MP42 decompressor not found
Discussion in 'Windows XP' started by larsonjean, 2003/05/11.
  1. 2003/05/11
    larsonjean
    larsonjean Well-Known Member Thread Starter
    I sent a friend of mine an 'avi' movie. She said that she couldn't open it.
    She said the movie took forever to load and then said "unable to read video; MP42 decompressor not found. But the audio of a baby crying/screaming came through.
    Where can she get the information to put on her computer so she can open this file.
    Thank you for your help.
    Jean
  2. 2003/05/11
    Abraxas
    Abraxas Inactive
    larsonjean
    Hi Abraxas,
    I did try to follow the links you sent. Two of them did not work and the one I did download didn't make a difference. Windows media player still won't open it. Do you have any other ideas?
    Jean
  5. 2003/05/15
    Abraxas
    Abraxas Inactive
    A codec that has solved a lot of peoples' problems with avi's is ffDShow.
    If this doesn't solve your immediate problem, maybe it will solve a future one.
    http://osdn.dl.sourceforge.net/sourceforge/ffdshow/ffdshow-20030424.exe
    The Microsoft codec pack is here, and includes support for mp42:
    http://download.microsoft.com/download/a/0/3/a0398036-25b9-410c-b371-c59957c1b0f4/WM9Codecs.exe
    So this avi file plays OK on your machine but not on your friend's? Have you installed any additional codecs other than the ones that come with XP?
    You could also compare your list of installed codecs with the ones on the other computer. I have 2 that mention mpeg4 specifically: MS mpeg4 and the XVid mpeg4 codec ( http://www.moviecodec.com/download/xvid112502.exe ).
    Use GSpot to find out both what specific codec the movie uses and whether it is installed on a particular machine:
    http://www.headbands.com/gspot/gspot22.zip
  6. 2003/05/18
    larsonjean
    Hi Abraxas,
    I was able to get the avi movie to play on my friend's machine. She was trying to get it playing while in AOL. Once we downloaded it to her desktop, we had no problem.
    Her computer and my big computer both are running Windows XP so we were able to open the avi file. We have not added any other codecs to our machines. We don't even know what they are.
    BUT, now I'm trying to get it to open on my older LAPTOP which runs Windows 98 SE. So far I have been unsuccessful. Maybe I should give up but I just want to know why it won't play.
    I did try the sites you sent:
    http://osdn.dl.sourceforge.net/sour...ow-20030424.exe
    http://download.microsoft.com/downl...4/WM9Codecs.exe
    but neither of them worked.
    I didn't compare the list of installed codes from my XP computer to my laptop because I don't know where to go to do this as you suggested.
    I did download GSpot to find out the specific codec the movie uses but I'm sorry, I'm new at this and it makes no sense to me.
    Here's some information that the GSpot shows:
    Video Format - Codec
    (4cc)mp42 (Name) S-Mpeg 4 version 2
    (Stat) Codec NOT installed
    Audio Format
    Codec Name: 0x0055(MP3) ID'd as MPEG-1 Layer 3
    (Stat) Codec is installed
    In my opinion it looks like (S-Mpeg 4 version 2) is not installed but where do I go to get it.
    Thanks for all your patience and help.
    Jean
  7. 2003/05/18
    mr_choco
    mr_choco Inactive
    Try www.divx.com
    Its a avi player but when you install it it has the option to just install the codecs. I used to get the same no visual but sound problem but since installing the divx codecs i have never had a problem with avi movies.
  8. 2003/05/18
    larsonjean
    Hi,
    I did go to the www.divx.com site and it looks like I have to pay for it. Is there a free version somewhere? I don't want to pay for it to play this one AVI file.
    Thanks,
    Jean
  9. 2003/05/18
    larsonjean
    Sorry, I found the free player. I will download it and see what happens.
    Jean
  10. 2003/05/18
    Abraxas
    Abraxas Inactive
    The Mpeg4 codec is included in the download for WMP9 codecs I posted above. The links worked fine for me. What happened when you tried them? The download should start immediately.
  11. 2003/05/19
    BruceKrymow
    BruceKrymow Inactive
    Hi, Jean ~
    (That makes me feel clean!) :p
    You don't need to pay for anything. Here is the direct download for DivX® Video 5.0.5 for Windows. It has the all the codecs you need and will incorporate itself directly into your current Windows Media Player. Do NOT use the DivX player that comes with it. During installation, you may be presented w/ the option to install the player --> choose the option to not install it. The codecs will be properly used by your existing Windows Media Player.
  12. 2003/05/19
    larsonjean
    BruceKrymow
    I did download just the codecs and not the player. Now I have in my program files a folder saying DivX Pro Codec with the following options, Decoder Configuration, DivX Help, EKG, Read Me. How do I get these codecs to install on my computer?
    Jean
  13. 2003/05/19
    mr_choco
    mr_choco Inactive
    They are installed.
  14. 2003/05/19
    BruceKrymow
    Hi, Jean ~
    What Choco said! :D
    If you ran the set up from your desktop, they are installed automatically. Ferthehelluvit, reboot and then open the AVI w/ WMP and you should be in business. :cool:
  15. 2003/05/19
    larsonjean
    Hi Everyone,
    I give up. This movie will just not play on my laptop running Windows 98. I think something must be wrong with my laptop. Let's forgot the whole thing, it isn't worth the bother.
    When I did try to open the movie, I again received an error message saying: Windows Media Player cannot play the file. The file is either corrupt or the Player does not support the format you are trying to play.
    This is the same message I have received every time. And it can't be corrupt as the file is playing on all the other computers.
    Thanks for all the excellent help. Forget the whole thing, it isn't worth the trouble.
    Jean
  16. 2003/05/19
    BruceKrymow
    Hi, Jean ~
    I refuse to give up!:eek:
    Media Player > Help > About
    What version of WMP do you have??
  17. 2003/05/20
    larsonjean
    OK, we'll try again. I have Windows Media Player Version 9.00.00.2980.
    I also have WinAmp and Real Player installed on this laptop.
    Jean
  18. 2003/05/20
    BruceKrymow
    Hi, Jean ~
    You or your friend :confused:
    You can't play it with WMP9 & w/ the d/l DivX??
  19. 2003/05/21
    larsonjean
    My friend's computer plays it fine now.
    It is my laptop computer that the video won't play. I have tried everything that was suggested in the previous postings.
    My laptop has only 64 mb RAM. Could this me the problem.
    I think now I am having problems with the WMP. I tried to play another avi file and it won't play either. Maybe I should uninstall the Windows Media Player and start all over again. What do you think.
    Jean
  20. 2003/05/21
    BruceKrymow
    larsonjean
    Thanks for sending the sites, Bruce. I looked them over and decided to forget about playing this video on my Win 98 machine. At least we now know why this couldn't be and we will let it rest there.
    Thanks again for everyone's help.
    Jean
