mobo advice for spare parts pc
Discussion in 'PC Hardware' started by snow, 2004/01/05.
  1. 2004/01/05
    snow
    snow Inactive Thread Starter
    Hello all,
    My youngest is using an old yard-sale Acer pc and needs something better. I have tons of spare parts from my own upgrades, and would like to use them on this project. My question is... what (cheap) mobo will work with what I have on hand?
    Acer box (has v55la-2 mobo that I want to toss)
    Celeron 433 370 pin fc-pga
    128mb Micron 168 pin sdram
    6.4g ide hard drive, cdrom.......
    I'd love to find a board that has audio and video integrated, and that would fit in the old Acer box...
    Any thoughts?
    snow,
  2. 2004/01/11
    iceolated
    iceolated Inactive
    Hi Snow,
    If this is your motherboard then you are probably looking at a new case with an ATX power supply.
    This Acer v55la-2 motherboard looks as though it has an AT power connector on it and from what I see in the diagram this motherboard has a proprietary layout (as many of the early Acer, Packard Bells etc did), so a standard AT board wouldn't fit in that case.
    Secondly, any board you get for that celeron 433 is almost certainely an ATX board. So even if a new Socket 370 motherboard did fit, your old power supply won't work.
    So you'll need a case with an ATX power supply to support your new ATX Socket 370 motherboard.
    None of the places I usually shop at seem to stock Socket 370 boards any more except Computer Geeks.
    Best of luck,
    ICE
    snow
    Thanks for the reply. After hours of surfing, I had pretty much figured out that I was going to have to shop for another box/board. An extra thanks for the link! As you said, there aren't many places to find the older boards and I hadn't heard of the one you listed. Hopefully this 'junk' pc will be up and running soon!
    Thanks again :)
    snow,
