Resolved LG W1934S(monitor) Problem
Discussion in 'PC Hardware' started by iHD, 2011/11/11.
  1. 2011/11/11
    iHD
    iHD Inactive Thread Starter
    Hello everyone...
    i got a LG monitor when i plug in, the buttons down to the screen turn on
    but the screen no!!!
    where should be the problem ?
    iHD,
  2. 2011/11/11
    wildfire
    wildfire Getting Old
    Hi iHD, Welcome to WindowsBBS :D
    I assume you mean that you can turn the monitor on but don't get any picture?
    If so do you see a No Signal message or similar?
    What colour is the LED when you turn the power on?
    iHD
    Yes i can turn on the monitor but i get no picture, nothing show on the screen
    Screen stay black.
    LED is blue
    iHD,
    wildfire
    Ok, sorry I can't help with this just now (I gave my old LG monitor away to a friend and won't see it for a week or so). To be honest I was hoping for a Red/orange or Green/Yellow (I'm colour blind) LED. I'm not too sure what blue represents.
    I'll leave this for others to answer and perhaps follow up next week if no one else can help.
  6. 2011/11/11
    iHD
    ok no problem :)
    iHD,
    #5
  7. 2011/11/11
    hawk22
    hawk22 Geek Member
    It is like mine, blue is "On "
    If possible, you might have to try another Monitor in order to establish whether or not you are getting a signal from your computer.
    At least then you will know if the problem is the Monitor or the Computer.
    hawk22
  8. 2011/11/12
    iHD
    Yes im using a different monitor now everything is ok.
    iHD,
    #7
  9. 2011/11/12
  10. 2011/11/12
    iHD
    Why should i do that ?
    i haven't repaired the monitor im asking for ...
    Hawk22 asked me to test if the monitor was the problem and not the desktop
    And read my reply i said im using a different monitor right now and every thing its fine with the desktop or graphic card, the problem is at the other monitor.
    iHD,
    #9
  11. 2011/11/12
    lj50 Lifetime Subscription
    Do you have another desktop to test the LG monitor on and if the monitor works it might be the graphics card.
  12. 2011/11/12
    iHD
    omg...
    The desktop WORKS FINE problem is the monitor
    im using a different monitor on the same desktop and everything is ok
    so the problem is LG monitor.
    iHD,
    #11
  13. 2011/11/12
    I wanted you to test the LG monitor on a different computer. Just to see if the monitor works at all and if it does work it might be your graphics card. If it does not work then it is the monitor. Just a process of elimination.
  14. 2011/11/12
    iHD
    Dude you don't understand me. There is no PROBLEM with my desktop im
    100% sure for that (im using it right now with another monitor). The problem is monitor when i plug in i get no
    message at the screen everything is black only the Turn on button is BLUE.
    iHD,
    #13
  15. 2011/11/12
    Because you have established that the monitor is faulty - end of story.
  16. 2011/11/12
    iHD
    i already knew that.
    I just need to know where should be the problem Screen ? Power supply ?
    iHD,
    #15
  17. 2011/11/12
    You posted that the blue led comes on so the odds are that the Power Supply is OK.
    So it's likeky to be an internal fault - are you using the same video cable for the substitute monitor - if so it is not a cable problem.
  18. 2011/11/12
    iHD
    the blue led is on but nothing show up on the screen.
    and i tried the same cable at another monitor and its ok.
    iHD,
    #17
  19. 2011/11/12
    It's clear then that the monitor has an internal fault.
  20. 2011/11/12
    Sorry about that.
