Laptop cooling fan
Discussion in 'PC Hardware' started by Bubba, 2006/05/24.
  1. 2006/05/24
    Bubba
    Bubba Inactive Thread Starter
    My laptop cooling fan keeps cycling, is that normal? I thought it should run all the time like my desktop PC?
  2. 2006/05/24
    That is normal behaviour - the fan will run when the temperature of the processor reaches a certain level and cut out when the temperature is reduced. Mobile processors run much cooler than desktop processors and do not require constant fan cooling.
    No, they are capable of running much hotter, some as high as 100˚C/212˚F, so they do not require constant cooling...
    Thanks for the correction - live and learn :)
  6. 2006/05/24
    Bubba
    Thanks for the responses, I feel better now.
  7. 2006/05/24
    Rockster2U
    Rockster2U Geek Member
    Maybe some are capable of running hotter but on the AMD side of the fence, they run at lower wattage and are thus designed to run cooler than their desktop counterparts. There are obvious differences between desktop cooling devices and laptop cooling devices so the bottom line may tip the scales back to an advantage for desktops, however, if a laptop CPU and a desktop CPU are run in the same hardware environment, the laptop cpu is going to generate less heat (again, from an AMD perspective - I'm an ignoramus when it comes to that other company's stuff).
    You rolled over quickly on that one Pete - Mr. Churchill would admire your statesmanship.
  8. 2006/05/25
    Me too :)
  9. 2006/05/25
    I'll wade in.
    Mobile processors were made for the confined space of a laptop configuration. Mobile processors can be successfully overclocked in a desktop setup with apparent ease,but I doubt you could run a desktop processor with the standard settings in a laptop.
    My guess, mobile processors may be underclocked relatives of the desktop processors (that way they will run cooler).
    I don't think you will find a laptop that can be "easily" overclocked...because they want an allowance for maximum processor capacity...without burning out from restricted cooling.
  10. 2006/05/25
    Both Intel Pentium M Processor with 2-MB L2 Cache and 533-MHz Front Side Bus and Intel® Coreâ„¢ Duo Processor and Intel® Coreâ„¢ Solo Processor on 65 nm manuals state:
    You can see (from the manual) that they are designed to run up to 100 °C
    Was a bit more trouble finding AMD mobile temps, but located a data sheet for AMD Turionâ„¢ Mobile Technology which gives 95 °C as Max die temp.
