monitor led on, no display
Discussion in 'PC Hardware' started by marty, 2004/12/22.
  1. 2004/12/22
    marty
    marty Inactive Thread Starter
    Normally I chuck monitors that don't work so have never learned anything about repairing them. In this case though I've got a Dell D1028L, 17" and the power led comes on but no other indication of it working. Since I'd rather have this 17" running than the 15" replacing it on that box, wonder if there are some things I can look at before putting out with the trash.
    Marty
  2. 2004/12/23
    Hi Marty,
    Have you tried it on another computer? It may not be getting a signal from the Graphics card. If it won't start on another computer it has probably had it.
    Suggestion?: If you could get a quote for repairs and compare that to the "going rate" on Ebay, you might make a little for yourself or even consider making it a present to a friend or relative that is using a 15 ", I'm sure it would be appreciated. Of course, it depends on the quote for repairs.
    marty
    Thanks Matt, but I'm interested in either doing the repair myself if possible or chucking it. And the computer that it stopped working with works fine with another monitor, so the fault must be in the monitor, yes?
    Marty
  5. 2004/12/23
    sparrow
    sparrow Inactive
    marty,
    There's enough high voltage in a crt monitor to electrocute you if you don't know what you're doing. Wouldn't suggest you try a repair yourself, from what you say.
  6. 2004/12/23
    marty
    Even when it's been unplugged for a month or more?
  7. 2004/12/23
    sparrow
    sparrow Inactive
    I don't know, but you need to know what capacitors to discharge and how to do it safely.
  8. 2004/12/23
    marty
    What's a capicitor look like? Like this thing here?
    { bzzzt, zorp, glack, thrump }
    My hair's curly enough, you've convinced me. In the trash it goes.
    Marty
  9. 2004/12/23
    sparrow
    sparrow Inactive
    My sediment exactly. :D
