Lavel and volume+
Discussion in 'Other PC Software' started by omedodoza, 2003/02/22.
  1. 2003/02/22
    omedodoza
    omedodoza Inactive Thread Starter
    How can I write a command to performed a quich farmat of a diskette in drive A with the volume label "world2disk "?
    What happend when the followin format is issued? Format E: where E: is a CD-RW?
    HOw can I write a command to include "world2" in the standard command promt?
    How can I write a command to to produce a directory listing of all the READ-ONLY Files in the COMPUTER subdirectory? Wht command should I used?
    I want to change to the root directory of the current drive, what command should I used?
    I want to remove the Energy subdirectory and all the files stored as well. What command do I need to type?
    Is the followinf command ok A:\> Copy C:world2.txt? I am trying to make a copy of a file named world2.txt currently on the root of C on the root of Drive A.?
    How can I Print a directory listing to the screen of all files ending in rtf extention on the D drive IN the Subdirectory world2?
  2. 2003/02/22
    Ian Harvie
    Ian Harvie Inactive
    In refrence to your post here :
    http://www.windowsbbs.com/showthread.php?s=&threadid=14953 the steps are basically the same.
    When using DOS an asterisk '*' is used as a wild card to help the manipulation of multiple files.
    format A: /Q /V:World2disk
    You will get an error, Microsoft does not support the erasing or formating of CDs in DOS, possibly 3rd party utilities will allow this but at present you will need to do it from windows.
    I'm not quite sure what you mean here... its possible to turn c:\ into something totally different, but I doubt thats what you want. :-|
    dir /A:R
    /A = attributes
    :R = attribute Read-Only
    CD\ will return you to the current drive
    deltree energy
    yes when located A:\, copy c:world2.txt should work :D
    the slowest way would be to cd into the sub directory on the d drive and then dir *.rtf, the fastest way from the root of any drive would be to type dir D:\world2\*.rtf
    my own question... isn't this in the XP section ? ;)
    ALSO this looks suspiciously like an educational assessment/exercise ... I hope its not :eek:
    *eyes them suspiciously*
    hope that helps :)
    Ian.
