Machine compatibility
Discussion in 'Legacy Windows' started by MrBill, 2012/10/26.
  1. 2012/10/26
    MrBill SuperGeek WindowsBBS Team Member Thread Starter
    Can't find a site to check if a PC will run Win 8 like M$ had for Win 7. I can find the specs for a machine, so I guess that it will have to do.
  2. 2012/10/27
    Hi Bill. Is the machine a pre-built OEM machine or is it a custom build?
    How old is the machine? What OS does that PC run now?
    The one in my specs. I have XP on one HD and Win 7 on the other. Thinking about getting rid of XP and upgrading to Win 8 just for kicks. I have room to add another HD if need be. I don't hardly use XP anymore. Just update it and all my security programs on it every month or so. I am pretty sure that it will run fine on it.
  5. 2012/10/27
    SpywareDr
    Microsoft.com > Windows 8 system requirements
  6. 2012/10/27
    Then that machine should work fine with Windows 8. Just note that your HD 4350 is no longer being supported by AMD since they stopped making new drivers for the HD 2000, 3000, and 4000 series of video cards.
