Linksys WRT54GX v2 as wireless range extender
Discussion in 'Networking (Hardware & Software)' started by andre123, 2009/07/01.
  1. 2009/07/01
    andre123
    andre123 Inactive Thread Starter
    Just wondering if i can use a Linksys WRT54GX v2 as a wireless range extender/repeater. i went to www.dd-wrt.com and they say that the WRT54GX is "not possible" but i dont know if the dd-wrt firmware is what i need..
    thanks for any help you throw my way..
  2. 2009/07/01
    I don't think so. From the Linksys Datasheet:
    dd-wrt firmware will not work on that particular Linksys router.
  5. 2009/07/01
    andre123
    so I'm sh!t out of luck with this router? if so is there any router that u do recommend that is cheap and effective
    thx again
  6. 2009/07/02
    http://www.dd-wrt.com/dd-wrtv3/dd-wrt/hardware.html
    Search for wrt65g abd see which models are supported.
    Or just get an access point (no router). Most stand alone access points can be used as repeaters. Or you can run a wire to the access point which is located up to several hundred feet away.
