MS Natural Keyboard Pro...USB?
Discussion in 'PC Hardware' started by barrytrute, 2002/10/21.
  1. 2002/10/21
    barrytrute
    barrytrute Inactive Thread Starter
    My MS Mouse works fine through one of the USB ports in my Natural Keyboard Pro but I can't get my flatbed scanner (Canon) to work. My scanner works fine when I plug it into the USB port on the back of my PC but those ports are already full with my keyboard and my Internet modem. Should I try buying a USB hub or will I probably have the same problem? The keyboard says that the USB ports are for low powered hardward like a mouse. Is my flatbed scanner too needy on power? Any help would be appreciated.
  2. 2002/10/21
    Bmoore1129
    Bmoore1129 Geek Member
    barrytrute
    You have Modem, Scanner, and Keyboard/Mouse combination...Not enough holes....You need to get a hub.:)
    Here is something else to muddy the waters with.
    There is another choice if you ever buy a new device that is USB v2.0 ready. There are PCI cards available for making your computer USB2.0 ready. They are v1.1 backward compatable and provides you with 4 more USB slots. Here is a good place to read about it.:cool:
    Mahmud603
    Mahmud603 Inactive
    I would second the suggestion in the last post and recommend a USB 2 PCI card.
    These cards come in several flavours giving you the choice of an extra 2 or 5 USB 2 connections.
    You will find that your scanner and other devices will run much faster.
    :cool:
