MSIE problem II
Discussion in 'Internet Explorer & Microsoft Edge' started by willieboye, 2002/08/01.
  1. 2002/08/01
    willieboye
    willieboye Inactive Thread Starter
    Back again with the same problem. (Although the Error window doesn't showup as often!)
    I am running WIN98 with IE6. I have AdAware installed. I have all the "listings" entered in IE Safety Zone.
    The last error signature: APP: Iexplore.exe/Ver. 6.02600.0/Mod: unknown/Ver: 0.0.0.0. and Offset: 11c073a6.
    Have I missed something in the previous postings? Or does anyone have a suggestion on which direction I should head in now? TIA willieboye
  2. 2002/08/01
    Daizy
    Daizy Inactive
    Hi Willieboye
    Without knowing what the other post was about..perhaps this page may help you sort out the error?
    Daizy
    Kevin Lifetime Subscription
    Kevin Well-Known Member
    willieboye,
    How about providing a link or links to those other posts. I suppose we could search them out, but...
  5. 2002/08/01
    willieboye
    Hi Daizy and Kevin. Previous post was "MSIE" has a problem. 23rd June, 02. Threads look like 6393 and 7066.
    Does this help? willieboye
    (I believe that I had better review these postings to see if I have covered everything!)
  6. 2002/08/01
    Daizy
    Daizy Inactive
    willieboye
    willieboye
    brett
    brett Inactive Alumni
    Do you have Office 2000 installed? If so, have you applied Service Release 1? If not, do so and see whether this resolves the problem. If you don't have Office 2000 installed, disable Error Reporting and you should get a more comprehensive error message (which you can post) when IE next crashes.
  10. 2002/08/02
    willieboye
    Hi Brett,
    If you have IE6 installed, should you still have to install IE5.5 Service Pack 2? The last time I checked the report error, I received a not to the effect that the program was no longer in use. TIA, willieboye
  11. 2002/08/02
    brett
    I was referring to the Service Release for Office 2000?
    If you disable the Reprting Tool (as per the link) you should get a more comprehensive version of the error message which yo can then copy and paste to the boards.
  12. 2002/08/03
    willieboye
    Hi Brett,
    In my haste to answer last time I forgot to mention that I don't have Office 2000. willieboye
