MS Cam loads always
Discussion in 'PC Hardware' started by sussertown, 2008/07/17.
  1. 2008/07/17
    sussertown
    sussertown Well-Known Member Thread Starter
    I rarely use my ms cam. I can't seem to get the service to stop loading on boot.
  2. 2008/07/17
    Start->Run and type msconfig
    Look in the startup tab and see if you see something there..
    sussertown
    it doesn't care if I remove it from the startup. It comes back. That's why I'm writing.
  5. 2008/07/18
    Control Panel->Admin Tools->Services-> look for the service and double click. Click Stop and or set it to manual/disabled.
  6. 2008/07/18
    sussertown
    I'll see if that holds up. I'm' sure it will if you say so. It's ashame that the device software can't be designed with consumers in mind.
