Multiple copes of IE running hang system
Discussion in 'Malware and Virus Removal Archive' started by SusanG, 2004/09/05.
  1. 2004/09/05
    SusanG
    SusanG Inactive Thread Starter
    I've tried to investigate this but I'm failing to find the correct search words.
    I'm running XP home.
    My system freezes periodically when I click on links in email. Outlook freezes and I cannot get onto the internet.
    When I look in the Task Mgr, I find multiple copies of IEXPLORE.EXE listed, even if there are no open IE sessions. If I delete the IE processes, the system will "unfreeze" and all is well.
    What is causing these IE sessions not to end? Any suggestions for search parameters will be greatly appreciated.
    Thank you.
  2. 2004/09/07
    Hi SusanG and welcome. Sorry this thread took so long to get a response for you.
    This sounds like a problem with spyware/malware so the first step will be to see how you stand on that. I'll be moving the thread to the security section when I finish this reply.
    Look in Quicklinks in my signature and use links there to do the following:
    - download, immediately update, and run Ad-aware. Check the box for a full scan. Let it remove all items it finds.
    - same for Spybot but you only need to remove the items it pre-checks for you. The others are harmless.
    - download Hijackthis. Extract it to a folder of it's own so maybe c:\hjt or c:\anti-spyware or something. Do not put it in a temp folder or directly on the desktop.
    Once you have Hijackthis on your drive (no install needed) run it and click the button to run a scan. Then click the button to save a log file and when it finishes, you will have a copy of the log opened in notepad. Select the entire contents and post that in a reply to this thread. We'll tell you how to proceed from there.
    SusanG
    Results
    Thanks for the welcome and help! I was out of town last week - hense the delay.
    I run SpySweeper every day, so I ran it and found 1 item
    Adaway found 5 cookies
    Spybot found 41 tracking cookies
    All were removed.
    Here's the log:
    Logfile of HijackThis v1.97.7
    Scan saved at 10:10:59 AM, on 9/15/2004
    Platform: Windows XP SP1 (WinNT 5.01.2600)
    MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
    C:\WINDOWS\system32\csrss.exe
    C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
    C:\Program Files\Roxio\Easy CD Creator 6\DragToDisc\DrgToDsc.exe
    C:\WINDOWS\System32\Ipen.exe
    C:\WINDOWS\System32\RunDll32.exe
    C:\Program Files\Norton SystemWorks\Password Manager\AcctMgr.exe
    C:\PROGRA~1\AWS\WEATHE~1\Weather.exe
    C:\Program Files\EPSON\EPSON SMART PANEL for Scanner\ESPMAIN.EXE
    C:\WINDOWS\System32\CTSvcCDA.EXE
    C:\Program Files\Common Files\EPSON\EBAPI\SAgent2.exe
    C:\WINDOWS\System32\mgabg.exe
    C:\Program Files\Norton SystemWorks\Norton Antivirus\navapsvc.exe
    C:\PROGRA~1\NORTON~1\NORTON~2\NPROTECT.EXE
    C:\WINDOWS\System32\ofps.exe
    C:\Program Files\Norton SystemWorks\Norton Antivirus\SAVScan.exe
    C:\PROGRA~1\NORTON~1\NORTON~2\SPEEDD~1\NOPDB.EXE
    C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
    C:\WINDOWS\System32\MsPMSPSv.exe
    C:\Program Files\Raxco\PerfectDisk\PDSched.exe
    C:\WINDOWS\System32\wuauclt.exe
    C:\Program Files\Microsoft Office\OFFICE11\WINWORD.EXE
    C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
    C:\Software Updates\Hijackthis\HijackThis.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.voy.com/14708/
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.voy.com/14708/
    O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
    O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton SystemWorks\Norton Antivirus\NavShExt.dll
    O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
    O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton SystemWorks\Norton Antivirus\NavShExt.dll
    O3 - Toolbar: FingerSystem IE Memo - {8D13872E-6174-49C1-B8D2-793F90CCAFAC} - C:\Program Files\Finger System Inc\Fingersystem Ipen Driver\FGIeMemo.dll
    O4 - HKLM\..\Run: [RoxioDragToDisc] "C:\Program Files\Roxio\Easy CD Creator 6\DragToDisc\DrgToDsc.exe "
    O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
    O4 - HKLM\..\Run: [IpenMOUSE] C:\WINDOWS\System32\Ipen.exe
    O4 - HKLM\..\Run: [Cmaudio] RunDll32 cmicnfg.cpl,CMICtrlWnd
    O4 - HKLM\..\Run: [AcctMgr] C:\Program Files\Norton SystemWorks\Password Manager\AcctMgr.exe /startup
    O4 - HKCU\..\Run: [Weather] C:\PROGRA~1\AWS\WEATHE~1\Weather.exe 1
    O4 - HKCU\..\Run: [SpySweeper] "C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe" /0
    O4 - Startup: Norton System Doctor.LNK = ?
    O4 - Global Startup: EPSON SMART PANEL for Scanner.lnk = C:\Program Files\EPSON\EPSON SMART PANEL for Scanner\ESPMAIN.EXE
    O4 - Global Startup: EPSON Status Monitor 3 Environment Check(2).lnk = C:\WINDOWS\system32\spool\drivers\w32x86\3\E_SRCV02.EXE
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
    O9 - Extra button: Research (HKLM)
    O9 - Extra button: Messenger (HKLM)
    O9 - Extra 'Tools' menuitem: Windows Messenger (HKLM)
    O9 - Extra button: WeatherBug (HKCU)
    O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
    O12 - Plugin for .tiff: C:\Program Files\Internet Explorer\PLUGINS\npqtplugin5.dll
    O16 - DPF: YExplorer1_8US.CAB - http://photos.groups.yahoo.com/ocx/us/yexplorer1_8us.cab
    O16 - DPF: {2B96D5CC-C5B5-49A5-A69D-CC0A30F9028C} (MiniBugTransporterX Class) - http://wdownload.weatherbug.com/minibug/tricklers/AWS/MiniBugTransporter.cab?
    O16 - DPF: {3E68E405-C6DE-49FF-83AE-41EE9F4C36CE} (Office Update Installation Engine) - http://office.microsoft.com/officeupdate/content/opuc.cab
    O16 - DPF: {9F1C11AA-197B-4942-BA54-47A8489BB47F} - http://v4.windowsupdate.microsoft.com/CAB/x86/unicode/iuctl.CAB?38084.6080208333
    O16 - DPF: {CE28D5D2-60CF-4C7D-9FE8-0F47A3308078} (ActiveDataInfo Class) - https://www-secure.symantec.com/techsupp/activedata/SymAData.cab
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
    O16 - DPF: {E77C0D62-882A-456F-AD8F-7C6C9569B8C7} (ActiveDataObj Class) - https://www-secure.symantec.com/techsupp/activedata/ActiveData.cab
  5. 2004/09/15
    Looks pretty clean. You do need to get the latest version of HJT though and run another scan to create a log. There may be some stuff v1.97 misses that v1.98.2 finds.
    Make sure you have the latest version of Weatherbug since there are XP issues with several of the earlier ones.
    Depending on how you work, you might want to run HJT and let it remove
    System tray control panel for C-Media based soundcards and not needed unless you use it a lot. You can get to the same C-media settings, when needed, from control panel. It basically just chews up system resources for no real benefit to you.
    I'll wait for the new HJT log but based on the protection you use and the 1.97 log, it's probably gonna be something else so running
    sfc /scannow
    is worth doing since it's the closest to an IE repair you can get with XP.
    SusanG
    Here's the logfile for the newer HJT.
    I ran SFC / scannow and it came up empty.
    I'll let you know if it keeps happening.
    Thanks,
    Susan
    Logfile of HijackThis v1.98.2
    Scan saved at 6:48:21 PM, on 9/15/2004
    C:\Program Files\Norton SystemWorks\Norton Utilities\SYSDOC32.EXE
    C:\Program Files\Microsoft Office\OFFICE11\OUTLOOK.EXE
    C:\Program Files\Internet Explorer\IEXPLORE.EXE
    O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
    O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
    O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\MSMSGS.EXE
    O9 - Extra button: WeatherBug - {AF6CABAB-61F9-4f12-A198-B7D41EF1CB52} - C:\PROGRA~1\AWS\WEATHE~1\Weather.exe (HKCU)
  7. 2004/09/15
    Well dang - I was really hoping the new HJT would show something that would be obvious and easy to fix. Ah well. Maybe one of the real security experts will spot something I missed.
    SFC runs very quickly and without telling you much of anything. You'd need to check your event logs for details since it does write a detailed event.
    #6
  8. 2004/09/15
    BillyBob Inactive
    For starters I would shut down ALL of Norton except the Anti-Virus.
    Especially Norton Protection. But MAKE SURE the Norton protected Recycle Bin is empty first.
    BillyBob
  9. 2004/09/19
    ngunja
    ngunja Inactive
    Multiple iexplore.exe
    Hi
    I have the same problem. I'm pretty sure its spyware. I ran SpyBot and it comes up with
    VX2/f (3 entries)
    DSO Exploit (5 entries)
    IE Plugin (1 entry)
    IGetNet (1 entry)
    and everytime i delete them, they come right back.
    Here is my hijack log
    Scan saved at 4:50:03 PM, on 9/19/2004
    MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
    C:\WINDOWS\System32\Ati2evxx.exe
    C:\WINDOWS\System32\ACS.exe
    C:\PROGRA~1\COMMON~1\AOL\ACS\acsd.exe
    C:\Program Files\Toshiba\Power Management\CeEPwrSvc.exe
    C:\Program Files\TOSHIBA\ConfigFree\CFSvcs.exe
    C:\WINDOWS\System32\DVDRAMSV.exe
    C:\Program Files\Norton AntiVirus\navapsvc.exe
    C:\Program Files\Norton AntiVirus\SAVScan.exe
    c:\TOSHIBA\Ivp\Swupdate\swupdtmr.exe
    C:\WINDOWS\wanmpsvc.exe
    C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
    C:\WINDOWS\system32\rundll32.exe
    C:\WINDOWS\system32\dla\tfswctrl.exe
    C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    C:\WINDOWS\AGRSMMSG.exe
    C:\Program Files\Apoint2K\Apoint.exe
    C:\Program Files\EzButton\EzButton.EXE
    C:\Program Files\TOSHIBA\E-KEY\CeEKey.exe
    C:\Program Files\TOSHIBA\TouchPad\TPTray.exe
    C:\Program Files\TOSHIBA\Touch and Launch\PadExe.exe
    C:\Program Files\TOSHIBA\ConfigFree\NDSTray.exe
    C:\Program Files\TOSHIBA\Power Management\CePMTray.exe
    C:\toshiba\ivp\ism\pinger.exe
    C:\Program Files\Viewpoint\Viewpoint Manager\ViewMgr.exe
    C:\Program Files\Athan\Athan.exe
    C:\WINDOWS\system32\ubbnifb.exe
    C:\Program Files\SED\SED.exe
    C:\Program Files\TOSHIBA\TOSCDSPD\toscdspd.exe
    C:\Program Files\MSN Messenger\MsnMsgr.Exe
    C:\Program Files\AIM\aim.exe
    C:\WINDOWS\System32\atmlib.exe
    C:\WINDOWS\system32\RAMASST.exe
    C:\Program Files\Apoint2K\Apntex.exe
    C:\Documents and Settings\Najmuddin Gunja\Desktop\pop.exe
    C:\Program Files\Spybot - Search & Destroy\SpybotSD.exe
    C:\WINDOWS\system32\taskmgr.exe
    C:\hjt.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://websearch.drsnsrch.com/sidesearch.cgi?id=
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://websearch.drsnsrch.com/sidesearch.cgi?id=
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://websearch.drsnsrch.com/sidesearch.cgi?id=
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://websearch.drsnsrch.com/sidesearch.cgi?id=
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://toshibadirect.com/
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch = http://websearch.drsnsrch.com/sidesearch.cgi?id=
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://websearch.drsnsrch.com/sidesearch.cgi?id=
    R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = websearch.drsnsrch.com/q.cgi?q=
    O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton AntiVirus\NavShExt.dll
    O3 - Toolbar: Viewpoint Toolbar - {F8AD5AA5-D966-4667-9DAF-2561D68B2012} - C:\Program Files\Viewpoint\Viewpoint Toolbar\ViewBar.dll
    O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
    O3 - Toolbar: (no name) - {2CDE1A7D-A478-4291-BF31-E1B4C16F92EB} - (no file)
    O4 - HKLM\..\Run: [dla] C:\WINDOWS\system32\dla\tfswctrl.exe
    O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
    O4 - HKLM\..\Run: [Apoint] C:\Program Files\Apoint2K\Apoint.exe
    O4 - HKLM\..\Run: [EzButton] C:\Program Files\EzButton\EzButton.EXE
    O4 - HKLM\..\Run: [CeEKEY] C:\Program Files\TOSHIBA\E-KEY\CeEKey.exe
    O4 - HKLM\..\Run: [TPNF] C:\Program Files\TOSHIBA\TouchPad\TPTray.exe
    O4 - HKLM\..\Run: [PadTouch] C:\Program Files\TOSHIBA\Touch and Launch\PadExe.exe
    O4 - HKLM\..\Run: [NDSTray.exe] NDSTray.exe
    O4 - HKLM\..\Run: [CeEPOWER] C:\Program Files\TOSHIBA\Power Management\CePMTray.exe
    O4 - HKLM\..\Run: [Pinger] c:\toshiba\ivp\ism\pinger.exe /run
    O4 - HKLM\..\Run: [ViewMgr] C:\Program Files\Viewpoint\Viewpoint Manager\ViewMgr.exe
    O4 - HKLM\..\Run: [Athan] C:\Program Files\Athan\Athan.exe
    O4 - HKLM\..\Run: [rpluuieaq] C:\WINDOWS\system32\ubbnifb.exe
    O4 - HKLM\..\Run: [SESync] "C:\Program Files\SED\SED.exe "
    O4 - HKLM\..\Run: [Win Server Updt] C:\WINDOWS\wupdt.exe
    O4 - HKCU\..\Run: [TOSCDSPD] C:\Program Files\TOSHIBA\TOSCDSPD\toscdspd.exe
    O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
    O4 - HKCU\..\Run: [AIM] C:\Program Files\AIM\aim.exe -cnetwait.odl
    O4 - HKCU\..\Run: [atmlib] C:\WINDOWS\System32\atmlib.exe
    O4 - HKCU\..\Run: [MyPrivacyIndexPath] "C:\Documents and Settings\Najmuddin Gunja\Desktop\Stuff\Omniquad MyPrivacy\MyPrivacy\MyPrivacyIndex.exe "
    O4 - Global Startup: RAMASST.lnk = C:\WINDOWS\system32\RAMASST.exe
    O8 - Extra context menu item: &Google Search - res://c:\program files\google\GoogleToolbar1.dll/cmsearch.html
    O8 - Extra context menu item: &Viewpoint Search - res://C:\Program Files\Viewpoint\Viewpoint Toolbar\ViewBar.dll/CXTSEARCH.HTML
    O8 - Extra context menu item: Backward Links - res://c:\program files\google\GoogleToolbar1.dll/cmbacklinks.html
    O8 - Extra context menu item: Cached Snapshot of Page - res://c:\program files\google\GoogleToolbar1.dll/cmcache.html
    O8 - Extra context menu item: Similar Pages - res://c:\program files\google\GoogleToolbar1.dll/cmsimilar.html
    O8 - Extra context menu item: Translate into English - res://c:\program files\google\GoogleToolbar1.dll/cmtrans.html
    O9 - Extra 'Tools' menuitem: Sun Java Console (HKLM)
    O9 - Extra 'Tools' menuitem: Yahoo! Messenger (HKLM)
    O9 - Extra button: AIM (HKLM)
    O9 - Extra button: Real.com (HKLM)
    O10 - Unknown file in Winsock LSP: c:\windows\system32\calsp.dll
    O10 - Unknown file in Winsock LSP: c:\windows\system32\lspak.dll
    O14 - IERESET.INF: START_PAGE_URL=http://www.toshiba.com
    O16 - DPF: {1D0D9077-3798-49BB-9058-393499174D5D} - file://c:\counter.cab
    O16 - DPF: {30528230-99F7-4BB4-88D8-FA1D4F56A2AB} (YInstStarter Class) - http://download.yahoo.com/dl/yinst/yinst_current.cab
    O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - http://messenger.msn.com/download/MsnMessengerSetupDownloader.cab
    O16 - DPF: {B9191F79-5613-4C76-AA2A-398534BB8999} (YAddBook Class) - http://us.dl1.yimg.com/download.yahoo.com/dl/installs/suite/yautocomplete.cab
    O16 - DPF: {DDFFA75A-E81D-4454-89FC-B9FD0631E726} - http://www.bundleware.com/activeX/DS3/DS3.cab
    Looking forward to your reply,
    najmuddin
