Issues running Firefox 1.5 and 2.x simultaneously
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by Chrismartin76, 2007/05/31.
  1. 2007/05/31
    Chrismartin76
    Chrismartin76 Inactive Thread Starter
    Hello All,
    I followed advice on an older post about how to run Firefox 1.5 and 2.x simultaneously. However I'm having a couple of problems when I click links in emails and IM windows or url shortcuts on my desktop.
    If Firefox is not open I get:
    Windows cannot find 'http://.... ". Make sure you typed the name correctly and then try again.
    If Firefox is running, then I get the above message and:
    Firefox is already running and not responding.
    Here are the files I have
    FIREFOX2.BAT
    @echo off
    set MOZ_NO_REMOTE=1
    start " " "C:\Program Files\Mozilla Firefox\firefox.exe" -p "default "
    set MOZ_NO_REMOTE=0​
    FIREFOX1.BAT
    @echo off
    set MOZ_NO_REMOTE=1
    start " " "C:\Program Files\Mozilla Firefox 1.5\firefox_1_5.exe" -p "05312007 "
    PROFILES.INI
    13:10 5/31/2007
    [General]
    StartWithLastProfile=1
    [Profile0]
    Name=default
    IsRelative=1
    Path=Profiles/43r98rol.default
    Default=1
    [Profile1]
    Name=05312007
    IsRelative=1
    Path=Profiles/clone_05312007.05312007​
    Thanks,
    Chris
  2. 2007/05/31
    Ramona
    Ramona Geek Member Alumni
    Welcome to the Forum, Chrismartin76
    Chris,
    I believe this is what you're looking for:
    Managing Multiple Firefox Profiles
    As of Firefox 2.0, you can use the "-no-remote" command line option instead of setting the var in a batch file.
    It's also worth noting that using no-remote breaks external links. That is, if you click on a link from your favorite chat client, the link will not open in your Firefox instance.
    A way around this, assuming you want to run two profiles at once, is to start your primary Firefox instance normally, from the Desktop shortcut, adding the default profile name:
    "C:\Program Files\Mozilla Firefox\firefox.exe " -p "default
    then start your second instance using -no-remote. This way, external links will still work (they will open in the primary instance).
    "C:\Program Files\Mozilla Firefox 1.5\firefox_1_5.exe" -p 05312007 -no-remote
    Let us know if this solves your problem.
    Chrismartin76
    This line doesn't seem to work--it launches firefox 2. According to geektolive, the -no-remote flag only works with firefox 2.0, but am I doing something wrong?
    I did change the registry setting for hkey_local_machine\software\microsoft\Windows\CurrentVersion\App Paths\firefox.exe to point to the 2.0 version. I don't know if that's relevant; I don't think it is.
    A workaround that does seem to work is to launch firefox 2.0 in a normal way and then launch firefox 1.5 via the batch file.
    Thanks,
    Chris
