Inactive Lost system restores
Discussion in 'Malware and Virus Removal Archive' started by chuckmg, 2010/11/01.
  1. 2010/11/01
    chuckmg Contributing Member
    chuckmg Inactive Thread Starter
    [Inactive] Lost system restores
    Broni,
    You resolved the virus problems I was having with my wife's NancXP system:
    My system, ChuckXP, showed signs of having a virus so I tried to repeat the detailed instructions you had provided then and have saved all the logs except GMER log which I could not get to run ... even in SAFE mode. None of the logs indicated any virus or malware except for the Kaspersky which I ran last. Your instructions said to run Kaspersky online ... but the online version would not run since I had it installed. Hence I did a complete scan with the installed version.
    This time Kaspersky found a system restore infection and I let it be quarantined. Since this did not improve my system's performance, I decided to restore to some previous date. When I went to do a system restore, there were no system restores prior to that day.
    When I went to restore from an Acronis backup, I found that it had stopped backing up the Boot Drive(C) in August and had not alerted me.
    Looks like I'll have to re-install the OS ... if so, plan to simply install Win 2007.
    Any comments?
  2. 2010/11/01
    Well, it'll be up to you.
    We can check your existing installation, or you want to reinstall Windows.
    Let me know, what you want to do.
    Thanks, Broni, but I think I'll clean house and go with Win 7.
    Chuck
  5. 2010/11/01
    No problem :)
    Good luck :)
