LAN interface gets unplugged
Discussion in 'Networking (Hardware & Software)' started by ralfska, 2004/12/17.
  1. 2004/12/17
    ralfska
    ralfska Well-Known Member Thread Starter
    Hi,
    maybe someone out there came across a similar issue like me:
    my problem is that occassionally I get disconnected from my IPS, because
    the LAN interface suddenly indicates "unplugged" while the cable is
    phisically plugged in. The strange bahavior cannot be predicted. It
    repairs itself when restarting the PC or unplugging and plugging the
    network cable (however the phisical connection is OK, for sure). I use the
    ONBOARD LAN and the latest drivers downloaded at Broadcom. The NIC is
    Broadcom NetXtreme Gigabit Ethernet Windows XP (32 bit) version 7.86
    11/23/04 75KB. A checkbox to allow to save power at the Broadcom
    NetXtreme Gigabit Ethernet is UNchecked. I've already tried to reinstall the network card. The BIOS is the latest. There is an option like LAN boot ROM which is disabled in bios - I'm not sure what it is for, however.
    I'm running Windows XP Pro SP2, motherboard ASUS A7V8X, Athlon 1800+ processor, a 300W power adapter, DDR RAM 512MB.
  2. 2004/12/17
    Miz
    Miz Inactive Alumni
    Have you tried the "limited or no connectivity" fix for SP2 systems discussed in Dez Bradley's sticky post at the top of this Networking forum? I used it weeks ago after getting disconnected numerous times a day. I haven't had any trouble with disconnects since.
    Miz,
    ralfska
    Thank you for the hint. Perheps I will try the fix, but before I want to determine whether there is everything OK with my NIC.
    Do you know of a good software which helped me test my network card? :)
  5. 2004/12/18
    Miz
    Miz Inactive Alumni
    My experience has been that a network card either works or it doesn't...meaning, if it works at all, it's okay.
    However, take a look at How to Test a Network Adapter if you want to make sure.
    Miz,
