
    FF - HKLM\Software\MozillaPlugins\@divx.com/DivX Player Plugin,version=1.0.0: C:\Program Files (x86)\DivX\DivX Player\npDivxPlayerPlugin.dll File not found
    FF - HKLM\Software\MozillaPlugins\@docu-track.com/PDF-XChange Viewer Plugin,version=1.0,application/pdf: File not found
    FF - HKLM\Software\MozillaPlugins\@java.com/JavaPlugin: C:\Program Files (x86)\Java\jre6\bin\plugin2\npjp2.dll (Sun Microsystems, Inc.)
    FF - HKLM\Software\MozillaPlugins\@microsoft.com/GENUINE: disabled File not found
    FF - HKLM\Software\MozillaPlugins\@Microsoft.com/NpCtrl,version=1.0: C:\Program Files (x86)\Microsoft Silverlight\4.1.10111.0\npctrl.dll ( Microsoft Corporation)
    FF - HKLM\Software\MozillaPlugins\@microsoft.com/OfficeAuthz,version=14.0: C:\PROGRA~2\MICROS~1\Office14\NPAUTHZ.DLL (Microsoft Corporation)
    FF - HKLM\Software\MozillaPlugins\@microsoft.com/SharePoint,version=14.0: C:\PROGRA~2\MICROS~1\Office14\NPSPWRAP.DLL (Microsoft Corporation)
    FF - HKLM\Software\MozillaPlugins\@microsoft.com/WLPG,version=15.4.3502.0922: C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll (Microsoft Corporation)
    FF - HKLM\Software\MozillaPlugins\@microsoft.com/WLPG,version=15.4.3508.1109: C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll (Microsoft Corporation)
    FF - HKLM\Software\MozillaPlugins\@microsoft.com/WLPG,version=15.4.3538.0513: C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll (Microsoft Corporation)
    FF - HKLM\Software\MozillaPlugins\@veetle.com/vbp;version=0.9.16: C:\Program Files (x86)\Veetle\VLCBroadcast\npvbp.dll (Veetle Inc)
    FF - HKLM\Software\MozillaPlugins\@veetle.com/veetleCorePlugin,version=0.9.16: C:\Program Files (x86)\Veetle\plugins\npVeetle.dll (Veetle Inc)
    FF - HKLM\Software\MozillaPlugins\@veetle.com/veetlePlayerPlugin,version=0.9.16: C:\Program Files (x86)\Veetle\Player\npvlc.dll (Veetle Inc)
    FF - HKLM\Software\MozillaPlugins\Adobe Reader: C:\Program Files (x86)\Adobe\Reader 10.0\Reader\AIR\nppdf32.dll (Adobe Systems Inc.)
    FF - HKCU\Software\MozillaPlugins\@docu-track.com/PDF-XChange Viewer Plugin,version=1.0,application/pdf: File not found
    FF - HKCU\Software\MozillaPlugins\@doubletwist.com/NPPodcast: C:\Program Files (x86)\Common Files\doubleTwist\NPPodcast.dll File not found
    FF - HKEY_LOCAL_MACHINE\software\mozilla\Firefox\Extensions\\fmconverter@gmail.com: C:\Program Files (x86)\Freemake\Freemake Video Converter\BrowserPlugin\Firefox\ [2012/04/09 12:32:32 | 000,000,000 | ---D | M]
    FF - HKEY_LOCAL_MACHINE\software\mozilla\Mozilla Firefox 11.0\extensions\\Components: C:\Program Files (x86)\Mozilla Firefox\components [2012/03/18 18:36:57 | 000,000,000 | ---D | M]
    FF - HKEY_LOCAL_MACHINE\software\mozilla\Mozilla Firefox 11.0\extensions\\Plugins: C:\Program Files (x86)\Mozilla Firefox\plugins [2012/04/12 15:24:44 | 000,000,000 | ---D | M]
    FF - HKEY_LOCAL_MACHINE\software\mozilla\Mozilla Thunderbird 11.0.1\extensions\\Components: C:\Program Files (x86)\Mozilla Thunderbird\components [2011/11/15 10:55:59 | 000,000,000 | ---D | M]
    FF - HKEY_LOCAL_MACHINE\software\mozilla\Mozilla Thunderbird 11.0.1\extensions\\Plugins: C:\Program Files (x86)\Mozilla Thunderbird\plugins [2012/04/12 15:24:44 | 000,000,000 | ---D | M]
    [2010/02/09 12:14:00 | 000,000,000 | ---D | M] (No name found) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Extensions
    [2010/02/09 12:14:00 | 000,000,000 | ---D | M] (No name found) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Extensions\{3550f703-e582-4d05-9a08-453d09bdfdc6}
    [2012/04/19 12:27:06 | 000,000,000 | ---D | M] (No name found) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Firefox\Profiles\k4bd1r1m.default\extensions
    [2011/12/09 11:00:01 | 000,000,000 | ---D | M] (Forecastfox) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Firefox\Profiles\k4bd1r1m.default\extensions\{0538E3E3-7E9B-4d49-8831-A227C80A7AD3}
    [2012/02/13 13:12:08 | 000,000,000 | ---D | M] (References.TV Community Toolbar) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Firefox\Profiles\k4bd1r1m.default\extensions\{4b897551-0a2b-4159-99e7-3cd721caec78}
    [2012/03/30 09:56:09 | 000,000,000 | ---D | M] (DownloadHelper) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Firefox\Profiles\k4bd1r1m.default\extensions\{b9db16a4-6edc-47ec-a1f4-b86292ed211d}
    [2011/05/01 22:01:30 | 000,000,000 | ---D | M] (Torbutton) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Firefox\Profiles\k4bd1r1m.default\extensions\{e0204bd5-9d31-402b-a99d-a6aa8ffebdca}
    [2011/04/12 11:25:08 | 000,000,000 | ---D | M] (Conduit Engine) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Firefox\Profiles\k4bd1r1m.default\extensions\engine@conduit.com
    [2010/02/06 23:32:02 | 000,000,000 | ---D | M] (TVU Web Player) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Firefox\Profiles\k4bd1r1m.default\extensions\firefox@tvunetworks.com
    [2012/01/03 11:17:38 | 000,000,000 | ---D | M] ( "Xmarks ") -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Firefox\Profiles\k4bd1r1m.default\extensions\foxmarks@kei.com
    [2011/03/22 20:34:34 | 000,000,000 | ---D | M] (IE Tab Plus) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Firefox\Profiles\k4bd1r1m.default\extensions\ietab@ip.cn
    [2011/03/19 14:40:55 | 000,000,000 | ---D | M] (Search Toolbar) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Firefox\Profiles\k4bd1r1m.default\extensions\searchtoolbar@zugo.com
    [2010/09/18 22:56:05 | 000,000,000 | ---D | M] (vShare Plugin) -- C:\Users\john.IBC1\AppData\Roaming\mozilla\Firefox\Profiles\k4bd1r1m.default\extensions\vshareus@toolbar
    [2012/04/19 11:01:02 | 000,002,325 | ---- | M] () -- C:\Users\john.IBC1\AppData\Roaming\Mozilla\Firefox\Profiles\k4bd1r1m.default\searchplugins\askcom.xml
    [2010/03/04 11:46:16 | 000,001,819 | ---- | M] () -- C:\Users\john.IBC1\AppData\Roaming\Mozilla\Firefox\Profiles\k4bd1r1m.default\searchplugins\bing.xml
    [2012/03/18 18:37:00 | 000,000,000 | ---D | M] (No name found) -- C:\Program Files (x86)\Mozilla Firefox\extensions
    [2011/10/17 09:38:49 | 000,000,000 | ---D | M] (Skype Click to Call) -- C:\Program Files (x86)\Mozilla Firefox\extensions\{82AF8DCA-6DE9-405D-BD5E-43525BDAD38A}
    () (No name found) -- C:\USERS\JOHN.IBC1\APPDATA\ROAMING\MOZILLA\FIREFOX\PROFILES\K4BD1R1M.DEFAULT\EXTENSIONS\{19503E42-CA3C-4C27-B1E2-9CDB2170EE34}.XPI
    () (No name found) -- C:\USERS\JOHN.IBC1\APPDATA\ROAMING\MOZILLA\FIREFOX\PROFILES\K4BD1R1M.DEFAULT\EXTENSIONS\{D10D0BF8-F5B5-C8B4-A8B2-2B9879E08C5D}.XPI
    () (No name found) -- C:\USERS\JOHN.IBC1\APPDATA\ROAMING\MOZILLA\FIREFOX\PROFILES\K4BD1R1M.DEFAULT\EXTENSIONS\TABSCOPE@XULDEV.ORG.XPI
    [2012/03/18 18:36:57 | 000,097,208 | ---- | M] (Mozilla Foundation) -- C:\Program Files (x86)\mozilla firefox\components\browsercomps.dll
    [2012/03/05 17:06:26 | 000,476,904 | ---- | M] (Sun Microsystems, Inc.) -- C:\Program Files (x86)\mozilla firefox\plugins\npdeployJava1.dll
    [2012/03/22 20:56:44 | 000,003,749 | ---- | M] () -- C:\Program Files (x86)\mozilla firefox\searchplugins\avg-secure-search.xml
    [2011/10/03 13:50:55 | 000,002,252 | ---- | M] () -- C:\Program Files (x86)\mozilla firefox\searchplugins\bing.xml
    [2011/11/10 10:33:46 | 000,002,040 | ---- | M] () -- C:\Program Files (x86)\mozilla firefox\searchplugins\twitter.xml
    O1 HOSTS File: ([2012/04/19 21:23:07 | 000,000,027 | ---- | M]) - C:\Windows\SysNative\drivers\etc\hosts
    O2 - BHO: (Octh Class) - {000123B4-9B42-4900-B3F7-F4B073EFC214} - C:\Program Files (x86)\Orbitdownloader\orbitcth.dll (Orbitdownloader.com)
    O2 - BHO: (no name) - {1BD0BEFE-F697-4eee-B7E1-76B849A5CB84} - No CLSID value found.
    O2 - BHO: (Java(tm) Plug-In SSV Helper) - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre6\bin\ssv.dll (Sun Microsystems, Inc.)
    O2 - BHO: (Skype Browser Helper) - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O2 - BHO: (Reg Error: Value error.) - {EAEE5C74-6D0D-4aca-9232-0DA4A7B866BA} - C:\Program Files (x86)\PicLensIE\cooliris.dll (Cooliris Inc.)
    O3 - HKLM\..\Toolbar: (Grab Pro) - {C55BBCD6-41AD-48AD-9953-3609C48EACC7} - C:\Program Files (x86)\Orbitdownloader\GrabPro.dll ()
    O3 - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\..\Toolbar\WebBrowser: (no name) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - No CLSID value found.
    O3 - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\..\Toolbar\WebBrowser: (Grab Pro) - {C55BBCD6-41AD-48AD-9953-3609C48EACC7} - C:\Program Files (x86)\Orbitdownloader\GrabPro.dll ()
    O4:64bit: - HKLM..\Run: [HotKeysCmds] C:\Windows\SysNative\hkcmd.exe (Intel Corporation)
    O4:64bit: - HKLM..\Run: [IAAnotif] C:\Program Files (x86)\Intel\Intel Matrix Storage Manager\IAAnotif.exe (Intel Corporation)
    O4:64bit: - HKLM..\Run: [IgfxTray] C:\Windows\SysNative\igfxtray.exe (Intel Corporation)
    O4:64bit: - HKLM..\Run: [IntelliPoint] C:\Program Files\Microsoft IntelliPoint\ipoint.exe (Microsoft Corporation)
    O4:64bit: - HKLM..\Run: [itype] C:\Program Files\Microsoft IntelliType Pro\itype.exe (Microsoft Corporation)
    O4:64bit: - HKLM..\Run: [Persistence] C:\Windows\SysNative\igfxpers.exe (Intel Corporation)
    O4:64bit: - HKLM..\Run: [PLFSetI] C:\Windows\PLFSetI.exe ()
    O4 - HKLM..\Run: [APSDaemon] C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe (Apple Inc.)
    O4 - HKLM..\Run: [LManager] C:\Program Files (x86)\Launch Manager\LManager.exe (Dritek System Inc.)
    O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorAdmin = 5
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: ConsentPromptBehaviorUser = 3
    O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\System: EnableLinkedConnections = 1
    O7 - HKU\.DEFAULT\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-18\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-19\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-20\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\Software\Policies\Microsoft\Internet Explorer\Control Panel present
    O7 - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoDrives = 0
    O8:64bit: - Extra context menu item: &Download by Orbit - C:\Program Files (x86)\Orbitdownloader\orbitmxt.dll (Orbitdownloader.com)
    O8:64bit: - Extra context menu item: &Grab video by Orbit - C:\Program Files (x86)\Orbitdownloader\orbitmxt.dll (Orbitdownloader.com)
    O8:64bit: - Extra context menu item: Do&wnload selected by Orbit - C:\Program Files (x86)\Orbitdownloader\orbitmxt.dll (Orbitdownloader.com)
    O8:64bit: - Extra context menu item: Down&load all by Orbit - C:\Program Files (x86)\Orbitdownloader\orbitmxt.dll (Orbitdownloader.com)
    O8 - Extra context menu item: &Download by Orbit - C:\Program Files (x86)\Orbitdownloader\orbitmxt.dll (Orbitdownloader.com)
    O8 - Extra context menu item: &Grab video by Orbit - C:\Program Files (x86)\Orbitdownloader\orbitmxt.dll (Orbitdownloader.com)
    O8 - Extra context menu item: Do&wnload selected by Orbit - C:\Program Files (x86)\Orbitdownloader\orbitmxt.dll (Orbitdownloader.com)
    O8 - Extra context menu item: Down&load all by Orbit - C:\Program Files (x86)\Orbitdownloader\orbitmxt.dll (Orbitdownloader.com)
    O9 - Extra Button: Launch Cooliris - {3437D640-C91A-458f-89F5-B9095EA4C28B} - C:\Program Files (x86)\PicLensIE\cooliris.dll (Cooliris Inc.)
    O9 - Extra Button: Skype Click to Call - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O9 - Extra 'Tools' menuitem : Skype Click to Call - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O10:64bit: - NameSpace_Catalog5\Catalog_Entries64\000000000009 [] - C:\Program Files\Bonjour\mdnsNSP.dll (Apple Inc.)
    O10 - NameSpace_Catalog5\Catalog_Entries\000000000009 [] - C:\Program Files (x86)\Bonjour\mdnsNSP.dll (Apple Inc.)
    O15 - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\..Trusted Domains: localhost ([]http in Local intranet)
    O15 - HKU\S-1-5-21-3852137769-1796420447-4257946896-1148\..Trusted Ranges: GD ([http] in Local intranet)
    O16 - DPF: {2EDF75C0-5ABD-49f9-BAB6-220476A32034} http://intel-drv-cdn.systemrequirementslab.com/multi/bin/sysreqlab_srlx.cab (System Requirements Lab Class)
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} http://java.sun.com/update/1.6.0/jinstall-1_6_0_31-windows-i586.cab (Java Plug-in 1.6.0_31)
    O16 - DPF: {971FC730-55F1-461F-83FD-B3BF5E1F039E} http://ibcoffice.dnsalias.net:81/AVC_AX_742.cab (AMCCtrl Class)
    O16 - DPF: {9B479D7B-916A-45B0-B042-D42865A60E21} http://bygollys.dnsalias.net/DvrOcx.cab (DvrOcx Control)
    O16 - DPF: {CAFEEFAC-0016-0000-0031-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_31-windows-i586.cab (Java Plug-in 1.6.0_31)
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} http://java.sun.com/update/1.6.0/jinstall-1_6_0_31-windows-i586.cab (Java Plug-in 1.6.0_31)
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab (Shockwave Flash Object)
    O16 - DPF: {D4003189-95B1-4A2F-9A87-F2B03665960D} http://www.vexcast.com/download/vexcast.cab (VodClient Control Class)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.15.1
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: Domain = ibc1.ibcbiometrics.com
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{265498E7-17C5-4F32-BAF0-8F51578684E7}: DhcpNameServer = 209.18.47.61 209.18.47.62
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{396ABDBE-4640-4B82-B353-20177B32E9B6}: DhcpNameServer = 192.168.15.1
    O18:64bit: - Protocol\Handler\intu-help-qb5 - No CLSID value found
    O18:64bit: - Protocol\Handler\livecall - No CLSID value found
    O18:64bit: - Protocol\Handler\msnim - No CLSID value found
    O18:64bit: - Protocol\Handler\qbwc - No CLSID value found
    O18:64bit: - Protocol\Handler\skype-ie-addon-data - No CLSID value found
    O18:64bit: - Protocol\Handler\wlmailhtml - No CLSID value found
    O18:64bit: - Protocol\Handler\wlpg - No CLSID value found
    O18 - Protocol\Handler\gopher - No CLSID value found
    O18 - Protocol\Handler\intu-help-qb5 {867FCB77-9823-4cd6-8210-D85F968D466F} - C:\Program Files (x86)\Intuit\QuickBooks Enterprise Solutions 10.0\HelpAsyncPluggableProtocol.dll (Intuit, Inc.)
    O18 - Protocol\Handler\ms-help - No CLSID value found
    O18 - Protocol\Handler\skype-ie-addon-data {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\skypeieplugin.dll (Skype Technologies S.A.)
    O20 - AppInit_DLLs: (C:\PROGRA~2\Google\GOOGLE~1\GoogleDesktopNetwork3.dll) - C:\Program Files (x86)\Google\Google Desktop Search\GoogleDesktopNetwork3.dll (Google)
    O20:64bit: - HKLM Winlogon: Shell - (Explorer.exe) - C:\Windows\explorer.exe (Microsoft Corporation)
    O20:64bit: - HKLM Winlogon: UserInit - (C:\Windows\system32\userinit.exe) - C:\Windows\SysNative\userinit.exe (Microsoft Corporation)
    O20:64bit: - HKLM Winlogon: VMApplet - (SystemPropertiesPerformance.exe) - C:\Windows\SysNative\SystemPropertiesPerformance.exe (Microsoft Corporation)
    O20:64bit: - HKLM Winlogon: VMApplet - (/pagefile) - File not found
    O20 - HKLM Winlogon: Shell - (Explorer.exe) - C:\Windows\SysWow64\explorer.exe (Microsoft Corporation)
    O20 - HKLM Winlogon: UserInit - (C:\Windows\system32\userinit.exe) - C:\Windows\SysWOW64\userinit.exe (Microsoft Corporation)
    O20 - HKLM Winlogon: VMApplet - (/pagefile) - File not found
    O20:64bit: - Winlogon\Notify\igfxcui: DllName - (igfxdev.dll) - C:\Windows\SysNative\igfxdev.dll (Intel Corporation)
    O32 - HKLM CDRom: AutoRun - 1
    O32 - AutoRun File - [2010/05/07 19:56:20 | 000,000,000 | RHSD | M] - J:\AUTORUN -- [ FAT32 ]
    O34 - HKLM BootExecute: (autocheck autochk *)
    O35:64bit: - HKLM\..comfile [open] -- "%1" %*
    O35:64bit: - HKLM\..exefile [open] -- "%1" %*
    O37:64bit: - HKLM\...com [@ = ComFile] -- "%1" %*
    O37:64bit: - HKLM\...exe [@ = exefile] -- "%1" %*
    O37 - HKLM\...com [@ = ComFile] -- "%1" %*
    NetSvcs:64bit: AppMgmt - C:\Windows\SysNative\appmgmts.dll (Microsoft Corporation)
    Drivers32:64bit: msacm.aacacm - AACACM.acm (fccHandler)
    Drivers32:64bit: msacm.ac3acm - ac3acm.acm (fccHandler)
    Drivers32:64bit: msacm.ac3filter - ac3filter.acm ()
    Drivers32:64bit: msacm.avis - ff_acm.acm ()
    Drivers32:64bit: msacm.l3acm - C:\Windows\System32\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32:64bit: msacm.l3pacm - l3codecp.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32:64bit: VIDC.FFDS - ff_vfw.dll ()
    Drivers32:64bit: VIDC.LAGS - lagarith.dll ( )
    Drivers32:64bit: vidc.x264 - x264vfw.dll ()
    Drivers32: msacm.aacacm - C:\Windows\SysWow64\AACACM.acm (fccHandler)
    Drivers32: msacm.ac3acm - C:\Windows\SysWow64\ac3acm.acm (fccHandler)
    Drivers32: msacm.ac3filter - C:\Windows\SysWow64\ac3filter.acm ()
    Drivers32: msacm.avis - C:\Windows\SysWow64\ff_acm.acm ()
    Drivers32: msacm.l3acm - C:\Windows\SysWOW64\l3codeca.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.l3pacm - C:\Windows\SysWow64\l3codecp.acm (Fraunhofer Institut Integrierte Schaltungen IIS)
    Drivers32: msacm.lameacm - C:\Windows\SysWow64\lameACM.acm (http://www.mp3dev.org/)
    Drivers32: vidc.cvid - C:\Windows\SysWow64\iccvid.dll (Radius Inc.)
    Drivers32: VIDC.FFDS - ff_vfw.dll File not found
    Drivers32: VIDC.LAGS - C:\Windows\SysWow64\lagarith.dll ( )
    Drivers32: vidc.tscc - C:\Windows\SysWow64\tsccvid.dll (TechSmith Corporation)
    Drivers32: VIDC.X264 - C:\Windows\SysWow64\x264vfw.dll ()
    CREATERESTOREPOINT
    Restore point Set: OTL Restore Point
    ========== Files/Folders - Created Within 30 Days ==========
    [2012/04/19 21:30:05 | 000,000,000 | ---D | C] -- C:\Windows\temp
    [2012/04/19 21:30:05 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\AppData\Local\temp
    [2012/04/19 21:23:13 | 000,000,000 | ---D | C] -- C:\$RECYCLE.BIN
    [2012/04/19 20:44:02 | 000,518,144 | ---- | C] (SteelWerX) -- C:\Windows\SWREG.exe
    [2012/04/19 20:44:02 | 000,406,528 | ---- | C] (SteelWerX) -- C:\Windows\SWSC.exe
    [2012/04/19 20:44:02 | 000,060,416 | ---- | C] (NirSoft) -- C:\Windows\NIRCMD.exe
    [2012/04/19 20:43:53 | 000,000,000 | ---D | C] -- C:\Windows\ERDNT
    [2012/04/19 20:43:52 | 000,000,000 | ---D | C] -- C:\ComboFix
    [2012/04/19 20:43:42 | 000,000,000 | ---D | C] -- C:\Qoobox
    [2012/04/19 11:03:36 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\AppData\Roaming\Shark007
    [2012/04/19 11:03:36 | 000,000,000 | ---D | C] -- C:\ProgramData\Shark007
    [2012/04/19 11:03:31 | 001,575,936 | ---- | C] (MPC-HC Team) -- C:\Windows\SysNative\VSFilter.dll
    [2012/04/19 11:03:31 | 000,360,960 | ---- | C] (fccHandler) -- C:\Windows\SysNative\aacacm.acm
    [2012/04/19 11:03:31 | 000,180,224 | ---- | C] (fccHandler) -- C:\Windows\SysNative\ac3acm.acm
    [2012/04/19 11:03:31 | 000,124,909 | ---- | C] (Open Source Software community project) -- C:\Windows\SysNative\pthreadGC2.dll
    [2012/04/19 11:03:31 | 000,000,000 | ---D | C] -- C:\Program Files\Shark007
    [2012/04/19 10:59:31 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Shark007 Codecs
    [2012/04/19 10:59:24 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\AppData\Roaming\Win7codecs
    [2012/04/19 10:59:12 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Win7codecs
    [2012/04/19 02:53:23 | 000,000,000 | ---D | C] -- C:\ProgramData\Win7codecs
    [2012/04/12 19:08:08 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\AppData\Local\ElevatedDiagnostics
    [2012/04/09 12:32:32 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Freemake
    [2012/04/09 12:32:32 | 000,000,000 | ---D | C] -- C:\ProgramData\Freemake
    [2012/04/06 15:56:58 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\AppData\Local\{1986FC31-91F6-4D2F-9832-10EF87B4AD42}
    [2012/04/06 15:55:33 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\Desktop\Lutefisk
    [2012/04/06 15:55:06 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\Desktop\Convert US Mortise to 1Touch Install Vids
    [2012/04/03 09:40:01 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
    [2012/04/03 09:39:19 | 000,000,000 | ---D | C] -- C:\Program Files\iPod
    [2012/04/03 09:39:18 | 000,000,000 | ---D | C] -- C:\Program Files\iTunes
    [2012/04/03 09:39:18 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\iTunes
    [2012/03/30 13:44:23 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\Desktop\converted
    [2012/03/30 13:42:13 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\AppData\Roaming\FastStone
    [2012/03/30 13:40:49 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\FastStone Image Viewer
    [2012/03/30 13:40:49 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\FastStone Image Viewer
    [2012/03/21 09:44:38 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\AppData\Roaming\SUPERAntiSpyware.com
    [2012/03/21 09:44:02 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SUPERAntiSpyware
    [2012/03/21 04:21:49 | 000,000,000 | ---D | C] -- C:\Users\john.IBC1\AppData\Roaming\Malwarebytes
    [2012/03/21 04:21:33 | 000,000,000 | ---D | C] -- C:\ProgramData\Malwarebytes
    [2012/03/21 04:21:32 | 000,024,904 | ---- | C] (Malwarebytes Corporation) -- C:\Windows\SysNative\drivers\mbam.sys
    [2012/03/21 04:21:32 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Malwarebytes' Anti-Malware
    ========== Files - Modified Within 30 Days ==========
    [2012/04/19 23:06:01 | 000,013,472 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-5P-1.C7483456-A289-439d-8115-601632D005A0
    [2012/04/19 23:06:01 | 000,013,472 | -H-- | M] () -- C:\Windows\SysNative\7B296FB0-376B-497e-B012-9C450E1B7327-5P-0.C7483456-A289-439d-8115-601632D005A0
    [2012/04/19 22:58:22 | 000,067,584 | --S- | M] () -- C:\Windows\bootstat.dat
    [2012/04/19 22:27:00 | 000,000,830 | ---- | M] () -- C:\Windows\tasks\Adobe Flash Player Updater.job
    [2012/04/19 21:23:07 | 000,000,027 | ---- | M] () -- C:\Windows\SysNative\drivers\etc\hosts
    [2012/04/19 20:39:24 | 000,000,936 | ---- | M] () -- C:\Users\john.IBC1\Desktop\ComboFix - Shortcut.lnk
    [2012/04/18 19:26:30 | 025,438,859 | ---- | M] () -- C:\Users\john.IBC1\Desktop\Battery pack issue on 2012 XL_1.mp4
    [2012/04/17 22:14:58 | 639,913,196 | ---- | M] () -- C:\Windows\MEMORY.DMP
    [2012/04/17 20:07:36 | 000,001,113 | ---- | M] () -- C:\Users\Public\Desktop\Malwarebytes Anti-Malware.lnk
    [2012/04/17 02:34:04 | 003,602,521 | ---- | M] () -- C:\regdll.bat
    [2012/04/13 10:36:20 | 001,639,628 | ---- | M] () -- C:\Windows\SysNative\perfh009.dat
    [2012/04/13 10:36:20 | 000,463,026 | ---- | M] () -- C:\Windows\SysNative\perfc009.dat
    [2012/04/13 10:36:20 | 000,006,386 | ---- | M] () -- C:\Windows\SysNative\PerfStringBackup.INI
    [2012/04/13 10:34:57 | 000,001,065 | ---- | M] () -- C:\Users\john.IBC1\Application Data\Microsoft\Internet Explorer\Quick Launch\Microsoft Outlook.lnk
    [2012/04/09 22:35:03 | 000,006,554 | ---- | M] () -- C:\Users\john.IBC1\0
    [2012/04/09 12:32:32 | 000,001,324 | ---- | M] () -- C:\Users\Public\Desktop\Freemake Video Converter.lnk
    [2012/04/06 17:07:09 | 000,000,111 | ---- | M] () -- C:\Windows\QBChanUtil_Trigger.ini
    [2012/04/04 15:56:40 | 000,024,904 | ---- | M] (Malwarebytes Corporation) -- C:\Windows\SysNative\drivers\mbam.sys
    [2012/04/04 10:57:48 | 000,018,944 | ---- | M] () -- C:\Users\john.IBC1\AppData\Local\DCBC2A71-70D8-4DAN-EHR8-E0D61DEA3FDF.ini
    [2012/04/03 09:40:01 | 000,001,783 | ---- | M] () -- C:\Users\Public\Desktop\iTunes.lnk
    [2012/03/30 13:40:50 | 000,001,109 | ---- | M] () -- C:\Users\Public\Desktop\FastStone Image Viewer.lnk
    [2012/03/30 00:05:24 | 001,715,029 | ---- | M] () -- C:\Users\john.IBC1\Desktop\fingerprint-door-lock-trinity-788.pdf
    [2012/03/22 19:04:36 | 000,092,160 | ---- | M] () -- C:\Windows\SysNative\ff_vfw.dll
    [2012/03/22 19:03:40 | 000,053,760 | ---- | M] () -- C:\Windows\SysNative\ff_acm.acm
    [2012/03/22 19:00:40 | 000,048,128 | ---- | M] () -- C:\Windows\SysWow64\ff_acm.acm
    [2012/04/19 20:44:02 | 000,256,000 | ---- | C] () -- C:\Windows\PEV.exe
    [2012/04/19 20:44:02 | 000,208,896 | ---- | C] () -- C:\Windows\MBR.exe
    [2012/04/19 20:44:02 | 000,098,816 | ---- | C] () -- C:\Windows\sed.exe
    [2012/04/19 20:44:02 | 000,080,412 | ---- | C] () -- C:\Windows\grep.exe
    [2012/04/19 20:44:02 | 000,068,096 | ---- | C] () -- C:\Windows\zip.exe
    [2012/04/19 20:39:24 | 000,000,936 | ---- | C] () -- C:\Users\john.IBC1\Desktop\ComboFix - Shortcut.lnk
    [2012/04/19 11:03:31 | 004,587,008 | ---- | C] () -- C:\Windows\SysNative\x264vfw.dll
    [2012/04/19 11:03:31 | 000,580,096 | ---- | C] () -- C:\Windows\SysNative\ac3filter64.acm
    [2012/04/19 11:03:31 | 000,580,096 | ---- | C] () -- C:\Windows\SysNative\ac3filter.acm
    [2012/04/19 11:03:31 | 000,205,824 | ---- | C] () -- C:\Windows\SysNative\unrar.dll
    [2012/04/19 11:03:31 | 000,148,992 | ---- | C] ( ) -- C:\Windows\SysNative\lagarith.dll
    [2012/04/19 11:03:31 | 000,092,160 | ---- | C] () -- C:\Windows\SysNative\ff_vfw.dll
    [2012/04/19 11:03:31 | 000,053,760 | ---- | C] () -- C:\Windows\SysNative\ff_acm.acm
    [2012/04/18 19:22:21 | 025,438,859 | ---- | C] () -- C:\Users\john.IBC1\Desktop\Battery pack issue on 2012 XL_1.mp4
    [2012/04/17 20:07:36 | 000,001,113 | ---- | C] () -- C:\Users\Public\Desktop\Malwarebytes Anti-Malware.lnk
    [2012/04/17 02:21:56 | 003,602,521 | ---- | C] () -- C:\regdll.bat
    [2012/04/09 22:35:00 | 000,006,554 | ---- | C] () -- C:\Users\john.IBC1\0
    [2012/04/03 09:40:01 | 000,001,783 | ---- | C] () -- C:\Users\Public\Desktop\iTunes.lnk
    [2012/03/30 13:40:50 | 000,001,109 | ---- | C] () -- C:\Users\Public\Desktop\FastStone Image Viewer.lnk
    [2012/03/30 00:05:24 | 001,715,029 | ---- | C] () -- C:\Users\john.IBC1\Desktop\fingerprint-door-lock-trinity-788.pdf
    [2012/03/29 23:40:58 | 000,000,830 | ---- | C] () -- C:\Windows\tasks\Adobe Flash Player Updater.job
    [2012/03/22 19:00:40 | 000,048,128 | ---- | C] () -- C:\Windows\SysWow64\ff_acm.acm
    [2012/03/15 07:40:28 | 004,826,112 | ---- | C] () -- C:\Windows\SysWow64\x264vfw.dll
    [2012/03/14 14:07:31 | 000,040,960 | ---- | C] () -- C:\Windows\SysWow64\VPN.dll
    [2012/01/09 20:45:18 | 000,178,688 | ---- | C] () -- C:\Windows\SysWow64\unrar.dll
    [2011/12/07 20:32:24 | 000,216,064 | ---- | C] ( ) -- C:\Windows\SysWow64\lagarith.dll
    [2011/10/17 11:57:53 | 000,161,985 | ---- | C] () -- C:\Users\john.IBC1\AppData\Local\census.cache
    [2011/10/17 11:57:47 | 000,132,169 | ---- | C] () -- C:\Users\john.IBC1\AppData\Local\ars.cache
    [2011/10/17 11:50:42 | 000,000,036 | ---- | C] () -- C:\Users\john.IBC1\AppData\Local\housecall.guid.cache
    [2011/08/19 22:26:28 | 000,667,280 | ---- | C] () -- C:\Windows\SysWow64\tx12.dll
    [2011/08/19 22:26:28 | 000,000,530 | ---- | C] () -- C:\Windows\SysWow64\tx12_ic.ini
    [2011/08/19 22:26:28 | 000,000,186 | ---- | C] () -- C:\Windows\SysWow64\Gsw32.exe.config
    [2011/08/17 11:33:28 | 000,007,648 | ---- | C] () -- C:\Users\john.IBC1\AppData\Local\resmon.resmoncfg
    [2011/05/20 01:26:53 | 000,000,241 | ---- | C] () -- C:\Windows\Brpfx04a.ini
    [2011/05/20 01:26:53 | 000,000,093 | ---- | C] () -- C:\Windows\brpcfx.ini
    [2011/05/20 01:26:11 | 000,000,426 | ---- | C] () -- C:\Windows\BRWMARK.INI
    [2011/05/20 01:26:11 | 000,000,034 | ---- | C] () -- C:\Windows\SysWow64\BD7340.DAT
    [2011/05/20 01:21:36 | 000,106,496 | ---- | C] () -- C:\Windows\SysWow64\BrMuSNMP.dll
    [2011/05/20 01:21:35 | 000,000,066 | ---- | C] () -- C:\Windows\Brfaxrx.ini
    [2011/05/20 01:21:35 | 000,000,000 | ---- | C] () -- C:\Windows\brdfxspd.dat
    [2011/05/20 01:21:14 | 000,045,056 | ---- | C] () -- C:\Windows\SysWow64\BRTCPCON.DLL
    [2011/05/20 01:21:05 | 000,000,114 | ---- | C] () -- C:\Windows\SysWow64\BRLMW03A.INI
    [2011/05/20 01:18:25 | 000,031,767 | ---- | C] () -- C:\Windows\maxlink.ini
    [2011/03/24 14:42:09 | 000,038,433 | ---- | C] () -- C:\Users\john.IBC1\AppData\Roaming\Microsoft Excel 97-2003.ADR
    [2010/10/02 20:48:15 | 000,000,133 | ---- | C] () -- C:\ProgramData\Microsoft.SqlServer.Compact.351.32.bc
    [2010/08/03 21:15:37 | 000,000,008 | RHS- | C] () -- C:\ProgramData\067B910D7E.sys
    [2010/08/03 21:15:36 | 000,005,642 | -HS- | C] () -- C:\ProgramData\KGyGaAvL.sys
    [2010/01/30 18:08:49 | 000,000,000 | ---D | M] -- C:\Users\John\AppData\Roaming\Thunderbird
    [2010/02/02 13:38:26 | 000,000,000 | ---D | M] -- C:\Users\John\AppData\Roaming\uTorrent
    [2011/09/07 22:11:27 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\Acronis
    [2010/02/05 13:50:53 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1
    [2011/03/19 17:11:55 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\Cyberduck
    [2010/04/29 18:21:17 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\DiskAid
    [2011/07/18 17:39:49 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\FileZilla
    [2010/10/08 03:54:29 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\FrostWire
    [2010/09/17 23:47:29 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\GrabPro
    [2011/03/25 03:46:47 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\HandBrake
    [2010/04/06 16:50:34 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\ImgBurn
    [2011/10/10 21:22:59 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\IObit
    [2011/06/14 12:03:44 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\JAM Software
    [2011/11/07 15:31:16 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\Kayako
    [2010/03/08 19:50:40 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\MusicBrainz
    [2012/04/09 19:37:18 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\Orbit
    [2012/03/30 13:38:55 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\PhotoScape
    [2010/09/17 23:45:18 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\ProgSense
    [2010/11/04 04:30:50 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\Samsung
    [2012/04/19 12:05:08 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\Shark007
    [2010/04/29 22:22:49 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\StreamTorrent
    [2010/07/15 18:38:28 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\SystemRequirementsLab
    [2011/11/17 13:06:36 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\TeamViewer
    [2010/02/09 12:13:59 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\Thunderbird
    [2010/04/20 12:14:21 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\Trillian
    [2011/07/15 13:17:20 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\Ulead Systems
    [2012/03/27 10:06:30 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\uTorrent
    [2012/04/19 12:06:37 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\Win7codecs
    [2010/10/21 14:36:09 | 000,000,000 | ---D | M] -- C:\Users\john.IBC1\AppData\Roaming\Windows Live Writer
    [2011/03/19 17:12:04 | 000,000,000 | -HSD | M] -- C:\Users\john.IBC1\AppData\Roaming\wyUpdate AU
    [2012/04/17 22:30:18 | 000,032,580 | ---- | M] () -- C:\Windows\Tasks\SCHEDLGU.TXT
  18. 2012/04/19
    nykrumrie
    nykrumrie Inactive Thread Starter
    duplicate
  19. 2012/04/19
    nykrumrie
    duplicate
  20. 2012/04/19
    nykrumrie
    I have no idea why that last post got sent twice I only did it once. I also seem to be in a new thread. Here is part 2 of the OTL.txt
    ========== Custom Scans ==========
    < %SYSTEMDRIVE%\*.* >
    [2010/10/02 16:04:13 | 000,002,006 | ---- | M] () -- C:\aqua_bitmap.cpp
    [2012/04/19 21:29:56 | 000,021,977 | ---- | M] () -- C:\ComboFix.txt
    [2011/09/02 17:14:45 | 000,000,022 | ---- | M] () -- C:\DebugTraceAP.log
    [2012/04/19 22:58:15 | 4220,440,576 | -HS- | M] () -- C:\pagefile.sys
    [2010/03/01 13:01:35 | 000,001,024 | ---- | M] () -- C:\PaypalHeader.htm
    [2012/04/19 12:16:39 | 000,002,138 | ---- | M] () -- C:\TDSSKiller.2.7.29.0_19.04.2012_12.16.36_log.txt
    [2012/04/19 13:05:57 | 000,002,138 | ---- | M] () -- C:\TDSSKiller.2.7.29.0_19.04.2012_13.05.54_log.txt
    [2012/04/19 13:52:26 | 000,266,506 | ---- | M] () -- C:\TDSSKiller.2.7.29.0_19.04.2012_13.34.37_log.txt
    < %systemroot%\Fonts\*.com >
    [2009/07/14 01:32:31 | 000,026,040 | ---- | M] () -- C:\Windows\Fonts\GlobalMonospace.CompositeFont
    [2009/07/14 01:32:31 | 000,026,489 | ---- | M] () -- C:\Windows\Fonts\GlobalSansSerif.CompositeFont
    [2009/07/14 01:32:31 | 000,029,779 | ---- | M] () -- C:\Windows\Fonts\GlobalSerif.CompositeFont
    [2009/07/14 01:32:31 | 000,043,318 | ---- | M] () -- C:\Windows\Fonts\GlobalUserInterface.CompositeFont
    < %systemroot%\Fonts\*.dll >
    < %systemroot%\Fonts\*.ini >
    [2009/06/10 16:49:50 | 000,000,065 | ---- | M] () -- C:\Windows\Fonts\desktop.ini
    < %systemroot%\Fonts\*.ini2 >
    < %systemroot%\Fonts\*.exe >
    < %systemroot%\system32\spool\prtprocs\w32x86\*.* >
    < %systemroot%\REPAIR\*.bak1 >
    < %systemroot%\REPAIR\*.ini >
    < %systemroot%\system32\*.jpg >
    < %systemroot%\*.jpg >
    < %systemroot%\*.png >
    < %systemroot%\*.scr >
    [2011/05/13 15:42:24 | 000,302,448 | ---- | M] (Microsoft Corporation) -- C:\Windows\WLXPGSS.SCR
    < %systemroot%\*._sy >
    < %APPDATA%\Adobe\Update\*.* >
    < %ALLUSERSPROFILE%\Favorites\*.* >
    < %APPDATA%\Microsoft\*.* >
    < %PROGRAMFILES%\*.* >
    [2009/07/14 00:54:24 | 000,000,174 | -HS- | M] () -- C:\Program Files (x86)\desktop.ini
    < %APPDATA%\Update\*.* >
    < %systemroot%\*. /mp /s >
    < %systemroot%\System32\config\*.sav >
    < %PROGRAMFILES%\bak. /s >
    < %systemroot%\system32\bak. /s >
    < %ALLUSERSPROFILE%\Start Menu\*.lnk /x >
    < %systemroot%\system32\config\systemprofile\*.dat /x >
    < %systemroot%\*.config >
    < %systemroot%\system32\*.db >
    < %APPDATA%\Microsoft\Internet Explorer\Quick Launch\*.lnk /x >
    [2011/04/12 10:48:28 | 000,000,221 | -HS- | M] () -- C:\Users\john.IBC1\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\desktop.ini
    < %USERPROFILE%\Desktop\*.exe >
    [2010/08/08 13:57:22 | 000,723,712 | ---- | M] (Reincubate) -- C:\Users\john.IBC1\Desktop\iPhoneBackupExtractor.exe
    [2009/05/19 14:33:26 | 000,315,392 | ---- | M] (Polymath) -- C:\Users\john.IBC1\Desktop\ThumblockReset.exe
    < %PROGRAMFILES%\Common Files\*.* >
    < %systemroot%\*.src >
    < %systemroot%\install\*.* >
    < %systemroot%\system32\DLL\*.* >
    < %systemroot%\system32\HelpFiles\*.* >
    < %systemroot%\tasks\*.* >
    [2012/04/19 22:58:31 | 000,000,006 | -H-- | M] () -- C:\Windows\tasks\SA.DAT
    [2012/04/17 22:30:18 | 000,032,580 | ---- | M] () -- C:\Windows\tasks\SCHEDLGU.TXT
    < %systemroot%\system32\rundll\*.* >
    < %systemroot%\winn32\*.* >
    < %systemroot%\Java\*.* >
    < %systemroot%\system32\test\*.* >
    < %systemroot%\system32\Rundll32\*.* >
    < %systemroot%\AppPatch\Custom\*.* >
    < %APPDATA%\Roaming\Microsoft\Windows\Recent\*.lnk /x >
    < %PROGRAMFILES%\PC-Doctor\Downloads\*.* >
    < %PROGRAMFILES%\Internet Explorer\*.tmp >
    < %PROGRAMFILES%\Internet Explorer\*.dat >
    < %USERPROFILE%\My Documents\*.exe >
    < %USERPROFILE%\*.exe >
    < %systemroot%\ADDINS\*.* >
    [2009/06/10 17:20:04 | 000,000,802 | ---- | M] () -- C:\Windows\ADDINS\FXSEXT.ecf
    < %systemroot%\assembly\*.bak2 >
    < %systemroot%\Config\*.* >
    < %systemroot%\REPAIR\*.bak2 >
    < %systemroot%\SECURITY\Database\*.sdb /x >
    [2012/04/11 04:02:43 | 000,008,192 | ---- | M] () -- C:\Windows\SECURITY\Database\edb.chk
    [2012/04/11 04:02:43 | 001,048,576 | ---- | M] () -- C:\Windows\SECURITY\Database\edb.log
    [2012/04/10 11:31:30 | 001,048,576 | ---- | M] () -- C:\Windows\SECURITY\Database\edbres00001.jrs
    [2012/04/10 11:31:30 | 001,048,576 | ---- | M] () -- C:\Windows\SECURITY\Database\edbres00002.jrs
    < %systemroot%\SYSTEM\*.bak2 >
    < %systemroot%\Web\*.bak2 >
    < %systemroot%\Driver Cache\*.* >
    < %PROGRAMFILES%\Mozilla Firefox\0*.exe >
    < %ProgramFiles%\Microsoft Common\*.* >
    < %ProgramFiles%\TinyProxy. >
    < %USERPROFILE%\Favorites\*.url /x >
    [2012/02/15 11:13:45 | 000,000,402 | -HS- | M] () -- C:\Users\john.IBC1\Favorites\desktop.ini
    < %systemroot%\system32\*.bk >
    < %systemroot%\*.te >
    < %systemroot%\system32\system32\*.* >
    < %ALLUSERSPROFILE%\*.dat /x >
    [2010/08/03 21:15:37 | 000,000,008 | RHS- | M] () -- C:\ProgramData\067B910D7E.sys
    [2011/07/06 14:54:39 | 000,005,642 | -HS- | M] () -- C:\ProgramData\KGyGaAvL.sys
    [2010/10/02 20:48:15 | 000,000,133 | ---- | M] () -- C:\ProgramData\Microsoft.SqlServer.Compact.351.32.bc
    [2010/02/02 13:45:01 | 000,002,412 | RHS- | M] () -- C:\ProgramData\ntuser.pol
    < %systemroot%\system32\drivers\*.rmv >
    < dir /b "%systemroot%\system32\*.exe" | find /i " " /c >
    < dir /b "%systemroot%\*.exe" | find /i " " /c >
    < %PROGRAMFILES%\Microsoft\*.* >
    < %systemroot%\System32\Wbem\proquota.exe >
    < %PROGRAMFILES%\Mozilla Firefox\*.dat >
    < %USERPROFILE%\Cookies\*.txt /x >
    < %SystemRoot%\system32\fonts\*.* >
    < %systemroot%\system32\winlog\*.* >
    < %systemroot%\system32\Language\*.* >
    < %systemroot%\system32\Settings\*.* >
    < %systemroot%\system32\*.quo >
    < %SYSTEMROOT%\AppPatch\*.exe >
    < %SYSTEMROOT%\inf\*.exe >
    < %SYSTEMROOT%\Installer\*.exe >
    < %systemroot%\system32\config\*.bak2 >
    < %systemroot%\system32\Computers\*.* >
    < %SystemRoot%\system32\Sound\*.* >
    < %SystemRoot%\system32\SpecialImg\*.* >
    < %SystemRoot%\system32\code\*.* >
    < %SystemRoot%\system32\draft\*.* >
    < %SystemRoot%\system32\MSSSys\*.* >
    < %ProgramFiles%\Javascript\*.* >
    < %systemroot%\pchealth\helpctr\System\*.exe /s >
    < %systemroot%\Web\*.exe >
    < %systemroot%\system32\msn\*.* >
    < %systemroot%\system32\*.tro >
    < %AppData%\Microsoft\Installer\msupdates\*.* >
    < %ProgramFiles%\Messenger\*.* >
    < %systemroot%\system32\systhem32\*.* >
    < %systemroot%\system\*.exe >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU >
    < HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\ Auto Update\Results\Install|LastSuccessTime /rs >
    ========== Files - Unicode (All) ==========
    [2012/02/24 14:52:51 | 000,000,000 | ---D | M](C:\Users\john.IBC1\Favorites\TV?) -- C:\Users\john.IBC1\Favorites\TV​
    < End of report >
  21. 2012/04/19
    nykrumrie
    EXTRA.txt
    OTL Extras logfile created on: 4/19/2012 11:08:34 PM - Run 1
    ========== Extra Registry (SafeList) ==========
    ========== File Associations ==========
    64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<extension>]
    .url[@ = InternetShortcut] -- C:\Windows\SysNative\rundll32.exe (Microsoft Corporation)
    .cpl [@ = cplfile] -- C:\Windows\SysWow64\control.exe (Microsoft Corporation)
    [HKEY_USERS\S-1-5-21-3852137769-1796420447-4257946896-1148\SOFTWARE\Classes\<extension>]
    .html [@ = FirefoxHTML] -- C:\Program Files (x86)\Mozilla Firefox\firefox.exe (Mozilla Corporation)
    ========== Shell Spawning ==========
    64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\<key>\shell\[command]\command]
    batfile [open] -- "%1" %*
    cmdfile [open] -- "%1" %*
    helpfile [open] -- Reg Error: Key error.
    htmlfile [print] -- rundll32.exe %SystemRoot%\system32\mshtml.dll,PrintHTML "%1" (Microsoft Corporation)
    inffile [install] -- %SystemRoot%\System32\rundll32.exe setupapi,InstallHinfSection DefaultInstall 132 %1 (Microsoft Corporation)
    InternetShortcut [open] -- "C:\Windows\System32\rundll32.exe" "C:\Windows\System32\ieframe.dll ",OpenURL %l (Microsoft Corporation)
    InternetShortcut [print] -- "C:\Windows\System32\rundll32.exe" "C:\Windows\System32\mshtml.dll ",PrintHTML "%1" (Microsoft Corporation)
    piffile [open] -- "%1" %*
    regfile [merge] -- Reg Error: Key error.
    scrfile [config] -- "%1 "
    scrfile [install] -- rundll32.exe desk.cpl,InstallScreenSaver %l
    scrfile [open] -- "%1" /S
    txtfile [edit] -- Reg Error: Key error.
    Unknown [openas] -- %SystemRoot%\system32\rundll32.exe %SystemRoot%\system32\shell32.dll,OpenAs_RunDLL %1
    Directory [AddToPlaylistVLC] -- "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" --started-from-file --playlist-enqueue "%1" ()
    Directory [Browse with FastStone] -- "C:\Program Files (x86)\FastStone Image Viewer\FSViewer.exe" "%1" ()
    Directory [cmd] -- cmd.exe /s /k pushd "%V" (Microsoft Corporation)
    Directory [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    Directory [PlayWithVLC] -- "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" --started-from-file --no-playlist-enqueue "%1" ()
    Folder [open] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    Folder [explore] -- Reg Error: Value error.
    Drive [find] -- %SystemRoot%\Explorer.exe (Microsoft Corporation)
    cplfile [cplopen] -- %SystemRoot%\System32\control.exe "%1 ",%* (Microsoft Corporation)
    ========== Security Center Settings ==========
    64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center]
    "cval" = 1
    "FirewallDisableNotify" = 0
    "AntiVirusDisableNotify" = 0
    "UpdatesDisableNotify" = 0
    64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Monitoring]
    64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc]
    "VistaSp1" = 28 4D B2 76 41 04 CA 01 [binary data]
    "AntiVirusOverride" = 0
    "AntiSpywareOverride" = 0
    "FirewallOverride" = 0
    64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center\Svc\Vol]
    ========== System Restore Settings ==========
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore]
    "DisableSR" = 0
    ========== Firewall Settings ==========
    64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall]
    64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\DomainProfile]
    64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsFirewall\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
    "EnableFirewall" = 1
    "DisableNotifications" = 0
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\GloballyOpenPorts\List]
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\PublicProfile]
    ========== Authorized Applications List ==========
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\AuthorizedApplications\List]
    "C:\Program Files (x86)\BioStar\Console\BioStar.exe" = C:\Program Files (x86)\BioStar\Console\BioStar.exe:*:Enabled:BioStar -- (Suprema)
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\AuthorizedApplications\List]
    "C:\Program Files (x86)\Orbitdownloader\orbitdm.exe" = C:\Program Files (x86)\Orbitdownloader\orbitdm.exe:*:Enabled:Orbit -- (Orbitdownloader.com)
    "C:\Program Files (x86)\Orbitdownloader\orbitnet.exe" = C:\Program Files (x86)\Orbitdownloader\orbitnet.exe:*:Enabled:Orbit -- (Orbitdownloader.com)
    ========== HKEY_LOCAL_MACHINE Uninstall List ==========
    64bit: [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall]
    "{071c9b48-7c32-4621-a0ac-3f809523288f}" = Microsoft Visual C++ 2005 Redistributable (x64)
    "{180C8888-50F1-426B-A9DC-AB83A1989C65}" = Windows Live Language Selector
    "{1ACC8FFB-9D84-4C05-A4DE-D28A9BC91698}" = Windows Live ID Sign-in Assistant
    "{1FB31F44-D4D0-4D76-944A-A1A5D79FD321}" = Windows Live Family Safety
    "{23170F69-40C1-2702-0915-000001000000}" = 7-Zip 9.15 (x64 edition)
    "{3ED4AD02-F631-4A4C-AAC8-2325996E5A56}" = Microsoft IntelliPoint 8.1
    "{446EE0D9-1F6B-42BF-8278-8D0B172BA15D}" = Microsoft IntelliType Pro 8.1
    "{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}" = Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148
    "{5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}" = Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161
    "{656DEEDE-F6AC-47CA-A568-A1B4E34B5760}" = Windows Live Remote Service Resources
    "{6DD01FF3-63CE-436B-96DB-61363EAA4EB8}" = MobileMe Control Panel
    "{6E3610B2-430D-4EB0-81E3-2B57E8B9DE8D}" = Bonjour
    "{847B0532-55E3-4AAF-8D7B-E3A1A7CD17E5}" = Windows Live Remote Client Resources
    "{8B485965-8EFE-464A-842F-CF8F18C3DFD7}" = iCloud
    "{8E34682C-8118-31F1-BC4C-98CD9675E1C2}" = Microsoft .NET Framework 4 Extended
    "{90140000-0015-0409-1000-0000000FF1CE}" = Microsoft Office Access MUI (English) 2010
    "{90140000-0015-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{EC583796-6BBB-47DD-B9CE-B5DA12D71135}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-0016-0409-1000-0000000FF1CE}" = Microsoft Office Excel MUI (English) 2010
    "{90140000-0016-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{EC583796-6BBB-47DD-B9CE-B5DA12D71135}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-0018-0409-1000-0000000FF1CE}" = Microsoft Office PowerPoint MUI (English) 2010
    "{90140000-0018-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{EC583796-6BBB-47DD-B9CE-B5DA12D71135}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-0019-0409-1000-0000000FF1CE}" = Microsoft Office Publisher MUI (English) 2010
    "{90140000-0019-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{EC583796-6BBB-47DD-B9CE-B5DA12D71135}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-001A-0409-1000-0000000FF1CE}" = Microsoft Office Outlook MUI (English) 2010
    "{90140000-001A-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{EC583796-6BBB-47DD-B9CE-B5DA12D71135}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-001B-0409-1000-0000000FF1CE}" = Microsoft Office Word MUI (English) 2010
    "{90140000-001B-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{EC583796-6BBB-47DD-B9CE-B5DA12D71135}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-001F-0409-1000-0000000FF1CE}" = Microsoft Office Proof (English) 2010
    "{90140000-001F-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{0242505C-4E90-407F-9299-B5B275F50D86}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-001F-040C-1000-0000000FF1CE}" = Microsoft Office Proof (French) 2010
    "{90140000-001F-040C-1000-0000000FF1CE}_Office14.PROPLUSR_{B51389C8-2890-4633-81D8-47D2A7402274}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-001F-0C0A-1000-0000000FF1CE}" = Microsoft Office Proof (Spanish) 2010
    "{90140000-001F-0C0A-1000-0000000FF1CE}_Office14.PROPLUSR_{1779650B-2E44-4A19-8DF6-3866D645764A}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-002C-0409-1000-0000000FF1CE}" = Microsoft Office Proofing (English) 2010
    "{90140000-002C-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{270CA0B9-9881-44DB-BC3B-37C7E66A044A}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-0043-0000-1000-0000000FF1CE}" = Microsoft Office Office 32-bit Components 2010
    "{90140000-0043-0000-1000-0000000FF1CE}_Office14.PROPLUSR_{E8B6D35B-0B6F-4DCE-9493-859BF3809A7F}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-0043-0409-1000-0000000FF1CE}" = Microsoft Office Shared 32-bit MUI (English) 2010
    "{90140000-0043-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{FCD1C311-8B02-4DBD-BA46-1079C629577E}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-0044-0409-1000-0000000FF1CE}" = Microsoft Office InfoPath MUI (English) 2010
    "{90140000-0044-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{EC583796-6BBB-47DD-B9CE-B5DA12D71135}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-006E-0409-1000-0000000FF1CE}" = Microsoft Office Shared MUI (English) 2010
    "{90140000-006E-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{516CA4A9-98E6-4F77-A863-CBD8487368E4}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-00A1-0409-1000-0000000FF1CE}" = Microsoft Office OneNote MUI (English) 2010
    "{90140000-00A1-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{EC583796-6BBB-47DD-B9CE-B5DA12D71135}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-00BA-0409-1000-0000000FF1CE}" = Microsoft Office Groove MUI (English) 2010
    "{90140000-00BA-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{EC583796-6BBB-47DD-B9CE-B5DA12D71135}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-0115-0409-1000-0000000FF1CE}" = Microsoft Office Shared Setup Metadata MUI (English) 2010
    "{90140000-0115-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{516CA4A9-98E6-4F77-A863-CBD8487368E4}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{90140000-0117-0409-1000-0000000FF1CE}" = Microsoft Office Access Setup Metadata MUI (English) 2010
    "{90140000-0117-0409-1000-0000000FF1CE}_Office14.PROPLUSR_{EC583796-6BBB-47DD-B9CE-B5DA12D71135}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{9068B2BE-D93A-4C0A-861C-5E35E2C0E09E}" = Intel® Matrix Storage Manager
    "{91140000-0011-0000-1000-0000000FF1CE}" = Microsoft Office Professional Plus 2010
    "{91140000-0011-0000-1000-0000000FF1CE}_Office14.PROPLUSR_{7BC9B5EB-125A-4E9B-97E1-8D85B5E960B8}" = Microsoft Office 2010 Service Pack 1 (SP1)
    "{95120000-00B9-0409-1000-0000000FF1CE}" = Microsoft Application Error Reporting
    "{95140000-007D-0409-1000-0000000FF1CE}" = Microsoft Outlook Social Connector Provider for Windows Live Messenger 64-bit
    "{95140000-007F-0409-1000-0000000FF1CE}" = Microsoft Outlook Hotmail Connector 64-bit
    "{aac9fcc4-dd9e-4add-901c-b5496a07ab2e}" = Microsoft Visual C++ 2005 Redistributable (x64) - KB2467175
    "{ABA4FAF1-6389-45F9-92CE-3914A4E5C471}" = PaperPort Image Printer 64-bit
    "{ad8a2fa1-06e7-4b0d-927d-6e54b3d31028}" = Microsoft Visual C++ 2005 Redistributable (x64)
    "{B6E3757B-5E77-3915-866A-CCFC4B8D194C}" = Microsoft Visual C++ 2005 ATL Update kb973923 - x64 8.0.50727.4053
    "{B8AD779A-82DA-4365-A7D0-AD3DCFC55CFF}" = Apple Mobile Device Support
    "{C3600AE6-93A0-3DB7-B7AA-45BD58F133B5}" = Microsoft Visual Studio 2010 Tools for Office Runtime (x64)
    "{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}" = SUPERAntiSpyware
    "{CEA21F20-DBF4-464C-8B81-28B8508AFDDD}" = Windows Live Family Safety
    "{CF8FFD12-602B-422D-AF1D-511B411E7632}" = iTunes
    "{DA54F80E-261C-41A2-A855-549A144F2F59}" = Windows Live MIME IFilter
    "{DF6D988A-EEA0-4277-AAB8-158E086E439B}" = Windows Live Remote Client
    "{E02A6548-6FDE-40E2-8ED9-119D7D7E641F}" = Windows Live Remote Service
    "{F5B09CFD-F0B2-36AF-8DF4-1DF6B63FC7B4}" = Microsoft .NET Framework 4 Client Profile
    "{FAE224AF-B15E-448B-88FA-1839A7570CF8}" = Intel® PROSet/Wireless WiMAX Software
    "Adobe Flash Player ActiveX" = Adobe Flash Player 11 ActiveX 64-bit
    "Adobe Flash Player Plugin" = Adobe Flash Player 11 Plugin 64-bit
    "CCleaner" = CCleaner
    "LSI Soft Modem" = LSI HDA Modem
    "Microsoft .NET Framework 4 Client Profile" = Microsoft .NET Framework 4 Client Profile
    "Microsoft .NET Framework 4 Extended" = Microsoft .NET Framework 4 Extended
    "Microsoft IntelliPoint 8.1" = Microsoft IntelliPoint 8.1
    "Microsoft IntelliType Pro 8.1" = Microsoft IntelliType Pro 8.1
    "Microsoft Visual Studio 2010 Tools for Office Runtime (x64)" = Microsoft Visual Studio 2010 Tools for Office Runtime (x64)
    "Office14.PROPLUSR" = Microsoft Office Professional Plus 2010
    "ProInst" = Intel PROSet Wireless
    "x64 Components_is1" = x64 Components v3.6.0
    "{02570AE0-BEE0-4A6C-BE3F-D806E9F2EA17}" = ScanSoft PaperPort 11
    "{0a45f664-3557-48b6-808d-79e58eed5153}" = Nero 9 Lite
    "{0B0F231F-CE6A-483D-AA23-77B364F75917}" = Windows Live Installer
    "{13A5E785-5197-4EAD-8EE3-D660271E49BC}" = Feedback Tool
    "{19BA08F7-C728-469C-8A35-BFBD3633BE08}" = Windows Live Movie Maker
    "{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148
    "{1F6AB0E7-8CDD-4B93-8A23-AA9EB2FEFCE4}" = Junk Mail filter update
    "{200FEC62-3C34-4D60-9CE8-EC372E01C08F}" = Windows Live SOXE Definitions
    "{243E10D8-64EA-427F-AB50-595A54CA12F3}" = QuickBooks Enterprise Solutions 12.0
    "{26A24AE4-039D-4CA4-87B4-2F83216031FF}" = Java(TM) 6 Update 31
    "{28006915-2739-4EBE-B5E8-49B25D32EB33}" = Atheros Driver Installation Program
    "{2902F983-B4C1-44BA-B85D-5C6D52E2C441}" = Windows Live Mesh ActiveX Control for Remote Connections
    "{294EA84A-B5AA-4C41-90EF-144A2A7EAA16}" = QuickBooks
    "{2A3FC24C-6EC0-4519-A52B-FDA4EA9B2D24}" = Windows Live Messenger
    "{2F8BA3FD-1FA9-4279-B696-712ABB12F09F}" = SmartSound Quicktracks 5
    "{3336F667-9049-4D46-98B6-4C743EEBC5B1}" = Windows Live Photo Gallery
    "{34F4D9A4-42C2-4348-BEF4-E553C84549E7}" = Windows Live Photo Gallery
    "{37B03AA0-B125-4649-900C-F26E1081F163}" = Camtasia Studio 7
    "{388E4B09-3E71-4649-8921-F44A3A2954A7}" = Microsoft Visual Studio 2005 Tools for Office Runtime
    "{3FC7CBBC4C1E11DCA1A752EA55D89593}" = DivX Version Checker
    "{46E1B1F2-A279-4356-9B17-029F9CC72EAE}" = Brother MFL-Pro Suite MFC-7340
    "{4A03706F-666A-4037-7777-5F2748764D10}" = Java Auto Updater
    "{50816F92-1652-4A7C-B9BC-48F682742C4B}" = Messenger Companion
    "{55268C00-5CC6-4471-808A-4768A86D903E}" = ThumbLock Management (PCMU)
    "{56C049BE-79E9-4502-BEA7-9754A3E60F9B}" = neroxml
    "{579684A4-DDD5-4CA3-9EA8-7BE7D9593DB4}" = Windows Live UX Platform Language Pack
    "{5C8AE145-C9F7-4883-9750-7ECD2B41CCCA}" = QuickVPN Client
    "{6421F085-1FAA-DE13-D02A-CFB412C522A4}" = Acrobat.com
    "{682B3E4F-696A-42DE-A41C-4C07EA1678B4}" = Windows Live SOXE
    "{69FDFBB6-351D-4B8C-89D8-867DC9D0A2A4}" = Windows Media Player Firefox Plugin
    "{6A9CA9F4-882C-4507-8557-5B576463A162}" = Hitachi LifeStudio 1.0.5.741 & Hitachi Backup 1.0.5.57
    "{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}" = Microsoft Visual C++ 2005 Redistributable
    "{716E0306-8318-4364-8B8F-0CC4E9376BAC}" = MSXML 4.0 SP2 Parser and SDK
    "{770657D0-A123-3C07-8E44-1C83EC895118}" = Microsoft Visual C++ 2005 ATL Update kb973923 - x86 8.0.50727.4053
    "{7748AC8C-18E3-43BB-959B-088FAEA16FB2}" = Nero StartSmart
    "{789A5B64-9DD9-4BA5-915A-F0FC0A1B7BFE}" = Apple Software Update
    "{78A96B4C-A643-4D0F-98C2-A8E16A6669F9}" = Windows Live Messenger Companion Core
    "{7B63B2922B174135AFC0E1377DD81EC2}" =
    "{7BE15435-2D3E-4B58-867F-9C75BED0208C}" = QuickTime
    "{80F7CA44-F3A5-4853-8BA6-DDF57CD4F078}" = Rosetta Stone Version 3
    "{837b34e3-7c30-493c-8f6a-2b0f04e2912c}" = Microsoft Visual C++ 2005 Redistributable
    "{83C292B7-38A5-440B-A731-07070E81A64F}" = Windows Live PIMT Platform
    "{84513125-0BC7-46F8-BE1E-309263B79AE2}" = Xmarks Thumbnails for IE
    "{84EBDF39-4B33-49D7-A0BD-EB6E2C4E81C1}" = Windows Live Sync
    "{86CE85E6-DBAC-3FFD-B977-E4B79F83C909}" = Microsoft Visual C++ 2008 Redistributable - KB2467174 - x86 9.0.30729.5570
    "{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}" = Microsoft Silverlight
    "{8ADFC4160D694100B5B8A22DE9DCABD9}" = DivX Player
    "{8BC4ED93-2FCA-4938-8FF0-F56B73E3C82D}" = BioStar 1.36 Client
    "{8C0CAA7A-3272-4991-A808-2C7559DE3409}" = Win7codecs
    "{8C6D6116-B724-4810-8F2D-D047E6B7D68E}" = Mesh Runtime
    "{8DD46C6A-0056-4FEC-B70A-28BB16A1F11F}" = MSVCRT
    "{90024193-9F13-4877-89D5-A1CDF0CBBF28}" = Feedback Tool
    "{92EA4134-10D1-418A-91E1-5A0453131A38}" = Windows Live Movie Maker
    "{933B4015-4618-4716-A828-5289FC03165F}" = VC80CRTRedist - 8.0.50727.6195
    "{9A25302D-30C0-39D9-BD6F-21E6EC160475}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17
    "{9BE518E6-ECC6-35A9-88E4-87755C07200F}" = Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161
    "{9D56775A-93F3-44A3-8092-840E3826DE30}" = Windows Live Mail
    "{A0C91188-C88F-4E86-93E6-CD7C9A266649}" = Windows Live Mesh
    "{A2BCA9F1-566C-4805-97D1-7FDC93386723}" = Adobe AIR
    "{A726AE06-AAA3-43D1-87E3-70F510314F04}" = Windows Live Writer
    "{A9BDCA6B-3653-467B-AC83-94367DA3BFE3}" = Windows Live Photo Common
    "{AA59DDE4-B672-4621-A016-4C248204957A}" = Skype™ 5.5
    "{AAAFC670-569B-4A2F-82B4-42945E0DE3EF}" = Windows Live Writer
    "{AAF454FC-82CA-4F29-AB31-6A109485E76E}" = Windows Live Writer
    "{AC76BA86-7AD7-1033-7B44-AA1000000001}" = Adobe Reader X (10.1.3)
    "{AC76BA86-7AD7-2447-0000-900000000003}" = Chinese Simplified Fonts Support For Adobe Reader 9
    "{AC76BA86-7AD7-5670-0000-900000000003}" = Korean Fonts Support For Adobe Reader 9
    "{AC76BA86-7AD7-5760-0000-900000000003}" = Japanese Fonts Support For Adobe Reader 9
    "{B282226A-5BCB-4458-808B-9AC7CD7DC6BE}" = BioStar VideoPhone
    "{B2EC4A38-B545-4A00-8214-13FE0E915E6D}" = Advertising Center
    "{B3DAF54F-DB25-4586-9EF1-96D24BB14088}" = Windows Movie Maker 2.6
    "{B6CF2967-C81E-40C0-9815-C05774FEF120}" = Skype Click to Call
    "{B8A2869E-30CA-40C5-9CF8-BD7354E57EF8}" = SmartSound Common Data
    "{BD5CA0DA-71AD-43DA-B19E-6EEE0C9ADC9A}" = Nero ControlCenter
    "{C4C91E02-D4E2-481E-BCBA-7D90CC8D43E1}" = LiveZilla
    "{C66824E4-CBB3-4851-BB3F-E8CFD6350923}" = Windows Live Mail
    "{C81A2FE0-3574-00A9-CED4-BDAA334CBE8E}" = Nero Online Upgrade
    "{CE95A79E-E4FC-4FFF-8A75-29F04B942FF2}" = Windows Live UX Platform
    "{CFF8B8E8-E086-4DE0-935F-FE22CAB54F80}" = Microsoft Search Enhancement Pack
    "{D0ACE89D-EC7F-470F-80BE-4C98ED366B32}" = Acer Crystal Eye webcam Ver:1.1.74.216
    "{D0B44725-3666-492D-BEF6-587A14BD9BD9}" = MSVCRT_amd64
    "{D3A80508-CD83-4CA3-8671-914A1BC78B61}" = Microsoft Sync Framework 2.0 Provider Services (x86) ENU
    "{D436F577-1695-4D2F-8B44-AC76C99E0002}" = Windows Live Photo Common
    "{D45240D3-B6B3-4FF9-B243-54ECE3E10066}" = Windows Live Communications Platform
    "{DC24971E-1946-445D-8A82-CE685433FA7D}" = Realtek USB 2.0 Card Reader
    "{DDC8BDEE-DCAC-404D-8257-3E8D4B782467}" = Windows Live Writer Resources
    "{DECDCB7C-58CC-4865-91AF-627F9798FE48}" = Windows Live Mesh
    "{E09C4DB7-630C-4F06-A631-8EA7239923AF}" = D3DX10
    "{E38C00D0-A68B-4318-A8A6-F7D4B5B1DF0E}" = Windows Media Encoder 9 Series
    "{E5B21F11-6933-4E0B-A25C-7963E3C07D11}" = Windows Live Messenger
    "{E8A80433-302B-4FF1-815D-FCC8EAC482FF}" = Nero Installer
    "{EB879750-CCBD-4013-BFD5-0294D4DA5BD0}" = Apple Application Support
    "{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}" = Microsoft SQL Server 2005 Compact Edition [ENU]
    "{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}" = Realtek High Definition Audio Driver
    "{F2AF3E5D-9697-485C-A5AC-E2B9468C446A}" = Safari
    "{F7FC9307-374E-4017-8E9D-DE1154780480}" = System Requirements Lab for Intel
    "{FE044230-9CA5-43F7-9B58-5AC5A28A1F33}" = Windows Live Essentials
    "{FF63121D-91C6-42CC-B341-F1AA729728E7}" = Microsoft Sync Framework 2.0 Core Components (x86) ENU
    "Adobe AIR" = Adobe AIR
    "com.adobe.mauby.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1" = Acrobat.com
    "dips64" = Desktop Icon Position Saver (64-bit)
    "DivX Plus DirectShow Filters" = DivX Plus DirectShow Filters
    "FastStone Image Viewer" = FastStone Image Viewer 4.6
    "FileZilla Client" = FileZilla Client 3.5.0
    "Freemake Video Converter_is1" = Freemake Video Converter version 3.0.2
    "Google Desktop" = Google Desktop
    "Graboid Video" = Graboid Video 1.71
    "HandBrake" = HandBrake 0.9.5
    "ImgBurn" = ImgBurn
    "InstallShield_{2F8BA3FD-1FA9-4279-B696-712ABB12F09F}" = SmartSound Quicktracks 5
    "InstallShield_{8BC4ED93-2FCA-4938-8FF0-F56B73E3C82D}" = BioStar 1.36 Client
    "InstallShield_{B8A2869E-30CA-40C5-9CF8-BD7354E57EF8}" = SmartSound Common Data
    "iWisoft Free Video Converter_is1" = iWisoft Free Video Converter 1.2
    "LiveResponse" = Kayako Desktop
    "LiveZilla" = LiveZilla
    "LManager" = Launch Manager
    "Malwarebytes' Anti-Malware_is1" = Malwarebytes Anti-Malware version 1.61.0.1400
    "Microsoft Visual Studio 2005 Tools for Office Runtime" = Microsoft Visual Studio 2005 Tools for Office Runtime
    "Mozilla Firefox 11.0 (x86 en-US)" = Mozilla Firefox 11.0 (x86 en-US)
    "Mozilla Thunderbird 11.0.1 (x86 en-US)" = Mozilla Thunderbird 11.0.1 (x86 en-US)
    "NirSoft BlueScreenView" = NirSoft BlueScreenView
    "Open record" = Open record
    "OpenSSL_is1" = OpenSSL 0.9.8d
    "Orbit_is1" = Orbit Downloader
    "PhotoScape" = PhotoScape
    "Smart Defrag 2_is1" = Smart Defrag 2
    "SopCast" = SopCast 3.2.4
    "StreamTorrent 1.0" = StreamTorrent 1.0
    "SystemRequirementsLab" = System Requirements Lab
    "TeamViewer 6" = TeamViewer 6
    "TVAnts 1.0" = TVAnts 1.0
    "TVUPlayer" = TVUPlayer 2.5.0.1
    "uTorrent" = µTorrent
    "Veetle TV" = Veetle TV 0.9.16
    "VirtualCloneDrive" = VirtualCloneDrive
    "VLC media player" = VLC media player 1.0.1
    "Windows Media Encoder 9" = Windows Media Encoder 9 Series
    "WinLiveSuite" = Windows Live Essentials
    ========== Last 10 Event Log Errors ==========
    [ Application Events ]
    Error - 4/19/2012 7:42:01 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = QuickBooks | ID = 4
    Description = An unexpected error has occured in "Intuit QuickBooks Enterprise Solutions
    12.0 ": DB error -101 ErrorMessage:'Not connected to a database' from file:'.\.\src\DMSQLTransaction.cpp'
    at line 175 from function:'DBMgr::SADMTransaction::DBSQLCommi
    Error - 4/19/2012 7:45:20 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-CAPI2 | ID = 4107
    Description = Failed extract of third-party root list from auto update cab at: <http://www.download.windowsupdate.com/msdownload/update/v3/static/trustedr/en/authrootstl.cab>
    with error: A required certificate is not within its validity period when verifying
    against the current system clock or the timestamp in the signed file. .
    Error - 4/19/2012 7:52:52 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-CAPI2 | ID = 4107
    Error - 4/19/2012 8:37:38 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-CAPI2 | ID = 4107
    Error - 4/19/2012 8:54:10 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = System Restore | ID = 8193
    Description =
    Error - 4/19/2012 9:21:33 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-CAPI2 | ID = 4107
    Error - 4/19/2012 9:39:45 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-CAPI2 | ID = 4107
    Error - 4/19/2012 10:45:54 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-CAPI2 | ID = 4107
    Error - 4/19/2012 10:53:55 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-CAPI2 | ID = 4107
    Error - 4/19/2012 10:59:01 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-CAPI2 | ID = 4107
    [ Media Center Events ]
    Error - 3/7/2010 4:29:07 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = MCUpdate | ID = 0
    Description = 3:29:05 PM - Failed to retrieve SportsSchedule.enc (Error: HTTP status
    404: The requested URL does not exist on the server. )
    Error - 3/24/2010 10:28:29 AM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = MCUpdate | ID = 0
    Description = 10:28:19 AM - Failed to retrieve Directory (Error: The operation has
    timed out)
    Error - 3/25/2010 9:49:21 AM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = MCUpdate | ID = 0
    Description = 9:48:35 AM - Error connecting to the internet. 9:49:16 AM - Unable
    to contact server..
    Error - 4/9/2010 9:14:56 AM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = MCUpdate | ID = 0
    Description = 9:14:56 AM - Failed to retrieve Directory (Error: The underlying connection
    was closed: An unexpected error occurred on a receive.)
    Error - 4/21/2010 9:26:22 AM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = MCUpdate | ID = 0
    Description = 9:26:16 AM - Failed to retrieve SportsV2 (Error: The operation has
    timed out)
    Error - 5/10/2010 3:21:43 AM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = MCUpdate | ID = 0
    Description = 3:21:10 AM - Failed to retrieve SportsSchedule-2.enc (Error: HTTP
    status 404: The requested URL does not exist on the server. )
    [ System Events ]
    Error - 4/19/2012 10:56:42 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = TermService | ID = 1067
    Description =
    Error - 4/19/2012 10:56:52 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Service Control Manager | ID = 7024
    Description = The Dritek WMI Service service terminated with service-specific error
    %%0.
    Error - 4/19/2012 10:58:28 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Service Control Manager | ID = 7000
    Description = The POLYMATH Astar2200 series USB2.0 Driver (Ast2200u.sys) service
    failed to start due to the following error: %%577
    Error - 4/19/2012 10:58:32 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-GroupPolicy | ID = 1129
    Description = The processing of Group Policy failed because of lack of network connectivity
    to a domain controller. This may be a transient condition. A success message would
    be generated once the machine gets connected to the domain controller and Group
    Policy has succesfully processed. If you do not see a success message for several
    hours, then contact your administrator.
    Error - 4/19/2012 10:58:48 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-Time-Service | ID = 46
    Description = The time service encountered an error and was forced to shut down.
    The error was: 0x80070700: An attempt was made to logon, but the network logon
    service was not started.
    Error - 4/19/2012 10:58:48 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Service Control Manager | ID = 7023
    Description = The Windows Time service terminated with the following error: %%1792
    Error - 4/19/2012 10:58:55 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-Time-Service | ID = 46
    Error - 4/19/2012 10:58:55 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Service Control Manager | ID = 7023
    Error - 4/19/2012 10:59:40 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = Microsoft-Windows-GroupPolicy | ID = 1129
    Error - 4/19/2012 11:01:54 PM | Computer Name = ROCCO-WIN7-X64.ibc1.ibcbiometrics.com | Source = TermService | ID = 1067
    Description =
    < End of report >
