Keyboard Problems
Discussion in 'PC Hardware' started by attackofbobs, 2006/03/14.
  1. 2006/03/14
    attackofbobs
    attackofbobs Inactive Thread Starter
    My keyboard is playin up. When i try to type in @ it always cums up with a ". this also happens with other buttons. can anyone help me please.
    Thanks.
  2. 2006/04/11
    Lesru
    Lesru Inactive
    I have been having the same problem since I installed a new hard drive (Windows 98SE). Definitely not the keyboard as I can use the same keyboard on another pc (Windows XP) and no problem. I have to use Shift 2 to get the '@' sign. I'm using a Belkin wireless keyboard and mouse with a kvm switch, but I've been using this for months without any problems. Any help?
    attackofbobs & Lesru - Welcome to the Board :)
    You both have the keyboard set to the US key pattern which is the default when installing XP.
    In Control Panel go to Regional and Language Options > Languages tab > Details and add the UK - or the appropriate keyboard for your location and remove the US keyboard.
  5. 2006/04/11
    Isn't shift 2 (upper case 2) the only way to get the @ sign or am I missing something?
  6. 2006/04/11
    Not in the UK :D
    Shift + 2 gives you " on a UK keyboard, @ on a US keyboard
  7. 2006/04/11
    Lesru
    Lesru Inactive
    Thanks PeteC - worked first time. :eek: Good welcome! :D
