mini dmp help
Discussion in 'Windows XP' started by keithsince59, 2007/03/10.
  1. 2007/03/10
    keithsince59
    keithsince59 Inactive Thread Starter
    Opened log file 'c:\debuglog.txt'
    Microsoft (R) Windows Debugger Version 6.6.0007.5
    Loading Dump File [C:\WINDOWS\Minidump\Mini030807-01.dmp]
    Executable search path is: C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\system32\drivers
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Product: WinNt
    Built by: 2600.xpsp_sp2_rtm.040803-2158
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055ab20
    Debug session time: Thu Mar 8 17:12:01.004 2007 (GMT+0)
    System Uptime: 0 days 2:07:10.491
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck A, {fffff994, ff, 1, 804dc186}
    Probably caused by : ntoskrnl.exe ( nt!KiRetireDpcList+53 )
    Followup: MachineOwner
    kd> !analyze -v;r;kv;lmtn;.logclose;q
    IRQL_NOT_LESS_OR_EQUAL (a)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If a kernel debugger is available get the stack backtrace.
    Arguments:
    Arg1: fffff994, memory referenced
    Arg2: 000000ff, IRQL
    Arg3: 00000001, value 0 = read operation, 1 = write operation
    Arg4: 804dc186, address which referenced memory
    Debugging Details:
    WRITE_ADDRESS: fffff994
    CURRENT_IRQL: ff
    FAULTING_IP:
    804dc186 c7839409000000000000 mov dword ptr [ebx+994h],0
    CUSTOMER_CRASH_COUNT: 1
    BUGCHECK_STR: 0xA
    TRAP_FRAME: f9e4cf74 -- (.trap fffffffff9e4cf74)
    ErrCode = 00000002
    eax=00000000 ebx=fffff000 ecx=00000002 edx=e2bee3ef esi=00000011 edi=c4209730
    eip=804dc186 esp=f9e4cfe8 ebp=ffdff980 iopl=0 nv up di pl zr na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010046
    nt!KiRetireDpcList+0x53:
    804dc186 c7839409000000000000 mov dword ptr [ebx+994h],0 ds:0023:fffff994=????????
    .trap
    Resetting default scope
    LAST_CONTROL_TRANSFER: from 804dc186 to 804e2158
    STACK_TEXT:
    f9e4cf74 804dc186 badb0d00 e2bee3ef f96287e9 nt!KiTrap0E+0x233
    f9e4cff4 804dbe2d f3fc62f4 00000000 00000000 nt!KiRetireDpcList+0x53
    f9e4cff8 f3fc62f4 00000000 00000000 00000000 nt!KiDispatchInterrupt+0x2a
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    f9e4cffc 00000000 00000000 00000000 00000000 0xf3fc62f4
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    SYMBOL_STACK_INDEX: 1
    SYMBOL_NAME: nt!KiRetireDpcList+53
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: nt
    IMAGE_NAME: ntoskrnl.exe
    DEBUG_FLR_IMAGE_TIMESTAMP: 41108004
    FAILURE_BUCKET_ID: 0xA_W_nt!KiRetireDpcList+53
    eax=ffdff13c ebx=000000ff ecx=00000000 edx=e2bee3ef esi=804dc186 edi=fffff994
    eip=804e2158 esp=f9e4cf5c ebp=f9e4cf74 iopl=0 nv up ei ng nz na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000286
    nt!KiTrap0E+0x233:
    804e2158 f7457000000200 test dword ptr [ebp+70h],20000h ss:0010:f9e4cfe4=00010046
    f9e4cf74 804dc186 badb0d00 e2bee3ef f96287e9 nt!KiTrap0E+0x233 (FPO: [0,0] TrapFrame @ f9e4cf74)
    f9e4cff4 804dbe2d f3fc62f4 00000000 00000000 nt!KiRetireDpcList+0x53 (FPO: [0,0,0])
    f9e4cff8 f3fc62f4 00000000 00000000 00000000 nt!KiDispatchInterrupt+0x2a (FPO: [Uses EBP] [0,0,1])
    start end module name
    804d7000 806eb780 nt ntoskrnl.exe Wed Aug 04 07:19:48 2004 (41108004)
    806ec000 806ffd80 hal halacpi.dll Wed Aug 04 06:59:04 2004 (41107B28)
    bf000000 bf011580 dxg dxg.sys Wed Aug 04 07:00:51 2004 (41107B93)
    bf012000 bf425a80 nv4_disp nv4_disp.dll Wed Aug 04 08:57:11 2004 (411096D7)
    bf800000 bf9c0380 win32k win32k.sys Wed Aug 04 07:17:30 2004 (41107F7A)
    f4277000 f42a0f00 kmixer kmixer.sys Wed Aug 04 07:07:46 2004 (41107D32)
    f42c4000 f42d8400 wdmaud wdmaud.sys Wed Aug 04 07:15:03 2004 (41107EE7)
    f4ddf000 f4dedd80 sysaudio sysaudio.sys Wed Aug 04 07:15:54 2004 (41107F1A)
    f526f000 f52af380 HTTP HTTP.sys Wed Aug 04 07:00:09 2004 (41107B69)
    f548d000 f54ef000 SPBBCDrv SPBBCDrv.sys Fri Nov 04 03:37:18 2005 (436AD76E)
    f5517000 f5528f20 NAVENG NAVENG.Sys Tue Jan 23 01:05:17 2007 (45B55F4D)
    f5529000 f55f7740 NavEx15 NavEx15.Sys Tue Jan 23 01:39:38 2007 (45B5675A)
    f5620000 f5678000 SAVRT SAVRT.SYS Fri Aug 26 22:11:23 2005 (430F857B)
    f5a38000 f5a8a180 srv srv.sys Wed Aug 04 07:14:44 2004 (41107ED4)
    f5b53000 f5b76000 Fastfat Fastfat.SYS Wed Aug 04 07:14:15 2004 (41107EB7)
    f5b9e000 f5bca400 mrxdav mrxdav.sys Wed Aug 04 07:00:49 2004 (41107B91)
    f6018000 f601b280 ndisuio ndisuio.sys Wed Aug 04 07:03:10 2004 (41107C1E)
    f6030000 f6047480 dump_atapi dump_atapi.sys Wed Aug 04 06:59:41 2004 (41107B4D)
    f6048000 f6065000 EraserUtilRebootDrv EraserUtilRebootDrv.sys Thu Feb 01 00:54:39 2007 (45C13A4F)
    f6065000 f60c6000 eeCtrl eeCtrl.sys Thu Feb 01 00:54:39 2007 (45C13A4F)
    f60c6000 f6134380 mrxsmb mrxsmb.sys Wed Aug 04 07:15:14 2004 (41107EF2)
    f6135000 f6160180 rdbss rdbss.sys Wed Aug 04 07:20:05 2004 (41108015)
    f6161000 f6175000 SAVRTPEL SAVRTPEL.SYS Fri Aug 26 22:11:25 2005 (430F857D)
    f6215000 f627d000 LVCodek2 LVCodek2.dll Tue Nov 13 23:39:50 2001 (3BF1AF46)
    f627d000 f6290000 LVCam2 LVCam2.dll Tue Nov 13 23:40:30 2001 (3BF1AF6E)
    f6290000 f62b1d00 afd afd.sys Wed Aug 04 07:14:13 2004 (41107EB5)
    f62b2000 f62d9c00 netbt netbt.sys Wed Aug 04 07:14:36 2004 (41107ECC)
    f62da000 f630b000 symidsco symidsco.sys Fri Jan 12 23:29:35 2007 (45A819DF)
    f630b000 f6334000 SYMFW SYMFW.SYS Tue Feb 13 01:10:09 2007 (45D10FF1)
    f635c000 f637f000 SYMEVENT SYMEVENT.SYS Sat Dec 16 00:30:34 2006 (45833E2A)
    f637f000 f639ff00 ipnat ipnat.sys Wed Aug 04 07:04:48 2004 (41107C80)
    f63a0000 f63db000 SYMTDI SYMTDI.SYS Tue Feb 13 01:10:06 2007 (45D10FEE)
    f63db000 f6432a80 tcpip tcpip.sys Wed Aug 04 07:14:39 2004 (41107ECF)
    f6433000 f6445400 ipsec ipsec.sys Wed Aug 04 07:14:27 2004 (41107EC3)
    f9482000 f9484900 Dxapi Dxapi.sys Fri Aug 17 21:53:19 2001 (3B7D843F)
    f948e000 f94c1200 update update.sys Wed Aug 04 06:58:32 2004 (41107B08)
    f9562000 f9572e00 psched psched.sys Wed Aug 04 07:04:16 2004 (41107C60)
    f9573000 f9589680 ndiswan ndiswan.sys Wed Aug 04 07:14:30 2004 (41107EC6)
    f958a000 f959d900 parport parport.sys Wed Aug 04 06:59:04 2004 (41107B28)
    f959e000 f95e3500 emu10k1m emu10k1m.sys Sat Aug 04 03:36:34 2001 (3B6B5FB2)
    f95e4000 f9607980 portcls portcls.sys Wed Aug 04 07:15:47 2004 (41107F13)
    f9608000 f961ca00 ac97via ac97via.sys Sun Jun 30 04:28:30 2002 (3D1E7ADE)
    f961d000 f963fe80 USBPORT USBPORT.SYS Wed Aug 04 07:08:34 2004 (41107D62)
    f9650000 f9653180 usb8023 usb8023.sys Wed Aug 04 07:04:30 2004 (41107C6E)
    f9668000 f968a680 ks ks.sys Wed Aug 04 07:15:20 2004 (41107EF8)
    f968b000 f969e780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 07:07:04 2004 (41107D08)
    f969f000 f986e3c0 nv4_mini nv4_mini.sys Thu Apr 08 03:30:48 2004 (4074B958)
    f988f000 f98a9580 Mup Mup.sys Wed Aug 04 07:15:20 2004 (41107EF8)
    f98aa000 f98d6a80 NDIS NDIS.sys Wed Aug 04 07:14:27 2004 (41107EC3)
    f98d7000 f9963480 Ntfs Ntfs.sys Wed Aug 04 07:15:06 2004 (41107EEA)
    f9964000 f997a780 KSecDD KSecDD.sys Wed Aug 04 06:59:45 2004 (41107B51)
    f997b000 f9999780 fltmgr fltmgr.sys Wed Aug 04 07:01:17 2004 (41107BAD)
    f999a000 f99b1480 atapi atapi.sys Wed Aug 04 06:59:41 2004 (41107B4D)
    f99b2000 f99d0880 ftdisk ftdisk.sys Fri Aug 17 21:52:41 2001 (3B7D8419)
    f99d1000 f99e1a80 pci pci.sys Wed Aug 04 07:07:45 2004 (41107D31)
    f99e2000 f9a0fd80 ACPI ACPI.sys Wed Aug 04 07:07:35 2004 (41107D27)
    f9a31000 f9a39c00 isapnp isapnp.sys Fri Aug 17 21:58:01 2001 (3B7D8559)
    f9a41000 f9a4b500 MountMgr MountMgr.sys Wed Aug 04 06:58:29 2004 (41107B05)
    f9a51000 f9a5dc80 VolSnap VolSnap.sys Wed Aug 04 07:00:14 2004 (41107B6E)
    f9a61000 f9a69e00 disk disk.sys Wed Aug 04 06:59:53 2004 (41107B59)
    f9a71000 f9a7d200 CLASSPNP CLASSPNP.SYS Wed Aug 04 07:14:26 2004 (41107EC2)
    f9a81000 f9a8b500 viaagp viaagp.sys Wed Aug 04 07:07:42 2004 (41107D2E)
    f9ab1000 f9abb600 p3 p3.sys Wed Aug 04 06:59:18 2004 (41107B36)
    f9ac1000 f9acd180 cdrom cdrom.sys Wed Aug 04 06:59:52 2004 (41107B58)
    f9ad1000 f9adf080 redbook redbook.sys Wed Aug 04 06:59:34 2004 (41107B46)
    f9ae1000 f9aeb380 imapi imapi.sys Wed Aug 04 07:00:12 2004 (41107B6C)
    f9af1000 f9affb80 drmk drmk.sys Wed Aug 04 07:07:54 2004 (41107D3A)
    f9b01000 f9b09e80 sfmanm sfmanm.sys Sat Aug 04 03:36:35 2001 (3B6B5FB3)
    f9b11000 f9b20d80 serial serial.sys Wed Aug 04 07:15:51 2004 (41107F17)
    f9b21000 f9b2de00 i8042prt i8042prt.sys Wed Aug 04 07:14:36 2004 (41107ECC)
    f9b31000 f9b3d880 rasl2tp rasl2tp.sys Wed Aug 04 07:14:21 2004 (41107EBD)
    f9b41000 f9b4b200 raspppoe raspppoe.sys Wed Aug 04 07:05:06 2004 (41107C92)
    f9b51000 f9b5cd00 raspptp raspptp.sys Wed Aug 04 07:14:26 2004 (41107EC2)
    f9b61000 f9b69900 msgpc msgpc.sys Wed Aug 04 07:04:11 2004 (41107C5B)
    f9b71000 f9b7af00 termdd termdd.sys Wed Aug 04 06:58:52 2004 (41107B1C)
    f9b81000 f9b8a480 NDProxy NDProxy.SYS Fri Aug 17 21:55:30 2001 (3B7D84C2)
    f9b91000 f9b9f100 usbhub usbhub.sys Wed Aug 04 07:08:40 2004 (41107D68)
    f9bb1000 f9bb9700 wanarp wanarp.sys Wed Aug 04 07:04:57 2004 (41107C89)
    f9bc1000 f9bcb000 SYMREDRV SYMREDRV.SYS Tue Feb 13 01:10:10 2007 (45D10FF2)
    f9bd1000 f9bdc000 SYMNDIS SYMNDIS.SYS Tue Feb 13 01:10:08 2007 (45D10FF0)
    f9be1000 f9bed000 SYMIDS SYMIDS.SYS Tue Feb 13 01:10:10 2007 (45D10FF2)
    f9c01000 f9c0d000 LVCD LVCD.sys Tue Nov 13 23:41:39 2001 (3BF1AFB3)
    f9c11000 f9c1ce00 STREAM STREAM.SYS Wed Aug 04 07:07:58 2004 (41107D3E)
    f9c21000 f9c29700 netbios netbios.sys Wed Aug 04 07:03:19 2004 (41107C27)
    f9c31000 f9c39880 Fips Fips.SYS Sat Aug 18 02:31:49 2001 (3B7DC585)
    f9c51000 f9c60900 Cdfs Cdfs.SYS Wed Aug 04 07:14:09 2004 (41107EB1)
    f9cb1000 f9cb7200 PCIIDEX PCIIDEX.SYS Wed Aug 04 06:59:40 2004 (41107B4C)
    f9cb9000 f9cbd900 PartMgr PartMgr.sys Sat Aug 18 02:32:23 2001 (3B7DC5A7)
    f9cd9000 f9cdd500 watchdog watchdog.sys Wed Aug 04 07:07:32 2004 (41107D24)
    f9ce9000 f9cee000 usbuhci usbuhci.sys Wed Aug 04 07:08:34 2004 (41107D62)
    f9d09000 f9d10000 fdc fdc.sys unavailable (00000000)
    f9d19000 f9d1ea00 mouclass mouclass.sys Wed Aug 04 06:58:32 2004 (41107B08)
    f9d21000 f9d27000 kbdclass kbdclass.sys Wed Aug 04 06:58:32 2004 (41107B08)
    f9d41000 f9d45880 TDI TDI.SYS Wed Aug 04 07:07:47 2004 (41107D33)
    f9d51000 f9d55580 ptilink ptilink.sys Fri Aug 17 21:49:53 2001 (3B7D8371)
    f9d61000 f9d65080 raspti raspti.sys Fri Aug 17 21:55:32 2001 (3B7D84C4)
    f9d71000 f9d76000 flpydisk flpydisk.sys Wed Aug 04 06:59:24 2004 (41107B3C)
    f9d89000 f9d8e200 vga vga.sys Wed Aug 04 07:07:06 2004 (41107D0A)
    f9d99000 f9d9e000 Msfs Msfs.SYS unavailable (00000000)
    f9da9000 f9db0880 Npfs Npfs.SYS Wed Aug 04 07:00:38 2004 (41107B86)
    f9dd1000 f9dd8580 RNDISMP RNDISMP.SYS Wed Aug 04 07:04:27 2004 (41107C6B)
    f9dd9000 f9de0000 SYMDNS SYMDNS.SYS Tue Feb 13 01:10:07 2007 (45D10FEF)
    f9e41000 f9e44000 BOOTVID BOOTVID.dll Fri Aug 17 21:49:09 2001 (3B7D8345)
    f9eb5000 f9eb7280 rasacd rasacd.sys Fri Aug 17 21:55:39 2001 (3B7D84CB)
    f9ed5000 f9ed7980 gameenum gameenum.sys Wed Aug 04 07:08:20 2004 (41107D54)
    f9edd000 f9ee0c80 serenum serenum.sys Wed Aug 04 06:59:06 2004 (41107B2A)
    f9ee9000 f9eeb580 ndistapi ndistapi.sys Fri Aug 17 21:55:29 2001 (3B7D84C1)
    f9efd000 f9f00c80 mssmbios mssmbios.sys Wed Aug 04 07:07:47 2004 (41107D33)
    f9f31000 f9f32b80 kdcom kdcom.dll Fri Aug 17 21:49:10 2001 (3B7D8346)
    f9f33000 f9f34100 WMILIB WMILIB.SYS Fri Aug 17 22:07:23 2001 (3B7D878B)
    f9f35000 f9f36500 viaide viaide.sys Wed Aug 04 06:59:42 2004 (41107B4E)
    f9f39000 f9f3ab00 ctlfacem ctlfacem.sys Sat Aug 04 03:36:32 2001 (3B6B5FB0)
    f9f3f000 f9f40100 swenum swenum.sys Wed Aug 04 06:58:41 2004 (41107B11)
    f9f49000 f9f4a280 USBD USBD.SYS Fri Aug 17 22:02:58 2001 (3B7D8682)
    f9f4d000 f9f4ef00 Fs_Rec Fs_Rec.SYS Fri Aug 17 21:49:37 2001 (3B7D8361)
    f9f51000 f9f52080 Beep Beep.SYS Fri Aug 17 21:47:33 2001 (3B7D82E5)
    f9f55000 f9f56080 mnmdd mnmdd.SYS Fri Aug 17 21:57:28 2001 (3B7D8538)
    f9f59000 f9f5a080 RDPCDD RDPCDD.sys Fri Aug 17 21:46:56 2001 (3B7D82C0)
    f9f61000 f9f62100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 22:07:23 2001 (3B7D878B)
    f9fc9000 f9fcb000 ParVdm ParVdm.SYS unavailable (00000000)
    f9fd9000 f9fda100 PfModNT PfModNT.sys Thu Dec 16 04:14:08 1999 (38586710)
    fa02a000 fa02ad00 dxgthk dxgthk.sys Fri Aug 17 21:53:12 2001 (3B7D8438)
    fa095000 fa095c00 audstub audstub.sys Fri Aug 17 21:59:40 2001 (3B7D85BC)
    fa0bb000 fa0bc000 Null Null.SYS unavailable (00000000)
    Unloaded modules:
    fa154000 fa155000 drmkaud.sys
    Checksum: 00000000
    f505f000 f506c000 DMusic.sys
    Checksum: 00000000
    f4f2f000 f4f3d000 swmidi.sys
    Checksum: 00000000
    f42a1000 f42c4000 aec.sys
    Checksum: 00000000
    f9f7d000 f9f7f000 splitter.sys
    Checksum: 00000000
    f43b3000 f43dd000 kmixer.sys
    Checksum: 00000000
    f5b13000 f5b22000 sysaudio.sys
    Checksum: 00000000
    f5c6b000 f5c80000 wdmaud.sys
    Checksum: 00000000
    f9fa5000 f9fa7000 MSPCLOCK.sys
    Checksum: 00000000
    f9f9d000 f9f9f000 MSPQM.sys
    Checksum: 00000000
    f9f47000 f9f49000 splitter.sys
    Checksum: 00000000
    Checksum: 00000000
    fa0ad000 fa0ae000 drmkaud.sys
    Checksum: 00000000
    f52d8000 f5302000 kmixer.sys
    Checksum: 00000000
    f61d5000 f61e2000 DMusic.sys
    Checksum: 00000000
    f5302000 f5325000 aec.sys
    Checksum: 00000000
    f541d000 f542b000 swmidi.sys
    Checksum: 00000000
    f9fa3000 f9fa5000 splitter.sys
    Checksum: 00000000
    f9d81000 f9d86000 Cdaudio.SYS
    Checksum: 00000000
    f9f29000 f9f2c000 Sfloppy.SYS
    Checksum: 00000000
    Closing open log file c:\debuglog.txt
  2. 2007/03/12
    mailman Lifetime Subscription
    mailman Geek Member
    Hi, Keith.
    I'm glad you now appear to have the correct symbols installed in your computer. :)
    I searched the Microsoft Knowledge Base (KB) for stop 0x0000000a and got over 200 results.
    Here is a link to one of those results that gives some general troubleshooting information regarding your "Blue Screen of Death" (BSOD) crash.
    It's probably best to access Microsoft Knowledge Base (KB) articles with Internet Explorer. I have found other web browsers (such as Firefox) have trouble rendering Microsoft KB web pages properly.
    In case you decide to test your RAM for errors, all of the following RAM testers have been recommended in this forum. However, opinions differ about which RAM tester is "best ".
    EDIT: Here's another page I found while searching for suggestions for another Windows BBS user.
    mailman Geek Member
