kodak image viewer problem
Discussion in 'Legacy Windows' started by Grantx, 2006/11/09.
  1. 2006/11/09
    Grantx
    Grantx Inactive Thread Starter
    When I select Kodak image viewer to view a jpg file, the image occupies the enter screen and I cannot find any way to exit (clear the screen) except using task manager to "End Task ". Problem started when I selected "full screen" and apparently did something wrong. Before that the Kodak image viewer worked fine for years. Is there any way to fix this without re-installing Win2k? Any suggestions appreciated. :)
    Grant
  2. 2006/11/09
    sparrow
    sparrow Inactive
    Try increasing screen resulution (rt-clk blank screen area and choose properties, then settings tab and drag 'Screen resolution' slider to right one or more places).
    If it's really 'full screen', you can displace a window thar's in the way by the keystrokes alt-spacebar n. Would also try the esc key and also F11 to see if they work; and usually the key that produces full screen toggles and hitting it again produces normal view.
    Grantx
    Thanks, Sparrow. Sure glad I joined this forum! It was not possible to access the screen properties with a rt clk but esc+F11 solved the problem.
    Grant
