Keyboard language icon in system tray
Discussion in 'Legacy Windows' started by shadowhawk, 2003/08/21.
  1. 2003/08/21
    shadowhawk
    shadowhawk Inactive Thread Starter
    I downloaded some **** in IE a while back that allows me to swtich keyboard languages from the taskbar. Whenever I start my browser (IE or Mozilla, it doesn't matter) the blue En icon shows up on my system tray. I right clicked it and clicked on Properties, but the option to remove it from the system tray is grayed out. Is there any way to get rid of it?
  2. 2003/08/21
    Welshjim
    Welshjim Inactive
    shadowhawk--Try Control Panel|Keyboard|Language tab. If checked, uncheck "enable indicatgor on taskbar ", click Apply|OK.
    shadowhawk
    That option is grayed out, as I indicated in my first post.
  5. 2003/08/22
    Welshjim
    Welshjim Inactive
    shadowhawk--I was suggesting getting at the option through a different route in hopes it might be available there.
    How about uninstalling the program that may have caused the problem?
  6. 2003/08/22
    shadowhawk
    That's just it, I didn't download any programs per say. I downloaded some kind of foreign language support and I don't know if it's uninstallable. It was something for IE so that I'd be able to type stuff in Japanese. But it appears when I use Mozy or AIM too.
