Resolved Mouse issues
Discussion in 'PC Hardware' started by elcajongunsfan, 2013/12/01.
  1. 2013/12/01
    elcajongunsfan Lifetime Subscriber
    elcajongunsfan Well-Known Member Thread Starter
    mouse was acting weird this morning... Browser text was highlighting as I moved the mouse up and down. So I went into device properties and this is what i see
    http://img843.imageshack.us/img843/4088/3ce4.jpg
    How do I stop the mouse from conflicting with mobo?
    I've never seen this before
  2. 2013/12/01
    Hi elcajongunsfan. Try uninstalling the mouse from Device Manager, reboot the computer and then allow Windows to reinstall the device.
    If that does not work then try plugging the mouse into an available USB port and see if that helps.
    You're saying stop using PS/2 and use USB only?
    Regards
  5. 2013/12/01
    There is an IRQ conflict going on with the mouse so see if uninstalling the mouse through Device Manager solves the problem. If not then yes use a USB port for the mouse and see if that resolves the conflict.
  6. 2013/12/02
    I looked at all my other computers and they also use Interrupt 12. I'll have to live with this for awhile because the mouse is a PS/2. Maybe go down and buy a USB mouse
  7. 2013/12/02
    SpywareDr
  8. 2013/12/02
    Don't matter what all your other computers are doing. They don't have a problem. Did you try uninstalling the mouse like Evan suggested?
  9. 2013/12/02
    Yes I did and it reported a successful install.But, the device properties still reports the conflict
    Regards
  10. 2013/12/02
    What OS are you operating?
    I would suggest running sfc /scannow to see if that will help. Neil.
  11. 2013/12/03
    Win 7 Ultimate 32 bit and I do not have an install disk for this
  12. 2013/12/03
    In my experience with 7 x64 Pro you don't need one.
  13. 2013/12/03
    SpywareDr
  14. 2013/12/05
    SFC passed..Thanks for suggestion
  15. 2013/12/05
    Time to try a USB mouse?
  16. 2013/12/05
    Clearly ;{D.. I'll report back this weekend on the results!!
  17. 2013/12/06
    Keep us posted on the outcome.
  18. 2013/12/06
    Yup..I installed a USB Microsoft Mouse and IRQ 12 disappeared. So I have to assume the PS/2 was conflicting with the motherboard resources
    Interesting issue--thanks to all who participated
  19. 2013/12/06
    Reboot the machine. Take out the USB Mouse and then put the other one back in. Then see what happens. May or may not have to reboot.
  20. 2013/12/07
    Well that's great that you were able to resolve the problem. :)
  21. 2013/12/07
    FWIW you should not detach/attach PS/2 with the PC booted up.
