Lan and wireless cant in 1 computer?
Discussion in 'Networking (Hardware & Software)' started by whis, 2006/12/05.
  1. 2006/12/05
    whis
    whis Inactive Thread Starter
    Hi All,
    I have 1 laptop using 2 connection, 1 is Lan and 1 is wireless network.
    Lan use to connect to server ( Server no internet connection)
    Wireless use to connect to internet.
    When i have 2 connection on, I cant access to internet.......
    How to fix this problem.
    My server is running Novell netware 6.5
    My laptop is running XP SP1.
    My wireless router is D-Link DI-524
    Below is the test i do for my computer.
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : TOSHIBA
    Node Type . . . . . . . . . . . . : Unknown
    Ethernet adapter Local Area Connection:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Ethernet NIC
    Physical Address. . . . . . . . . : 00-02-3F-7D-F1-7D
    Dhcp Enabled. . . . . . . . . . . : No
    IP Address. . . . . . . . . . . . : 192.168.0.3
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.0.1
    DNS Servers . . . . . . . . . . . : 202.188.0.133
    202.188.1.5
    Ethernet adapter Wireless Network Connection:
    Description . . . . . . . . . . . : D-Link AirPlus G DWL-G122 Wireless USB Adapter(rev.C)
    Physical Address. . . . . . . . . : 00-17-9A-81-68-92
    IP Address. . . . . . . . . . . . : 192.168.0.100
    202.188.1.5
    whis,
  2. 2006/12/05
    Jason Qi
    Jason Qi Inactive
    You IP addresses have problems.
    192.168.0.3/24 and 192.168.0.100/24 are in the same IP segment.
    You can change either Dlink router or Novell netware Server's DHCP setting to let your "lan" and wireless network in different segments.
    For example:
    You can set your "lan" IP address as 192.168.1.x instead of 192.168.0.x
    whis
    i was try this and it was work.
    But i try on other PC running XP SP2, it not work..........
    please help... Thank you.
    whis,
    whis
    No body know? ..................:(
    whis,
    Bill Castner
    Bill Castner Inactive
    There is no need to subnet your connections; both had perfectly valid IP addressing from your ipconfig results.
    Nor do you need both connections. Your results for both wired and wireless adapters show a proper Gateway, and enumeration of DNS servers. In other words, you have a valid internet connection on both adapters through the router.
    XP does not mind having two connections; however, because of your likely use of automaticly assigned metrics, only the wired connection would be in use. It would be effectively the same as not having a wireless connection at all. See the Microsoft "Cable Guy" discussion: http://www.microsoft.com/technet/community/columns/cableguy/cg0405.mspx
    So the issue then remains: why cannot you get out on the internet. We would have to know a lot more information, but one reason is that site policies using IPSec are blocking you.
    As a pure guess, lets at least remove any possible Winsock corruption issues as a possible cause. Download WinsockFix: http://www.tacktech.com/pub/winsockfix/WinsockFix.zip
    Unzip to a new folder, and run the application. When it finishes, reboot and test.
    But no matter what, I can absolutely assure you that having both wired and wireless connections is not the source of your problem.
