Manual entry of URLs
Discussion in 'Internet Explorer & Microsoft Edge' started by OldBob, 2004/06/07.
  1. 2004/06/07
    OldBob
    OldBob Inactive Thread Starter
    I fixed a problem with IE 6 that had been infected with the CoolWebSearch trojan. Now the user has to type in the full url
    i.e. http://www.windowsbbs.com....
    Normally, you don't have to insert the http://, windows will insert that for you. What's happened here ... any ideas.
    The good news is that CoolWebSearch is gone.
    Thanks for any help
  2. 2004/06/07
    Welshjim
    Welshjim Inactive
    OldBob
    That did take me to the answer. the registry entry for www was empty. It should have been http://
    Thanks a bunch
  5. 2004/06/07
    Welshjim
    Welshjim Inactive
    OldBob--Thanks so much for posting back. Always good to hear a suggestion helped.
