@Mr. B - Acronis help?
Discussion in 'Other PC Software' started by savagcl, 2005/01/22.
  1. 2005/01/22
    savagcl Lifetime Subscription
    Mr. B, in a previous thread, you mentioned that you were using Acronis True
    Image. and that you didnt have the acronis partition.
    What startup processes are being loaded for AcronisTI?
    Some say all 3 processes are required, some have 2 processes. So i was
    wondering, if you restore (and create(?)) images from the boot CD are these 3
    processes needed to be running at all times? I know that during the day, they
    will start (in the background) and create incremental changes. but since i dont
    use the incremental changes at all, its a waste of time and CPU resources.
    I'm trying to determine why my sys has slowed down. It seems to be more
    noticeable when a program is starting to be executed. For example, Mozilla-
    it used to up and running before i could get my finger off the mouse button
    but now it takes a couple of seconds before even the splash screen shows.
    Thanks, Guy,
    savagcl
  2. 2005/01/23
    bluzkat
    bluzkat Inactive
    The only process I have running for TruImage is "TruImageMonitor.exe" and it is very small (724K). The Acronis Scheduler is running also but I believe that is from a different application. You wouldn't need 'Acronis scheduler' running if you didn't set the app to run at a specific time. I don't believe I need to have TruImageMonitor running either (since I do everything manually), but I didn't bother with it since it relatively small.
    Have you checked for spyware and adware? Apparent slowdown for no apparent reason is a warning sign (check for viruses and trojans also).
    I ran across your other post (in the XP forum) and added a note to that. I've got to go out for a couple hours (and 'play in the snow' :eek: ) I'll check back later.
    B :cool:
