Monitor changed color
Discussion in 'Legacy Windows' started by ladyLuck, 2003/08/09.
  1. 2003/08/09
    ladyLuck
    ladyLuck Inactive Thread Starter
    I don't know what key I hit but while I was typing I slipped and instantly my monitor changed colors. It is pink. I went to the control panel/ display to make the changes. I can change the colors of the text but what do I do to change the main body. In other words while I'm typing in the message area, it's pink, not the usual white. Also the icons on my task bar are a different color. How do I fix this mess?
    Someone please help:confused: :confused:
  2. 2003/08/09
    merlin
    merlin Inactive
    Can you restore your registry ?
    regards
    noahdfear
    noahdfear Inactive
    Right click on an open area of the desktop>properties>appearance tab.......select a scheme and apply. You can also select the items in the list and choose a color/font for each and save as any scheme you like. Hope it's as simple a problem as this! :p
  5. 2003/08/09
    ladyLuck
    Merlin I have never done anything with the registry. Can you give instructions?
    Noah I have gone there but I'm don't understand some of the choices. I have been able to change colors on some of the "items ". I can't figure out which one would make the change in the color of this message area.
  6. 2003/08/09
    ladyLuck
    About the Monitor
    Just wanted to let you know . While trying to move a folder the screen went from pink to green and then back to normal. Thanks all for the help.
    Now I'm only half crazy:)
  7. 2003/08/09
    noahdfear
    noahdfear Inactive
    That would be 'window' :)
    P.S. Didn't mean to put a smilie sticking out it's tounge on previous post. Wasn't paying attention and thought it was regular smilie as in this one. Sorry!
