memory problem I think...
Discussion in 'Legacy Windows' started by Adam Wal, 2005/02/25.
  1. 2005/02/25
    Adam Wal
    Adam Wal Inactive Thread Starter
    My computer suffers from serious Lag and memory problems.
    It runs slow and is becoming a large problem
    It has suffered many DLL problems, mainly KERNEL32.dll
    Please help, and ask If you need any specs., reports, etc. posting
  2. 2005/02/25
    charlesvar
    charlesvar Inactive Alumni
    Hello Adam,
    When did this start? Was it suddenly or a progression?
    How much memory do you have?
    What's running in the background? For too many startup programs, refer to this thread http://www.windowsbbs.com/showthread.php?t=37002
    Regards - Charles
    Adam Wal
    It started a long time ago (up to a year), and seems to have become worse over the last year or so.
    But it is only recently I have found these forums
    I have 76.6 Gb of memory on my C: drive in total
    but have only used 7.38 Gb of it
    When i start up i have 14 programs shown running in task manager
    does that help?
  5. 2005/02/26
    charlesvar
    Hi Adam,
    By memory, I thought you meant physical RandomAccesMemory, and that is the standard industry nomenclature for that term, not Hard Drive space which you seem to have in abundance
    Go back to that thread I referenced and use the links I provided to look up what these 14 programs are and see if they are needed - disabling uneeded processes will speed up your system.
    Regards - Charles
  6. 2005/02/26
    Adam Wal
    I have minimised down the programs from task manager, although it seems it told me to delete 'rundll32'
    I have had problems with this in the past, so i did this straight away
    now when i got into control panel nothing will work, and it comes up asking where rundll32 is,
    :confused: im confused
  7. 2005/02/26
    charlesvar
    Hi Adam,
    I should have asked this in the previous post: Task Manager is an XP utility, and as far as I know, not in WinME, so what is this program? Is it a 3rd party program? Can you recall the exact wording of it seems it told me to delete 'rundll32'?
    As for replacing it, do you have a WinME disc? If so, do a search for it, the full name is RUNDLL32.exe. It belongs in the Windows folder, not in any of the Windows sub-folders.
    Regards - Charles
  8. 2005/02/27
    Adam Wal
    The 'task manager' I am using is the one when you press Alt + Ctrl + Del
    Is that not task manager?
    and the wording telling me to delete rundll32 was on the internet on one of the links you gave me, I think it was the first or second one, any help to you?
  9. 2005/02/27
    charlesvar
    Hi Adam,
    Ok, but disabling any process this way is temporary - will start up again on next bootup.
    To stop startups: One of two ways - using msconfig: Run > type msconfig > ok > startup tab and uncheck boxes.
    From the linked WinME thread, that is the way to disable startups.
    Please be more specific on the rundll deletion - could you copy/paste the reference and which link it was, have to be very precise here, I don't want to quess anymore here.
    Regards - Charles
  10. 2005/02/27
    Adam Wal
    reason for deleting rundll32:
    " rundll32.exe is a process which executes DLL's an places their libraries into the memory, so they can be used more efficiently by applications.This program is important for the stable and secure running of your computer and should not be terminated. Note: rundll32.exe is also a process which is registered as the W32.Miroot.Worm. This Trojan allows attackers to access your computer, stealing passwords and personal data. It is a registered security risk and should be removed immediately. Please see additional details regarding this process "
  11. 2005/02/27
    charlesvar
    Hi Adam,
    Ok, so what made you think it was a virus?
    What you're giving me is a conflated quote, and the recomendation to delete is ONLY after you make sure that it's not the MS process.
    I can send you a copy of rundll32.exe - PM me to tell me where.
    Regards - Charles
  12. 2005/02/28
    Adam Wal
    though my mam and dad are saying to reformat it
    I probably will do this then leave for a week or so
    I will imform you of any errors after this
  13. 2005/02/28
    charlesvar
    Hi Adam,
    I decided that it would be better for you to download a copy of Rundl32.exe - here: http://www.spywareinfo.com/~merijn/winfiles.html
    Merijn is the author of HijackThis and other ant-malware programs, so I have complete confidence that this is a legitimate copy.
    The copy that I have is from my saved WinMe files that I created before I took Me off my system. I don't really know whether this file is system dependent or not. So in order not to have any questions about it, a fresh copy I think would be better.
    Regards - Charles
  14. 2005/02/28
    Adam Wal
    cool, thanks now the control panel is back up working.
    Thoughh like i said before, my mam and dad are insiting on reformating the computer
  15. 2005/02/28
    charlesvar
    Hi Adam,
    A few more suggestions:
    Run the on-line virus checkers linked to in this page: http://www.windowsbbs.com/links.php
    And download MS's Anti-Spyware app, link for it on this page: http://www.windowsnewsletter.com/current-issue.html
    Quite good - at the moment it has the best record for detection and removal. It comes with resident protection which I don't use - I have other defenses, whether you want to devote the resources to it is for you to judge.
    If you do reformat, consider installing XP, no 9X resource bottleneck - handles memory much better.
    Regards - Charles
  16. 2005/03/04
    Adam Wal
    I now have xp installed, and it seems to be alright, apart from one thing...
    I cant find my sound drivers, anywhere
    Can you help in this matter?
    and do you know how to find out what your sound card is?
  17. 2005/03/04
    charlesvar
    Hi Adam,
    Right click My Computer > Hardware > Device Manager > Expand Sound video tree.
    Double click Legacy Drivers
    In that tree, should be a name such as Creative SB Live (mine) - Double click that.
    Double clicking on these items takes you to a page that will show the Device Status.
    Are there any yellow question marks next to any of the devices?
    Now that you have XP, you should post in the XP forum, you're post will be looked at by far more people :)
    Regards - Charles
