Keyboard Problems
Discussion in 'Windows XP' started by Mopman43, 2012/05/24.
  1. 2012/05/24
    Mopman43
    Mopman43 Inactive Thread Starter
    My keyboard works when I am typing, but whenever I try to play a game online, it doesn't work at all for that. I have a Windows HP Labtop, not sure of other facts about it.
  2. 2012/05/24
    Welcome to BBS.
    Can you give us a link to one of the games?
    jaydeee
    jaydeee Inactive
    guess it has something to do with the settings of your game. If you can try to set your game settings to default I guess that would help.
  5. 2012/05/25
    Mopman43
    No no, see, it is not 1 game, or 1 site, it is, more or less, all the online games I play that require the keyboard.
  6. 2012/05/25
    See post # 2.
  7. 2012/05/25
    Mopman43
    Do you have the latest version of Adobe Flash Player installed? It shoule be 11.2.202.235
  9. 2012/05/26
    Mopman43
    Could I have a link?
    Because I don't really know...
  10. 2012/05/26
    Look in Control Panel/Add or remove programs and it will tell you what version you have.
    Here is the link also. http://get.adobe.com/flashplayer/ Be sure to uncheck the Google Tool Bar unless you want it.
  11. 2012/05/26
    Mopman43
    The link said I already had it, but my control panel says I have version 10.
  12. 2012/05/26
    Uninstall it then go back and get it again.
  13. 2012/05/26
    Mopman43
    Well, I uninstalled and re installed everything I could see labeled adobe, but your link said the same thing it has the whole time
    "Your Google Chrome browser already includes Adobe® Flash® Player built-in. Google Chrome will automatically update when new versions of Flash Player are available. "
  14. 2012/05/26
    Instead of using Google Chrome, try using IE and see what happens with the keyboard.
  15. 2012/05/27
    Mopman43
    I've already tried that, but the game won't actually load.
    And with Firefox, it runs so slow I can't do anything.
