Issues: setting 2 NIC's (TCP/IP)
Discussion in 'Windows Server System' started by fdenis83, 2008/10/13.
  1. 2008/10/13
    fdenis83
    fdenis83 Inactive Thread Starter
    Hey fellas,
    I am trying to setup a sbs 2003, so that it has an internal network that is controlled by server, which is connected to the internet. I also want all the the computers on the intranet to be connected to the internet.
    Map:
    >modem
    >server
    >hub
    >workstation 1
    >worstation 2
    >workstation 3
    >printer
    The issue now :rolleyes:.....
    When setting up my 2 NIC's I have one set to the Static IP (internet) and other to a completely different tcp/ip stuff.
    Nic1 (internet)
    IP: 71.xx.xxx.251
    subnet: 255.255.255.248
    gateway: 71.xx.xxx.249
    dns1: 65.32.1.65
    dns2: 65.32.1.70
    Nic2 (intranet)
    IP: 192.168.16.2
    subnet: 255.255.255.0
    gateway: 192.168.16.1
    dns1: 65.32.1.71
    dns2: 65.32.1.81
    When I hit "ok" on the tcp/ ip properties screen of the NIC2 I get this warning:
    WARNING- Multiple default gateways are intended to provide redundancy to a
    single network such as and Intranet or the Internet. They will not function
    properly when the gateways are on two separate, disjoint networks (such as
    one on your intranet and one on the Internet). Do you want to save this
    configuration? ( which I hit cancel, and type up my issue here))
    SOooooo now I wonder well it says nothing about this in the book that I'm going through, so what do I do?
    Do I infact want to create to seperate networks, or do I want them to function one and one on the same gateway?
    I showed what my ideal layout above, so if anyone can help it would be much apreciated!:D
  2. 2008/10/13
    fdenis83
    Ok well I ended up following the is article on microsoft that I luckly came across.
    http://support.microsoft.com/?id=825763
    It told me to set the server local network as:
    nic2
    IP: 192.168.16.2
    gateway: blank
    dns1: 65.32.1.71
    dns2: blank
    and then follow a few steps other specified steps. Guess what? IT WORKED!
    Soooo I'm currently configuring the rest, but feel free to chime in if you think I should have done something else, or just feel the need to confirm the information (would make me happy :D).
    ReggieB
    ReggieB Inactive Alumni
    As an SBS server is by definition also a 2003 AD server, you need to set it as the primary DNS for your network. That means that the NIC TCP/IP settings for DNS need to point at the server itself. So
    dns1: 192.168.16.2
    dns2: blank
    You need to set up forwarders in the DNS service to get your DNS talking to the outside world correctly. Have a look at this article that describes how you need to set up DNS on the server:
    http://support.microsoft.com/kb/814591
  5. 2008/10/14
    fdenis83
    Ok one more thing!
    How do I configure my server to let my laptop access my computer remotely? By that I mean I want to connect to one of the workstations remotely.
    Please any info on this would be awesome. For some reason I'm having a hard time finding information on this. I have plenty of info on how to setup the remote location, but I can't find anything on how to setup the server so that it will except the request to connect. (I'm sure I just don't know the terminology which is making this much harder).
    Thanks again,
    Dimitri
  6. 2008/10/15
    ReggieB
    fdenis83
    That log me in site is pretty cool, but thats not exactly what I wanted.
    Although I kind of figured it out.
    I just needed to type in the right thing into the browser.
    I could either sign in FTP or static IP of the server.
    example:
    ftp
    https://server.sexyladys/remote
    or
    ip
    http://71.75.989.786/remote
    and then use the user login info that was created earlier, such as
    Password: sexyman
    Thats is it! As far as connecting through a browser.
    Although I keep getting **** error 800 if I try signing through the desktop remote access shortcut.....
