Issues with Permissions, Malware maybe involved!
Discussion in 'Malware and Virus Removal Archive' started by Evan Omo, 2008/03/27.
  1. 2008/03/27
    Evan Omo Computer Support Technician Staff Thread Starter
    Hi. On my dad's computer which is running Windows XP Professional, the problem was that Windows Explorer wouldn't load. I tried every possible solution I could think of and I couldn't get Windows Explorer to start up. My dad and I went to Bestbuy and bought a Windows XP Professional CD. I then got home and made a repair install of the OS. Everything went fine and when I logged on, Windows Explorer started up normally. :D I then proceeded to go to windows update to install all of the latest patches. The website wouldn't load and it hung on "Checking if your computer has the latest windows updating software for use with the website." The website would never load past that point and I don't recieve the prompt to load the ActiveX control. Anyway I recieved a lot of updates that were downloaded by Automatic Updates. When I tried to install them, they try to install but I get a notification that all of the updates failed to install. :mad: I've also tried to install Adobe Flash Player and Windows Media Player 11 but they both failed to install. I really have no idea as to why every update I try seems to fail? :( I have tried various solutions to reset the permissions to the defaults all without success. I have tried Dail a Fix, Microsoft Knowledge base Articles on resetting permossions, and follwing instructions from http://adobe.com/go/tn_19166 and http://windowssecrets.com/2007/09/27/03-Stealth-Windows-update-prevents-XP-repair. I don't know what else to try. If I can't solve this problem then I may as well just format the machine and start over. :(
    Here is the Deckard Log.
    Deckard's System Scanner v20071014.68
    Run by Robert Omo on 2008-03-27 15:49:55
    Computer is in Normal Mode.
    -- System Restore --------------------------------------------------------------
    Successfully created a Deckard's System Scanner Restore Point.
    -- Last 5 Restore Point(s) --
    18: 2008-03-27 23:50:18 UTC - RP18 - Deckard's System Scanner Restore Point
    17: 2008-03-27 23:26:45 UTC - RP17 - Software Distribution Service 3.0
    16: 2008-03-27 23:25:25 UTC - RP16 - Software Distribution Service 3.0
    15: 2008-03-27 21:04:51 UTC - RP15 - Installed Windows Resource Kit Tools - SubInAcl.exe
    14: 2008-03-27 20:40:45 UTC - RP14 - Installed Windows XP KB926239.
    -- First Restore Point --
    1: 2008-03-27 19:21:51 UTC - RP1 - System Checkpoint
    Backed up registry hives.
    Performed disk cleanup.
    -- HijackThis (run as Robert Omo.exe) ------------------------------------------
    Scan saved at 3:52:30 PM, on 3/27/2008
    MSIE: Internet Explorer v7.00 (7.00.5730.0013)
    C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
    C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
    C:\WINDOWS\system32\cisvc.exe
    C:\Program Files\Common Files\Microsoft Shared\VS7Debug\mdm.exe
    C:\Program Files\SiteAdvisor\6253\SAService.exe
    C:\Program Files\Spyware Terminator\sp_rsser.exe
    C:\Program Files\Common Files\AOL\1103495592\ee\AOLSoftware.exe
    C:\Program Files\SiteAdvisor\6253\SiteAdv.exe
    C:\WINDOWS\system32\cidaemon.exe
    C:\Documents and Settings\Robert Omo\Desktop\dss.exe
    C:\PROGRA~1\TRENDM~1\HIJACK~1\Robert Omo.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://red.clientapps.yahoo.com/customize/ycomp/defaults/su/*http://www.yahoo.com
    R3 - URLSearchHook: (no name) - {EA756889-2338-43DB-8F07-D1CA6FB9C90D} - (no file)
    R3 - URLSearchHook: (no name) - {BED5E28A-2A6A-01C6-3EEC-20807C4E0095} - (no file)
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
    O2 - BHO: (no name) - {089FD14D-132B-48FC-8861-0048AE113215} - C:\Program Files\SiteAdvisor\6253\SiteAdv.dll
    O2 - BHO: (no name) - {3464B9E7-2150-0FAE-0612-2F00CAB78F98} - (no file)
    O2 - BHO: Spybot-S&D IE Protection - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O2 - BHO: (no name) - {65D70B12-91A1-EC53-A448-9A2B28E18CC9} - (no file)
    O2 - BHO: (no name) - {E297D808-40EE-6A4E-BD5C-4B76621F0DC6} - (no file)
    O3 - Toolbar: McAfee SiteAdvisor - {0BF43445-2F28-4351-9252-17FE6E806AA0} - C:\Program Files\SiteAdvisor\6253\SiteAdv.dll
    O4 - HKLM\..\Run: [HostManager] C:\Program Files\Common Files\AOL\1103495592\ee\AOLSoftware.exe
    O4 - HKLM\..\Run: [SpywareTerminator] "C:\Program Files\Spyware Terminator\SpywareTerminatorShield.exe "
    O4 - HKLM\..\Run: [SiteAdvisor] C:\Program Files\SiteAdvisor\6253\SiteAdv.exe
    O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe "
    O4 - HKLM\..\Run: [MP10_EnsureFileVer] C:\WINDOWS\inf\unregmp2.exe /EnsureFileVersions
    O4 - HKCU\..\Run: [Weather] C:\PROGRA~1\AWS\WEATHE~1\Weather.exe 1
    O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
    O4 - HKCU\..\Run: [SpybotSD TeaTimer] C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
    O4 - HKCU\..\Run: [AOL Fast Start] "C:\Program Files\America Online 9.0a\AOL.EXE" -b
    O4 - Global Startup: Lexmark X125 Settings Utility.lnk = C:\Program Files\Lexmark X125\LEX125SU.exe
    O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
    O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O9 - Extra 'Tools' menuitem: Spybot - Search & Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} -
    O16 - DPF: {13EC55CF-D993-475B-9ACA-F4A384957956} (Controller Class) - https://www.windowsonecare.com/install/cli/1.0.0971.38/WinSSWebAgent.CAB
    O16 - DPF: {215B8138-A3CF-44C5-803F-8226143CFC0A} (Trend Micro ActiveX Scan Agent 6.6) -
    O16 - DPF: {4A3CF76B-EC7A-405D-A67D-8DC6B52AB35B} (QDiagAOLCCUpdateObj Class) - http://aolcc.aol.com/computercheckup/qdiagcc.cab
    O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} - http://download.av.aol.com/molbin/shared/mcinsctl/en-us/4,0,0,83/mcinsctl.cab
    O16 - DPF: {56393399-041A-4650-94C7-13DFCB1F4665} (PSFormX Control) -
    O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} (Windows Live Safety Center Base Module) - http://scan.safety.live.com/resource/download/scanner/wlscbase5059.cab
    O16 - DPF: {8167C273-DF59-4416-B647-C8BB2C7EE83E} (WebSDev Control) - http://liveupdate.msi.com.tw/autobios/LOnline/install.cab
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Plug-in) -
    O16 - DPF: {A90A5822-F108-45AD-8482-9BC8B12DD539} (Crucial cpcScan) -
    O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (ZoneIntro Class) - http://zone.msn.com/binFramework/v10/ZIntro.cab32846.cab
    O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} - http://download.av.aol.com/molbin/shared/mcgdmgr/en-us/1,0,0,20/mcgdmgr.cab
    O16 - DPF: {CAFEEFAC-0014-0000-0000-ABCDEFFEDCBA} (Java Plug-in) -
    O16 - DPF: {CAFEEFAC-0014-0002-0006-ABCDEFFEDCBA} (Java Plug-in) -
    O16 - DPF: {CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA} (Java Plug-in) -
    O16 - DPF: {CAFEEFAC-0015-0000-0005-ABCDEFFEDCBA} (Java Plug-in) -
    O16 - DPF: {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA} (Java Plug-in) -
    O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} -
    O16 - DPF: {E8F628B5-259A-4734-97EE-BA914D7BE941} -
    O16 - DPF: {EF791A6B-FC12-4C68-99EF-FB9E207A39E6} -
    O20 - Winlogon Notify: Extensions - C:\WINDOWS\
    O20 - Winlogon Notify: mllmk - C:\WINDOWS\
    O20 - Winlogon Notify: ShellCompatibility - C:\WINDOWS\
    O22 - SharedTaskScheduler: {03413bf7-e34c-445b-bfc0-a2b127255871} - incestuously - (no file)
    O23 - Service: AOL Connectivity Service (AOL ACS) - AOL LLC - C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
    O23 - Service: AOL TopSpeed Monitor (AOL TopSpeedMonitor) - America Online, Inc - C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
    O23 - Service: SiteAdvisor Service - Unknown owner - C:\Program Files\SiteAdvisor\6253\SAService.exe
    O23 - Service: Spyware Terminator Clam Service (sp_clamsrv) - Crawler.com - C:\Program Files\WinClamAVShield\sp_clamsrv.exe
    O23 - Service: Spyware Terminator Realtime Shield Service (sp_rssrv) - Crawler.com - C:\Program Files\Spyware Terminator\sp_rsser.exe
    End of file - 7179 bytes
    -- File Associations -----------------------------------------------------------
    .reg - regfile - shell\open\command - "%1" %*
    .scr - scrfile - shell\open\command - "%1" %*
    -- Drivers: 0-Boot, 1-System, 2-Auto, 3-Demand, 4-Disabled ---------------------
    R1 PQNTDrv - c:\windows\system32\drivers\pqntdrv.sys <Not Verified; PowerQuest Corporation; PowerQuest product>
    R1 sp_rsdrv2 (Spyware Terminator Driver 2) - c:\windows\system32\drivers\sp_rsdrv2.sys
    R2 ASCTRM - c:\windows\system32\drivers\asctrm.sys <Not Verified; Windows (R) 2000 DDK provider; Windows (R) 2000 DDK driver>
    S3 ENTECH - c:\windows\system32\drivers\entech.sys <Not Verified; EnTech Taiwan; PowerStrip>
    S3 TVICHW32 - c:\windows\system32\drivers\tvichw32.sys <Not Verified; EnTech Taiwan; TVicHW32 Generic Device Driver for Windows 95/98/ME/NT/2000/2003/XP/XP64>
    -- Services: 0-Boot, 1-System, 2-Auto, 3-Demand, 4-Disabled --------------------
    R2 sp_rssrv (Spyware Terminator Realtime Shield Service) - "c:\program files\spyware terminator\sp_rsser.exe" <Not Verified; Crawler.com; Crawler Spyware Terminator>
    S3 sp_clamsrv (Spyware Terminator Clam Service) - "c:\program files\winclamavshield\sp_clamsrv.exe" <Not Verified; Crawler.com; Spyware Terminator>
    -- Device Manager: Disabled ----------------------------------------------------
    No disabled devices found.
    -- Scheduled Tasks -------------------------------------------------------------
    2008-03-27 15:00:00 278 --ah----- C:\WINDOWS\Tasks\BDCDA72C91364728.job
    2008-03-27 15:00:00 276 --ah----- C:\WINDOWS\Tasks\BC6C25F691E7C8F2.job
    2008-03-27 15:00:00 276 --ah----- C:\WINDOWS\Tasks\B4FF56CD9134C1D1.job
    2008-03-27 15:00:00 280 --ah----- C:\WINDOWS\Tasks\AE4AA6E791895F0B.job
    2008-03-27 15:00:00 276 --ah----- C:\WINDOWS\Tasks\AB3827FB9183DDF7.job
    2008-03-27 15:00:00 276 --ah----- C:\WINDOWS\Tasks\AACB1CB0918490B8.job
    2008-03-27 15:00:00 276 --ah----- C:\WINDOWS\Tasks\A9F3FDE391847523.job
    2008-03-27 15:00:00 276 --ah----- C:\WINDOWS\Tasks\A6AE74A591EDEBA1.job
    2008-03-27 12:48:35 428 --ah----- C:\WINDOWS\Tasks\User_Feed_Synchronization-{754D0594-BE19-4EA4-B2FB-CF8418844CB2}.job
    -- Files created between 2008-02-27 and 2008-03-27 -----------------------------
    6137-61-37 13:76:09 0 dr------- C:\Documents and Settings\Evan Omo\My Documents
    2008-03-27 15:52:11 0 d-------- C:\Program Files\Trend Micro
    2008-03-27 15:19:57 0 d-------- C:\WINDOWS\LastGood
    2008-03-27 13:16:50 0 d-------- C:\WINDOWS\system32\CatRoot2
    2008-03-27 13:16:24 0 d--h----- C:\Program Files\WindowsUpdate
    2008-03-27 13:13:22 0 d-------- C:\Documents and Settings\Administrator\Application Data\Adobe
    2008-03-27 13:04:56 0 d-------- C:\Program Files\Windows Resource Kits
    2008-03-27 12:38:29 0 d-------- C:\Program Files\Windows Media Connect 2
    2008-03-27 12:33:36 0 d-------- C:\WINDOWS\system32\drivers\UMDF
    2008-03-27 12:12:20 0 d-a------ C:\Documents and Settings\All Users\Application Data\TEMP
    2008-03-27 11:55:20 0 d-------- C:\Documents and Settings\All Users\Application Data\Windows Genuine Advantage
    2008-03-27 11:17:00 0 d-------- C:\WINDOWS\Prefetch
    2008-03-27 10:36:21 0 d-------- C:\Program Files\Common Files\ODBC
    2008-03-27 02:18:06 0 d-------- C:\WINDOWS\Provisioning
    2008-03-27 02:18:06 0 d-------- C:\WINDOWS\PeerNet
    2008-03-27 02:18:06 0 d-------- C:\WINDOWS\ehome
    2008-03-24 19:41:25 0 d-------- C:\Program Files\Auslogics
    2008-03-24 19:12:39 0 d-------- C:\Documents and Settings\All Users\Application Data\Adobe
    2008-03-17 18:22:27 0 dr-h----- C:\Documents and Settings\Robert Omo\Recent
    2008-03-14 21:12:27 0 d-------- C:\Documents and Settings\Evan Omo\Application Data\Malwarebytes
    2008-03-12 20:38:33 0 d-------- C:\Documents and Settings\Robert Omo\LimeWire Store Purchased
    2008-03-12 19:31:11 0 d-------- C:\Program Files\SpywareBlaster
    2008-03-11 18:25:31 0 dr-h----- C:\Documents and Settings\Evan Omo\Recent
    2008-03-10 20:53:15 0 d-------- C:\Documents and Settings\Robert Omo\Application Data\Malwarebytes
    2008-03-10 20:52:46 0 d-------- C:\Documents and Settings\All Users\Application Data\Malwarebytes
    -- Find3M Report ---------------------------------------------------------------
    2008-03-27 15:47:18 0 d-------- C:\Documents and Settings\Robert Omo\Application Data\SiteAdvisor
    2008-03-27 15:19:22 0 d-------- C:\Program Files\WinClamAVShield
    2008-03-27 12:06:19 0 d-------- C:\Program Files\Spyware Terminator
    2008-03-27 11:43:10 0 d-------- C:\Program Files\Common Files\Adobe
    2008-03-27 11:38:05 0 d-------- C:\Program Files\Common Files\AOL
    2008-03-27 11:37:57 0 d-a------ C:\Program Files\Common Files
    2008-03-27 11:37:50 0 d-------- C:\Program Files\Common Files\aolshare
    2008-03-27 10:54:50 0 d-------- C:\Program Files\Movie Maker
    2008-03-27 10:52:09 23348 --a----c- C:\WINDOWS\system32\emptyregdb.dat
    2008-03-27 10:50:20 0 d-------- C:\Program Files\Messenger
    2008-03-27 10:50:14 0 d-------- C:\Program Files\Windows NT
    2008-03-24 20:11:33 0 d-------- C:\Documents and Settings\Robert Omo\Application Data\DeepBurner
    2008-03-19 18:16:32 0 d-------- C:\Documents and Settings\Robert Omo\Application Data\WeatherBug
    2008-03-17 17:51:17 0 d-------- C:\Documents and Settings\Robert Omo\Application Data\Spyware Terminator
    2008-03-12 20:39:10 0 d-------- C:\Documents and Settings\Robert Omo\Application Data\LimeWire
    2008-03-10 20:51:07 0 d-------- C:\Program Files\Common Files\Wise Installation Wizard
    2008-02-20 18:01:25 3932 --a----c- C:\Documents and Settings\Robert Omo\Application Data\LMLayout.dat
    2008-02-20 18:01:25 268 --a----c- C:\Documents and Settings\Robert Omo\Application Data\LMCPaper.dat
    2008-02-08 12:25:26 1632 --a------ C:\WINDOWS\system32\d3d8caps.dat
    2008-02-05 16:14:54 0 d--h----- C:\Program Files\InstallShield Installation Information
    2008-02-02 21:01:06 1744 --a------ C:\WINDOWS\system32\d3d9caps.dat
    2008-01-30 09:23:01 22576 --a----c- C:\Documents and Settings\Robert Omo\Application Data\GDIPFONTCACHEV1.DAT
    2008-01-15 18:11:12 618 --a------ C:\Documents
    -- Registry Dump ---------------------------------------------------------------
    [HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{3464B9E7-2150-0FAE-0612-2F00CAB78F98}]
    [HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{65D70B12-91A1-EC53-A448-9A2B28E18CC9}]
    [HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{E297D808-40EE-6A4E-BD5C-4B76621F0DC6}]
    "HostManager "= "C:\Program Files\Common Files\AOL\1103495592\ee\AOLSoftware.exe" [09/25/2006 04:52 PM]
    "SpywareTerminator "= "C:\Program Files\Spyware Terminator\SpywareTerminatorShield.exe" [02/14/2008 07:33 PM]
    "SiteAdvisor "= "C:\Program Files\SiteAdvisor\6253\SiteAdv.exe" [08/24/2007 01:57 PM]
    "Adobe Reader Speed Launcher "= "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [01/11/2008 10:16 PM]
    "MP10_EnsureFileVer "= "C:\WINDOWS\inf\unregmp2.exe" [02/28/2006 04:00 AM]
    "ctfmon.exe "= "C:\WINDOWS\system32\ctfmon.exe" [02/28/2006 04:00 AM]
    "Weather "= "C:\PROGRA~1\AWS\WEATHE~1\Weather.exe" []
    "MSMSGS "= "C:\Program Files\Messenger\msmsgs.exe" [08/04/2004 01:06 AM]
    "CheckRegDefragService "=" " []
    "SpybotSD TeaTimer "= "C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe" [01/28/2008 11:43 AM]
    "AOL Fast Start "= "C:\Program Files\America Online 9.0a\AOL.exe" [07/12/2005 06:17 AM]
    C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
    Lexmark X125 Settings Utility.lnk - C:\Program Files\Lexmark X125\LEX125SU.exe [10/31/2004 4:38:16 PM]
    Microsoft Office.lnk - C:\Program Files\Microsoft Office\Office10\OSA.EXE [2/13/2001 12:01:04 AM]
    [HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\explorer]
    "NoActiveDesktop "=00000000
    "NoSaveSettings "=00000000
    "ClearRecentDocsOnExit "=00000000
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\Extensions]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\mllmk]
    [HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\ShellCompatibility]
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\control\lsa]
    "Notification Packages "= scecli
    [HKEY_LOCAL_MACHINE\system\currentcontrolset\control\securityproviders]
    SecurityProviders msapsspc.dll, schannel.dll, digest.dll, msnsspc.dll,
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\aawservice "
    -- Hosts -----------------------------------------------------------------------
    127.0.0.1 babe.the-killer.bz
    127.0.0.1 www.babe.the-killer.bz
    127.0.0.1 babe.k-lined.com
    127.0.0.1 www.babe.k-lined.com
    127.0.0.1 did.i-used.cc
    127.0.0.1 www.did.i-used.cc
    127.0.0.1 coolwwwsearch.com
    127.0.0.1 www.coolwwwsearch.com
    127.0.0.1 coolwebsearch.com
    127.0.0.1 www.coolwebsearch.com
    8347 more entries in hosts file.
    -- End of Deckard's System Scanner: finished at 2008-03-27 15:53:40 ------------
  2. 2008/03/27
    noahdfear
    noahdfear Inactive
    Hi Evan :)
    Download SmitfraudFix by S!Ri, saving it to the desktop.
    • Restart the computer in Safe Mode and Logon to your account.
    • Double-click SmitfraudFix.exe to start the tool and press 2, then hit Enter.
    • You will be prompted 'Do you want to clean the registry?' answer Y (yes) and hit Enter.
    • If prompted to replace the infected wininet.dll file (if found), answer Y (yes) and hit Enter to restore a clean file.
    • Reboot to normal mode when the tool completes.
    Download ComboFix by sUBs from here, saving the file to your desktop.
    Please disable realtime protection applications as they sometime interfere with the tool. Check this link for your applicable programs.
    • Close all open programs and windows
    • Double click combofix.exe and follow the prompts.
    • It may reboot your computer and resume running when you logon. Wait for it to complete. When finished, it will open a log for you. Post the ComboFix log, the C:\rapport.txt log from SmitfraudFix and a new HijackThis log in your next reply.
    Note: Do not mouseclick combofix's window while its running. That may cause it to stall
    Hey Dave, thanks. Here are the logs you requested!
    Hijackthis Log
    Scan saved at 9:12:05 PM, on 3/27/2008
    C:\Program Files\Common Files\AOL\1206677203\ee\AOLSoftware.exe
    C:\Program Files\Common Files\AOL\Loader\aolload.exe
    C:\Program Files\Common Files\AOL\1206677203\ee\AOLDesktop.exe
    C:\WINDOWS\explorer.exe
    C:\WINDOWS\system32\notepad.exe
    C:\Program Files\Internet Explorer\IEXPLORE.EXE
    O2 - BHO: AOL Toolbar BHO - {7C554162-8CB7-45A4-B8F4-8EA1C75885F9} - C:\Program Files\AOL\AOL Toolbar 5.0\aoltb.dll
    O3 - Toolbar: AOL Toolbar - {DE9C389F-3316-41A7-809B-AA305ED9D922} - C:\Program Files\AOL\AOL Toolbar 5.0\aoltb.dll
    O4 - HKLM\..\Run: [HostManager] C:\Program Files\Common Files\AOL\1206677203\ee\AOLSoftware.exe
    O4 - Startup: AOL Desktop.lnk = C:\Program Files\Common Files\AOL\Launch\aollaunch.exe
    End of file - 6579 bytes
    ComboFix Log
    ComboFix 08-03-26.3 - Robert Omo 2008-03-27 20:57:54.1 - NTFSx86
    Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.290 [GMT -8:00]
    Running from: C:\Documents and Settings\Robert Omo\Desktop\ComboFix.exe
    * Created a new restore point
    WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
    C:\Documents and Settings\Karen Omo\Application Data\APPATC~1
    C:\Documents and Settings\Karen Omo\Application Data\ASKS~1
    C:\Documents and Settings\Karen Omo\Start Menu\Programs\Outerinfo
    C:\Documents and Settings\Karen Omo\Start Menu\Programs\Outerinfo\Terms.lnk
    C:\Documents and Settings\Karen Omo\Start Menu\Programs\Outerinfo\Uninstall.lnk
    C:\Documents and Settings\Robert Omo\Application Data\FNTS~1
    C:\Documents and Settings\Robert Omo\Application Data\Sskdmns.dll
    C:\Documents and Settings\Robert Omo\Application Data\TSKS~1
    C:\WINDOWS\crosof~1.net
    C:\WINDOWS\mcroso~1.net
    C:\WINDOWS\scurit~1
    C:\WINDOWS\stem~1
    C:\WINDOWS\system32\components
    C:\WINDOWS\system32\crosof~1.net
    C:\WINDOWS\system32\curity~1
    C:\WINDOWS\system32\dobe~1
    C:\WINDOWS\system32\guard.tmp
    C:\WINDOWS\system32\icroso~1.net
    C:\WINDOWS\system32\mcrh.tmp
    C:\WINDOWS\system32\ppatch~1
    C:\WINDOWS\system32\sembly~1
    C:\WINDOWS\system32\sks~1
    C:\WINDOWS\system32\sks~1\m?hta.exe
    C:\WINDOWS\system32\stem32~1
    C:\WINDOWS\system32\stera.log
    C:\WINDOWS\system32\wnsxs~1
    C:\WINDOWS\winsysupd71.dat
    C:\WINDOWS\ymbols~1
    C:\WINDOWS\ymbols~1\scanregw.exe
    ((((((((((((((((((((((((( Files Created from 2008-02-28 to 2008-03-28 )))))))))))))))))))))))))))))))
    2008-03-27 20:28 . 2008-03-27 20:28 1,980 --a------ C:\WINDOWS\system32\tmp.reg
    2008-03-27 20:26 . 2007-09-05 23:22 289,144 --a------ C:\WINDOWS\system32\VCCLSID.exe
    2008-03-27 20:26 . 2006-04-27 16:49 288,417 --a------ C:\WINDOWS\system32\SrchSTS.exe
    2008-03-27 20:26 . 2008-03-22 15:49 86,528 --a------ C:\WINDOWS\system32\VACFix.exe
    2008-03-27 20:26 . 2008-03-26 08:50 82,432 --a------ C:\WINDOWS\system32\IEDFix.exe
    2008-03-27 20:26 . 2003-06-05 20:13 53,248 --a------ C:\WINDOWS\system32\Process.exe
    2008-03-27 20:26 . 2004-07-31 17:50 51,200 --a------ C:\WINDOWS\system32\dumphive.exe
    2008-03-27 20:26 . 2007-10-03 23:36 25,600 --a------ C:\WINDOWS\system32\WS2Fix.exe
    2008-03-27 20:11 . 2003-01-10 13:13 33,588 -ra------ C:\WINDOWS\system32\drivers\wanatw4.sys
    2008-03-27 20:06 . 2008-03-27 20:06 <DIR> d-------- C:\Program Files\Common Files\aolshare
    2008-03-27 18:14 . 2008-03-27 18:14 <DIR> d-------- C:\Documents and Settings\Robert Omo\Application Data\acccore
    2008-03-27 18:09 . 2008-03-27 18:09 <DIR> d-------- C:\Documents and Settings\Evan Omo\Application Data\acccore
    2008-03-27 17:36 . 2008-03-27 17:36 <DIR> d-------- C:\Program Files\Viewpoint
    2008-03-27 17:36 . 2008-03-27 17:36 <DIR> d-------- C:\Documents and Settings\All Users\Application Data\Viewpoint
    2008-03-27 17:35 . 2008-03-27 20:12 <DIR> d-------- C:\Program Files\Common Files\AOL
    2008-03-27 17:34 . 2008-03-27 17:34 <DIR> d-------- C:\Documents and Settings\All Users\Application Data\AOL OCP
    2008-03-27 17:31 . 2008-03-27 17:31 <DIR> d-------- C:\Documents and Settings\All Users\Application Data\AOL Downloads
    2008-03-27 15:52 . 2008-03-27 15:52 <DIR> d-------- C:\Program Files\Trend Micro
    2008-03-27 13:20 . 2008-03-27 13:22 7,348,224 --a------ C:\WINDOWS\sectest.db
    2008-03-27 13:16 . 2008-03-27 20:11 <DIR> d-------- C:\WINDOWS\system32\CatRoot2
    2008-03-27 13:04 . 2008-03-27 13:04 <DIR> d-------- C:\Program Files\Windows Resource Kits
    2008-03-27 12:39 . 2008-03-27 19:45 23,392 --a------ C:\WINDOWS\system32\nscompat.tlb
    2008-03-27 12:39 . 2008-03-27 19:45 16,832 --a------ C:\WINDOWS\system32\amcompat.tlb
    2008-03-27 12:38 . 2008-03-27 12:38 <DIR> d-------- C:\Program Files\Windows Media Connect 2
    2008-03-27 12:33 . 2008-03-27 19:15 <DIR> d-------- C:\WINDOWS\system32\drivers\UMDF
    2008-03-27 12:17 . 2006-09-25 17:58 23,856 --a------ C:\WINDOWS\system32\spupdsvc.exe
    2008-03-27 11:35 . 2008-03-27 11:35 0 --a------ C:\WINDOWS\system32\REN41.tmp
    2008-03-27 11:35 . 2008-03-27 11:35 0 --a------ C:\WINDOWS\system32\REN40.tmp
    2008-03-27 11:19 . 2008-03-27 11:19 13,646 --a------ C:\WINDOWS\system32\wpa.bak
    2008-03-27 11:12 . 2006-02-28 04:00 28,288 --a--c--- C:\WINDOWS\system32\dllcache\xjis.nls
    2008-03-27 11:10 . 2006-02-28 04:00 571,392 --a--c--- C:\WINDOWS\system32\dllcache\tintlgnt.ime
    2008-03-27 11:09 . 2006-02-28 04:00 482,304 --a--c--- C:\WINDOWS\system32\dllcache\pintlgnt.ime
    2008-03-27 11:08 . 2006-02-28 04:00 1,875,968 --a--c--- C:\WINDOWS\system32\dllcache\msir3jp.lex
    2008-03-27 11:07 . 2006-02-28 04:00 1,158,818 --a--c--- C:\WINDOWS\system32\dllcache\korwbrkr.lex
    2008-03-27 11:06 . 2006-02-28 04:00 13,463,552 --a--c--- C:\WINDOWS\system32\dllcache\hwxjpn.dll
    2008-03-27 11:05 . 2006-02-28 04:00 1,677,824 --a--c--- C:\WINDOWS\system32\dllcache\chsbrkr.dll
    2008-03-27 11:04 . 2006-02-28 04:00 369,664 --a--c--- C:\WINDOWS\system32\dllcache\asp51.dll
    2008-03-27 11:03 . 2006-02-28 04:00 2,134,528 --a--c--- C:\WINDOWS\system32\dllcache\smtpsnap.dll
    2008-03-27 10:56 . 2008-03-27 10:56 488 -rah----- C:\WINDOWS\system32\logonui.exe.manifest
    2008-03-27 10:55 . 2006-02-28 04:00 16,384 --a--c--- C:\WINDOWS\system32\dllcache\isignup.exe
    2008-03-27 10:55 . 2008-03-27 10:55 749 -rah----- C:\WINDOWS\WindowsShell.Manifest
    2008-03-27 10:55 . 2008-03-27 10:55 749 -rah----- C:\WINDOWS\system32\wuaucpl.cpl.manifest
    2008-03-27 10:55 . 2008-03-27 10:55 749 -rah----- C:\WINDOWS\system32\sapi.cpl.manifest
    2008-03-27 10:55 . 2008-03-27 10:55 749 -rah----- C:\WINDOWS\system32\nwc.cpl.manifest
    2008-03-27 10:55 . 2008-03-27 10:55 749 -rah----- C:\WINDOWS\system32\ncpa.cpl.manifest
    2008-03-27 10:50 . 2006-02-28 04:00 169,984 --a--c--- C:\WINDOWS\system32\dllcache\iisui.dll
    2008-03-27 10:50 . 2006-02-28 04:00 60,928 --a--c--- C:\WINDOWS\system32\dllcache\iisclex4.dll
    2008-03-27 10:50 . 2006-02-28 04:00 19,968 --a------ C:\WINDOWS\system32\inetsloc.dll
    2008-03-27 10:50 . 2006-02-28 04:00 19,968 --a--c--- C:\WINDOWS\system32\dllcache\inetsloc.dll
    2008-03-27 10:50 . 2006-02-28 04:00 7,168 --a------ C:\WINDOWS\system32\wamregps.dll
    2008-03-27 10:50 . 2006-02-28 04:00 7,168 --a--c--- C:\WINDOWS\system32\dllcache\wamregps.dll
    2008-03-27 10:50 . 2006-02-28 04:00 3,584 --a------ C:\WINDOWS\system32\iismui.dll
    2008-03-27 10:50 . 2006-02-28 04:00 3,584 --a--c--- C:\WINDOWS\system32\dllcache\iismui.dll
    2008-03-27 10:41 . 2004-08-04 00:56 4,274,816 --a------ C:\WINDOWS\system32\nv4_disp.dll
    2008-03-27 10:41 . 2004-08-03 22:29 1,897,408 --a------ C:\WINDOWS\system32\drivers\nv4_mini.sys
    2008-03-27 10:36 . 2006-02-28 04:00 66,082 --a--c--- C:\WINDOWS\system32\dllcache\c_28603.nls
    2008-03-27 10:36 . 2006-02-28 04:00 66,082 --a------ C:\WINDOWS\system32\c_28603.nls
    2008-03-27 10:36 . 2006-02-28 04:00 24,661 --a------ C:\WINDOWS\system32\spxcoins.dll
    2008-03-27 10:36 . 2006-02-28 04:00 24,661 --a--c--- C:\WINDOWS\system32\dllcache\spxcoins.dll
    2008-03-27 10:36 . 2006-02-28 04:00 13,312 --a------ C:\WINDOWS\system32\irclass.dll
    2008-03-27 10:36 . 2006-02-28 04:00 13,312 --a--c--- C:\WINDOWS\system32\dllcache\irclass.dll
    2008-03-27 10:34 . 2006-02-28 04:00 1,086,058 -ra------ C:\WINDOWS\SET8C.tmp
    2008-03-27 10:34 . 2006-02-28 04:00 1,042,903 -ra------ C:\WINDOWS\SET8B.tmp
    2008-03-27 02:18 . 2008-03-27 02:18 <DIR> d-------- C:\WINDOWS\Provisioning
    2008-03-27 02:18 . 2008-03-27 02:28 <DIR> d-------- C:\WINDOWS\PeerNet
    2008-03-27 02:18 . 2008-03-27 02:29 <DIR> d-------- C:\WINDOWS\ehome
    2008-03-27 02:18 . 2008-03-27 15:17 536,428,544 --a------ C:\WINDOWS\MEMORY.DMP
    2008-03-26 19:47 . 2007-07-30 19:18 34,136 --a------ C:\WINDOWS\system32\wucltui.dll.mui
    2008-03-26 19:47 . 2007-07-30 19:19 25,944 --a------ C:\WINDOWS\system32\wuaucpl.cpl.mui
    2008-03-26 19:47 . 2007-07-30 19:19 25,944 --a------ C:\WINDOWS\system32\wuapi.dll.mui
    2008-03-26 19:47 . 2007-07-30 19:18 20,312 --a------ C:\WINDOWS\system32\wuaueng.dll.mui
    2008-03-24 19:41 . 2008-03-24 19:44 <DIR> d-------- C:\Program Files\Auslogics
    2008-03-14 21:12 . 2008-03-14 21:12 <DIR> d-------- C:\Documents and Settings\Evan Omo\Application Data\Malwarebytes
    2008-03-12 19:31 . 2008-03-27 12:12 <DIR> d-------- C:\Program Files\SpywareBlaster
    2008-03-28 05:04 --------- d-----w C:\Program Files\WinClamAVShield
    2008-03-28 04:23 --------- d-----w C:\Documents and Settings\Robert Omo\Application Data\SiteAdvisor
    2008-03-28 04:12 --------- d-----w C:\Documents and Settings\All Users\Application Data\AOL
    2008-03-28 02:28 --------- d-----w C:\Documents and Settings\Evan Omo\Application Data\SiteAdvisor
    2008-03-28 01:22 --------- d-----w C:\Program Files\Spyware Terminator
    2008-03-28 01:22 --------- d-----w C:\Documents and Settings\Robert Omo\Application Data\Spyware Terminator
    2008-03-28 00:00 --------- d-----w C:\Documents and Settings\All Users\Application Data\SiteAdvisor
    2008-03-27 23:01 --------- d-----w C:\Documents and Settings\Administrator\Application Data\SiteAdvisor
    2008-03-27 20:06 --------- d-----w C:\Documents and Settings\Evan Omo\Application Data\Spyware Terminator
    2008-03-27 19:43 --------- d-----w C:\Program Files\Common Files\Adobe
    2008-03-27 04:15 --------- d-----w C:\Documents and Settings\All Users\Application Data\Spyware Terminator
    2008-03-25 03:41 --------- d-----w C:\Documents and Settings\Evan Omo\Application Data\Auslogics
    2008-03-15 22:55 --------- d-----w C:\Documents and Settings\Karen Omo\Application Data\Spyware Terminator
    2008-02-21 02:01 3,932 -c--a-w C:\Documents and Settings\Robert Omo\Application Data\LMLayout.dat
    2008-02-21 02:01 268 -c--a-w C:\Documents and Settings\Robert Omo\Application Data\LMCPaper.dat
    2008-02-15 03:33 138,752 ----a-w C:\WINDOWS\system32\drivers\sp_rsdrv2.sys
    2008-02-07 06:04 --------- d-----w C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy
    2008-02-07 06:02 --------- d-----w C:\Program Files\Spybot - Search & Destroy
    2008-02-06 00:14 --------- d--h--w C:\Program Files\InstallShield Installation Information
    2008-01-30 17:23 22,576 -c--a-w C:\Documents and Settings\Robert Omo\Application Data\GDIPFONTCACHEV1.DAT
    2008-01-16 02:33 3,932 -c--a-w C:\Documents and Settings\Evan Omo\Application Data\LMLayout.dat
    2008-01-16 02:33 268 -c--a-w C:\Documents and Settings\Evan Omo\Application Data\LMCPaper.dat
    2007-10-13 02:51 3,932 -c--a-w C:\Documents and Settings\Karen Omo\Application Data\LMLayout.dat
    2007-10-13 02:51 268 -c--a-w C:\Documents and Settings\Karen Omo\Application Data\LMCPaper.dat
    2006-08-08 02:48 50,371 -c--a-w C:\WINDOWS\Internet Logs\zlclient_2nd_2006_08_07_15_39_31_small.dmp.zip
    2005-09-21 16:49 120,996 -c-ha-w C:\Documents and Settings\Robert Omo\Application Data\ptads.bin
    2005-09-15 20:37 94,939 -c-ha-w C:\Documents and Settings\Evan Omo\Application Data\ptads.bin
    2005-09-05 02:50 79,712 -c-ha-w C:\Documents and Settings\Karen Omo\Application Data\ptads.bin
    2004-11-30 02:15 23,040 -c--a-w C:\Documents and Settings\Evan Omo\Application Data\GDIPFONTCACHEV1.DAT
    2002-01-18 14:52 3,932 -c----w C:\Documents and Settings\LocalService\Application Data\LMLayout.dat
    "ctfmon.exe "= "C:\WINDOWS\system32\ctfmon.exe" [2006-02-28 04:00 15360]
    "Weather "= "C:\PROGRA~1\AWS\WEATHE~1\Weather.exe" [ ]
    "MSMSGS "= "C:\Program Files\Messenger\msmsgs.exe" [2004-08-04 01:06 1667584]
    "SpybotSD TeaTimer "= "C:\Program Files\Spybot - Search & Destroy\TeaTimer.exe" [2008-01-28 11:43 2097488]
    "SpywareTerminator "= "C:\Program Files\Spyware Terminator\SpywareTerminatorShield.exe" [2008-02-14 19:33 2957824]
    "SiteAdvisor "= "C:\Program Files\SiteAdvisor\6253\SiteAdv.exe" [2007-08-24 13:57 36640]
    "Adobe Reader Speed Launcher "= "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-11 22:16 39792]
    "MP10_EnsureFileVer "= "C:\WINDOWS\inf\unregmp2.exe" [2006-02-28 04:00 208896]
    "HostManager "= "C:\Program Files\Common Files\AOL\1206677203\ee\AOLSoftware.exe" [2007-10-08 13:50 41824]
    Lexmark X125 Settings Utility.lnk - C:\Program Files\Lexmark X125\LEX125SU.exe [2004-10-31 16:38:16 1990656]
    Microsoft Office.lnk - C:\Program Files\Microsoft Office\Office10\OSA.EXE [2001-02-13 00:01:04 83360]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center]
    "AntivirusOverride "=dword:00000001
    "C:\\Program Files\\Messenger\\msmsgs.exe "=
    "C:\\Program Files\\Common Files\\AOL\\TopSpeed\\3.0\\aoltpsd3.exe "=
    "C:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe "=
    "C:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe "=
    "C:\\Program Files\\Common Files\\AOL\\Loader\\aolload.exe "=
    "C:\\Program Files\\Common Files\\AOL\\1206677203\\ee\\aolsoftware.exe "=
    "C:\\Program Files\\Common Files\\AOL\\1206677203\\ee\\AOLDesktop.exe "=
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]
    "3389:TCP "= 3389:TCP:mad:xpsp2res.dll,-22009
    R1 sp_rsdrv2;Spyware Terminator Driver 2;C:\WINDOWS\System32\drivers\sp_rsdrv2.sys [2008-02-14 19:33]
    R3 SMC55T;SMC EZ Card 10/100 (SMC1255TX);C:\WINDOWS\system32\DRIVERS\SMC55T51.sys [2002-07-05 15:31]
    S2 UMAXPCLS;Print Port Scanner Driver;C:\WINDOWS\system32\DRIVERS\umaxpcls.sys [2001-08-17 12:58]
    S3 AN983;ADMtek AN983/AN985/ADM951X 10/100Mbps Fast Ethernet Adapter;C:\WINDOWS\system32\DRIVERS\AN983.sys [2004-08-03 22:31]
    "2008-03-28 05:00:00 C:\WINDOWS\Tasks\A6AE74A591EDEBA1.job "
    - c:\docume~1\evanom~1\applic~1\longsl~1\Corn meow amok.exe
    "2008-03-28 05:00:00 C:\WINDOWS\Tasks\A9F3FDE391847523.job "
    "2008-03-28 05:00:00 C:\WINDOWS\Tasks\AACB1CB0918490B8.job "
    "2008-03-28 05:00:00 C:\WINDOWS\Tasks\AB3827FB9183DDF7.job "
    "2008-03-28 05:00:00 C:\WINDOWS\Tasks\AE4AA6E791895F0B.job "
    - c:\docume~1\robert~1\applic~1\longsl~1\Corn meow amok.exe
    "2008-03-28 05:00:00 C:\WINDOWS\Tasks\B4FF56CD9134C1D1.job "
    "2008-03-28 05:00:00 C:\WINDOWS\Tasks\BC6C25F691E7C8F2.job "
    "2008-03-28 05:00:00 C:\WINDOWS\Tasks\BDCDA72C91364728.job "
    - c:\docume~1\kareno~1\applic~1\longsl~1\Corn meow amok.exe
    "2008-03-27 20:48:35 C:\WINDOWS\Tasks\User_Feed_Synchronization-{754D0594-BE19-4EA4-B2FB-CF8418844CB2}.job "
    - C:\WINDOWS\system32\msfeedssync.exe
    catchme 0.3.1344 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
    Rootkit scan 2008-03-27 21:04:56
    Windows 5.1.2600 Service Pack 2 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    PROCESS: C:\WINDOWS\explorer.exe
    -> C:\Program Files\SiteAdvisor\6253\saHook.dll
    ------------------------ Other Running Processes ------------------------
    C:\WINDOWS\System32\wdfmgr.exe
    Completion time: 2008-03-27 21:08:23 - machine was rebooted
    ComboFix-quarantined-files.txt 2008-03-28 05:07:29
    Pre-Run: 68,332,752,896 bytes free
    Post-Run: 68,258,512,896 bytes free
  5. 2008/03/27
    SmitFraudFix Log
    SmitFraudFix v2.309
    Scan done at 20:27:28.03, Thu 03/27/2008
    Run from C:\Documents and Settings\Robert Omo\Desktop\SmitfraudFix
    OS: Microsoft Windows XP [Version 5.1.2600] - Windows_NT
    The filesystem type is NTFS
    Fix run in safe mode
    »»»»»»»»»»»»»»»»»»»»»»»» SharedTaskScheduler Before SmitFraudFix
    !!!Attention, following keys are not inevitably infected!!!
    SrchSTS.exe by S!Ri
    Search SharedTaskScheduler's .dll
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler]
    "incestuously "= "{03413bf7-e34c-445b-bfc0-a2b127255871} "
    »»»»»»»»»»»»»»»»»»»»»»»» Killing process
    »»»»»»»»»»»»»»»»»»»»»»»» hosts
    127.0.0.1 localhost
  6. 2008/03/27
    SmitFraudFix Log Continued
  7. 2008/03/27
    noahdfear
    noahdfear Inactive
    Skip the entire HOSTS File section and post what remains, please.
  8. 2008/03/27
    Sorry about that Dave. I didn't know that you didn't want me to post the hosts file.
    Here is the remainder of the SmitFraudFix log without the hosts file included
    »»»»»»»»»»»»»»»»»»»»»»»» VACFix
    VACFix
    Credits: Malware Analysis & Diagnostic
    Code: S!Ri
    »»»»»»»»»»»»»»»»»»»»»»»» Winsock2 Fix
    S!Ri's WS2Fix: LSP not Found.
    »»»»»»»»»»»»»»»»»»»»»»»» Generic Renos Fix
    GenericRenosFix by S!Ri
    »»»»»»»»»»»»»»»»»»»»»»»» Deleting infected files
    C:\WINDOWS\system32\ot.ico Deleted
    »»»»»»»»»»»»»»»»»»»»»»»» IEDFix
    IEDFix
    Code: S!Ri
    »»»»»»»»»»»»»»»»»»»»»»»» DNS
    HKLM\SYSTEM\CCS\Services\Tcpip\..\{C169E8AF-F2E2-4209-9B4E-CEE5C4E31811}: DhcpNameServer=64.85.239.20 64.85.239.21
    HKLM\SYSTEM\CS1\Services\Tcpip\..\{C169E8AF-F2E2-4209-9B4E-CEE5C4E31811}: DhcpNameServer=64.85.239.20 64.85.239.21
    HKLM\SYSTEM\CS2\Services\Tcpip\..\{C169E8AF-F2E2-4209-9B4E-CEE5C4E31811}: DhcpNameServer=64.85.239.20 64.85.239.21
    HKLM\SYSTEM\CS3\Services\Tcpip\..\{C169E8AF-F2E2-4209-9B4E-CEE5C4E31811}: DhcpNameServer=64.85.239.20 64.85.239.21
    HKLM\SYSTEM\CCS\Services\Tcpip\Parameters: DhcpNameServer=64.85.239.20 64.85.239.21
    HKLM\SYSTEM\CS1\Services\Tcpip\Parameters: DhcpNameServer=64.85.239.20 64.85.239.21
    HKLM\SYSTEM\CS2\Services\Tcpip\Parameters: DhcpNameServer=64.85.239.20 64.85.239.21
    HKLM\SYSTEM\CS3\Services\Tcpip\Parameters: DhcpNameServer=64.85.239.20 64.85.239.21
    »»»»»»»»»»»»»»»»»»»»»»»» Deleting Temp Files
    »»»»»»»»»»»»»»»»»»»»»»»» Winlogon.System
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
    "System "=" "
    »»»»»»»»»»»»»»»»»»»»»»»» Registry Cleaning
    Registry Cleaning done.
    »»»»»»»»»»»»»»»»»»»»»»»» SharedTaskScheduler After SmitFraudFix
    SrchSTS.exe by S!Ri
    »»»»»»»»»»»»»»»»»»»»»»»» End
  9. 2008/03/28
    noahdfear
    noahdfear Inactive
    No problem RE: posting the HOSTS file entries. No way you could have known, nor would I have known they would be present. ;)
    You should disable Spybot's TeaTimer until after we're done, as it can prevent some of the registry changes that need to be made.
    • Open Spybot Search & Destroy.
    • In the Mode menu click "Advanced mode" if not already selected.
    • Choose "Yes" at the Warning prompt.
    • Expand the "Tools" menu.
    • Click "Resident ".
    • Uncheck the "Resident "TeaTimer" (Protection of overall system settings) active." box.
    • In the File menu click "Exit" to exit Spybot Search & Destroy.
    Reboot.
    Scan again with HijackThis and place a check next to the following entries, then click Fix Checked.
    O16 - DPF: {56393399-041A-4650-94C7-13DFCB1F4665} (PSFormX Control) -O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Plug-in) -
    O16 - DPF: {A90A5822-F108-45AD-8482-9BC8B12DD539} (Crucial cpcScan) -O16 - DPF: {CAFEEFAC-0014-0000-0000-ABCDEFFEDCBA} (Java Plug-in) -
    Close HijackThis.
    Copy and paste each of the following bolded commands into the Start>Run dialog then hit enter.
    If each command opens the corresponding longsl~1 folder (I don't know what the folder's actual name is), use the Menu 'up one folder' icon to go up to the app data folder then delete the longsl~1 folder(s).
    Next, once again, please disable any realtime protection applications. Highlight and copy the contents of the code box below and paste it into a blank notepad, then save it to your desktop as;
    Filename: CFScript.txt
    Save As Type: All Files (*.*)
    File::
    Registry::
    [-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{3464B9E7-2150-0FAE-0612-2F00CAB78F98}]
    [-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{65D70B12-91A1-EC53-A448-9A2B28E18CC9}]
    [-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{E297D808-40EE-6A4E-BD5C-4B76621F0DC6}]
     "CheckRegDefragService "=-
    [-HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\Extensions]
    [-HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\mllmk]
    [-HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\ShellCompatibility]
    Close all other windows and programs. Now drag the CFScript.txt onto ComboFix.exe and drop it, using the left mouse button. Combofix should run and may reboot the computer when it's done. A log will open when it's complete. Post the contents of that log along with a fresh HijackThis log.
    Please do not click on the ComboFix window while it is running a scan. This can cause it to stall.
  10. 2008/03/28
    Here are the logs!
    ComboFix
    ComboFix 08-03-26.3 - Robert Omo 2008-03-28 9:46:14.2 - NTFSx86
    Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.283 [GMT -8:00]
    Command switches used :: C:\Documents and Settings\Robert Omo\Desktop\CFScript.txt
    FILE ::
    C:\WINDOWS\system32\_000218_.tmp.dll
    2008-03-27 13:16 . 2008-03-27 21:55 <DIR> d-------- C:\WINDOWS\system32\CatRoot2
    2008-03-24 19:09 . 2006-02-28 04:00 2,804,224 --a------ C:\WINDOWS\system32\msi.dll
    2008-03-24 19:09 . 2006-02-28 04:00 2,804,224 --a------ C:\WINDOWS\system32\dllcache\msi.dll
    2008-03-24 19:09 . 2006-02-28 04:00 884,736 --a------ C:\WINDOWS\system32\msimsg.dll
    2008-03-24 19:09 . 2006-02-28 04:00 884,736 --a------ C:\WINDOWS\system32\dllcache\msimsg.dll
    2008-03-24 19:09 . 2006-02-28 04:00 331,264 --a------ C:\WINDOWS\system32\msihnd.dll
    2008-03-24 19:09 . 2006-02-28 04:00 331,264 --a------ C:\WINDOWS\system32\dllcache\msihnd.dll
    2008-03-24 19:09 . 2006-02-28 04:00 77,312 --a------ C:\WINDOWS\system32\msiexec.exe
    2008-03-24 19:09 . 2006-02-28 04:00 77,312 --a------ C:\WINDOWS\system32\dllcache\msiexec.exe
    2008-03-24 19:09 . 2006-02-28 04:00 44,032 --a------ C:\WINDOWS\system32\msisip.dll
    2008-03-24 19:09 . 2006-02-28 04:00 44,032 --a------ C:\WINDOWS\system32\dllcache\msisip.dll
    2008-03-28 17:51 --------- d-----w C:\Program Files\WinClamAVShield
    2008-03-28 17:32 --------- d-----w C:\Documents and Settings\Robert Omo\Application Data\SiteAdvisor
    2006-08-01 23:39 410,096 -csha-w C:\WINDOWS\system32\kmllm.bak1
    2006-08-22 20:08 910,123 -csha-w C:\WINDOWS\system32\kmllm.bak2
    2006-08-22 23:25 526,351 -csha-w C:\WINDOWS\system32\kmllm.ini2
    ((((((((((((((((((((((((((((( snapshot@2008-03-27_21.07.01.39 )))))))))))))))))))))))))))))))))))))))))
    + 2005-05-04 22:45:26 13,536 ------w C:\WINDOWS\system32\spmsg.dll
    Rootkit scan 2008-03-28 09:51:44
    hidden files: 0
    Completion time: 2008-03-28 9:55:59 - machine was rebooted
    ComboFix-quarantined-files.txt 2008-03-28 17:55:18
    ComboFix2.txt 2008-03-28 05:08:24
    Pre-Run: 68,198,899,712 bytes free
    Post-Run: 68,186,361,856 bytes free
    Hijackthis
    Scan saved at 9:59:09 AM, on 3/28/2008
    End of file - 5484 bytes
  11. 2008/03/28
    noahdfear
    noahdfear Inactive
    Looking much better. Please delete the ComboFix.exe file you currently have and download a fresh copy from here, saving it to your desktop.
    Once again, please disable any realtime protection applications. Highlight and copy the contents of the code box below and paste it into a blank notepad, then save it to your desktop as;
    File::
    Close all other windows and programs. Now drag the CFScript.txt onto ComboFix.exe and drop it, using the left mouse button. Combofix should run and may reboot the computer when it's done. A log will open when it's complete. Post the contents of that log.
  12. 2008/03/28
    The computer seems faster and it isn't locking up as much as it used to. Thanks. :)
    ComboFix Log
    ComboFix 08-03-27.1 - Robert Omo 2008-03-28 12:01:23.3 - NTFSx86
    Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.272 [GMT -8:00]
    FILE ::
    C:\WINDOWS\system32\_000109_.tmp.dll
    2008-03-28 10:37 . 2006-02-28 04:00 2,804,224 --a------ C:\WINDOWS\system32\msi.dll
    2008-03-28 10:37 . 2006-02-28 04:00 2,804,224 --a------ C:\WINDOWS\system32\dllcache\msi.dll
    2008-03-28 10:37 . 2006-02-28 04:00 884,736 --a------ C:\WINDOWS\system32\msimsg.dll
    2008-03-28 10:37 . 2006-02-28 04:00 884,736 --a------ C:\WINDOWS\system32\dllcache\msimsg.dll
    2008-03-28 10:37 . 2006-02-28 04:00 331,264 --a------ C:\WINDOWS\system32\msihnd.dll
    2008-03-28 10:37 . 2006-02-28 04:00 331,264 --a------ C:\WINDOWS\system32\dllcache\msihnd.dll
    2008-03-28 10:37 . 2006-02-28 04:00 77,312 --a------ C:\WINDOWS\system32\msiexec.exe
    2008-03-28 10:37 . 2006-02-28 04:00 77,312 --a------ C:\WINDOWS\system32\dllcache\msiexec.exe
    2008-03-28 10:37 . 2006-02-28 04:00 44,032 --a------ C:\WINDOWS\system32\msisip.dll
    2008-03-28 10:37 . 2006-02-28 04:00 44,032 --a------ C:\WINDOWS\system32\dllcache\msisip.dll
    2008-03-27 13:16 . 2008-03-28 11:53 <DIR> d-------- C:\WINDOWS\system32\CatRoot2
    2008-03-28 20:07 --------- d-----w C:\Program Files\WinClamAVShield
    2008-03-28 19:54 --------- d-----w C:\Documents and Settings\Robert Omo\Application Data\SiteAdvisor
    - 2006-02-28 12:00:00 8,384,000 -c--a-w C:\WINDOWS\system32\dllcache\shell32.dll
    + 2007-10-26 03:36:51 8,454,656 -c--a-w C:\WINDOWS\system32\dllcache\shell32.dll
    + 2007-12-04 00:39:18 112,016 ----a-w C:\WINDOWS\system32\Macromed\Download\Download.dll
    + 2007-12-04 00:39:18 59,717 ----a-w C:\WINDOWS\system32\Macromed\Download\Install.exe
    - 2006-02-28 12:00:00 8,384,000 ----a-w C:\WINDOWS\system32\shell32.dll
    + 2007-10-26 03:36:51 8,454,656 ----a-w C:\WINDOWS\system32\shell32.dll
    + 2007-03-06 01:22:33 14,048 ------w C:\WINDOWS\system32\spmsg.dll
    - 2006-02-01 00:28:24 16,384 ----a-w C:\WINDOWS\system32\xpsp3res.dll
    + 2007-10-29 10:26:53 115,712 ----a-w C:\WINDOWS\system32\xpsp3res.dll
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\aawservice]
    Rootkit scan 2008-03-28 12:06:58
    hidden files: 0
    Completion time: 2008-03-28 12:12:01 - machine was rebooted
    ComboFix-quarantined-files.txt 2008-03-28 20:11:24
    ComboFix2.txt 2008-03-28 17:56:00
    ComboFix3.txt 2008-03-28 05:08:24
    Pre-Run: 68,065,361,920 bytes free
    Post-Run: 68,051,968,000 bytes free
    2008-03-28 19:36:25 --- E O F ---
  13. 2008/03/28
    noahdfear
    noahdfear Inactive
    Well, progress has been made, but there's also been a backslide somehow. Please make sure Spybot's TeaTimer is disabled as previously instructed, then create yet another CFScript.txt with the contents of the code box below.
    KillAll::
    Registry::
    Drag-n-drop CFScript.txt onto ComboFix.exe and post the new ComboFix.txt when it completes. I'd like to see a fresh HijackThis log after running ComboFix too.
  14. 2008/03/28
    Hey Dave. I got a BSOD after I disabled Spybots Team Timer which was Bad_Pool_Header Stop 0x000000c2. I restarted the machine without a problem. Its just strange why I got a BSOD from doing that. Anyway here are the logs! :)
    ComboFix
    ComboFix 08-03-27.1 - Robert Omo 2008-03-28 14:40:41.4 - NTFSx86
    Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.305 [GMT -8:00]
    2008-03-27 13:16 . 2008-03-28 14:33 <DIR> d-------- C:\WINDOWS\system32\CatRoot2
    2008-03-27 02:18 . 2008-03-28 14:30 536,428,544 --a------ C:\WINDOWS\MEMORY.DMP
    2008-03-28 22:46 --------- d-----w C:\Program Files\WinClamAVShield
    2008-03-28 20:40 --------- d-----w C:\Documents and Settings\Robert Omo\Application Data\SiteAdvisor
    + 2008-03-28 22:34:32 5,986 ----a-w C:\WINDOWS\SoftwareDistribution\EventCache\{BB398CD8-6CAA-4A98-A60E-64D265F0F83B}.bin
    "2008-03-28 22:48:02 C:\WINDOWS\Tasks\User_Feed_Synchronization-{754D0594-BE19-4EA4-B2FB-CF8418844CB2}.job "
    Rootkit scan 2008-03-28 14:46:07
    hidden files: 0
    Completion time: 2008-03-28 14:50:45 - machine was rebooted
    ComboFix-quarantined-files.txt 2008-03-28 22:50:17
    ComboFix2.txt 2008-03-28 20:12:02
    ComboFix3.txt 2008-03-28 17:56:00
    ComboFix4.txt 2008-03-28 05:08:24
    Pre-Run: 68,000,075,776 bytes free
    Post-Run: 67,989,532,672 bytes free
    2008-03-28 20:42:47 --- E O F ---
    Hijackthis
    Scan saved at 2:57:08 PM, on 3/28/2008
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://msn.com/
    O16 - DPF: {215B8138-A3CF-44C5-803F-8226143CFC0A} -
    O16 - DPF: {56393399-041A-4650-94C7-13DFCB1F4665} -
    O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} -
    O16 - DPF: {A90A5822-F108-45AD-8482-9BC8B12DD539} -
    O16 - DPF: {CAFEEFAC-0014-0000-0000-ABCDEFFEDCBA} (Java Plug-in 1.4.0) -
    O16 - DPF: {CAFEEFAC-0014-0002-0006-ABCDEFFEDCBA} (Java Plug-in 1.4.2_06) -
    O16 - DPF: {CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA} -
    O16 - DPF: {CAFEEFAC-0015-0000-0005-ABCDEFFEDCBA} -
    O16 - DPF: {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA} -
    End of file - 6257 bytes
  15. 2008/03/28
    noahdfear
    noahdfear Inactive
    Very odd you would BSOD like that :confused:
    With TeaTimer disabled, fix the following entries with HijackThis.
    That guard.tmp file has reared up 3 times now. Lets run another tool just in case. Download VundoFix by Atribune, saving it to your desktop.
    • Double-click VundoFix.exe to run it.
    • Click the Scan for Vundo button.
    • Once it's done scanning, click the Remove Vundo button.
    • You will receive a prompt asking if you want to remove the files, click YES
    • Once you click yes, your desktop will go blank as it starts removing Vundo.
    • When completed, it will prompt that it will reboot your computer, click OK.
    • Please post the contents of C:\vundofix.txt and a new HijackThis log in a reply here.
    Note: It is possible that VundoFix encounters a file it could not remove. In this case, VundoFix will run on reboot. If that happens, follow the above instructions starting from "Click the Scan for Vundo button" when VundoFix appears upon rebooting.
  16. 2008/03/29
    VundoFix Log
    VundoFix V7.0.3
    Scan started at 10:42:10 AM 3/29/2008
    Listing files found while scanning....
    No infected files were found.
    Hijackthis Log
    Scan saved at 11:03:28 AM, on 3/29/2008
    C:\Program Files\Common Files\AOL\1206762463\ee\AOLSoftware.exe
    O4 - HKLM\..\Run: [HostManager] C:\Program Files\Common Files\AOL\1206762463\ee\AOLSoftware.exe
    End of file - 5411 bytes
  17. 2008/03/29
    noahdfear
    noahdfear Inactive
    OK, something is restoring these registry entires. Since it appears TeaTimer is indeed disabled, maybe it's Spyware Terminator. Please disable it's protection(s) and fix the following with HijackThis.
    Reboot and create a fresh HijackThis log then post it here.
  18. 2008/03/29
    Hijackthis Log
    Scan saved at 3:49:32 PM, on 3/29/2008
    C:\Program Files\Common Files\AOL\ACS\AOLacsd.exe
    End of file - 5122 bytes
    At this point, I've tried to install some windows Updates such as Windows installer 3.1, and some other applications such as AOL 9.1. I get an access is denied error when trying to install windows installer 3.1 and I get that same error message when trying to install any windows update for Windows XP. Adobe Flash Player won't install correctly, AOL won't start up correctly and neither will Microsoft Office XP. So I think a reformat is in order since things haven't really improved. Malware may have played a part in the access is denied errors but there are probably some corrupted files that the repair installation didn't fix which is causing all of the updates that I try to fail to install or run properly. I have already backed up all the valuable data on the machine to my USB Flash Drive. If you have any other suggesstions before I format the machine let me know. I greatly appreciate your help Dave. :cool:
  19. 2008/03/29
    noahdfear
    noahdfear Inactive
    We could probably spend at least twice the amount of time troubleshooting permissions problems as it would take to format and clean install. ;)
  20. 2008/03/30
    Hey Dave. Just wanted to let you know that I formatted the machine and I spent the last few hours reinstallnig all of the Windows updates and my security software. Everything looks good and is running great. Again thank you so much for helping me out and being patient with me. I am very grateful for your help. ;):):cool::D
  21. 2008/03/30
    noahdfear
    noahdfear Inactive
    Happy to help ....... you're welcome. Glad to hear you're up and running again. :)
