Laptop Problems [NTOSKRNL.EXE is missing or corrupt]
Discussion in 'Windows XP' started by adrianv, 2009/07/18.
  1. 2009/07/18
    adrianv
    adrianv Well-Known Member Thread Starter
    Hello, I am having a problem with my Laptop, details below. I would appreciate any help.
    inspriron 6400
    T2300 @1.66GHz
    1.66GHz, 1.99GB of RAM
    Micorosoft Windows XP
    Home edition Version 2002,
    Service pk2.
    About a month before the rest of the issues
    First thing to go was the Battery-Microsoft ACPI\PNP0C0A\1 Battery Control method compliant.
    I usally had the laptop powered through AC, so the battery did not get much use but I never took it out of the pc,
    anyhow- Turned on the laptop one day & a Low battery warning appeared so I had a look in power options but the battery was not present.
    Pluged out the AC power & the laptop shuts down straight away.
    (Error message file missing or corrupt- NTOSKRNL.EXE is missing or corrupt.)
    Second- Touchpad Synaptics PS/2 port poninting device - Not registering movement or if it did it would be really really slow, or shoot across the screen but mostly just stuck in the one place.
    Third- Keyboard Microsoft Standard 101/102 Natural PS/2 keyboard- Again Not registering when you press the keys, you have to press really hard three or four times to get one character.
    (When I plug-in a USB mouse & keyboard I have it works fine.)
    Fourth- Network Card Broadcom 440x 10/100 integrated controller not registering any cable connection, device manager is saying all is fine & checked Computer Services but nothing I could see that was disabled.
    tried reinstalling but the same story Error message file missing or corrupt-NTOSKRNL.EXE
    adrianv is online now Add to adrianv's Reputation Report Post Reply With Quote
  2. 2009/07/18
    adrianv
    Thanks for your reply. I will let you know how I get on.
