Monitoring individual proceses
Discussion in 'Legacy Windows' started by rlambert7, 2003/09/25.
  1. 2003/09/25
    rlambert7
    rlambert7 Inactive Thread Starter
    My PC is running Me, and runs VERY slow. I installed the System Monitor, and have discovered that the processor is always at 100% . Is there any other tool in Windows (or for Windows) that will indicate WHICH processes are consuming the system resources?
    Thank you.
  2. 2003/09/25
    brett
    brett Inactive Alumni
    Wintop (tho' aimed at Win95 it'll run perfectly well under ME).
    HTH.
    rlambert7
    Thanks, I'll certainly check that out. I just had found a monitoring tool called "Process Explorer" from Sysinternals. I downloaded that, and ran it. It didn't indicate to me anything unusual CPU usage-wise, so I'm wondering if the System Monitor tool's indication of 100% is bogus.
    I also noticed that the System Monitor was showing a lot of page faults, so I guess I'lll have to investigate that. Do you know of any monitoring tool that will display the page faulting of individual processes?
  5. 2003/09/26
    brett
    ‘Fraid not. Maybe run Wintop and see whether that mirrors Process Explorer’s results. Some system specs could help too.
