Memtest86: Help Diagnosing [DUMP DATA]
Discussion in 'Windows XP' started by larold, 2006/06/28.
  1. 2006/06/28
    larold
    larold Inactive Thread Starter
    Hello all, I have been having troubles with my computer blue screening and rebooting (stop errors)...at first i believed it to be a driver problem and used windows debugger which pointed to a few drivers....so i checked for new, and even downgraded some to older ones (ati's new drivers for my card were pointed to and seemed to be iffy so i downgraded them to the originals)..a couple days of no blue screens or reboots...i thought i was in the clear...wrong.
    so after the frustration worn off a bit i did some more research and started testing with memtest86 v3.2.....the first time i scanned my two modules (512mb x 2) it flooded my screen with errors and i let it do a lot of passes because at that time i didn't know it ran continuously and it racked up about 400 errors. yeah so now you say "hey it is your ram, are you stupid!?" come on now that was my first thought too, but then i tried testing each module by themselves and guess what? no errors when they are used by themselves...not to mention i tried every possible combination on the board trying to find a bad memory socket...as you would imagine this took forever with no true pinpointed bad module, socket, or anything. Before even running any tests i had ordered a new 1 gb stick from newegg....and of course i wanted to test it just because...it had no errors by its lonesome...so that was good....but then i thought i didn't want to waste my 512 mb sticks by just discarding them both as faulty so i tested the following ways with memtest...
    all three modules: errors showed up...i wasnt surprised.
    the new module(1 gb) and one of the old modules(512mb): no errors
    the new module(1 gb) and the other old module(512mb): no errors
    ....this made me think.... "hmm? "
    I then just tested the two old modules once again...a lot of errors showed up for numerous restarts of the test and what not....
    Now even more frustrating news: today i tried the above testings again...no errors have showed up.....not even with just the two old modules which were giving me the errors in the first place...so what does this mean? I have no idea why no errors are showing up now and why they were in the first place...this doesnt make any sense to me really...you think if one of the 512mb modules was bad it would show up no matter what the combination is but it wasn't....it was only showing up with both of the 512mb modules in...and now with both of the 512mb modules in it isn't showing any errors in memtest86....any ideas? Each dump would point to a driver but i messed with all of the drivers it pointed to and it still occurred (blue screens/reboots)....the system is less than a year old...never had problems before...everything is compatible with each other (hardware is for sure) and i never had any troubles before and have not installed anything out of the ordinary...no virus problems and no spyware/adware problems...i'm running out of ideas!
  2. 2006/06/28
    It's very possible your ram isn't causing the BSOD. But there are a few million other possibilities...
    Introduction to Stop Errors
    "Stop errors in a nutshell are errors that are serious enough to cause Windows to stop. They are similar to the blue screen errors that were present on Windows 9x, however there is no option to try and resume the session in a Windows NT Stop Error (Windows 2000 and all XP members included). "
    Continued:
    http://mvps.org/marksxp/WindowsXP/bsod.php
    Go here to search for the error message:
    http://support.microsoft.com/default.aspx?scid=fh;EN-US;kbhowto&sd=GN&ln=EN-US&FR=0
    larold
    Thanks for the quick reply and links! I will definately look them up. As for my memtest results do you know why it shows errors sometimes and other times it doesn't? I just moved the 512mb modules around and just got flooded with errors on test 6....here is to show how my banks looked for these tests (i took the 1 gb module out because im sure it isnt the cause.) The letters are to distinguish between the two different memory modules.
    -512mb(A)
    -empty
    -512mb(B)
    -empty
    ...no errors...but then i switched them like this below..
    -512mb(B)
    -empty
    -512mb(A)
    -empty
    ...my screen was flooded with 79 errors on test 6 and each said it was 268.2 mb...
    is memtest pulling my leg? or is one of these modules indeed bad?
    i forgot to mention this is dual channel memory....DDR400
  5. 2006/06/28
    larold
    I already used the microsoft memory tool and it came back with no errors. As for them being matched pairs the answer is yes because they were installed by gateway as a built system from their site...and they do support dual channel...they never had a problem before but now i seem to be getting random stop errors and they sometimes show errors in memtest and other times don't show anything..not sure what the problem is...i can't pinpoint it...
  7. 2006/06/28
    Have you checked out Event Viewer for error messages relating to the BSOD's and any other problems??
  8. 2006/06/28
    larold
    Yeah I have...sorry for not explaining some of the issues i saw in the event viewer that apply to this...of the system errors they seems to point to drivers when i debugged the date of the occurrences....system files such as an ati.sys (video card) file and a sr.sys file (system restore) would be faulted...i rolled back my ati drivers and then looked up the sr.sys on google and most say it wouldnt create the blue screens...
    do you think i should try to reinstall windows? some say to but then again memtest testing is not giving me any closure about my ram.
  9. 2006/06/28
    I wouldn't reinstall Windows at this time - there's no guarantee that doing that would fix the problem, especially as it may be hardware related.
    Have you removed the video card - if it's a plug in card and reseated it? I would clean the contacts with a soft pencil eraser.
    If the video is an onboard chip try try reinstalling/updating the chipset drivers - you might do that anyway.
    Run the computer for an extended period with just the 1 Gb RAM module fitted.
    If you want to take System Restore out of the equation turn it off (all restore points will be deleted) - I rather doubt that is the source of the problem.
  10. 2006/06/28
    larold
    i have an ati radeon x600 128mb video card which is pci express
    i will clean its contacts and reseat it...and as you said i am going to keep the 512mb modules out for the time being and see if i get any more errors...if not i would presume the ram is going bad....i will be single channeling until my order of another gig of corsair ram comes in the mail...boo
    so if it is indeed the old modules it wont hurt much...i'm hoping its not something more serious!
    as for drivers i dont know why they would just start giving me problems...but i know stuff happens...technicians will always have a job! lol
  11. 2006/06/28
    I suggest you get some Contact Cleaner. You can spray the connectors of the RAM modules (and even wipe them gently with a clean, soft, lint-free cloth), but also spray the slots on the motherboard. Make certain it has completely dried and the vapours have disipated before reapplying the power.
    When you reinsert the modules, push evenly on both ends. Check the clips are seated all the way.
  12. 2006/06/28
    larold
    Okay I will post a dump when I do get a chance...which won't be until Saturday morning when I actually have time on my home machine while my girlfriend is at work. lol As for cleaning the contacts of the memory that is something i'll also tackle that morning...i'll be at Best Buy later today so i can grab a can! Thanks for the help guys...I appreciate the input on this headache! I will post the dump asap...then maybe we can narrow this thing down... :)
  14. 2006/06/29
    larold
    okay so i got to the computer for a few minutes today and did the dumps real quicjk...ill post in order....here they are!!
    ***6/18/06*****
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck C2, {7, cd4, 4, e183c370}
    GetUlongFromAddress: unable to read from 8056a9f0
    Probably caused by : ntkrnlmp.exe ( nt!ExFreePoolWithTag+2c1 )
    Followup: MachineOwner
    1: kd> !analyze -v;r;kv;lmtn;.logclose;q
    BAD_POOL_CALLER (c2)
    The current thread is making a bad pool request. Typically this is at a bad IRQL level or double freeing the same allocation, etc.
    Arguments:
    Arg1: 00000007, Attempt to free pool which was already freed
    Arg2: 00000cd4, (reserved)
    Arg3: 00000004, Memory contents of the pool block
    Arg4: e183c370, Address of the block of pool being deallocated
    Debugging Details:
    POOL_ADDRESS: e183c370
    BUGCHECK_STR: 0xc2_7
    CUSTOMER_CRASH_COUNT: 1
    LAST_CONTROL_TRANSFER: from 80550fc5 to 805371aa
    STACK_TEXT:
    eba38bec 80550fc5 000000c2 00000007 00000cd4 nt!KeBugCheckEx+0x1b
    eba38c3c 805823d4 e183c370 00000000 e156ec68 nt!ExFreePoolWithTag+0x2c1
    eba38c58 805928c1 e15c6e60 e156ec68 e102fb3c nt!CmpCleanUpKcbValueCache+0x3d
    eba38c6c 8059296e e15c6e60 e1795008 80571f3d nt!CmpCleanUpKcbCacheWithLock+0x1a
    eba38c78 80571f3d eba38c8c 80571f1e e156ec68 nt!CmpGetDelayedCloseIndex+0x16
    eba38c80 80571f1e e156ec68 eba38c98 80571e4a nt!CmpAddToDelayedClose+0xa
    eba38c8c 80571e4a e156ec68 eba38cb0 80572561 nt!CmpDereferenceKeyControlBlockWithLock+0x38
    eba38c98 80572561 e156ec68 00000000 e450b708 nt!CmpDereferenceKeyControlBlock+0x12
    eba38cb0 8056c78f e450b720 00000000 e450b708 nt!CmpDeleteKeyObject+0x92
    eba38ccc 804e1957 e450b720 00000000 00000502 nt!ObpRemoveObjectRoutine+0xdf
    eba38ce4 8056ea9e 8549a750 e30b2520 84bd4020 nt!ObfDereferenceObject+0x4c
    eba38cfc 8056e9bc e30b2520 e450b720 00000502 nt!ObpCloseHandleTableEntry+0x155
    eba38d44 8056ea06 00000502 00000001 00000000 nt!ObpCloseHandle+0x87
    eba38d58 804dd99f 00000502 022ff17c 7c90eb94 nt!NtClose+0x1d
    eba38d58 7c90eb94 00000502 022ff17c 7c90eb94 nt!KiFastCallEntry+0xfc
    WARNING: Frame IP not in any known module. Following frames may be wrong.
    022ff17c 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    80550fc5 83f801 cmp eax,0x1
    SYMBOL_STACK_INDEX: 1
    FOLLOWUP_NAME: MachineOwner
    SYMBOL_NAME: nt!ExFreePoolWithTag+2c1
    MODULE_NAME: nt
    IMAGE_NAME: ntkrnlmp.exe
    DEBUG_FLR_IMAGE_TIMESTAMP: 42250f77
    FAILURE_BUCKET_ID: 0xc2_7_nt!ExFreePoolWithTag+2c1
    eax=f778f13c ebx=00000cd4 ecx=00000000 edx=00000000 esi=e183c368 edi=00000000
    eip=805371aa esp=eba38bd4 ebp=eba38bec iopl=0 nv up ei ng nz na po nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000286
    nt!KeBugCheckEx+0x1b:
    805371aa 5d pop ebp
    eba38bec 80550fc5 000000c2 00000007 00000cd4 nt!KeBugCheckEx+0x1b (FPO: [Non-Fpo])
    eba38c3c 805823d4 e183c370 00000000 e156ec68 nt!ExFreePoolWithTag+0x2c1 (FPO: [Non-Fpo])
    eba38c58 805928c1 e15c6e60 e156ec68 e102fb3c nt!CmpCleanUpKcbValueCache+0x3d (FPO: [Non-Fpo])
    eba38c6c 8059296e e15c6e60 e1795008 80571f3d nt!CmpCleanUpKcbCacheWithLock+0x1a (FPO: [Non-Fpo])
    eba38c78 80571f3d eba38c8c 80571f1e e156ec68 nt!CmpGetDelayedCloseIndex+0x16 (FPO: [0,0,0])
    eba38c80 80571f1e e156ec68 eba38c98 80571e4a nt!CmpAddToDelayedClose+0xa (FPO: [Non-Fpo])
    eba38c8c 80571e4a e156ec68 eba38cb0 80572561 nt!CmpDereferenceKeyControlBlockWithLock+0x38 (FPO: [Non-Fpo])
    eba38c98 80572561 e156ec68 00000000 e450b708 nt!CmpDereferenceKeyControlBlock+0x12 (FPO: [Non-Fpo])
    eba38cb0 8056c78f e450b720 00000000 e450b708 nt!CmpDeleteKeyObject+0x92 (FPO: [Non-Fpo])
    eba38ccc 804e1957 e450b720 00000000 00000502 nt!ObpRemoveObjectRoutine+0xdf (FPO: [Non-Fpo])
    eba38ce4 8056ea9e 8549a750 e30b2520 84bd4020 nt!ObfDereferenceObject+0x4c (FPO: [0,0,0])
    eba38cfc 8056e9bc e30b2520 e450b720 00000502 nt!ObpCloseHandleTableEntry+0x155 (FPO: [Non-Fpo])
    eba38d44 8056ea06 00000502 00000001 00000000 nt!ObpCloseHandle+0x87 (FPO: [Non-Fpo])
    eba38d58 804dd99f 00000502 022ff17c 7c90eb94 nt!NtClose+0x1d (FPO: [Non-Fpo])
    eba38d58 7c90eb94 00000502 022ff17c 7c90eb94 nt!KiFastCallEntry+0xfc (FPO: [0,0] TrapFrame @ eba38d64)
    start end module name
    804d7000 806fd000 nt ntkrnlmp.exe Tue Mar 01 19:57:27 2005 (42250F77)
    806fd000 8071dd00 hal halmacpi.dll Wed Aug 04 01:59:09 2004 (41107B2D)
    bf000000 bf011580 dxg dxg.sys Wed Aug 04 02:00:51 2004 (41107B93)
    bf012000 bf055000 ati2dvag ati2dvag.dll Tue Mar 21 22:56:42 2006 (4420CAFA)
    bf055000 bf094000 ati2cqag ati2cqag.dll Tue Mar 21 22:12:22 2006 (4420C096)
    bf094000 bf0ca000 atikvmag atikvmag.dll Tue Mar 21 22:18:34 2006 (4420C20A)
    bf0ca000 bf354120 ati3duag ati3duag.dll Tue Mar 21 22:40:09 2006 (4420C719)
    bf355000 bf469100 ativvaxx ativvaxx.dll Tue Mar 21 22:33:39 2006 (4420C593)
    bf800000 bf9c1180 win32k win32k.sys Wed Oct 05 20:05:44 2005 (43446A58)
    bffa0000 bffe5c00 ATMFD ATMFD.DLL Wed Aug 04 03:56:56 2004 (411096C8)
    eb6a0000 eb6a8080 ipfltdrv ipfltdrv.sys Fri Aug 17 16:55:07 2001 (3B7D84AB)
    eb958000 eb998100 HTTP HTTP.sys Fri Oct 08 19:48:20 2004 (41672744)
    ebc41000 ebc92300 srv srv.sys Mon May 09 20:17:49 2005 (427FFDAD)
    ebf1b000 ebf1de80 secdrv secdrv.sys Fri Jan 16 08:16:04 2004 (4007E414)
    ec04d000 ec05c900 Cdfs Cdfs.SYS Wed Aug 04 02:14:09 2004 (41107EB1)
    ec1e2000 ec1f6400 wdmaud wdmaud.sys Wed Aug 04 02:15:03 2004 (41107EE7)
    ec21f000 ec24b400 mrxdav mrxdav.sys Wed Aug 04 02:00:49 2004 (41107B91)
    ec270000 ec272e40 mdmxsdk mdmxsdk.sys Wed Mar 17 14:04:10 2004 (4058A12A)
    ec454000 ec462d80 sysaudio sysaudio.sys Wed Aug 04 02:15:54 2004 (41107F1A)
    ec4c0000 ec4c3280 ndisuio ndisuio.sys Wed Aug 04 02:03:10 2004 (41107C1E)
    ee60c000 ee623480 dump_atapi dump_atapi.sys Wed Aug 04 01:59:41 2004 (41107B4D)
    ee64c000 ee66f000 Fastfat Fastfat.SYS Wed Aug 04 02:14:15 2004 (41107EB7)
    ee70f000 ee7cc7a0 avg7core avg7core.sys Mon May 22 11:18:28 2006 (4471D644)
    ee7cd000 ee83ba00 mrxsmb mrxsmb.sys Fri May 05 05:41:42 2006 (445B1DD6)
    ee83c000 ee866a00 rdbss rdbss.sys Fri May 05 05:47:55 2006 (445B1F4B)
    ee867000 ee888d00 afd afd.sys Wed Aug 04 02:14:13 2004 (41107EB5)
    ee889000 ee8e2940 vsdatant vsdatant.sys Thu Mar 16 12:48:29 2006 (4419A4ED)
    ee8e3000 ee903f00 ipnat ipnat.sys Wed Sep 29 18:28:36 2004 (415B3714)
    ee904000 ee92bc00 netbt netbt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
    ee92c000 ee983d80 tcpip tcpip.sys Thu Apr 20 07:51:47 2006 (444775D3)
    ee984000 ee996400 ipsec ipsec.sys Wed Aug 04 02:14:27 2004 (41107EC3)
    ee9db000 ee9dd900 Dxapi Dxapi.sys Fri Aug 17 16:53:19 2001 (3B7D843F)
    ee9df000 ee9fff80 portcls portcls.sys Mon Mar 15 20:41:47 2004 (40565B5B)
    eea00000 eec23300 RtkHDAud RtkHDAud.sys Thu Aug 26 01:12:30 2004 (412D713E)
    f6c64000 f6c66f80 mouhid mouhid.sys Fri Aug 17 16:47:57 2001 (3B7D82FD)
    f6c6c000 f6c9f200 update update.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f6ca0000 f6cd0100 rdpdr rdpdr.sys Wed Aug 04 02:01:10 2004 (41107BA6)
    f6cf9000 f6d09e00 psched psched.sys Wed Aug 04 02:04:16 2004 (41107C60)
    f6d0a000 f6d20680 ndiswan ndiswan.sys Wed Aug 04 02:14:30 2004 (41107EC6)
    f6d21000 f6d34900 parport parport.sys Wed Aug 04 01:59:04 2004 (41107B28)
    f6d35000 f6de1300 HSF_CNXT HSF_CNXT.sys Thu Mar 17 11:50:30 2005 (4239B556)
    f6de2000 f6ede580 HSF_DPV HSF_DPV.sys Thu Mar 17 11:51:13 2005 (4239B581)
    f6edf000 f6f01680 ks ks.sys Wed Aug 04 02:15:20 2004 (41107EF8)
    f6f02000 f6f38100 HSFHWBS2 HSFHWBS2.sys Thu Mar 17 11:50:35 2005 (4239B55B)
    f6f39000 f6f5be80 USBPORT USBPORT.SYS Wed Aug 04 02:08:34 2004 (41107D62)
    f6f5c000 f6f94e80 yk51x86 yk51x86.sys Fri May 13 09:00:36 2005 (4284A4F4)
    f6f95000 f6fb9000 HDAudBus HDAudBus.sys Wed Mar 17 18:12:09 2004 (4058DB49)
    f6fb9000 f6fcc780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 02:07:04 2004 (41107D08)
    f6fcd000 f7150000 ati2mtag ati2mtag.sys Tue Mar 21 22:56:21 2006 (4420CAE5)
    f7168000 f716bc80 mssmbios mssmbios.sys Wed Aug 04 02:07:47 2004 (41107D33)
    f716c000 f716e580 hidusb hidusb.sys Fri Aug 17 17:02:16 2001 (3B7D8658)
    f7198000 f71a0d80 HIDCLASS HIDCLASS.SYS Wed Aug 04 02:08:18 2004 (41107D52)
    f71b8000 f71c0880 Fips Fips.SYS Fri Aug 17 21:31:49 2001 (3B7DC585)
    f71d8000 f71e0700 netbios netbios.sys Wed Aug 04 02:03:19 2004 (41107C27)
    f71e8000 f71f6d80 arp1394 arp1394.sys Wed Aug 04 01:58:28 2004 (41107B04)
    f71f8000 f7200700 wanarp wanarp.sys Wed Aug 04 02:04:57 2004 (41107C89)
    f7228000 f7236100 usbhub usbhub.sys Wed Aug 04 02:08:40 2004 (41107D68)
    f7238000 f7252580 Mup Mup.sys Wed Aug 04 02:15:20 2004 (41107EF8)
    f7253000 f727fa80 NDIS NDIS.sys Wed Aug 04 02:14:27 2004 (41107EC3)
    f7280000 f730c480 Ntfs Ntfs.sys Wed Aug 04 02:15:06 2004 (41107EEA)
    f730d000 f7323780 KSecDD KSecDD.sys Wed Aug 04 01:59:45 2004 (41107B51)
    f7324000 f7335f00 sr sr.sys Wed Aug 04 02:06:22 2004 (41107CDE)
    f7336000 f7354780 fltMgr fltMgr.sys Wed Aug 04 02:01:17 2004 (41107BAD)
    f739a000 f73b1480 atapi atapi.sys Wed Aug 04 01:59:41 2004 (41107B4D)
    f73b2000 f73c9800 SCSIPORT SCSIPORT.SYS Wed Aug 04 01:59:39 2004 (41107B4B)
    f73ca000 f73ef700 dmio dmio.sys Wed Aug 04 02:07:13 2004 (41107D11)
    f73f0000 f740e880 ftdisk ftdisk.sys Fri Aug 17 16:52:41 2001 (3B7D8419)
    f740f000 f741fa80 pci pci.sys Wed Aug 04 02:07:45 2004 (41107D31)
    f7420000 f744dd80 ACPI ACPI.sys Wed Aug 04 02:07:35 2004 (41107D27)
    f7497000 f749fc00 isapnp isapnp.sys Fri Aug 17 16:58:01 2001 (3B7D8559)
    f74a7000 f74b1500 MountMgr MountMgr.sys Wed Aug 04 01:58:29 2004 (41107B05)
    f74b7000 f74c3c80 VolSnap VolSnap.sys Wed Aug 04 02:00:14 2004 (41107B6E)
    f7547000 f754fe00 disk disk.sys Wed Aug 04 01:59:53 2004 (41107B59)
    f7557000 f7563200 CLASSPNP CLASSPNP.SYS Wed Aug 04 02:14:26 2004 (41107EC2)
    f7597000 f75a5e80 ohci1394 ohci1394.sys Wed Aug 04 02:10:05 2004 (41107DBD)
    f75a7000 f75b4000 1394BUS 1394BUS.SYS Wed Aug 04 02:10:03 2004 (41107DBB)
    f75f7000 f7606180 nic1394 nic1394.sys Wed Aug 04 01:58:28 2004 (41107B04)
    f7617000 f761fd00 intelppm intelppm.sys Wed Aug 04 01:59:19 2004 (41107B37)
    f7627000 f7633e00 i8042prt i8042prt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
    f7637000 f7646d80 serial serial.sys Wed Aug 04 02:15:51 2004 (41107F17)
    f7647000 f7651380 imapi imapi.sys Wed Aug 04 02:00:12 2004 (41107B6C)
    f7657000 f7661980 Cdr4_xp Cdr4_xp.SYS Sat Apr 03 01:35:07 2004 (406E5B1B)
    f7667000 f7673180 cdrom cdrom.sys Wed Aug 04 01:59:52 2004 (41107B58)
    f7677000 f7685080 redbook redbook.sys Wed Aug 04 01:59:34 2004 (41107B46)
    f7687000 f7693880 rasl2tp rasl2tp.sys Wed Aug 04 02:14:21 2004 (41107EBD)
    f7697000 f76a1200 raspppoe raspppoe.sys Wed Aug 04 02:05:06 2004 (41107C92)
    f76a7000 f76b2d00 raspptp raspptp.sys Wed Aug 04 02:14:26 2004 (41107EC2)
    f76b7000 f76bf900 msgpc msgpc.sys Wed Aug 04 02:04:11 2004 (41107C5B)
    f76c7000 f76d0f00 termdd termdd.sys Wed Aug 04 01:58:52 2004 (41107B1C)
    f76d7000 f76e0480 NDProxy NDProxy.SYS Fri Aug 17 16:55:30 2001 (3B7D84C2)
    f7707000 f7715b80 drmk drmk.sys Wed Aug 04 02:07:54 2004 (41107D3A)
    f7717000 f771d200 PCIIDEX PCIIDEX.SYS Wed Aug 04 01:59:40 2004 (41107B4C)
    f771f000 f7723900 PartMgr PartMgr.sys Fri Aug 17 21:32:23 2001 (3B7DC5A7)
    f772f000 f7736880 Npfs Npfs.SYS Wed Aug 04 02:00:38 2004 (41107B86)
    f774f000 f7757000 SASKUTIL SASKUTIL.sys Thu Mar 02 14:50:35 2006 (44074C8B)
    f7757000 f775e000 SASDIFSV SASDIFSV.SYS Thu Feb 02 16:06:15 2006 (43E27447)
    f7767000 f776d780 USBSTOR USBSTOR.SYS Wed Aug 04 02:08:44 2004 (41107D6C)
    f7787000 f778be20 PxHelp20 PxHelp20.sys Tue Feb 01 18:23:42 2005 (42000F7E)
    f7797000 f779c020 wanatw4 wanatw4.sys Tue Jul 16 11:23:14 2002 (3D343A62)
    f77b7000 f77bca00 mouclass mouclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f77bf000 f77c3500 watchdog watchdog.sys Wed Aug 04 02:07:32 2004 (41107D24)
    f77df000 f77e4200 vga vga.sys Wed Aug 04 02:07:06 2004 (41107D0A)
    f77ef000 f77f3a80 Msfs Msfs.SYS Wed Aug 04 02:00:37 2004 (41107B85)
    f77ff000 f7804000 usbuhci usbuhci.sys Wed Aug 04 02:08:34 2004 (41107D62)
    f7807000 f780d800 usbehci usbehci.sys Wed Aug 04 02:08:34 2004 (41107D62)
    f7827000 f782d180 HIDPARSE HIDPARSE.SYS Wed Aug 04 02:08:15 2004 (41107D4F)
    f782f000 f7836580 Modem Modem.SYS Wed Aug 04 02:08:04 2004 (41107D44)
    f7837000 f783d000 kbdclass kbdclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f7847000 f784dc80 avg7rsxp avg7rsxp.sys Wed Feb 22 19:40:37 2006 (43FD0485)
    f7857000 f785d000 Cdralw2k Cdralw2k.SYS Sat Apr 03 01:32:19 2004 (406E5A73)
    f785f000 f7866000 GEARAspiWDM GEARAspiWDM.sys Tue Mar 01 23:05:17 2005 (42253B7D)
    f7867000 f786c000 SASENUM SASENUM.SYS Mon Feb 13 17:21:44 2006 (43F10678)
    f786f000 f7873f80 point32 point32.sys Tue Mar 15 04:40:15 2005 (4236AD7F)
    f7877000 f787d000 pgfilter pgfilter.sys Sun Sep 18 21:02:52 2005 (432E0E3C)
    f787f000 f7883880 TDI TDI.SYS Wed Aug 04 02:07:47 2004 (41107D33)
    f788f000 f7893580 ptilink ptilink.sys Fri Aug 17 16:49:53 2001 (3B7D8371)
    f789f000 f78a3080 raspti raspti.sys Fri Aug 17 16:55:32 2001 (3B7D84C4)
    f78a7000 f78aa000 BOOTVID BOOTVID.dll Fri Aug 17 16:49:09 2001 (3B7D8345)
    f795f000 f7962c80 serenum serenum.sys Wed Aug 04 01:59:06 2004 (41107B2A)
    f7967000 f7969280 rasacd rasacd.sys Fri Aug 17 16:55:39 2001 (3B7D84CB)
    f797f000 f7981580 ndistapi ndistapi.sys Fri Aug 17 16:55:29 2001 (3B7D84C1)
    f7997000 f7998b80 kdcom kdcom.dll Fri Aug 17 16:49:10 2001 (3B7D8346)
    f7999000 f799a100 WMILIB WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
    f79a3000 f79a4580 intelide intelide.sys Wed Aug 04 01:59:40 2004 (41107B4C)
    f79a5000 f79a6700 dmload dmload.sys Fri Aug 17 16:58:15 2001 (3B7D8567)
    f79b1000 f79b2100 swenum swenum.sys Wed Aug 04 01:58:41 2004 (41107B11)
    f79b9000 f79ba280 USBD USBD.SYS Fri Aug 17 17:02:58 2001 (3B7D8682)
    f79bf000 f79c1000 i2omgmt i2omgmt.SYS Wed Aug 04 02:00:50 2004 (41107B92)
    f79c3000 f79c4f00 Fs_Rec Fs_Rec.SYS Fri Aug 17 16:49:37 2001 (3B7D8361)
    f79c7000 f79c8080 Beep Beep.SYS Fri Aug 17 16:47:33 2001 (3B7D82E5)
    f79cb000 f79cc080 mnmdd mnmdd.SYS Fri Aug 17 16:57:28 2001 (3B7D8538)
    f79cf000 f79d0080 RDPCDD RDPCDD.sys Fri Aug 17 16:46:56 2001 (3B7D82C0)
    f79d7000 f79d80c0 avg7rsw avg7rsw.sys Sun Sep 18 20:09:31 2005 (432E01BB)
    f79fb000 f79fc100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
    f7a05000 f7a06d40 ASCTRM ASCTRM.SYS Mon Feb 05 12:50:30 2001 (3A7EE7E6)
    f7a21000 f7a22380 avgtdi avgtdi.sys Sat Sep 03 20:38:58 2005 (431A4222)
    f7a87000 f7a87b80 Null Null.SYS Fri Aug 17 16:47:39 2001 (3B7D82EB)
    f7b41000 f7b41d00 dxgthk dxgthk.sys Fri Aug 17 16:53:12 2001 (3B7D8438)
    f7bb5000 f7bb5c00 audstub audstub.sys Fri Aug 17 16:59:40 2001 (3B7D85BC)
  15. 2006/06/29
    larold
    Opened log file 'c:\debuglog.txt'
    Microsoft (R) Windows Debugger Version 6.6.0003.5
    Loading Dump File [C:\WINDOWS\Minidump\Mini062206-01.dmp]
    Executable search path is: C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\system32\drivers
    Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 2600.xpsp_sp2_gdr.050301-1519
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x805624a0
    Debug session time: Thu Jun 22 15:45:30.500 2006 (GMT-4)
    System Uptime: 0 days 7:43:07.209
    Loading Kernel Symbols
    BugCheck C2, {7, cd4, 0, c3c}
    *** WARNING: Unable to verify timestamp for ati2mtag.sys
    *** ERROR: Module load completed but symbols could not be loaded for ati2mtag.sys
    Probably caused by : ati2mtag.sys ( ati2mtag+397cb )
    Arguments:
    Arg3: 00000000, Memory contents of the pool block
    Arg4: 00000c3c, Address of the block of pool being deallocated
    Debugging Details:
    STACK_TEXT:
    eb43e264 80550fc5 000000c2 00000007 00000cd4 nt!KeBugCheckEx+0x1b
    eb43e2b4 bf802acb 00000c3c 00000000 eb43e2d4 nt!ExFreePoolWithTag+0x2c1
    eb43e2c4 bf8a15e5 00000c3c e3032138 eb436308 win32k!HeavyFreePool+0xbb
    eb43e2d4 bf8a5437 00000c4c e4421d20 00000000 win32k!EngFreeMem+0x1c
    eb43e468 804ed134 849fb7e8 eb43e484 f72825d3 win32k!lGetGlyphBitmap+0x229
    eb43e49c 804ebf49 00000001 00000000 eb43e7f0 nt!CcRemapBcb+0x3e
    eb43e4b4 8057d9f7 00bb4878 00000000 00000000 nt!CcGetVirtualAddress+0xc4
    eb43e51c f70067cb 849fb7e8 eb43e54c 00001000 nt!CcMapData+0x8b
    eb43e544 f72a8647 f72a865c 849fb7e8 e2eafba8 ati2mtag+0x397cb
    eb43e5c0 804dc605 849fb818 e2eafae0 00000000 Ntfs!FindMoveableIndexRoot+0xcf
    eb43e5ec f72823a9 c0000034 849fb7e8 00000000 nt!ExReleaseResourceLite+0x8d
    eb43e604 849fb7e8 00000014 c0000034 849fb7e8 Ntfs!NtfsReleaseAllResources+0x62
    f728049e 5e39f729 b6850f60 f6000107 0f040546 0x849fb7e8
    f72804a2 b6850f60 f6000107 0f040546 00054a85 0x5e39f729
    f72804a6 f6000107 0f040546 00054a85 084e8b00 0xb6850f60
    f72804aa 0f040546 00054a85 084e8b00 0000c1f7 0xf6000107
    f72804ae 00054a85 084e8b00 0000c1f7 850f0001 0xf040546
    f72804b2 084e8b00 0000c1f7 850f0001 0000053b 0x54a85
    f72804b6 00000000 850f0001 0000053b 3b58468b 0x84e8b00
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    ati2mtag+397cb
    f70067cb ?? ???
    SYMBOL_STACK_INDEX: 8
    SYMBOL_NAME: ati2mtag+397cb
    MODULE_NAME: ati2mtag
    IMAGE_NAME: ati2mtag.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 4420cae5
    FAILURE_BUCKET_ID: 0xc2_7_ati2mtag+397cb
    eax=f778f13c ebx=00000cd4 ecx=00000000 edx=00000000 esi=00000c34 edi=e30323f0
    eip=805371aa esp=eb43e24c ebp=eb43e264 iopl=0 nv up ei ng nz na po nc
    805371aa 5d pop ebp
    eb43e264 80550fc5 000000c2 00000007 00000cd4 nt!KeBugCheckEx+0x1b (FPO: [Non-Fpo])
    eb43e2b4 bf802acb 00000c3c 00000000 eb43e2d4 nt!ExFreePoolWithTag+0x2c1 (FPO: [Non-Fpo])
    eb43e2c4 bf8a15e5 00000c3c e3032138 eb436308 win32k!HeavyFreePool+0xbb (FPO: [Non-Fpo])
    eb43e2d4 bf8a5437 00000c4c e4421d20 00000000 win32k!EngFreeMem+0x1c (FPO: [Non-Fpo])
    eb43e468 804ed134 849fb7e8 eb43e484 f72825d3 win32k!lGetGlyphBitmap+0x229 (FPO: [Non-Fpo])
    eb43e49c 804ebf49 00000001 00000000 eb43e7f0 nt!CcRemapBcb+0x3e (FPO: [Non-Fpo])
    eb43e4b4 8057d9f7 00bb4878 00000000 00000000 nt!CcGetVirtualAddress+0xc4 (FPO: [Non-Fpo])
    eb43e51c f70067cb 849fb7e8 eb43e54c 00001000 nt!CcMapData+0x8b (FPO: [Non-Fpo])
    eb43e5c0 804dc605 849fb818 e2eafae0 00000000 Ntfs!FindMoveableIndexRoot+0xcf (FPO: [Non-Fpo])
    eb43e5ec f72823a9 c0000034 849fb7e8 00000000 nt!ExReleaseResourceLite+0x8d (FPO: [Non-Fpo])
    eb43e604 849fb7e8 00000014 c0000034 849fb7e8 Ntfs!NtfsReleaseAllResources+0x62 (FPO: [Non-Fpo])
    eb498000 eb4d8100 HTTP HTTP.sys Fri Oct 08 19:48:20 2004 (41672744)
    eb539000 eb541080 ipfltdrv ipfltdrv.sys Fri Aug 17 16:55:07 2001 (3B7D84AB)
    ebf2f000 ebf31e80 secdrv secdrv.sys Fri Jan 16 08:16:04 2004 (4007E414)
    ec07d000 ec08c900 Cdfs Cdfs.SYS Wed Aug 04 02:14:09 2004 (41107EB1)
    ec314000 ec316e40 mdmxsdk mdmxsdk.sys Wed Mar 17 14:04:10 2004 (4058A12A)
    ec4b0000 ec4b3280 ndisuio ndisuio.sys Wed Aug 04 02:03:10 2004 (41107C1E)
    ee624000 ee647000 Fastfat Fastfat.SYS Wed Aug 04 02:14:15 2004 (41107EB7)
    ee8e3000 ee90ac00 netbt netbt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
    ee90b000 ee92bf00 ipnat ipnat.sys Wed Sep 29 18:28:36 2004 (415B3714)
    f6c60000 f6c62f80 mouhid mouhid.sys Fri Aug 17 16:47:57 2001 (3B7D82FD)
    f6cd1000 f6cd3580 hidusb hidusb.sys Fri Aug 17 17:02:16 2001 (3B7D8658)
    f71a8000 f71b0d80 HIDCLASS HIDCLASS.SYS Wed Aug 04 02:08:18 2004 (41107D52)
    f74e7000 f74f5d80 sysaudio sysaudio.sys Wed Aug 04 02:15:54 2004 (41107F1A)
    f7727000 f772ba80 Msfs Msfs.SYS Wed Aug 04 02:00:37 2004 (41107B85)
    f7737000 f773e880 Npfs Npfs.SYS Wed Aug 04 02:00:38 2004 (41107B86)
    f7757000 f775f000 SASKUTIL SASKUTIL.sys Thu Mar 02 14:50:35 2006 (44074C8B)
    f775f000 f7766000 SASDIFSV SASDIFSV.SYS Thu Feb 02 16:06:15 2006 (43E27447)
    f7767000 f776c000 SASENUM SASENUM.SYS Mon Feb 13 17:21:44 2006 (43F10678)
    f7777000 f777d780 USBSTOR USBSTOR.SYS Wed Aug 04 02:08:44 2004 (41107D6C)
    f77bf000 f77c3f80 point32 point32.sys Tue Mar 15 04:40:15 2005 (4236AD7F)
    f77e7000 f77ec200 vga vga.sys Wed Aug 04 02:07:06 2004 (41107D0A)
    f77ef000 f77f3500 watchdog watchdog.sys Wed Aug 04 02:07:32 2004 (41107D24)
    f77f7000 f77fd000 pgfilter pgfilter.sys Sun Sep 18 21:02:52 2005 (432E0E3C)
    f784f000 f7855180 HIDPARSE HIDPARSE.SYS Wed Aug 04 02:08:15 2004 (41107D4F)
    f7877000 f787dc80 avg7rsxp avg7rsxp.sys Wed Feb 22 19:40:37 2006 (43FD0485)
    f79c1000 f79c3000 i2omgmt i2omgmt.SYS Wed Aug 04 02:00:50 2004 (41107B92)
    f79c5000 f79c6f00 Fs_Rec Fs_Rec.SYS Fri Aug 17 16:49:37 2001 (3B7D8361)
    f79c9000 f79ca080 Beep Beep.SYS Fri Aug 17 16:47:33 2001 (3B7D82E5)
    f79cd000 f79ce080 mnmdd mnmdd.SYS Fri Aug 17 16:57:28 2001 (3B7D8538)
    f79d1000 f79d2080 RDPCDD RDPCDD.sys Fri Aug 17 16:46:56 2001 (3B7D82C0)
    f79d9000 f79da0c0 avg7rsw avg7rsw.sys Sun Sep 18 20:09:31 2005 (432E01BB)
    f79f3000 f79f4100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
    f7a15000 f7a16d40 ASCTRM ASCTRM.SYS Mon Feb 05 12:50:30 2001 (3A7EE7E6)
    f7a3f000 f7a40380 avgtdi avgtdi.sys Sat Sep 03 20:38:58 2005 (431A4222)
    f7a99000 f7a99b80 Null Null.SYS Fri Aug 17 16:47:39 2001 (3B7D82EB)
    f7b5b000 f7b5bd00 dxgthk dxgthk.sys Fri Aug 17 16:53:12 2001 (3B7D8438)
    f7bc6000 f7bc6c00 audstub audstub.sys Fri Aug 17 16:59:40 2001 (3B7D85BC)
  16. 2006/06/29
    larold
    Debug session time: Mon Jun 26 23:37:48.890 2006 (GMT-4)
    System Uptime: 0 days 6:40:39.605
    BugCheck 1000000A, {990000, 2, 1, 806ffa2a}
    Probably caused by : sr.sys ( sr!SrFastIoQueryStandardInfo+37 )
    0: kd> !analyze -v;r;kv;lmtn;.logclose;q
    IRQL_NOT_LESS_OR_EQUAL (a)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If a kernel debugger is available get the stack backtrace.
    Arguments:
    Arg1: 00990000, memory referenced
    Arg2: 00000002, IRQL
    Arg3: 00000001, value 0 = read operation, 1 = write operation
    Arg4: 806ffa2a, address which referenced memory
    Debugging Details:
    WRITE_ADDRESS: 00990000
    CURRENT_IRQL: 2
    FAULTING_IP:
    hal!KeAcquireInStackQueuedSpinLock+3a
    806ffa2a 8902 mov [edx],eax
    BUGCHECK_STR: 0xA
    LAST_CONTROL_TRANSFER: from f7b77147 to 806ffa2a
    STACK_TEXT:
    ae947b38 f7b77147 886922f0 00000001 00126860 hal!KeAcquireInStackQueuedSpinLock+0x3a
    ae947b38 f7b77147 886922f0 00000001 00126860 Ntfs!NtfsFastQueryStdInfo+0xa3
    ae947c90 f7837ab3 887acf90 00000001 00126848 Ntfs!NtfsFastQueryStdInfo+0xa3
    ae947cac 8057edfd 887acf90 00000001 00126848 sr!SrFastIoQueryStandardInfo+0x37
    ae947d48 804dd99f 000002c4 00126860 00126848 nt!NtQueryInformationFile+0x216
    ae947d48 7c90eb94 000002c4 00126860 00126848 nt!KiFastCallEntry+0xfc
    00126868 00000000 00000000 00000000 00000000 0x7c90eb94
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    f7837ab3 eb02 jmp sr!SrFastIoQueryStandardInfo+0x3b (f7837ab7)
    SYMBOL_STACK_INDEX: 3
    SYMBOL_NAME: sr!SrFastIoQueryStandardInfo+37
    MODULE_NAME: sr
    IMAGE_NAME: sr.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 41107cde
    FAILURE_BUCKET_ID: 0xA_W_sr!SrFastIoQueryStandardInfo+37
    eax=ae947b2c ebx=00000000 ecx=88692325 edx=00990000 esi=886922f0 edi=8878eda8
    eip=806ffa2a esp=ae947b1c ebp=ae947b38 iopl=0 nv up ei ng nz na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010282
    hal!KeAcquireInStackQueuedSpinLock+0x3a:
    806ffa2a 8902 mov [edx],eax ds:0023:00990000=????????
    ae947b38 f7b77147 886922f0 00000001 00126860 hal!KeAcquireInStackQueuedSpinLock+0x3a (FPO: [0,1,0])
    ae947b38 f7b77147 886922f0 00000001 00126860 Ntfs!NtfsFastQueryStdInfo+0xa3 (FPO: [Non-Fpo])
    ae947c90 f7837ab3 887acf90 00000001 00126848 Ntfs!NtfsFastQueryStdInfo+0xa3 (FPO: [Non-Fpo])
    ae947cac 8057edfd 887acf90 00000001 00126848 sr!SrFastIoQueryStandardInfo+0x37 (FPO: [Non-Fpo])
    ae947d48 804dd99f 000002c4 00126860 00126848 nt!NtQueryInformationFile+0x216 (FPO: [Non-Fpo])
    ae947d48 7c90eb94 000002c4 00126860 00126848 nt!KiFastCallEntry+0xfc (FPO: [0,0] TrapFrame @ ae947d64)
    ae3d3000 ae3ea480 dump_atapi dump_atapi.sys Wed Aug 04 01:59:41 2004 (41107B4D)
    ae9e0000 aea20100 HTTP HTTP.sys Fri Oct 08 19:48:20 2004 (41672744)
    af179000 af1ca300 srv srv.sys Mon May 09 20:17:49 2005 (427FFDAD)
    af3bf000 af3c1e80 secdrv secdrv.sys Fri Jan 16 08:16:04 2004 (4007E414)
    af423000 af432900 Cdfs Cdfs.SYS Wed Aug 04 02:14:09 2004 (41107EB1)
    af49b000 af4c7400 mrxdav mrxdav.sys Wed Aug 04 02:00:49 2004 (41107B91)
    af602000 af605100 mdmxsdk mdmxsdk.sys Wed Oct 05 19:58:05 2005 (4344688D)
    af6f7000 af70b400 wdmaud wdmaud.sys Wed Aug 04 02:15:03 2004 (41107EE7)
    af980000 af983280 ndisuio ndisuio.sys Wed Aug 04 02:03:10 2004 (41107C1E)
    af9ac000 af9bad80 sysaudio sysaudio.sys Wed Aug 04 02:15:54 2004 (41107F1A)
    b1abc000 b1abd380 avgtdi avgtdi.sys Sat Sep 03 20:38:58 2005 (431A4222)
    b1b12000 b1b17000 SASENUM SASENUM.SYS Mon Feb 13 17:21:44 2006 (43F10678)
    b1b2a000 b1b30000 pgfilter pgfilter.sys Sun Sep 18 21:02:52 2005 (432E0E3C)
    b1b52000 b1b75000 Fastfat Fastfat.SYS Wed Aug 04 02:14:15 2004 (41107EB7)
    b1c15000 b1cd27a0 avg7core avg7core.sys Mon May 22 11:18:28 2006 (4471D644)
    b1cd3000 b1d41a00 mrxsmb mrxsmb.sys Fri May 05 05:41:42 2006 (445B1DD6)
    b1d42000 b1d6ca00 rdbss rdbss.sys Fri May 05 05:47:55 2006 (445B1F4B)
    b1d6d000 b1d8ed00 afd afd.sys Wed Aug 04 02:14:13 2004 (41107EB5)
    b1db7000 b1e15e80 vsdatant vsdatant.sys Sun Jun 18 19:26:23 2006 (4495E11F)
    b1e16000 b1e36f00 ipnat ipnat.sys Wed Sep 29 18:28:36 2004 (415B3714)
    b1e37000 b1e5ec00 netbt netbt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
    b1e5f000 b1eb6d80 tcpip tcpip.sys Thu Apr 20 07:51:47 2006 (444775D3)
    b1eb7000 b1ec9400 ipsec ipsec.sys Wed Aug 04 02:14:27 2004 (41107EC3)
    b1ef6000 b1ef8900 Dxapi Dxapi.sys Fri Aug 17 16:53:19 2001 (3B7D843F)
    b1f12000 b1f32f80 portcls portcls.sys Mon Mar 15 20:41:47 2004 (40565B5B)
    b1f33000 b2156300 RtkHDAud RtkHDAud.sys Thu Aug 26 01:12:30 2004 (412D713E)
    ba1c7000 ba1cf080 ipfltdrv ipfltdrv.sys Fri Aug 17 16:55:07 2001 (3B7D84AB)
    ba237000 ba239f80 mouhid mouhid.sys Fri Aug 17 16:47:57 2001 (3B7D82FD)
    ba23f000 ba272200 update update.sys Wed Aug 04 01:58:32 2004 (41107B08)
    ba273000 ba2a3100 rdpdr rdpdr.sys Wed Aug 04 02:01:10 2004 (41107BA6)
    ba2a4000 ba2b4e00 psched psched.sys Wed Aug 04 02:04:16 2004 (41107C60)
    ba2b5000 ba2cb680 ndiswan ndiswan.sys Wed Aug 04 02:14:30 2004 (41107EC6)
    ba2cc000 ba2df900 parport parport.sys Wed Aug 04 01:59:04 2004 (41107B28)
    ba2e0000 ba38f480 HSF_CNXT HSF_CNXT.sys Fri Jul 22 14:00:58 2005 (42E1345A)
    ba390000 ba48cb00 HSF_DPV HSF_DPV.sys Fri Jul 22 14:02:08 2005 (42E134A0)
    ba48d000 ba4af680 ks ks.sys Wed Aug 04 02:15:20 2004 (41107EF8)
    ba4b0000 ba4e8700 HSFHWBS2 HSFHWBS2.sys Fri Jul 22 14:01:08 2005 (42E13464)
    ba4e9000 ba50be80 USBPORT USBPORT.SYS Wed Aug 04 02:08:34 2004 (41107D62)
    ba50c000 ba546e80 yk51x86 yk51x86.sys Mon Sep 19 11:33:14 2005 (432EDA3A)
    ba547000 ba56b000 HDAudBus HDAudBus.sys Wed Mar 17 18:12:09 2004 (4058DB49)
    ba56b000 ba57e780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 02:07:04 2004 (41107D08)
    ba57f000 ba65d000 ati2mtag ati2mtag.sys Thu Nov 11 22:02:01 2004 (419427A9)
    ba685000 ba688c80 mssmbios mssmbios.sys Wed Aug 04 02:07:47 2004 (41107D33)
    ba6a9000 ba6ab580 ndistapi ndistapi.sys Fri Aug 17 16:55:29 2001 (3B7D84C1)
    ba6ad000 ba6af580 hidusb hidusb.sys Fri Aug 17 17:02:16 2001 (3B7D8658)
    ba6c9000 ba6ccc80 serenum serenum.sys Wed Aug 04 01:59:06 2004 (41107B2A)
    ba6d5000 ba6dbc80 avg7rsxp avg7rsxp.sys Wed Feb 22 19:40:37 2006 (43FD0485)
    ba6dd000 ba6e1880 TDI TDI.SYS Wed Aug 04 02:07:47 2004 (41107D33)
    ba6f5000 ba6fb780 USBSTOR USBSTOR.SYS Wed Aug 04 02:08:44 2004 (41107D6C)
    ba6fd000 ba704000 GEARAspiWDM GEARAspiWDM.sys Tue Mar 01 23:05:17 2005 (42253B7D)
    ba705000 ba70b000 Cdralw2k Cdralw2k.SYS Sat Apr 03 01:32:19 2004 (406E5A73)
    ba745000 ba75f580 Mup Mup.sys Wed Aug 04 02:15:20 2004 (41107EF8)
    ba770000 ba77e100 usbhub usbhub.sys Wed Aug 04 02:08:40 2004 (41107D68)
    ba780000 ba78eb80 drmk drmk.sys Wed Aug 04 02:07:54 2004 (41107D3A)
    ba7b0000 ba7b9480 NDProxy NDProxy.SYS Fri Aug 17 16:55:30 2001 (3B7D84C2)
    ba7c0000 ba7c9f00 termdd termdd.sys Wed Aug 04 01:58:52 2004 (41107B1C)
    ba7d0000 ba7d8900 msgpc msgpc.sys Wed Aug 04 02:04:11 2004 (41107C5B)
    ba7e0000 ba7ebd00 raspptp raspptp.sys Wed Aug 04 02:14:26 2004 (41107EC2)
    ba7f0000 ba7fa200 raspppoe raspppoe.sys Wed Aug 04 02:05:06 2004 (41107C92)
    bf012000 bf04c000 ati2dvag ati2dvag.dll Thu Nov 11 22:02:23 2004 (419427BF)
    bf04c000 bf089000 ati2cqag ati2cqag.dll Thu Nov 11 21:22:24 2004 (41941E60)
    bf089000 bf0bf000 atikvmag atikvmag.dll Tue Mar 21 22:18:34 2006 (4420C20A)
    bf0bf000 bf2f2320 ati3duag ati3duag.dll Thu Nov 11 21:43:23 2004 (4194234B)
    bf2f3000 bf35d000 ativvaxx ativvaxx.dll Thu Nov 11 21:38:17 2004 (41942219)
    f740a000 f7418080 redbook redbook.sys Wed Aug 04 01:59:34 2004 (41107B46)
    f741a000 f7426180 cdrom cdrom.sys Wed Aug 04 01:59:52 2004 (41107B58)
    f742a000 f7434980 Cdr4_xp Cdr4_xp.SYS Sat Apr 03 01:35:07 2004 (406E5B1B)
    f743a000 f7444380 imapi imapi.sys Wed Aug 04 02:00:12 2004 (41107B6C)
    f744a000 f7459d80 serial serial.sys Wed Aug 04 02:15:51 2004 (41107F17)
    f745a000 f7471480 atapi atapi.sys Wed Aug 04 01:59:41 2004 (41107B4D)
    f7472000 f7489800 SCSIPORT SCSIPORT.SYS Wed Aug 04 01:59:39 2004 (41107B4B)
    f748a000 f74af700 dmio dmio.sys Wed Aug 04 02:07:13 2004 (41107D11)
    f74b0000 f74ce880 ftdisk ftdisk.sys Fri Aug 17 16:52:41 2001 (3B7D8419)
    f74cf000 f74dbe00 i8042prt i8042prt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
    f74df000 f74ee180 nic1394 nic1394.sys Wed Aug 04 01:58:28 2004 (41107B04)
    f74ef000 f74f7d00 intelppm intelppm.sys Wed Aug 04 01:59:19 2004 (41107B37)
    f753f000 f7547880 Fips Fips.SYS Fri Aug 17 21:31:49 2001 (3B7DC585)
    f754f000 f755c000 1394BUS 1394BUS.SYS Wed Aug 04 02:10:03 2004 (41107DBB)
    f755f000 f756de80 ohci1394 ohci1394.sys Wed Aug 04 02:10:05 2004 (41107DBD)
    f756f000 f757fa80 pci pci.sys Wed Aug 04 02:07:45 2004 (41107D31)
    f7580000 f75add80 ACPI ACPI.sys Wed Aug 04 02:07:35 2004 (41107D27)
    f75f7000 f75ffc00 isapnp isapnp.sys Fri Aug 17 16:58:01 2001 (3B7D8559)
    f7607000 f7611500 MountMgr MountMgr.sys Wed Aug 04 01:58:29 2004 (41107B05)
    f7617000 f7623c80 VolSnap VolSnap.sys Wed Aug 04 02:00:14 2004 (41107B6E)
    f7627000 f762f700 wanarp wanarp.sys Wed Aug 04 02:04:57 2004 (41107C89)
    f7637000 f7645d80 arp1394 arp1394.sys Wed Aug 04 01:58:28 2004 (41107B04)
    f7657000 f765f700 netbios netbios.sys Wed Aug 04 02:03:19 2004 (41107C27)
    f7677000 f7681000 SASKUTIL SASKUTIL.sys Fri Jun 09 18:43:30 2006 (4489F992)
    f7687000 f768fd80 HIDCLASS HIDCLASS.SYS Wed Aug 04 02:08:18 2004 (41107D52)
    f76a7000 f76afe00 disk disk.sys Wed Aug 04 01:59:53 2004 (41107B59)
    f76b7000 f76c3200 CLASSPNP CLASSPNP.SYS Wed Aug 04 02:14:26 2004 (41107EC2)
    f76d7000 f76e1000 srescan srescan.sys Tue May 16 16:36:24 2006 (446A37C8)
    f7707000 f770d200 PCIIDEX PCIIDEX.SYS Wed Aug 04 01:59:40 2004 (41107B4C)
    f770f000 f7713900 PartMgr PartMgr.sys Fri Aug 17 21:32:23 2001 (3B7DC5A7)
    f7717000 f771c200 vga vga.sys Wed Aug 04 02:07:06 2004 (41107D0A)
    f7757000 f775d180 HIDPARSE HIDPARSE.SYS Wed Aug 04 02:08:15 2004 (41107D4F)
    f7777000 f777be20 PxHelp20 PxHelp20.sys Tue Feb 01 18:23:42 2005 (42000F7E)
    f7787000 f778b580 ptilink ptilink.sys Fri Aug 17 16:49:53 2001 (3B7D8371)
    f77af000 f77b3080 raspti raspti.sys Fri Aug 17 16:55:32 2001 (3B7D84C4)
    f77b7000 f77bc020 wanatw4 wanatw4.sys Tue Jul 16 11:23:14 2002 (3D343A62)
    f77bf000 f77c4a00 mouclass mouclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f77df000 f77e3500 watchdog watchdog.sys Wed Aug 04 02:07:32 2004 (41107D24)
    f77e7000 f77ec000 usbuhci usbuhci.sys Wed Aug 04 02:08:34 2004 (41107D62)
    f77ef000 f77f5800 usbehci usbehci.sys Wed Aug 04 02:08:34 2004 (41107D62)
    f7807000 f780bf80 point32 point32.sys Tue Mar 15 04:40:15 2005 (4236AD7F)
    f780f000 f7816580 Modem Modem.SYS Wed Aug 04 02:08:04 2004 (41107D44)
    f781f000 f7825000 kbdclass kbdclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
    f7830000 f7841f00 sr sr.sys Wed Aug 04 02:06:22 2004 (41107CDE)
    f7887000 f7893880 rasl2tp rasl2tp.sys Wed Aug 04 02:14:21 2004 (41107EBD)
    f7897000 f789a000 BOOTVID BOOTVID.dll Fri Aug 17 16:49:09 2001 (3B7D8345)
    f7943000 f7945280 rasacd rasacd.sys Fri Aug 17 16:55:39 2001 (3B7D84CB)
    f7951000 f7967780 KSecDD KSecDD.sys Wed Aug 04 01:59:45 2004 (41107B51)
    f7968000 f7986780 fltMgr fltMgr.sys Wed Aug 04 02:01:17 2004 (41107BAD)
    f7987000 f7988b80 kdcom kdcom.dll Fri Aug 17 16:49:10 2001 (3B7D8346)
    f7989000 f798a100 WMILIB WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
    f7993000 f7994580 intelide intelide.sys Wed Aug 04 01:59:40 2004 (41107B4C)
    f7995000 f7996700 dmload dmload.sys Fri Aug 17 16:58:15 2001 (3B7D8567)
    f799f000 f79a0100 swenum swenum.sys Wed Aug 04 01:58:41 2004 (41107B11)
    f79a7000 f79a8280 USBD USBD.SYS Fri Aug 17 17:02:58 2001 (3B7D8682)
    f79a9000 f79ab000 i2omgmt i2omgmt.SYS Wed Aug 04 02:00:50 2004 (41107B92)
    f79ad000 f79aef00 Fs_Rec Fs_Rec.SYS Fri Aug 17 16:49:37 2001 (3B7D8361)
    f79b1000 f79b2080 Beep Beep.SYS Fri Aug 17 16:47:33 2001 (3B7D82E5)
    f79b5000 f79b6080 mnmdd mnmdd.SYS Fri Aug 17 16:57:28 2001 (3B7D8538)
    f79b9000 f79ba080 RDPCDD RDPCDD.sys Fri Aug 17 16:46:56 2001 (3B7D82C0)
    f79c9000 f79ca0c0 avg7rsw avg7rsw.sys Sun Sep 18 20:09:31 2005 (432E01BB)
    f79d1000 f79d2d40 ASCTRM ASCTRM.SYS Mon Feb 05 12:50:30 2001 (3A7EE7E6)
    f79e7000 f79e8100 dump_WMILIB dump_WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
    f7a22000 f7a4ea80 NDIS NDIS.sys Wed Aug 04 02:14:27 2004 (41107EC3)
    f7aa9000 f7aa9d00 dxgthk dxgthk.sys Fri Aug 17 16:53:12 2001 (3B7D8438)
    f7ab3000 f7ab3b80 Null Null.SYS Fri Aug 17 16:47:39 2001 (3B7D82EB)
    f7ac1000 f7ac1c00 audstub audstub.sys Fri Aug 17 16:59:40 2001 (3B7D85BC)
    f7b52000 f7bde480 Ntfs Ntfs.sys Wed Aug 04 02:15:06 2004 (41107EEA)
    I'm not sure if you needed the unloaded modules in all of the posts but i was going over the character limit for posting!!! let me know
  17. 2006/06/29
    larold
    IDriver.exe - Application Error : The instruction at
    "0x0166f020" referenced memory at "0x00000ba0 ". The memory could not be
    "read ".
    just got this ina dialogue box when installing an update for itunes....it didnt show as an error in event log...
    the memory code is not what mine was but this is the type of notification i got...not sure what it means really
    this is with the new module installed.
    ***edit***
    found this on a website about installing...so it isnt to be worried about??? hmm weird
    "On rare occasions, you may see the following error during installation of the Agilent IO Libraries Suite:
    The instruction at "0x77511029" referenced memory at "0x0000005c ". The memory could not be "read ".
    (The instruction and memory locations may vary.) If you see this error, click OK in the error dialog box, and the installation will continue. No further action is necessary; the IO Libraries Suite will be correctly installed
    then this from microsoft:
    "This behavior occurs because the operating system does not allocate a large enough buffer for the maximum string length permitted. When the data is greater than the buffer size. "
  18. 2006/07/05
    larold
    i put two sticks of new corsair 1 gb ddr in and running in dual channel since the last posts and no problems have occurred yet...so far the system has been up consistantly with no blue screens... *crosses fingers*
