Resolved MS Money problem
Discussion in 'Other PC Software' started by derekd, 2006/12/05.
  1. 2006/12/05
    derekd
    derekd Well-Known Member Thread Starter
    Two days ago I used the MS money option to go on line. Big mistake. Eveytime i start the program now or select any of the menu items...up pops a dialogue box.
    "File Download"
    File Name - MNY24.surfplace
    Type - Surfboard Shim Doc Object View
    From - Surf.mar@
    Options Are - Open, Save, Cancel.
    I have to open the file to continue.
    I have tracked the MNY24.surfplace file to 'my user' file under Documents and settings and it resides in the Temp file in Local Settings. Also there is a file called 'Perflib_Perfdata_b4c.dat together with a number of text files that don't open. have run AVG free edition and Ad-Aware SE Personal, Spybot - S&D and Spyware Doctor but they all report that no problems exist. Can anybody tell me what to do next.
  2. 2006/12/07
    derekd
    MS Money hijack?
    Further to my message, after talking to a friend I tried Windows Defender and MS Malicious Software Removal tool but no joy - am still told I have no problem!
    derekd
    MS Money hijack?
    Thank you for your reply. I have tried to read all the material you suggested but find myself a little lost! All I want to do is remove the MSN/Money linkage so I stop having to click the pop up menu to use my Money program. I do not wish to use Money as a browser.
  6. 2006/12/10
    Bmoore1129
    Bmoore1129 Geek Member
    derekd
    Open Money
    Go to Tools>Options>General tab.
    Uncheck everything and select account register in the dropdown list.
    Go to Connections tab and select use my default browser.
    When I open Money, I get the my check register as the first page.
  7. 2006/12/16
    derekd
    Thank you for your suggestions - gave them a go but still have the same problem. Would it work if I removed MS Money from my C:\ drive and install it on my second hard drive? I don't want to have to clean the drive and reload XP if I don't have to!
    derekd
  8. 2006/12/17
    Bmoore1129
    If you uninstall Money and then re install on another drive, it is possible to clear up some problem. You will have to redo all your preferences. It is a good idea to keep your.mny files and backup files on another partition. You should move them before you uninstall.
    I keep my regular money file on another partition and back up to yet another partition and also to a USB Flash Drive.
  9. 2006/12/19
    derekd
    Thanks for your comments. Will do as suggested.
    derekd
