ME home network setup problems!!!!
Discussion in 'Networking (Hardware & Software)' started by Dna2k3, 2002/12/01.
  1. 2002/12/01
    Dna2k3
    Dna2k3 Inactive Thread Starter
    ok so here it is: i have a highspeed dsl from sympatico.since i have ME i went and dled the access manager so it can support ME and i did. So when i click on access manager and tried to connect to the net it says "the program failed to locate a suitable adapter to make a connection.it appears that you need to install an adapter into your computer." thats one of the problems..
    SECOND: HOW DO I NETWORK WITH THIS ME ****!!!! i went to home networking places tried to setup a home network and did, but when i tried to open my entire network so i can connect to the other pc which iam using now(xp) it says "Unable to browse the network. Windows is unable to gain access to network. "
    if u know whats the problem plz reply..
  2. 2002/12/01
    Dagga
    Dagga Inactive
    With xDSL you need 2 network cards if your wanting to share your xDSL connection to the rest of your LAN.
    Internet<----->|1NIC - NIC2|<------->Your LAN
    Or
    You might be able to use internet connection sharing (haven't used this is a long while)?
    If you have another box floating about you could use this as your internet gateway/firewall/NAT. Read this for some ideas:
    http://www.wpool.com/guides/gateways.html
    Or(again)
    Start from scratch and learn how to setup a unix based firewall/NAT gateway. Either Redhat or OpenBSD will do this for you. I use OpenBSD, very secure!
    Cheers
    Dagga
    Dna2k3
    nonono.. i already have 2 ethernets in and i got a linksys hub when i used to have 98 on the other one which is now ME it used to work fine i used to share internet and files and etc... but now i dont know whats wrong with it. it wont let me network nore connect to the net individually on ME.. any suggestions?
  5. 2002/12/02
    Dagga
    Dagga Inactive
    ah! Your connecting ME to a XP machine (pays to fully read your first post, duh!) On your XP machine you need to use a password with your user account.
    Then create your shares these are read only shares, change if you want write access.
    Make sure both work group names are the same.
    Create a user account for your ME machine (on the XP machine) or use the same user name/password as your XP Machine.
    I'm in in the right direction here?
    Cheers
    Dagga
  6. 2002/12/02
    Dna2k3
    hehe sry but iam lsot here what exactly do i have to do, to fix this??? and take a look at my first problem plz cause iam having problems connecting the ME pc to the net without the network hub i jsut cant connect it.. plus can u plz give me instructions on what your supposed to do to network to ME?
  7. 2002/12/02
    Dna2k3 - more information please.
    1. Please say what NICs (network interface cards) you are using in the ME PC. And if you got new drivers for them when you changed over to ME from 98.
    1.a. If you are connecting directly from the ME PC to your modem, you will need to use the same cable that once connected modem and hub. It may not be wired the same as a PC <-> Hub cable (probably isn't) and if you have the wrong sort of cable, you don't get a connection.
    2. What are you using to allow internet sharing and which PC is in control of that?
    3. On the ME PC, do start~run~winipcfg, click the button for details, and post all the information you get.
    4. For ME and XP to network together properly, you will need to do as Dagga said. Here it is in a little more detail.
    - you must be logging on to both PCs. Username and password both and you will have better luck. You can use the same logon for each if you want.
    - if you choose to use different user names, you will need to add the ME username/password to the list of users the XP PC knows about. So, from the XP PC, right-click My Computer and select manage. Go to the users & groups section, open the users folder, and add the ME user & password.
    #6
  8. 2002/12/02
    Dna2k3
    ok nevermind guys i got it fixed. and i dont think its true to what dagga said cause mine now works like crystal. u dont need to do all the password thing u told me about. so iam fine guys, thanks anywayz.
  9. 2002/12/03
    Be nice if you said how you got it fixed.
    Only way I can think of to avoid having username/password on ME that XP knows about is to enable the guest account. You can certainly do that but it leaves the XP box way too wide open for my taste.
    #8
