Making web pages display right
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by KevinB52379, 2003/01/16.
  1. 2003/01/16
    KevinB52379
    KevinB52379 Inactive Thread Starter
    As I recall there was a command that could be added to the user.js file to make it so that web pages displayed properly. There is still a problem with MS pages displaying right, such as www.microsoft.com/windowsmedia
    What is the command to add? I am using netscape 7.01. I know there is one, I had it before. Is there an updated one that works better at displaying web pages than the older one did? I thought that MS pages eventually did display right in netscape 7 but they look wrong in NS 7.01 again. But anyway any ideas?
  2. 2003/01/16
    Ramona
    Ramona Geek Member Alumni
    Hi Kevin,
    This is most likely the User Agent String Spoof you are remembering:
    user_pref( "general.useragent.override ", "Mozilla/5.0 (Windows; U; Windows NT 5.0; en-US; rv:0.9.4) Gecko/20011022 Netscape6/6.2 ");
    Ramona :D
    KevinB52379
    Ok I used that command in my user.js file in my c:\windows\application data\mozialla\profiles\default\xxxx.slt folder and it didnt fix this problem. I am running Windows ME
    Please go to www.microsoft.com/windowsmedia
    Perhaps someone will see what I mean. The page is chopped off basically. You cant see the links on top and there's a little horizontal line in the windows logo on the left. I thought thee was a trick that would make pages such as MS ones display correctly. By the way I created a text document, put that command in, turned off word wrap. then I saved it as user.js. opened the browser and the page still displays incorrectly
