MS Word Problem opening documents
Discussion in 'Other PC Software' started by RonUK, 2007/06/05.
  1. 2007/06/05
    RonUK
    RonUK Inactive Thread Starter
    bit of a strange one. I can no longer open Word documents from folders however I can open the same documents using the Open function within Word itself. When I click on a document in a folder it prompts the system to launch the Office Installer. Unfortunately I work remotely from my company's IT department and I don't possess the installation CD for Office. Excel and PowerPoint are fine.
  2. 2007/06/05
    Dennis L Inactive Alumni
    Possible a file association issue. Check in
    Folder Options | File Types and associate .DOC files to open with Word.
    RonUK
    Hi Dennis,
    thanks for the reply. Already done this. Problem still there.
  5. 2007/06/06
    Need to get the IT dept to send you a cd...Or grab one next time you're in the office...
