Monitor screen blacking out
Discussion in 'PC Hardware' started by stinkingdog101, 2008/06/07.
  1. 2008/06/07
    stinkingdog101
    stinkingdog101 Inactive Thread Starter
    I have a Dell Inspiron Laptop 1000 running windows Xp. With Celeron 2.2 Ghz
    My problem is the screen goes black after no particular time. I can still communicate on IM so I know the computer is still actually running. The only way I can seem to get it to come back on is shutting off the computer and rebooting. While this is erradict it is very annoying. Any ideas ?
  2. 2008/06/07
    At a guess I would say a hardware problem rather than a software problem - build up of heat - not necessarily a lot, causing the graphics chip to duck out or a connection somewhere between mobo and screen. May even be the backlight failing.
    Regardless you should reinstall the graphics drivers - get them from Dell website - and see if that cures the problem.
    Also, try monitor on another computer.
  5. 2008/06/08
    Oops :)
  6. 2008/06/08
    Oooops...LOL
  7. 2008/06/08
    mflynn
    mflynn Inactive
    But you could attach it to an external VGA monitor to see if issue still exists.
    Mike
  8. 2008/06/08
    mflynn
    mflynn Inactive
    Additionally I would reset the display by removing all Wallpapers Backgrounds and screen savers even change the resolution to a higher or lower save it then set the resoloutions back to what you want.
    As generic as possible.
    Power Mnagement is very important to a laptop!
    But turn off Power management, reboot and turn back on and recheck settings.
    Mike
