Load Balancing with Dial-Up modems possible?
Discussion in 'Windows XP' started by Debug, 2002/04/28.
  1. 2002/04/28
    Debug
    Debug Inactive Thread Starter
    Hi
    I'm trying to blance the Net load off 2 modems dial-up to 2 ISP's (2 seperate dial-up connections connected).
    In africa the ISP's havent heard of multi-linking.
    If you connect in this manner, the load is shifted to the last connection and the 1st simply idles.
    Hoping someone know of a way to keep things balanced.
    I found a registry setting to enable load balancing - but it only works on network adapters.
    Regards
    Debug
    BTW: Maybe this is helpful if you need to Log Off = and log on again with another account but keep your dialup connected (it will disconnect if you log off) :D
    Registry entry:
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
    "KeepRasConnections "= "1 "
  2. 2002/04/29
    Dorfmann
    Dorfmann Inactive
