Resolved keys transposed: shift + @ gives " ...
Discussion in 'Windows XP' started by bobox, 2010/04/22.
  1. 2010/04/22
    bobox
    bobox Inactive Thread Starter
    Folks,
    An easy one for the expertise here, I'm sure.
    I rebuild my IBM T42 laptop recently and all works well except that some keys aren't giving me what I expect, specifically
    key for 2 (shift for ") gives me 2 and (shifted) @
    key for ' (shift for @) gives me ' and (shifted) "
    key for # (shift for ~) gives me \ and |
    (the key for \ (shift for |) gives me \ and |, too; and i haven't been able to find hash and tilde assigned to any other keys [I had to paste these symbols in from Excel])
    I'm sure there's a trivial explanation for this ... and I'll be very grateful to hear it ...
    TIA
  2. 2010/04/22
    The odds are that you have the wrong keyboard language installed - USA is the default
    Control Panel > Regional & Language ......
    Check the correct language is set - keyboard underLanguages tab - Text services abd Input Settings > Details.
    bobox
    sorted: thank you
    The odds were spot on - thank you. I had also acquired a tick in the supplemental langugae support boxes, removal of which freed up some more space.
  5. 2010/04/22
    You're welcome :)
    Please mark this thread as 'Resolved', see .....
