KB953356 - SP3 Fix for AMD Processors
Discussion in 'Windows XP' started by ackerberg, 2008/07/18.
  1. 2008/07/18
    ackerberg
    ackerberg Inactive Thread Starter
    108
    Long Island, NY
    Computer Experience:
    Experienced
    I noticd that MS released a download for those wanting to install SP3 on an AMD processor. Has anyone tried this? and have you had any problems?
    Thanks.
  2. 2008/07/18
    1,093
    Staffordshire, UK
    Usually not enough
    Have to be careful here - it only applies to loading an image produced on an Intel powered computer to an AMD powered computer ....
    Error message after you upgrade a computer that uses a processor other than an Intel processor to Windows XP Service Pack 2 or to Windows XP Service Pack 3: "STOP: 0x0000007E " ....
    My main box runs an AMD dual core CPU - I have installed several of the beta releases of SP3, the Release Candidates and now the RCM version, all without issue.
    ackerberg
    108
    Long Island, NY
    Experienced
    Pete,
    If you read the instructions carefully you will see that it recommends you install that file before installing SP3. They recently, this month July, seemed to have changed the writeup. Are you saying that this is not the way to avoid the problem of the rebooting?
  5. 2008/07/19
    1,093
    Most people wouldn't know.
    You can download it to any computer with a non-Intel processor. As the download page says:
    If you don't need it it won't do any harm.
    ackerberg
    108
    Long Island, NY
    Experienced
    I am a bit confused. Pete, are you saying this download doesn't solve the problem of the AMD processor continually restarting after an SP3 install? Or don't you know or are not sure?
  7. 2008/07/19
    1,093
    Staffordshire, UK
    Usually not enough
    Not at all - I merely pointed out, indirectly, that the problem was likely to occur on OEM computers which have an AMD CPU and were originally imaged at source with an image created on an Intel based computer.
    My own AMD based computer is home built and the OS installed from a retail CD - hence I experienced no issues. It would seem that the problem only arises on imaged drives as outlined above, but one wonders which CPU base was used to create the original XP CD and it's successors.
    Bottom line, as Arie has posted, installing the patch will do no harm if not required.
  8. 2008/07/19
    ackerberg
    108
    Long Island, NY
    Experienced
    Thank you.
