Mozilla 1.6 passwords problem
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by FireDancer, 2004/08/30.
  1. 2004/08/30
    FireDancer Lifetime Subscription
    FireDancer Inactive Thread Starter
    Hi all,
    I am running Mozy 1.6, WIN98 SE and have been for a long while but have recently run into a small yet irritating problem. For the longest time I have had Mozy save my passwords to a few select sites I use, WindowsBBS being one of them only due to the fact and I hate to admit it but I am lazy when it come to entering this info :D .
    It seems that Mozy doesnt want to even ask me if I want to remember my password for WindowsBBS and it is getting quite annoying as I am actually haveing to type LOL ;) anyways I have gone into EDIT~PREFERANCES~SECURITY~PASSWORDS and looked around to see if there was somwhere I could insert my info and save it but that option does not seem available.
    Is there a way to get my good friend Mozy to ask me once again if I want to save my password here at WindowsBBS. The only thing I can possibly think that might of happened is that It asked at one time and I told it NO or NEVER for this site! :(
    Very Best Regards,
    ~FIREDANCER~
  2. 2004/08/30
    Ramona
    Ramona Geek Member Alumni
    Hi Firedancer,
    Exit Windows BBS, and clear the Cache for good measure. Open the Password Manager, and delete the password for Windows BBS. When you next access Windows BBS, you should get the Password Manager dialog asking to save the Password.
    Let us know if you continue to have this annoyance.
    Ramona
    Hello Ramona
    Allthough I love conversing you I am having to type way to much tonight LOL J/K anyways I did as you suggested and still no luck!!!! :(
    ~FIREDANCER~
  5. 2004/08/30
    Ramona
    Firedancer,
    Do the other sites for which you have passwords work without problems? I'm assuming that this is the only site, right?
    Have you tried logging off WindowsBBS, which will delete your cookie for the site. Clear the Cache, then log back on and see if Password Manager asks to save.
    If not, the password file (somenumber.s) might be corrupt. If so, your only alternative would be to rename the file, and let Mozilla rebuild the file. You can then open Mozilla to WindowsBBS, and when asked for your password, you should get the dialog asking to save. You will lose all passwords if you do this, and will have to re-enter for all the other sites.
    Ramona
  6. 2004/08/30
    Hi Ramona,
    Yes, that is correct
    Yes, and it does not ask to save at any time
    This file does not exsist on my machine, I searched using START~FIND~FILES/FOLDERS as well as going through all folders in C:\Program Files\mozilla.org\Mozilla and could not locate it to rename.
    Not sure what to try now :rolleyes: tee hee but anyways thanks so much for your help it is always appreciated if you have any more ideas I am open to suggestions. I am gonna go to Mozy site and see if i can search out this problem and any possible remmodies :) will post back if I find any.
    Regards,
    ~FIREDANCER~ ;)
  7. 2004/08/31
    Ramona
    FireDancer,
    I believe you took me literally on the file name. By somenumber.s, e.g., the file name would be 12345678.s, or 35478913.s, etc. Just "some numbers" with an "s" extension. The file is located (depending on your OS) in the *.slt (salted) folder. See: Profiles Location for your OS.
    Ramona
  8. 2004/08/31
    Ramona,
    Goodmorning to you...
    I did infact take you literally and I appologise :D. I did find the file you were speaking of and am not sure how to rename it. Can you instruct me on that?
    ~FIREDANCER~ :p
  9. 2004/08/31
    Westside
    Westside Inactive Alumni
    Right click on the icon, and select Rename
    Call it any name you want, but leaving the extention. Like stinker1234...s
    It should be rebuilt after exiting Explorer.
  10. 2004/08/31
    Thanks, I guess I wasnt clear.. I do infact know how to rename a file but was curious if it had to have certain name before or after the extention.
    The file has a name of Old12345.s and I see a new file was rebuilt but it still does not ask me to save a P word at windowsbbs even now it is working for other sites though :( Can I just delete the old file ?
    ~FIREDANCER~ :mad:
  11. 2004/08/31
    Ramona
    FireDancer,
    Sure, you can delete the old file. Can't figure out what is going on though, as rebuilding the file should have done the job.
    Try again deleting the WindowsBBS password.
    Open the Cookie Manager, Tools | Cookie Manager
    Remove all WindowsBBS cookies
    Check the list of Cookie Sites to ensure that WindowsBBS has not inadvertently been added to the list of sites not allowed. Log out of the site, log back in...
    Ramona
  12. 2004/08/31
    Ramona,
    All I can say is..................UGGGHHHHHH! :(
    ~FIREDANCER~
  13. 2004/09/01
    Hello
    Just wanted to drop aline to say thanks to all that helped. After renaming the old file and it still not working I deleted it and guess what?????? It works now!!!!! :D Thanks so much again
    ~FIREDANCER~ ;)
  14. 2004/09/01
    Ramona
    FireDancer,
    Good news indeed, as I was stumped on why it wasn't working for you. Deleting the old file shouldn't have made one whit of difference, but since it did, good going!
    Ramona
