Login Problem
Discussion in 'Windows XP' started by PCFarmer, 2008/12/15.
  1. 2008/12/15
    PCFarmer
    PCFarmer Inactive Thread Starter
    I have this strange login problem that recently started after changing my hard drive for a larger one which I reloaded with a Norton Ghost Image. I also uninstalled Norton Internet Security and installed Kaspersky Internet Security but I don't this this is the cause of the problem.
    The login problem occurs when I switch on the PC and leave it about five minutes before logging in (CTRL-ALT-DEL). I get the startup music and desktop background but no start menu, taskbar or any desktop icons. If I login without delay my login works fine.
    I am using Windows XP Pro with SP2. Don't really want to install SP3 yet because I am in the middle of writing a device driver that depends on SP2 symbol files.
    I created a new account and the same happens so it looks as though the problem is common to all accounts (although I have only tried two of them).
    When the problem occurs I cannot CTRL-ALT-DEL to determine if explorer has started or not, in fact the keyboard is completely dead. CTRL-ESC does not work either but I am certain the taskbar has not been lost because when I do login successfully its there in the correct place and autohides as it should.
    Kaspersky has not reported any problems and I have also run HouseCall by Trend Micro which reports no problems (apart from one or two cookies and some Windows updates that I have not yet applied).
    Anyone seen this before or got any ideas?
    Regards PCFarmer
  2. 2008/12/15
    Besides Not leaving the pc till you've logged in, does the XP screen saver kick in?
    You should be getting a pre login type screen saver.
    PCFarmer
    Hi Steve,
    The pre-login screen saver is as normal and I have not left the PC on long enough to see if the usual screen saver kicks in.
    I have started the PC in safe mode, then exited and then started again in normal mode and the problem seems to have been resolved but I don't see why.
    Any idea why this would solve the problem?
    Regards PCFarmer
